Tom's Hardware > Forum > Games General > PC Gaming > Crysis: 1920x1200 res. problem
Forum Games General : PC Gaming - Crysis: 1920x1200 res. problem
For some reason I can't choose 1920x1200 resolution on Crysis. The highest it'll let me go is 1770x100 (something like that). Do I need Vista to be able to go that high with the resolution?
Sponsored Links
whats ur graphics card
Reply to ridinondub247
- 0 +
I'll just post all specs:
Q6600 @ 3.0GHz
HD4870
Gigabyte X48T-DQ6
2GB DDR3 1600
Reply to Zoobix
You certainly don't need vista for this resolution; but other than that I don't know what the problem could be. Do you have the newest drivers installed?
Reply to aziraphale
- 0 +
Yep, I installed the new drivers the day they came out. I was looking forward to them.
Reply to Zoobix
- 0 +
ever seen a guy play crysis with a fx 5200 128bm ;)
Reply to fyrexia
If you're not getting this resolution it either means 2 things:
1 - Your video Card doesn't support it (Which I doubt - just install the latest drivers)
OR
2- Your Screen doesn't support it.
------------------------------ Windows XP MCE & Vista 64-bit (dual boot)
XFX NFORCE 680I LT SLI w/ OCZ Platinum 4 Gigs Dual DDR2 @ 800MHz
Intel Core 2 Quad Q6600 @ 2.4GHz w/ ChillTec Thermo Electric CPU Cooler
MSI NX8800 GTX & X-Fi XtremeGamer Soundblaster
Reply to Alex The PC Gamer
same problem here....8.7 Catalyst
Sapphire 4870 on 37" Full HD LCD TV.....
no 1920x1080 option...
any ideas ?
Reply to dwe_khal
- 0 +
^ the game isn't 1080p.... its a 16:10 ratio not a 16:9 ratio...
its most likely a driver issue....
you can also force resolutions in config files
Reply to thogrom
There are 1236 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
