Router shows same outside IP-adress for all my PCs
More related threads to : Router shows same outside IP-adress for all my PCs
(11/30/2009) Router connection(11/27/2009) Can't connect to router settings
(11/27/2009) Does an xp computer talk to a windows 7 box using a linksys wired router(11/25/2009) Router problems
(11/24/2009) Can connect to DIR-655 router but no internet access(11/23/2009) How many laptops can we connect through one wireless router?
(11/30/2009) If I use VOIP with my companies Router connected to my router can they see all I(11/22/2009) Need some help chosing a modem and router...
(11/21/2009) Winxp two connections same computer(11/20/2009) How to use internet and intranet at the same time
(11/21/2009) Half duplex on the WAN?(11/19/2009) Modem - Computer - Router
(11/20/2009) I'm baffled at what I encountered yesterday at home. The home I moved to has Ca(12/01/2009) Why cant I run Mac OS X and Windows XP off same ethernet hub?
(11/17/2009) How do I connect my 2 desktop PCs together?(11/17/2009) Router Will Not Turn On / Connect to Power
(11/17/2009) Need GREAT Wireless Router(11/13/2009) I have a modem i want to put a switch rather than a router is it possible?
(11/12/2009) 2nd router to att router(11/11/2009) 2 routers cannot access computers on 1st router
(11/07/2009) Do I need a new Router?(11/06/2009) Windows 7 home network on router
(11/13/2009) Help with troubleshooting Cisco 1760 router(11/11/2009) Unable to Access Router Admin Page
(11/02/2009) Connect one router to another to make new network?(11/01/2009) Looking for recommendation on ADSL/wireless router/powerline in one
(11/01/2009) How does a router makes difference between a public IP and a local IP(11/02/2009) Installed new router and other computers cant get on the internet
(11/03/2009) Wireless router choise(10/28/2009) Lan part in my router is not working
(11/06/2009) LINKSYS WRT54GL UNABLE TO CONNECT THE ROUTER(10/25/2009) Configure Wireless Router with Nuvox T1 Circuit
(10/24/2009) Help choose a new router(10/22/2009) Since we installed our cisco router interent is very slow
(10/19/2009) Router and switch connection(10/19/2009) Router Problems....
(10/19/2009) Linksys router cant access browser configuration(10/19/2009) Edimax BR-6424n Router not connecting to Modem
(10/20/2009) Something wrong with my router!(10/19/2009) Silly question -- ISP assigned IP with different subnet than router
(10/16/2009) DHCP Server and Print Server on the same box(10/14/2009) Good gigabit router.
(10/13/2009) Can i use more than one IP address on the same DHCP server(10/10/2009) Can fax using adsl router
(10/09/2009) Linksys Router RT41-BU - hangups !!$%?(10/09/2009) How to access internet from wireless router to toshiba laptop
(10/08/2009) How to share the internet connection by two computers without using router(10/09/2009) Netgear Wireless Router Connection Issue
(10/10/2009) Should the firewall/router be the dhcp or should the modem be dhcp(10/05/2009) Advantages of using router than switch
(10/04/2009) Guest Access Prob..Connect Belkin N1 Vision to Belkin N+ Gateway(10/02/2009) Dl 624 router
(10/03/2009) Cannot connect Adsl modem wtih wifi router.(10/01/2009) Wireless Router and AT&T Modem
(09/28/2009) Added linksys befsr41 router: have internet but no lan(09/27/2009) Sonicwall pro 200 netgear router and some confusion
(09/24/2009) Low siganal strength coming from router(09/24/2009) Cable broadband router/switch
(09/25/2009) Cable router/switch(09/21/2009) Netgear /DG834Bv3 dsl modem/router
(09/20/2009) Belkin router query(09/21/2009) Do I need a Firewall when I use a router?
(09/18/2009) Using windows server 2008 as a router(09/19/2009) Computer no longer connecting to router.
(09/17/2009) Router/switch problem(09/17/2009) 2 internet connection in one router
(09/22/2009) 2 internet connection in 1 router(09/19/2009) Using a router as a wireless adapter?
(09/20/2009) Best cheap router?(09/16/2009) LAN speed slow unless through router?!
(09/17/2009) Basic question about wireless router(09/15/2009) Network diagram broadban to switch to router to switch to router
(09/16/2009) How do you connect 3 computers to a router connected to the modem?(09/13/2009) How to convert AnyDATA AWR 500-A wifi router into switch
(09/12/2009) ATT DSL Service with Linksys WRT54G Router(09/11/2009) Workgroup to domain with same settings
(09/10/2009) Small business wifi router for voip and LAN traffic(09/14/2009) Router keeps on freezing my browser page
(09/10/2009) I have cox internet and a router need to hook up all my laptops in the house(09/10/2009) Multiple cable on the same switch
(09/18/2009) Best router for gaming and wifi N?(09/04/2009) Can I secure 2 ports on an 8 port shared router?
(09/03/2009) Good business grade router for under $500.(09/02/2009) Now that I tried to install a new router my computers are all screwy!
(09/01/2009) SMC barricade router blocking access to printer on LAN(09/02/2009) Netgear router FVS318 & speed limitations
(09/21/2009) Bizarre Network issue. Can no logner connect properly to router(s)(08/31/2009) Connecting a Wireless router to a modem/Wireless router, Help!
(09/13/2009) 2Wire Router/Modem and 24 port switch?(08/27/2009) Router and switch
(08/28/2009) Router question(09/14/2009) What Router should I get ?
(08/23/2009) Netgear Router problems(09/23/2009) ZyXEL P-660HW Series router problem
(08/25/2009) NAS + Router(08/24/2009) New Router troubles
(08/19/2009) Can connect through modem, but not through router(08/18/2009) Linksys router stacking under Thomson?
(08/18/2009) Cannot connect to the internet through a router!(08/15/2009) What router to buy for high speed gaming
(08/14/2009) Which Cisco Router to choose?(08/10/2009) Attaching cable to ceiling/sheetrock (outside of wall)
(08/29/2009) 25 year old female Chinese college student vs router(08/11/2009) Weird Networking/Router Problem [SOLVED]
(08/15/2009) Can I share connection with router and switch?(08/04/2009) 3 PCs 2 users
(08/03/2009) Router Suggestion for NAS(08/01/2009) Modem and router connection
(07/31/2009) My new pc cannot connect to the router(08/04/2009) New router, bad Xbox Live
(07/30/2009) Sam's Club WRT110 Linksys Router Question(07/29/2009) Home router setup with no modem password
(07/29/2009) New AT&T Supplied Motorola Modem/Linksys Router Connection Problem(07/25/2009) Modem and Router confusion
(07/23/2009) Router slowing internet(08/01/2009) File Sharing on same Network....XP and Vista
(07/18/2009) Belkin Wireless G Router(07/16/2009) Router with Firewall adds 6Mb speed reduction!
(07/15/2009) Sharing files/printer through router + switch(07/15/2009) Router issue
(07/14/2009) Router problem(07/22/2009) Trendnet Router Problem
(07/11/2009) Router Problem(07/07/2009) Internet And Router Problem
(07/06/2009) Netgear router(07/07/2009) Router hardware question
(07/06/2009) Trying to network a Windows ME system with Windows Vista on a router.(07/04/2009) Toshiba router wont connect
(06/28/2009) Lose Router Connection(07/01/2009) Internet link unstable in Netgear Router
(08/24/2009) Industrial Rugged GPRS HSUPA VPN Router(06/26/2009) Problems networking with FiOS router
(06/23/2009) Router and Switch Question(06/23/2009) Modem+router or dedicated?
(06/18/2009) Network settings problem? Cant change router with same settings(06/19/2009) 2 Router Set Up - 1 Wired, 1 Wireless
(06/19/2009) Modem+Router+Switch+2 Routers(06/11/2009) Can I use this Router as a Modem?
(06/15/2009) Video How-To: Linksys Router Setup(06/09/2009) Need a rock-solid performance Router for Bittorrent
(06/09/2009) Please help by suggesting a good router(06/10/2009) Best Wired GB router with SPI
(06/04/2009) Computer loses connection to router(06/07/2009) Can access the Router but doesn't have Internet[Wired]
(06/07/2009) Change IP router automatically(06/27/2009) Turning a PC into a Router
(08/22/2009) D-Link DI-524 router "config.bin"(05/28/2009) Building a router, where are the NICs?
(05/26/2009) Router Question?(05/30/2009) Which router to buy
(06/02/2009) Router suggestion for a rigged network...(05/29/2009) Ethernet + Router Problem -- extremely weird -- please help
(05/22/2009) I need a new router that doesn't bottleneck my bandwidth speed(05/12/2009) Blocking wireless access to single comp on router.
(05/10/2009) New modem or router ?(05/12/2009) 2nd router DSL thru a different phone jack?
(05/01/2009) Netgear CG814WG router question(09/09/2009) Linksys Router & ATT DSL Setup Help Please???
(04/20/2009) Router capping speeds?(05/18/2009) Computer won't start with router on
(04/16/2009) Router Modem and Nic speeds(04/15/2009) Help with setting up a Wifi Router
(04/18/2009) Wireless router on LAN(04/14/2009) Problem with WBR-3406TX Router
(04/15/2009) Controlling Internet Access via Router Settings(04/11/2009) Help Choosing A Router
(10/10/2009) Can't get wireless Netgear router to work(04/09/2009) Modem connects to interwebs, router won't let my comp connect!
(04/07/2009) Port forwarding for linksys router model befw11s4(03/23/2009) What router should I buy
(03/25/2009) 2 Wire Router, how to Firewall wired connections from Wireless?(03/22/2009) Why can't the modem recognize wired router connection but will work on wireless?
(03/19/2009) Wireless AND Wired on same Machine(03/22/2009) Need a recommend for a router
(03/17/2009) Router upgrade?(03/11/2009) Switch from Cable internet to DSL router not working
(03/08/2009) MSI RG60G router Help what is SPI etc(03/10/2009) Get router or use main computer as hub?
(02/28/2009) Random Request timed out when ping router(02/28/2009) Need Help Choosing A New Router
(05/17/2009) Connecting Verizon Fios Router to a Netgear Wireless Router(02/24/2009) Linksys Router Help
(02/24/2009) Got New Router | Confused by DSL Cable Instead of Ethernet(02/20/2009) Same Internal and External domain name
(11/03/2009) 2 wireless routers on same network(02/16/2009) Setting up more PCs on a Network
(04/22/2009) D-Link Extreme N Dual Router(02/13/2009) Pinging PCs connected with crossover Cat5 cable
(02/12/2009) Unusual Router Problem(02/12/2009) LAN via router problem with two PCs
(02/16/2009) Laptop connecting to my router disrupts internet(02/09/2009) Wideview and an 8 port router
(02/09/2009) Wideview and 8 port router(02/07/2009) Linksys WRT54G router and Siemens 4100 bridge mode configuration problem.
(02/05/2009) Using router in a college lan(10/10/2009) Need Router That Routes Multiple External IPs
(02/03/2009) How to convert a Wireless B router into a switch?(02/01/2009) Router to router connection
(02/15/2009) How do you connect Router to Router?(01/26/2009) Router vs. Switch
(01/24/2009) Router Question(01/22/2009) How can i set up a lan with out a router/server
(01/21/2009) Is it the modem or router!(01/22/2009) Ethernet access away from router?
(06/13/2009) RJ45-shaped ADSL Line port? N+ Wireless Modem Router(07/16/2009) Internet Slow Through Router
(01/17/2009) Better Router(01/15/2009) What happend to my router? help!
(01/20/2009) Gaming and p2p router setup and suggestions(01/13/2009) Router hunting
(01/06/2009) Is the DGL-4500 Xtreme N Gaming Router the best router for gaming?(01/06/2009) What is the best router for p2p and gaming? what to buy?
(01/05/2009) Best modem / router(12/30/2008) Can't Access BEC 5200S Modem/router
(12/29/2008) Problems replacing wireless router w/ new wireless router(04/20/2009) Is there a wireless router with a category content filtering??
(12/18/2008) Using both local and wireless internet at the same time?(12/26/2008) Problems renewing ipconfig without router
(12/29/2008) Router + Switch = internet?(12/03/2008) New Router Suggestions
(12/02/2008) D-Link router problem(10/01/2009) linksys router crashes my connection every time i
(11/23/2008) Linux Router(11/17/2008) Multiple boxes connecting to the same game server
(11/17/2008) Upgrading Router, but to which one?(12/19/2008) VPN on Windows 2000 in domainand behid router
(10/27/2008) What Wireslls Router is best? please help!(10/24/2008) Gigabit router suggestion please
(10/23/2008) Internet speed shows incorrect result?(10/12/2008) will a switch improve my router
(12/03/2008) My Router Suddenly Closed all the Ports I opened - WTF?(12/29/2008) P2P brings router to it's knees?
(10/01/2008) Question about 1 Router, 1 Network Printer & 2 PCs(10/01/2008) No LAN on router
(09/29/2008) Good router(09/23/2008) Remote Desktop Does Not Work Within Home Network
(09/17/2008) gaming router(09/21/2008) Secure Router / Firewall
(09/19/2008) New router - ethernet cables?(09/19/2008) unstable wireless connection netgear router
(10/13/2008) I need a router with a *configurable* 10Mbps Full Duplex WAN port!(09/19/2008) Problems with the Linksys WRT54G v2.2 router
(10/01/2008) Can a Router slowly fail?(10/01/2008) how to open port on my router
(09/19/2008) What do I need for office router/switch(09/07/2008) Need help with router
(09/06/2008) Do I need to change my router to use Optus ADSL2+?(09/05/2008) New router
(09/06/2008) How to setup DSL router?(09/03/2008) 1 internet line into 2 NIC on same PC
(01/04/2009) Can't get Linksys router to work with AT&T DSL(09/06/2008) Bypassing Router Time Restrictions
(09/07/2008) need router advice please(01/17/2009) INTERMITTENT WIRELESS: Netgear router or Dell D620 problem??
(08/28/2008) Router recommendation?(08/20/2008) Newbie trying to setup wireless router,need advice
(08/19/2008) Is the D-Link DGL-4300 router cable/dsl or adsl?(08/22/2008) Connecting PC-PC and sharing internet without router
(08/30/2008) Hook linksys wireless router and 2 switches to main router(08/15/2008) ADSL router and PC cabling
(08/13/2008) Sp3 Router problem(08/09/2008) Router gone bad or conditions worsening to blame
(08/04/2008) New Router(07/31/2008) Please recomend a Cable modem and router.
(07/30/2008) High ping when router introduced to network(07/30/2008) 2 router port forwarding
(07/29/2008) New Router - Advice needed.(07/27/2008) Share USB aircard with multiple PCs
(07/24/2008) Linksys RV042 router issue(07/20/2008) Gaming/Torrent Router
(07/18/2008) Which router?(07/18/2008) Router Woes
(07/16/2008) Router not giving a 192 address(07/20/2008) Basic Router Advice Needed
(07/15/2008) Help choosing a router from 4.(08/21/2008) Router to switch to PCs?
(07/10/2008) Looking for new router(11/30/2009) Setup gigabit home network using 100mbps Router but Gigabit switches
(07/04/2008) Need advise on a cable router(07/03/2008) Looking for a new router
(06/27/2008) LAN port problem - works fine with adsl modem but not router(06/26/2008) Help getting my linksys wireless router to work
(07/04/2008) Hosting on Modem(Fast) versus Router (Slower) Should I Upgrade Router?(08/06/2008) Wireless router with print server
(06/21/2008) Very confused as to which router to get!(03/16/2009) zoom x6 router help
(12/07/2009) Old laptop into linux router(06/04/2008) Router lag issue
(05/31/2008) 2 router configuration issues(12/05/2009) Problems with router (d-link dir 100)
(06/02/2008) linksys router issue(06/02/2008) Router Advice needed
(05/10/2008) DGL-4500 router and Gamefuel Plz Helpppp(11/27/2009) Two internet connections, 1 router, 1 PC.
(05/05/2008) D Link DIR 655/ router check in(05/01/2008) This stupid computer wont do anything that it needs to with my router
(04/29/2008) philips / Talk takl router sna5630/ns(04/26/2008) Looking for application or router for capping bandwidth
(10/01/2008) Connecting a Wireless Router to My ::ahem:: neighbors WiFi Internet(04/20/2008) networking 2 pcs (via adsl router?)
(04/18/2008) gaming router(04/17/2008) how does ADSL router/switch work?
(04/17/2008) Doubled internet bandwidth, but gaming ping remains the same.(03/31/2008) Belkin router only allowing max of 2 wired connections!?
(03/29/2008) which lower price dual wan router(04/01/2008) How to connect 2 PCs via switch?
(03/24/2008) 2Wire DSL Modem/router w/Linksys 4124 switch and Linksys WRT350N(03/24/2008) Need a new reliable wireless router
(03/26/2008) Which router?(03/24/2008) Router Issue
(03/29/2008) Zoom X6 Modem/Router Security Issues(03/16/2008) loss of speed bec of router?
(03/12/2008) How to network share between router a and router b?(09/20/2009) LAN not working, Wireless working fine (D-Link DGL-4300 router)
(03/09/2008) Media Sharing / router problem(03/12/2008) best QOS router for the money.
(03/12/2008) Looking for router that is fast enough for 27,000 kb/s connection(03/12/2008) P2P and gaming router
(03/05/2008) 0 knowledge - need help picking router(10/01/2008) Weird problem with Belkin G wireless router.
(02/19/2008) Help with Linksys Router.(02/12/2008) Need Help with VNP and Linksys Router
(02/11/2008) need new wifi router or go powerline(02/08/2008) router ip address changed due to modem
(02/06/2008) Adding Wireless Access Point to 2Wire HGV 2700 Router(12/07/2008) Problem with Lan connection with Telefonica (Spain) ZyXel router
(02/01/2008) Need additional ports than what my existing wireless router provides.(01/31/2008) best wireless router for a wii, 360, ps3
(03/12/2008) Dual Ethernet mobo + router question(01/26/2008) How is a switch different from a router?
(01/25/2008) So is it time to replace this POS (Vonage) Linksys wired router?(02/25/2008) Finding router information
(01/24/2008) Router Dropping connection under heavy load(01/21/2008) lag problem with new wireless router
(01/21/2008) adsl modem + switch no router...(01/19/2008) Cant find Router charts
(01/18/2008) Internet via USB adapter and local network via wired router?(01/17/2008) Please suggest wired router for Vista
(01/15/2008) Can I plug a wireless router into a wired router?(01/15/2008) Router Troubleshooting Issue
(01/15/2008) need help turning Linksys WRT54G into a bridge router(01/04/2008) Strange problem with router Belkin
(12/25/2007) Connecting two PC and a Router Local Network(12/28/2007) setting up wired/wireless routers on same subnet?
(12/21/2007) Looking for a cheap reliable router(12/19/2007) Att 2210 modem wont connect to linksys befsr41 router
(12/06/2007) configure router d-link di624, unknown address(12/04/2007) Router: D-Link DGL-4300 Please Help
(11/29/2007) Stable router that can handle BT(11/29/2007) Which wireless router should i get for my laptop?
(11/28/2007) Router - Firewall blocking stuff(11/27/2007) Aztech DSL600ER Router
(08/17/2009) Netgear FVG318 router blocking (some) outgoing FTP(11/26/2007) router or router+switch
(11/21/2007) Router or Switch ?(11/16/2007) Linux Home Server Behind FIOS Router | No Joy
(11/15/2007) Did anyone use/try the router Asus WL-500g Premium?(11/16/2007) do i need a router?
(11/15/2007) Looking for a firewall/router with full featured NAT(06/10/2009) Need assistance choosing a replacement router on Verizon FIOS
(11/10/2007) One router, two 'puters, two speeds - HIS n HERS(11/12/2007) WNR854T router reboots itself on settings update
(11/08/2007) my connection dies suddenly behind a router(11/07/2007) Help! Why wont my Router Talk to my Switch??
(09/13/2009) Belkin F5D7230-4 v2000 router stalls when browsing Google Maps(10/28/2007) Netopia R910: Router -to-Router VPN, Can't PING Remote LAN
(10/24/2007) Best ADSL2 Wireless Router(09/28/2009) using a dsl router with a cable modem
(10/05/2007) Router Blew Out, Some Computers Connect Through Switch But Not All(09/30/2007) Installing NAT & Firewall behind ADSL Router
(09/25/2007) router slowing int(09/22/2007) i just bought a router... now i have downloading issues
(09/21/2007) Does using a router to split the internet to 2 computers slow it down?(09/20/2007) DSL With Router and switch?
(09/14/2007) Need a new router, g or n? newb-ish(09/14/2007) Daisy Chaing Router for VoIP
(09/13/2007) server behind a university router(10/12/2007) How, exactly, do I connect my 2nd router (D-Link DI-624) to my first
(09/04/2007) Router can't sign in MSN Messenger(10/12/2007) Connecting 2 PCs on 1 router
(09/04/2007) urgent Router help(09/03/2007) Connecting router and modem
(09/06/2007) WinXP not detecting IP address assigned by router(08/28/2007) How to Reconnect to router w/ DHCP off
(08/22/2007) USR8000-02.Disable router side ?(08/29/2007) Why does router need DSL login?
(09/05/2007) Dual WAN router suggestions needed(08/21/2007) could i transfer files to another computer using a router?
(08/22/2007) Router problems in a new apartment(08/21/2007) Problem Networking XP Pro for file/printer sharing thru WRT54G Router
(08/15/2007) I need help accessing the router to open a port(08/10/2007) 2 Internet connections used on same computer
(09/19/2007) Using a router/switch in a dorm room...(11/06/2009) Will 100mbps modem/router limit Gigabit switch connections?
(08/15/2007) Cat 5e Outside(07/21/2007) Netgear router ton Linksys VOIP box connection problem
(07/18/2007) Buffalo G300N router slows Internet to a stop(07/17/2007) two broadband internet connections on same computer
(08/06/2007) Netgear Router and browser issues(07/20/2007) 1 of 2 COMPS connected through router
(07/12/2007) Random & Frequent DSL Drops - Caused by Linksys Router?(11/05/2007) Is a software firewall needed with a router?
(07/02/2007) Router on remote pc?(06/17/2007) Buffalo Router WHR-HP-G54 - Web Server
(06/18/2007) Which router for Westell 6100???(06/16/2007) Having a lot of trouble installing Ethernet router modems
(06/17/2007) High performence bandwidth-control router.(06/20/2007) router not working
(07/07/2007) cable router(09/21/2007) problem with daisy chained wireless router
(05/21/2007) Router/firewall with gateway a/v protection?(05/21/2007) Help with router routing tables
(05/18/2007) my c4500 cisco router(05/18/2007) How to connect one router on the internet to a router.
(05/17/2007) Reliable router for a hotel(05/13/2007) TRENDnet router/ USB adapter makes comp freeze.
(05/15/2007) Can a networking guru please help me set-up my router/LAN?(05/10/2007) is my router slowing my lan speed
(05/05/2007) Do router/modems go bad?(05/08/2007) How important is the router's role?
(05/08/2007) GIGABIT Router or GIGABIT Switch & Recommendation Please(04/30/2007) using an extra computer as a firewall/router?
(05/20/2007) using an extra computer as a firewall/router?(04/27/2007) Router or switch?
(04/27/2007) Router Help(05/20/2007) Router
(04/26/2007) Linksys PAP2 before or after the router?(04/24/2007) Wireless public network access with DSL wireless router?
(04/21/2007) router, modem compatibility(07/13/2007) Lag problem with Router and modem!
(04/20/2007) How to access my DSL Router ?(04/22/2007) nub ?: Firewall problem with wireless router
(04/18/2007) What do you think about this new D-Link Router...(04/17/2007) Two routers cannot ping pc's on router 2
(04/15/2007) HELP PLEASE!!! Router Resetting every 8 to 10 seconds!????(04/07/2007) Need router recommendation
(04/08/2007) Router cannot share internet connection(04/05/2007) what's the best wireless vpn cable/dsl router for home offic
(04/04/2007) Sudden Problem with Router(04/10/2007) Can't find network (router)
(03/24/2007) busted / bricked router?(04/01/2007) Need a New Router!
(03/20/2007) Dual Gigabit MB W/3 PCs(03/20/2007) Vista Compatible Router
(04/10/2007) Router With Bandwidth control for 40 PC's(03/16/2007) Router problem...
(03/15/2007) signals: external antenna router & internal one?(03/15/2007) Recomended Wired Gaming Router?
(04/23/2007) Networking to another PC through router.(03/03/2007) wired router recommendation
(02/26/2007) Hi everyone looking for a router for gaming with a high rang(03/02/2007) monitoring traffic through standard router
(02/22/2007) Stupid D Link Router(02/26/2007) changing channels on wireless router help improve connection
(02/19/2007) spare pc to be used as a router....(02/24/2007) Router to Dial-up cable
(02/19/2007) Second router for more ports don't show on network(10/05/2008) gaming router
(02/19/2007) what do you think of Linksys WRT300N router?(02/10/2007) how to connect a laptop to someone else wireless router...
(02/10/2007) What router to get?(02/09/2007) My router is acting funny.
(02/08/2007) Wired and Wireless at the same time?(02/13/2007) Router or Hub
(02/15/2007) Cisco Router IP Reset?(02/06/2007) having some trouble with router.
(02/11/2007) I can overclock my router?!?!(02/01/2007) do i need a router?
(02/06/2007) Frequent lag spikes using WRT54GL router wired connection(02/13/2007) Struggling installing wireless router, losing internet conne
(01/30/2007) access-list cisco router 1721(01/28/2007) Is the WRT54GL a good wireless router?
(01/25/2007) router seems to have been hubified - has it been cracked?(01/26/2007) PC to router connecting Problem!
(01/21/2007) winxp, netgear router, no internet...(01/20/2007) is it possible to relocate my router?
(02/04/2007) Can I MOVE my router successfully....?(01/20/2007) Actiontec model M1424-WR Router question
(01/22/2007) looking for a router(01/31/2007) What router is best for heavy P2P with heavy limit of 80$?
(01/14/2007) WEIRD SHARING PROBLEM W/ WIRELESS ROUTER(01/23/2007) Setting up a router with the connection from another router
(01/14/2007) Good Router Suggestion(01/30/2007) Firewall is different from router?
(01/19/2007) connecting wireless router to a hardwired router(01/11/2007) new router question
(01/12/2007) Need help troubleshooting a router(01/13/2007) Router Fast enough for Roadrunner Premium?
(01/09/2007) P2P programs disconnect Router !(01/10/2007) Gaming Router Question
(01/10/2007) Time for a Router Upgrade?(01/03/2007) Old PC into a Router problem
(01/02/2007) Wireless network/router advice/questions(01/01/2007) best cable modem router?
(01/03/2007) Which MIMO Gaming g/draft-N Router?(01/04/2007) Router or Windows problem? Router ignores pc
(12/29/2006) question about adsl router(12/29/2006) Router problems
(01/08/2007) USR8200 router...I've tried everything to open a port.(12/20/2006) is there a router limit?
Sponsored links
