802.11 B and G speed factor
Archived from groups: alt.internet.wireless (More info?)
Monday I am going to one of the electronic stores to pick up a wireless
router and adapter for Verizon DSL.
Is there any noticable speed distance between B and G technology?? I will
mostly use it for internet, can't see doing many file transfers between home
computers. I see these advertisements pushing G routers
for their great speed.....but swith DSL internet not sure it really matters.
The bargains are with the 802.11b routers....so it's tempting to go with
them and replace it down the road if need be. Seems the technology changes
yearly anyways. Any insight into speed factor appreciated. Likely will go
with B, unless a good argument can be made for the G Broadband.
7 answers Last reply
More about speed factor
  1. Archived from groups: alt.internet.wireless (More info?)
    Yes, I was wondering if distance plays a role in speed for through-put of
    data. Sounds like it may in situations. I heard both arguments. B is just a
    good as G for the internet. Other argument is G is slightly better
    for wireless reception.
    "snow" <dlessard@powerlink.net> wrote in message
    news:10ielu5ifdr9bcb@corp.supernews.com...
    home
    matters.
  2. Archived from groups: alt.internet.wireless (More info?)
    fwiw
    I mapped all the drives on my laptop from my old reliable desktop and use
    all the desktop programs on my laptop via G wifi .. my laptop only has
    3.5g/b of used C HDD space but has the whole alphabet of D,E,F,G etc of
    drives too - remote storage out the gazzoo ;) wifi-G works well but is
    somewhat slow with large program loading or larger graphic saves, don't
    think I'd be happy with B.
    As you distance yourself from the AP/Router the through-put drops and you
    might find B is slowing you down a bit sooner than G will.
    home
    matters.
  3. Archived from groups: alt.internet.wireless (More info?)
    news:10ieul1i14dp79a@corp.supernews.com...
    a
    Everything I've read indicates that B and G differ very little in terms of
    range. And they respond similarly to absorbing construction materials,
    because that depends on frequency and not encoding technique. 802.11g has a
    slight edge in that it is less sensitive to multipath echo.
    will
    > home
    > matters.
    changes
    go
  4. Archived from groups: alt.internet.wireless (More info?)
    home
    matters.
    Since the ADSL link is the bottleneck for Internet use, there won't be a
    speed difference between 802.11B and 802.11G devices.
    However, 802.11B has a security problem, so if you're concerned about
    preventing eavesdropping or wardrivers, choose the "G" model.
    FWIW.
    William
    (Filter noise from my address for direct replies.)
  5. Archived from groups: alt.internet.wireless (More info?)
    "William Warren" <william_warren_nonoise@comcast.net> wrote in
    news:4eRVc.298047$%_6.70898@attbi_s01:
    What security issue exists for 802.11b that does not apply to 802.11g?
    Tom McCune
    My PGP Page & FAQ: http://www.McCune.cc/PGP.htm
  6. Archived from groups: alt.internet.wireless (More info?)
    "Tom McCune" <news@DELETE_THISmccune.cc> wrote in message
    news:Uo0Wc.36883$Kt5.14967@twister.nyroc.rr.com...
    > Tom McCune
    At the standards level, none. However, the OP asked which device to buy, and
    manufacturers have chosen to include WPA features in their 802.11G devices,
    which is an improvement over the WEP security found in 802.11B equipment.
    Those interested in the standards process may consult
    http://csrc.nist.gov/publications/nistpubs/800-48/NIST_SP_800-48.pdf for an
    excellent treatise on WEP security issues
    http://standards.ieee.org/getieee802/ for information on progress in 802.1X
    and 802.11i.
    HTH.
    William
  7. Archived from groups: alt.internet.wireless (More info?)
    On Sat, 21 Aug 2004 10:11:04 -0400, in alt.internet.wireless , "snow"
    B is 11Mb max, G is 50Mb max. Apart from that.... :-)
    > will mostly use it for internet, can't see doing many file transfers between home
    >computers.
    In that case, unless you have a 100meg internet connection, you'll see
    absolutely no difference.
    Mark McIntyre
    CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html>
    CLC readme: <http://www.ungerhu.com/jxh/clc.welcome.txt>
    ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
    http://www.newsfeeds.com The #1 Newsgroup Service in the World! >100,000 Newsgroups
    ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Routers Internet Wireless Networking
