Q6600 temp on first boot
More related threads to : Q6600 temp on first boot
(11/14/2009) Where Should I Place A Temp Probe To Read Ambient Temp(11/16/2009) Q6600 vs E8500 vs Q9550 vs QX9770
(11/13/2009) Cpu temp monitor(11/14/2009) Boot screen does not show installed amount of RAM on pc
(11/13/2009) Help Me Please Will This Power My Q6600 and 8800GT?(11/14/2009) First time cpu install
(11/23/2009) Xeon E5530 Max temp?(11/12/2009) Any problems with running a Q6600 CPU with DDR3?
(11/12/2009) Rebooting Problem with Q6600(11/11/2009) Problem at first start
(11/10/2009) Q6600 high idle and load temps(11/11/2009) Need help - first build
(11/10/2009) Hp compaq dc5750 microtower doesnt boot(11/08/2009) AMD Athlon 5400+ Dual Core Temp Problem
(11/08/2009) TEMP(11/10/2009) Q9550 temp.are these rite??
(11/07/2009) Q6600 overclocking(11/07/2009) System boot failure insert system disk
(11/08/2009) My first conputer build and i need a CPU(11/07/2009) CPU temp
(11/06/2009) Was the E8400's stuck temp sensor problem fixed for the newer E8400's?(11/12/2009) Install cpu cooler and computer won't boot
(11/03/2009) CPU temp i5 with Hyper 212+ what should it be looking like?(11/02/2009) Cool down Q6600 with stock cooler?
(11/03/2009) Computer will not boot(11/01/2009) PC wont boot up anymore
(10/31/2009) Unlocked Phenom II X3 temp issues(11/03/2009) Laptop wont Boot!
(10/30/2009) Cpu button had to be pressed a number of times to boot up(10/29/2009) Fans going crazy, computer won't boot
(10/28/2009) Toshiba Tecra 8100 wont just boot(10/28/2009) Q6600 bottleneck on 4870 crossfire x3 gpus?
(10/27/2009) Why intel q9650 does not boot(10/26/2009) First time buying non-stock cooler
(10/25/2009) Need help with boot and stability issues(10/26/2009) Core i7 920 the new c2q q6600?
(10/25/2009) Computer will not boot up(10/25/2009) First time build - Water cooling
(10/27/2009) Click sound on boot(10/22/2009) Boot sequence of inspiron 531s bios setup
(10/21/2009) Normal cpu temp phenom 9950 be(10/21/2009) Is 8 degrees difference between two cores' temp normal?
(10/27/2009) The Once Famous Q6600... Now Dead?(10/21/2009) Laptop won't boot up/blue sceen all the forums say to do this or that in the sta
(10/21/2009) My first extreme build(10/18/2009) Chassis fans stopped AND hdd won't boot
(10/14/2009) Cannot boot from hibernate(10/14/2009) Irql not less or equal STOP won\'t boot
(10/13/2009) Can't find the core temp issue (Core i7 + EVGA X58)(10/13/2009) MB wont boot needs BIOS upgrade for AM3
(10/12/2009) Minimum temp for Core 2 Duo?(10/08/2009) Which temp utility to believe?
(10/07/2009) Should I be worried about my temp?(10/11/2009) Intel C2Q Q9550 Temp
(10/07/2009) I7 temp: LGA1156 vs LGA1366?(10/09/2009) Boot suddenly takes 10 min.
(10/15/2009) How do i boot from two master harddrives(10/05/2009) Q6600 running too hot?
(10/18/2009) Fans spinning, but no boot(10/03/2009) Q6600 G0 temperatures
(10/02/2009) Monitor says check signal computer wont boot(10/01/2009) Q6600 -to- Q9550
(10/01/2009) What temp should my i7 920 be running at?(11/24/2009) My CPU temp always reads 98C in BIOS
(10/02/2009) I7 D0 stepping - How to undervolt/low temp @ idle(10/03/2009) No boot or beeps
(09/29/2009) Core temp(10/07/2009) Help! My first custom computer! Need Suggestions / Support
(09/27/2009) Building my first computer...(10/02/2009) Upgrade to Q9650 from Q6600
(10/01/2009) The two question! Die and Temp...(09/25/2009) CPU temp higher than CORE temp??
(09/25/2009) E8400 vs Q6600 which is better?(09/24/2009) Boot Up Issues - Must Hit Reset For PC To Boot
(09/23/2009) Faster CPU will not boot, no video(09/30/2009) Power on but no boot or post
(09/30/2009) Newly build computer need to boot up twice after overnight off(09/29/2009) Gaming: Should I upgrade my Q6600 to Q9xxx?
(09/23/2009) Help! pc won't boot! No beeps! No display!(09/25/2009) Can't boot up computer - "Reboot & select proper boot device.."
(09/18/2009) Core 2 Quad 8200 temp is a bit weird...(09/18/2009) E7500 doesn't boot
(09/25/2009) Q9400 temp help(10/26/2009) Only one core detected (on my dual core) in CPU-Z/Core Temp/Prime95etc
(09/20/2009) Failure to boot(09/16/2009) Installed a fresh cpu, no boot up though.
(09/15/2009) Cant boot after upgrading cpu(09/16/2009) Processor temp problems
(12/02/2009) [Case Log] Project Sestren Worklog -World's First Back/Outside Mounted(09/13/2009) First Time PC rebuild
(09/14/2009) Q9650 stock temp spikes(09/22/2009) 955BE Core Temp
(09/06/2009) Help!!! My new comp wont boot up!!!!(09/05/2009) Q6600 CPU only showing one core
(09/05/2009) My custom pc won't boot after changing CPU voltage.(09/03/2009) Q6600 w/ zalman 9500, heating problems
(09/03/2009) One core temp too high?(09/02/2009) Speed Fan vs Real Temp
(09/22/2009) BSOD for no apparent reason, now not able to boot up(09/01/2009) I7 xeon stamped q7wj wont boot
(08/29/2009) PC Won't Boot Suddenly...(09/01/2009) New system Locks during 1st boot
(08/29/2009) How does the P4 660 3.6g Costa Rica stack up against the Q6600(08/28/2009) Computer won't boot when PWR Fan is connected
(08/29/2009) Computer wont boot after installing new Intel Processor(08/30/2009) Component advice for i7 editing computer
(08/28/2009) BOOT PROBLEM(09/05/2009) Buying first Sound Card in 15 years. Help me Choose.
(08/28/2009) Q6600 Deactivated?(08/26/2009) CPU Temp
(08/27/2009) HELP!! CPU temp spikes(11/27/2009) Q9550 temp problems
(08/24/2009) Q9550 temp issues leave me stumped(08/25/2009) Q6600 vs Q9550...is it worth the upgrade?
(08/24/2009) Q6600 To Hot ?(08/21/2009) Dual OS boot issue...
(08/21/2009) Cpu temp and fan speed is much higher in BIOS than in windows 7, why?(08/19/2009) Asus Xonar DX - first soundcard need advice
(08/25/2009) Not sure about CPU temp..(08/18/2009) Q6600 Thermal Paste Help + Overclocking
(08/17/2009) New PC Computer Boot Screen Atrifacts(08/18/2009) 9950 vs Q6600
(08/17/2009) Worth upgrading from an oc'd q6600 and 8800gtx to something newer?(08/16/2009) I7 920 Temp and monitoring software
(08/16/2009) Cpu temp wont work?(08/14/2009) Q8200 Temps Speedfan Real temp C1 20c hotter?
(08/14/2009) Computer won't boot Need Help(08/14/2009) Should I be concerned? (temp wise?)
(08/14/2009) Speed Fan Vs Core Temp?(08/14/2009) HELP!! PC won't boot after attempted upgrade
(08/12/2009) High Temp Issue(08/12/2009) Upgrading from a Q6600
(08/11/2009) After Re-applying thermal paste, Temp skyrocketed(08/08/2009) Need help with Inpsiron 6000 boot!
(09/19/2009) Q6600/6700 What are your settings?(08/04/2009) Q6600 high idle & load temps help please
(08/04/2009) Corsair HX1000 - system won't boot(08/11/2009) Considering future upgrade. ?'s and Opinions Intel Core 2 Quad Q6600?
(08/01/2009) Everest Temp utility, Which CPU temp to read?(08/02/2009) Upgrade GPU or CPU first? (specs inside)
(08/07/2009) Core I7 C0 revision and issues with memory controller/temp(08/01/2009) 750w PS won't boot with 2 GTX260's
(08/02/2009) My first Computer... Please Help!(08/02/2009) System won't boot
(08/01/2009) E8400 Temp variable from one chip to another?(07/31/2009) E8400 Temp variable from one chip to another?
(07/29/2009) Infinite Boot loop ( sometimes not )(07/29/2009) What do you think about this custom PC?
(07/29/2009) Disk Boot Failure(07/29/2009) Q6600 very hot
(07/28/2009) Dell 5150 no powe or no boot tech questions(10/05/2009) C2D E6750 Temp question
(07/23/2009) Is my 3rd Core Broken? Q6600(07/22/2009) First PC Build...double checking.
(07/22/2009) Upgrading for first time - Please help me(07/21/2009) Which is better? Q6600 or E8400 CPU?
(07/21/2009) Water cooling. Q6600 4870CF(07/21/2009) Q6600 cooled by thermaltake big water 735? good or bad?
(07/20/2009) Boot System Stuck at "PS2 Keyboard not found"(07/17/2009) CPU temp
(07/17/2009) CPU Temp Programs?(07/17/2009) Q6600 Vs. Core i7
(07/16/2009) What cpu to upgrade from q6600(07/16/2009) I7 920 idle temp
(07/17/2009) My first build and my ?s(07/18/2009) CPUZ giving confusing results for Q6600...
(07/16/2009) E8400 vs. OC e2160(07/15/2009) AMD x4 Phenome 955 BE 3.2ghz idel temp??
(07/18/2009) Upgrade from q6600 to i7 920. worth it?(07/13/2009) Core Temp Change
(07/13/2009) I7 950 upgrade from q6600?(07/11/2009) Q6600 to q9550 upgrade?
(07/10/2009) Which temp in speedfan is my cpu?(11/29/2009) AMD Athlon 64 X2 6000+ High Temp!
(07/10/2009) Just Curious – Can Change Multiplier on Intel Q6600(07/16/2009) Huge temp difference between cores
(07/08/2009) Cpu temp too high and pc crashes(07/04/2009) Installed new MaxOrb Ex cooler on Q9450.the cores have different temp.
(07/06/2009) Q6600 & Heatsink(07/04/2009) First Custom, Need feedback
(07/03/2009) Q9550 temp?(07/03/2009) VOLTAGE AND TEMP NOOOOOB HELP!!!!!
(07/02/2009) EP-45 UD3R mobo + Q6600 + Titan fenrir TTC-NK85TZ Cooler!?(07/01/2009) Cpu temp help
(06/30/2009) Q6600 upgrade(06/30/2009) Quick question about my CPU temp.
(06/30/2009) Problems with Q6600(06/27/2009) Can't boot from CD at all.
(06/25/2009) System won't boot when powered on, only LED's light up.(06/24/2009) Time to upgrade from q6600 and nforce? halp!
(06/27/2009) Tjunction temp and cpu temp clarification?(06/21/2009) Power on, but no boot?
(07/10/2009) PC cannot boot(06/20/2009) What happen if AMD Phenom 2 temp up to 65 C
(06/15/2009) Q6600 vs i7 920 GAMING?(06/18/2009) New cpu boot problem
(07/22/2009) What is an acceptable n/b temp?(06/12/2009) CPU temp problems/AC freezer 64pro problems
(06/17/2009) Boot problems(07/12/2009) Insanely High CPU temp Intel d965
(06/10/2009) My Q6600 hit 85C at stock speed!!(06/11/2009) Temp problem
(06/10/2009) Q6600 voltage required to boot ?(06/09/2009) C2D core temp always around 80C
(06/08/2009) AMD Phenom X3 Temp Concern(06/07/2009) Foxconn A690VM2MA won't boot with Phenom 8650
(07/24/2009) I7 / x58 won't boot(06/10/2009) Q6600 showing 1 core in Win XP
(06/05/2009) Temp differs between programs by alot help!!!(06/04/2009) Coolit Domino ALC Advanced Q6600 & 4870?
(06/04/2009) Normal system temp?(06/03/2009) System Reset and Athlon 2600+ Temp
(06/03/2009) Boot from cd problem(06/01/2009) NEED SERIOS HELP computer wont boot/ hardrive not reconsied!
(05/31/2009) Phenom II 955 temp(05/31/2009) New CPU..now computer wont boot up
(05/29/2009) Q6600 or E6750 with 8800GT SLi(05/30/2009) Changed CPUs and new processor won't boot with 4gb ram
(05/25/2009) Failure To Boot(06/01/2009) Q9550 &Stock Cooler Idle temp seems high Help?
(05/24/2009) Q6600 Overclock(05/24/2009) E8400 Temp Ok?
(05/23/2009) Q8300 Temp Question(05/23/2009) Quick help please with case fans and temp
(05/23/2009) [CPU and other compenents] Advice of my first gaming pc build(05/23/2009) Does higher ram frequency affect cpu core temp?
(05/22/2009) Q6600 temperatures(05/22/2009) I7 stock temp
(05/21/2009) Q6600 Tenperatures. Is it Ok??????(05/18/2009) PC BOOT SLOW
(05/17/2009) I replaced my CPU and now it won't boot(05/16/2009) Cpu core temp
(05/16/2009) My Q6600 Hight temps!!(05/16/2009) SATA HDD enclosurewith fan and temp
(05/15/2009) Q6600 or PD 965 extreme?(05/15/2009) Vx450 corsair psu temp
(05/14/2009) Immediate shut down after one beep, no boot screen even :((05/27/2009) Can u please help me out in knowing a good system configuration.. for animations
(05/13/2009) Best graphics card for q6600 .(05/13/2009) Need help with first time upgrade/build
(05/13/2009) Q6600 alternative?(11/02/2009) Upgrade Q6600 or Buy New i7 920?
(05/12/2009) Disc boot failure(05/13/2009) TF2 E8500 Vs QUAD Q6600?
(05/10/2009) Core i7 & Q6600(05/08/2009) Witch Stupid temp Monitor?
(05/06/2009) CPU turning on but no POST/boot(05/06/2009) Cloned HD into new Q6600 box
(05/09/2009) My CPU temp(05/06/2009) Q6600 DIED - Recommended Upgrade
(05/04/2009) My First Build(05/14/2009) Vista 64 boot slower with core i7
(05/03/2009) Toshiba tecra m2 boot problem(05/03/2009) CPU Temp
(05/02/2009) I7 920 different temp cores?(05/20/2009) Q6600 temp
(05/01/2009) HT on q6600?(05/02/2009) Core 2 quad Q6600 rev. G0
(04/30/2009) Master Boot Record Error(04/29/2009) Cleaned (dusted) PC, rearranged wires, no boot
(05/17/2009) Just Upgraded CPU; Computer Won't Boot!(04/26/2009) Noob cpu temp question
(04/27/2009) Ambient room temp.?(04/26/2009) Can't get past message "reboot and select proper boot device or Insert boot med
(04/26/2009) Replaced CPU, doesnt get past boot screen(04/25/2009) Q6600 temps
(04/24/2009) Xps 420(q6600) help(04/24/2009) Lowest temp cases
(04/25/2009) First computer build(04/24/2009) AMD Phenom II 920 vs Intel Q6600
(04/22/2009) Q6600, xp help needed(04/20/2009) Q6600 or phenom II x4 940
(04/21/2009) CPU temp is unusually high(04/24/2009) Help computer wont Boot
(05/13/2009) Phenom II 940 temp question's(04/18/2009) My first PC build
(05/25/2009) Clarkdale (32nm) first looks.(04/16/2009) Q6600 for $131.07 on the Egg
(04/15/2009) PC will not boot when cold!(04/14/2009) CPU Mhz varies every time I boot to XP
(04/13/2009) HELP!: CPU showed one core, now it wont even boot correctly.(04/17/2009) Q9400 temp question
(04/14/2009) Q6600 vs Q9400(04/13/2009) Is my cpu temp high?
(04/10/2009) Overclocking the q6600, opinions?(04/09/2009) CPU Temp
(05/11/2009) I7 920 temp(04/10/2009) Checking for broken parts: CPU Temp (..Too high?) and Prime95
(04/09/2009) Re-lapping my Q6600?(04/10/2009) Same Price - Overclocking - Q6600 VS. Q9400
(04/07/2009) My first water cooling plan. Need feedback please(04/07/2009) Computer wont boot up.
(04/05/2009) Cpu won't boot up(04/05/2009) Cpu temp
(04/04/2009) Boot Block and Infinite Restarts(04/02/2009) Building my first Comp Question About Monitor
(04/02/2009) Q6600 Overclock Potential(04/03/2009) Wild temp & Problems
(04/07/2009) E8400 vs Q6600 question.(04/02/2009) Q6600 DDR3 Motherboard
(03/29/2009) Q6600 60c idle(03/28/2009) E8400 safe temp using a stock fan ?
(03/31/2009) What is better? q6600 or q8300?(03/30/2009) Core i7 920 idle temp high
(03/30/2009) Q6600 Heatsink(03/26/2009) Q6600 Core 1 maxed out
(04/09/2009) Q6600 temps idle at 80c(06/15/2009) 7750 KUMA Temp. Help!
(06/23/2009) Unbelievably high CPU temp?(03/27/2009) Pc wont boot problem
(03/20/2009) Q6600 or phenom 9650(03/20/2009) Winodws Boot Marnage Error
(03/19/2009) Suggested Forums to Request Used Q6600(03/19/2009) Prevent laptop CPU overheating and boot failures - low tech solution
(03/23/2009) CPU temp P4(03/19/2009) Q6600 heatsink advice
(03/22/2009) Which CPU temp is correct?(03/17/2009) Cpu temp issue
(03/17/2009) Q8200 vs Q6600 (G0) Temps(03/16/2009) Q6600 vs Q9450
(03/15/2009) Q6600(03/16/2009) New Q6600 makes Games lag realy bad
(05/27/2009) Intel Core2 Quad: Q6600 vs Q8200 - Which is better?(03/16/2009) Q6600 Cooler help
(03/15/2009) Q6600 running way hot(03/15/2009) Q8300 or q6600
(03/14/2009) Computer won't boot help!(03/12/2009) Temp Difference between cores..
(03/12/2009) Wich should i upgrade first.(03/11/2009) Help me in overclocking my Q6600
(03/09/2009) CPU Temp help(03/05/2009) Core i7 a good idea for a first builder ?
(03/06/2009) Q6600 on a EVGA 123-YW-E175-A1 wont show all 4 cores?(03/04/2009) Q6600 Only Showing 2 Cores
(03/03/2009) Intel e7300 temp(03/03/2009) Cpu temp problem
(03/03/2009) Dual Boot(06/13/2009) E8600 or Q6600
(03/04/2009) Memory Question overclock q6600(03/01/2009) Q6600 from Newegg
(02/28/2009) First Build - 109 degree C CPU(02/27/2009) CPU temp problems
(02/27/2009) Mobo won't boot after cpu upgrade(02/25/2009) Cou temp
(02/25/2009) First look: AMD Athlon 64x2 7750(02/24/2009) Phenom II load temp
(02/25/2009) Cpu temp(02/20/2009) Upgrade Bios = 15 degree cpu temp drop PLZ EXPLAIN
(02/19/2009) New cooling / heatsync for Q6600(02/18/2009) MSI 975x PUE Q6700 High CPU Temp
(02/19/2009) Quad core Q6600 2.4Ghz or Core 2 duo e8400 3.00Ghz(02/15/2009) Really High CPU Temp reading - Faulty Sensors?
(02/14/2009) Building my first system, Q6600 I need your review please...Thanks !(02/12/2009) Windows XP will not boot up
(03/07/2009) I7 920 Idle temp question.(02/16/2009) Accurate temp monitoring with i7
(02/12/2009) Q6600 v Q8200 v Q9400 - quickie(02/11/2009) E8400 Temp
(02/09/2009) PICS of my Antec 900 mods - First Time Build(02/08/2009) Is Q6600 still "the" cpu ?
(02/09/2009) Boot problem(02/08/2009) Q6600 Reach 98-100 heat problem
(02/07/2009) First Shope Link for Phenom X3 720 Black Edition .(06/22/2009) Q6600 vs q9400 vs q8300. Which to choose?
(02/06/2009) Boot Problems(02/05/2009) "System" Temp?
(02/04/2009) Computer takes a while to boot(02/02/2009) First build - I need help
(02/02/2009) Possible Temp sensor problem(03/11/2009) Q6600 with GIGABYTE GA-EP45-UD3R
(08/31/2009) No Overclocking - q6600 vs q8200(01/29/2009) Computer boot up
(01/29/2009) Part II - The q6600 Strikes Back, of "I'd like some expertise please..(01/28/2009) Q6600 or Q9550
(01/29/2009) Q6600 temp help(01/29/2009) Help regarding AMD Phenom X3 temp
(01/31/2009) E8500 or q6600(01/29/2009) Q6600 temps
(01/27/2009) Q9550 Core Temp Delta(01/27/2009) G0 q6600 temperature question
(01/29/2009) How Are my CPU Load Temps?(Q6600 Stock)(01/31/2009) AMD Athlon 5000 temp issues
(01/24/2009) Q6600 High Temps(01/24/2009) Amd 4200x2 vs q6600
(01/27/2009) Power on, no boot with different hardware(01/28/2009) Q6600 board suggestions with a 8800 GTX
(01/21/2009) Intel CEO warns first loss in 22 years is possible in Q1(01/22/2009) Q6600 vs E8400 gaming/longevity
(01/20/2009) Got a burning smell from my case. One core of my Q6600 burnt?(01/21/2009) Lowering vcore EP-45 and Q6600
(01/26/2009) Q6600 or i7 920?(01/20/2009) My Q6600 is dieing waht should I replace it with ?
(01/19/2009) Suggestions For My First Build?(01/18/2009) I7 Temp/Hsf question
(01/19/2009) Q6600 temperature concerns(01/18/2009) Questions on the Q6600
(01/17/2009) Q9550 core temp hang(01/27/2009) Toshiba TECRA M2 Boot problems
(01/16/2009) CPU Temp readings are static(01/15/2009) Steve Jobs not as well as he first thought..
(01/15/2009) Q9400- What's a good temp range?(01/16/2009) My first build, looking for comments/feedback/reviews...
(01/16/2009) Please review my first build. Thank you.(07/05/2009) What is the best HSF for a Q6600 overclocked to 3.0 / 3.2
(01/13/2009) Intel q6600 problem?(01/30/2009) Q6600 Vs. Q8200
(05/29/2009) Intel Core 2 Quad Temp sensor defect(01/10/2009) CPU Voltage & Temp Fluctuation - Help!
(01/12/2009) PC won't power up or boot(01/10/2009) Q6600 and how to OC Asus P5N-T
(01/10/2009) How do i oc an intel q6600 to 3.0ghz?(01/09/2009) Problem with pc,wont boot
(01/09/2009) Is it silly to consider other than Q6600?(05/16/2009) New Intel 5200 won't boot
(01/09/2009) Q6600 or E8500(01/08/2009) CPU Temp
(01/09/2009) Need your experitse on making a Q6600 media/gaming PC(01/07/2009) Bottleneck: Which Goes up first?
(01/08/2009) Q6600 vs q 9550(01/07/2009) I've got new machine (I7+ Asus P6T etc') and my temp' is too high!
(01/07/2009) Q6600 or Q9300(01/05/2009) First Build Help - Freezing in BIOS
(03/16/2009) Q6600 or phenom x4 9950(01/16/2009) Q6600 Very High Temps + Arctic Cooling Freezer 7 Pro
(01/07/2009) Attaching Temp Probes(01/02/2009) New system w/ Q6600 Quad CPU and 9800 GT Video, do I have enough juice
(01/02/2009) Will a 500 Watt Antec run a q6600?(01/05/2009) E8400 or Q6600 for WoW?
(01/13/2009) E8400 temperature on first boot(05/28/2009) Q9300 temp issues
(01/03/2009) Large difference in Core Temp?(12/30/2008) E8400 or Q6600
(12/30/2008) Q8200 v q6600 v e8400...(12/31/2008) E5200 temp sensor..
(12/30/2008) Q6600 with new heatsink temp shot up to 51C in 5 mins using memtest(01/02/2009) Q6600 or Phenom 9850 x4? which one should I go for?
(12/28/2008) New cpu Q6600 or E8400(12/29/2008) I7 Temp help
(12/28/2008) Q6600 Different Core temps(01/16/2009) Cpu Temp To High ?
(12/27/2008) Ticking sound on Q6600(12/26/2008) Q6600 Overheating??
(12/27/2008) Q6600 to E8500 question(01/31/2009) Q6600 Idle Overheat + Zalman 9700 NT 100%
(12/24/2008) E8400 very high temp on P5Q PRO(12/26/2008) Q6600 running too hot with Xiggy 1284, no OC
(09/06/2009) Q6600 vs. Q9550(12/24/2008) CPU temp rising very fast
(12/23/2008) CPU temp rising very fast(12/23/2008) Need Help with Starting computer for first time
(12/23/2008) Cold Boot Trouble(12/26/2008) Overclocked Q6600 @ 3.51GHz Idle Temperature = 45 ?
(12/22/2008) Q6600 vs i7 920 - Cost, power consumption, heat(04/17/2009) High temp for i7 Running @ Stock
(12/20/2008) First time build my own computer. Please help.(12/17/2008) Q6600 50% up in price?
(12/18/2008) How did Intel do it the first time out(12/17/2008) E8500 vs Q6600 same price, what should i get?
(03/23/2009) Q6600 and the Q9300(12/16/2008) Boot from cd using pci ide card
(12/17/2008) Q6600 muliplier stay at 6 in Vista 64, changes in Vista 32(12/16/2008) E8500,Q6600 OR Q9300
(12/16/2008) CPU temp 111C(12/16/2008) How far could I OC my Q6600 with this setup and stock cooling?
(12/12/2008) Help Needed!!!!!! Q6600 Alarming Temps!!!(01/10/2009) First Fully Liquid Submerged Commerical PC
(12/12/2008) Q6600 Only sees two cores(12/11/2008) Q6600 with GD35EC???
(12/11/2008) Q6600 with OCZ Vendetta 2 or Vanquisher(12/11/2008) Can Q6600 handle 4780??
(12/11/2008) Q6600 or e8500 (Newbie)(12/10/2008) CPU temp - which temps are being used?
(12/09/2008) Q6600 to Q9450 on Asus P5K-E?(12/08/2008) anyone else seen this temp behavior?
(12/06/2008) q9550 vs q6600(12/05/2008) E5200 Different temp readings for each core
(12/05/2008) another temp thread e8400 90c(12/09/2008) e8500 idle and load temp problems?
(12/06/2008) Help me chose (Q6600 or E8400)(12/06/2008) Why the scaling of my core i7 920 is so poor, even worse than Q6600?
(12/04/2008) Q6600 Problem, core always at 100%(12/04/2008) 5000BE = Boot, Phenom = No Boot!
(12/04/2008) Pentium D temp(12/02/2008) Cooling a Q6600 on an Asus P5K3 motherboard
(12/03/2008) Will Phenom II become the new q6600?(12/02/2008) q6600 lagging
(12/03/2008) MSI P965 Platinum & E6600 Temp Issues!(12/01/2008) Q6600 Overclock and Tweaking
(12/03/2008) Q8200 or Q6600(11/30/2008) Help with Cpu Temp and RPM Please...
(11/29/2008) Dell Inspiron Won't Boot(11/29/2008) Q6600 temps....part 7+
(11/29/2008) CPU Temp and PC Shut Down Issues(11/28/2008) Q6600 gets the chop
(11/29/2008) Is my Q6600 damaged?(11/27/2008) Core 2 Duo E8400 or Core 2 Quad Q6600?
(01/17/2009) Are my q6600 temps ok?(11/26/2008) Whats starndard CPU temp for a Pentium 4?
Sponsored links
