Chain two routers, can't route between 10.x and 192.168.x?
More related threads to : Chain two routers, can't route between 10.x and 192.168.x?
(11/27/2009) Help with route command (Unless there is another way)(12/01/2009) Two routers, one house, seperate networks
(11/23/2009) ROUTERS(11/30/2009) Splitting signal with two routers.
(11/20/2009) 192.168.?.?(11/20/2009) Im curious about quality but affordable routers can anyone please help
(11/18/2009) Reliable Routers(11/13/2009) ROUTERS
(11/11/2009) Dual WAN Routers(11/11/2009) 2 routers cannot access computers on 1st router
(11/01/2009) How does a router makes difference between a public IP and a local IP(10/23/2009) Connecting 10 computers in LAN which we use hub switches or routers?
(10/21/2009) Setting up ad hoc network between two laptops for sharing internet con(10/21/2009) How to create an application to interact with the routers
(10/16/2009) Which of these routers to get?(10/09/2009) It is possible to use 2 routers in 1 cable modem
(10/06/2009) Can a virus spread between non networked yet physically connected pcs?(10/02/2009) I would like to know how to hook up three routers together.
(09/24/2009) How does routers and Switcher work(09/24/2009) Share between mac and pc
(09/24/2009) How to setup 2 internet - 2 routers - as 1 LAN(09/16/2009) Help required regarding routers and ISPs
(09/09/2009) Blocking DHCP between 2 networks(09/05/2009) 2 routers in one house?
(09/02/2009) Will most routers power a PoE device?(09/08/2009) Using two Linksys Wireless-G routers to expand wireless coverage.
(08/15/2009) When would you route and when would you switch on a network?(08/10/2009) Problem between two switches while connecting
(08/04/2009) Two routers and a switch(08/28/2009) Does QOS in cheap routers really works?
(07/24/2009) Go to first new post Comparison between different analogic card(07/16/2009) Help with Routers and Switches
(07/12/2009) 2 Routers(07/12/2009) File sharing between Windows 7 and Vista!
(07/09/2009) Question about setting up network of 2 routers and 1 firewall(07/03/2009) How to access routers admin menu?
(07/01/2009) Route Wireless Internet on A Mac Out Through Its Ethernet(06/24/2009) Setting up a few routers
(06/26/2009) Dasiy Chain Switches vs. Cascading Routers(06/17/2009) Severe Packet Loss Between Cable Modem and Computer
(06/19/2009) Modem+Router+Switch+2 Routers(06/14/2009) Setting up 2 routers and a switch
(05/28/2009) How to use two routers and a static ip with internet camera(05/22/2009) Internet share between two pc's
(05/21/2009) Routers(05/20/2009) What is the difference between these two modems?
(05/10/2009) Split internet between cable/wifi plus qos?(04/30/2009) IEEE 802.3ad routers?
(04/19/2009) Dual LANs sharing one WAN connection with pinholes between the LANs(03/22/2009) Internet Sharing Between 2 PC's
(03/19/2009) Problems sharing Internal HDD between two networked Vista PC's(11/03/2009) 2 wireless routers on same network
(01/30/2009) Creating a VPN between two computesr(01/08/2009) Article: Apple, Belkin, Trendnet Make Most Reliable Routers
(02/11/2009) A begginers question regarding routers(01/01/2009) Multiple routers with single switch
(12/03/2008) gaming routers, are they all they're cracked up to be(11/26/2008) Hooking multiple routers together? Configurations?
(11/10/2009) Sharing 20Mbps Connection Between 7 computers(10/15/2008) How to connect three routers?
(10/05/2008) Netgear Routers cause DoS attack!(10/03/2008) Some basic info on writing between two computers
(10/09/2008) Port forwarding from behind 2 routers(09/22/2008) Electronic noise - a problem for wireless routers?
(09/19/2008) Can't share data between two routers(09/10/2008) Sharing music between 2 people on school network
(08/29/2008) Issues with Road Runner with Digital Phone and Wireless routers?(08/22/2008) Sharing a folder between mac and PC
(08/06/2008) How to get Maximum Transfer Speeds between Desktop & Laptop(08/04/2008) routers
(08/13/2008) Connect one computer to two routers(07/30/2008) Can you make two routers connect to eachother?
(07/24/2008) ipadd not detecting & trying for file sharing between desktop & laptop(08/19/2008) Problems Bridging 2 Routers
(07/18/2008) Interface tracking on Cisco routers(06/24/2008) 2 Linksys routers & IP addresses
(05/30/2008) Port Forwarding through two Routers.(05/13/2008) use 2 wireless routers to add ethernet cables?
(04/23/2008) connecting two routers(03/12/2008) How to network share between router a and router b?
(02/22/2008) 2 segment network problems.... upgrading..waps and routers(01/12/2008) Cannot share between Vista and Xp
(12/27/2007) A question about routers.(12/28/2007) setting up wired/wireless routers on same subnet?
(11/18/2007) Help with 2 routers and powerline adapters(01/01/2009) Problem with the Netgear CG814WG V2 with cable internet.
(10/18/2007) Security Levels of Routers(09/25/2007) Sharing Files between computers wirlessly
(11/14/2007) Cisco Router-Toggles between connected and disconnected(11/07/2007) Two Routers with Two Internet Connections on One Network
(08/21/2007) Daisy chain routers and run servers(07/17/2007) Two wireless routers, but need to keep seperate
(07/10/2007) Where to purchase gaming routers in the UK?(06/29/2007) File sharing between subnets using Windows?
(06/01/2007) Choosing between internet speeds. Need help.(05/21/2007) 100MB throughput routers/firewalls?
(05/12/2007) copy files between 2 routers(05/09/2007) im stuck heeeeelllppp!!! - Multi routers
(05/08/2007) 2 internet connections, 2 routers, help!(04/17/2007) Two routers cannot ping pc's on router 2
(04/18/2007) 2 routers preventing me to access internet(04/14/2007) daisy chain 7 Linksys SD216
(05/02/2007) 2 wireless routers???????(03/16/2007) Windows File Sharing between WLAN and LAN, D-Link DSL-2740B
(01/26/2007) Best Non-overheating Wireless Routers?(02/15/2007) Are there any better routers then the D-Link DGL-4300 gaming
(01/12/2007) a gigabit lan connection between 2 pc's on a 6 pc network(12/09/2006) Extending my wireless network with 2 Routers
(12/04/2006) Networking with Wireless and Wired Routers(11/17/2006) Slow transfer between Macbook Pro, Maxtor Shared Storage II
(11/22/2006) Cisco 831 router vs high end home routers(11/13/2006) external vs internal anntennas affect performance on routers
(11/12/2006) 2 routers and sharing between them(11/07/2006) Problem with two wireless routers in a network
(11/10/2006) 2 wireless routers conected to cable modem?(11/03/2006) Linux routers any good?
(10/23/2006) Connecting two wireless routers (using one as a bridge)(10/06/2006) Can't see network computer with 2 Routers - HELP
(09/19/2006) How to Daisy Chain(09/13/2006) 2 routers and 2 Internets
(09/12/2006) Routers in home performance, do they really differ?(09/09/2006) 2 ISPs and three routers help!!!!!
(09/06/2006) switching routers on DSL??(09/02/2006) Cisco 2505, 2507, and 2516 Routers
(08/30/2006) Damsel in Distress!!! (Over WiFi Routers) :((08/13/2006) bridge connections multiple routers on 1 pc?
(08/20/2006) What's the difference between a hub and a router??(07/27/2006) Difference between routers: compact vs regular
(07/06/2006) Two Routers on the outside interface of PIX 515(06/21/2006) Two routers in the outside interface of a PIX 515
(06/08/2006) 2 Routers, second not functioning as expected(06/04/2006) Two Routers - One Wired, One Wireless Problem
(05/26/2006) help, does anyone know if these routers exist??(05/25/2006) Looking to setup US and Canada Route
(05/14/2006) Dlink routers won't allow net access(04/09/2006) How install static route on Linksys WRT54GS?
(03/31/2006) VPN Tunnel between BEFSX41 and Netscreen 5 Series(03/22/2006) routers
(03/12/2006) Two routers on different subnets(03/08/2006) Newbie question on firewalls/routers/internet protection
(06/18/2009) Networking two routers(02/10/2006) Crossover GbE link between two computers
(02/05/2006) Proxy Chain Loopback(01/26/2006) Anyone here familier with Networking between Mac and PC?
(01/21/2006) Filemaker hosted between 2 offices(01/20/2006) What other Wireless Routers have Internet access restriction
(01/19/2006) Two routers in series? Noob(01/03/2006) 1 Modem, 1 Switch, 2 Routers - Question?
(01/03/2006) Headset Communeicaton between 2 comps on network(12/22/2005) Trouble communicating between two routers
(11/25/2005) Cisco 2500 Series routers behind IPCop Router Issues...(09/15/2005) Cascading Wireless/Wired Routers
(08/08/2005) uplinking routers(06/25/2005) Q: redundant uplinks between gigabit switches?
(05/30/2005) Are there any home DSL routers that can allocate static IP..(04/11/2005) SOHO routers with 10/100 WAN ports?
(05/05/2005) Linksys Routers(03/25/2005) Routing between VLANs using a Layer 3 Switch
(03/11/2005) VLANs: do all switches in a route have to support it?(02/25/2005) Wanting to share internet between two networks
(02/24/2005) Wanting to share internet between two networks(01/24/2005) 802.3ad Link Aggregation between two hosts using crossover..
(01/20/2005) connecting two wireless routers(12/30/2004) differences between 802.3 and Ethernet ?
(11/23/2004) Cisco Router route statement(11/16/2004) Relationship between Cable core diameter and current in CA..
(11/07/2004) Wither simple ethernet-ethernet routers?(10/11/2004) question about link aggregation between switches.
(09/02/2004) Feedback on load-balancing twin WAN routers, anyone?(07/06/2004) daisy chain Netgear RT314 and RP614?
(06/15/2004) Switch question, daisy chain VS home run(12/03/2004) Help with setting up a NAT/Firewall to route at my office.
(08/25/2005) USA direct route @$.0049(07/15/2005) Configuring Qos in Alcatel routers
(11/11/2009) Is Media Gateway necessary between UMTS(ATM-cell based) an..(05/02/2005) Needed route to Myanmar
(04/25/2005) difference between softswitchs....(04/25/2005) difference between softswitchs....
(05/01/2005) PRI b-channel LCKO problem between Cisco VOIP Gateway and ..(03/02/2005) Skype problems with routers and NAT
(01/12/2005) VoIP Between two offices(02/02/2005) VoIP - PRI between Definity G3 and 2611 Gateway
(09/08/2004) Q: About connections between Voip provider and the telepho..(08/03/2004) VoIP & IVR Gateways, Switches, Routers etc.
(06/25/2004) Difference between a Handytone 486 and Sipura 2000/3000(09/27/2005) Other VPN routers compatible with Check Point
(07/22/2005) VPN and routing between branches(07/21/2005) VPN between VOIP gateways
(07/15/2005) IPSec between different firewalls - help/advice(07/13/2005) POPTOP + no route problem
(06/29/2005) VPN Between two Netgear FVS318, and VPN passthrough to Ser..(06/15/2005) Static route through Netscreen Remote: can it be done?
(06/06/2005) VPN between 3 zywalls(03/08/2005) VPN to China between Cisco Pix 515 and Netgear FVS318
(02/12/2005) two Netgear FVS328 VPN routers with static and dynamic IP(02/01/2005) Chaining VPN Connections with Netgear Routers
(01/26/2005) create VPN between 2 peers and with one behind a NAT device(11/24/2004) ike problem building a vpn between cisco and solaris
(11/15/2004) ROUTE, VPN and DSL(12/19/2004) VPN between ISDN and ADSL
(11/01/2004) Cannot make VPN through 2 routers(10/17/2009) VPN Connection between RV042 and Cisco 1760
(09/03/2004) Difference between Linksys BEFVP41 and RV042?(07/31/2004) Connect remote office with two VPN routers?
(07/30/2004) How to connect 2 Networks behind 2 Routers over internet(07/13/2004) Linksys befvp41 VPN networking with other brand routers
(06/18/2004) Linksys VPN routers stop passing traffic through establish..(06/14/2004) VPN Support between XP Home and XP Professional editions?
(06/10/2004) route trouble(05/19/2004) Small Help with VPN and 2 Routers? (Network Everywhere [Li..
(04/27/2004) vpn between vigor 2600 and watchgaurd soho6(04/15/2004) IPSec VPN between two different routers
(09/30/2005) Linksys Routers showing open UDP ports???(07/19/2004) Conflict between Norton Antivirus and Sygate?
(07/12/2004) Questions about passive FTP, firewalls and Routers(07/09/2004) Give me the low down on the differences between the Cisco ..
(06/30/2004) mySql behind NAT firewall: does everyone appear as 192.168..(06/03/2004) 3 dlink routers no longer configurable
(05/19/2004) W2K Firewall That Can Route Outbound Packets on Same Inter..(05/11/2004) Securing linksys routers
(05/05/2004) Concerning SOHO routers and Port forwarding -- Is this cor..(04/28/2004) Any one use D-link firewalls/routers?
(04/23/2004) Changing TCP/IP settings in routers/firewall(04/19/2004) Compatability issues between the NetScreen 5GT and Cisco PIX
(04/20/2004) Site VPN failed between Checkpoint AI R55 gateways(05/16/2005) Settings between MN-500 and Speedstream 5260
(02/13/2005) Filesharing woes between XP and Win2000 using microsoft wi..(12/31/2004) routers
(12/26/2004) 2 Routers(12/29/2004) I can't connect to WINMX through my netgear wireless route..
(11/30/2004) sharing a wireless connection between xp pro/2000 pro(10/20/2004) Two routers - able to boost signal?
(10/07/2004) 2 wireless routers(09/15/2004) Routers
(08/31/2004) switching between wireless adator to ethernet cable(08/29/2004) How do you rollback the drivers for the MN500 routers?
(08/09/2004) Is it possible to add persistent route record to MN700?(08/02/2004) wifi daisy chain MN-700?
(07/29/2004) MS Wireless-B and -G routers: New firmware?(06/09/2004) Loosing Connection between MN500 & MN520
(05/30/2004) Difference between b and g(05/04/2004) How can I switch between wireless and ethernet
(04/27/2004) routers(04/27/2004) joining two MN-700 networks between houses
(04/25/2004) How to get routing between wireless and wired nets on MN-700(09/30/2005) Network problem between two windows XP machines!
(09/16/2005) Communication required between two hosts over the internet..(07/28/2005) FS routers gateways etc
(07/22/2005) Linking Two ADSL Routers(07/01/2005) FS routers etc
(06/11/2005) How to create a VPN-tunnel between a ZyWall 10 and NetScre..(06/16/2005) help with small business routers...
(05/14/2005) two routers, one gets ontacted continuously(04/09/2005) 2 routers in Win XP SP2
(04/03/2005) 2 network routers(03/09/2005) Route Print Interface
(03/12/2005) Setting static route: Linksys WRT54G - Cisco 2514(01/21/2005) Ping works, trace route works, but nothing else.
(02/11/2005) Ok guys and gals. How do i hook up 2 routers. 2 explain. I..(12/22/2004) Configuring two routers
(04/27/2005) Wi-fi and wired routers(10/04/2005) Routers without Firewalls?
(08/15/2005) Two routers(08/08/2005) wired & wireless routers together
(06/21/2005) Switching between mulitple networks(04/05/2005) inet sharing between winxp and win2k
(02/24/2005) Unauthorize to access between WinXP(10/03/2004) Sharing DSL between PC and Mac
(09/17/2004) Sharing Internet between 2 WIN98 PC(09/14/2004) Sharing internet connection between 2 pcs .
(09/14/2004) Problems filesharing between 2 pc's(06/18/2004) Network Between XP, 2000, ME
(03/17/2004) Multi DMZ cable modem routers(05/04/2004) Stacking routers
(01/24/2004) Making a data conn between wirless laptop & PC(03/06/2004) routers
(01/18/2004) Difference between a router and a switch(12/29/2003) Routers Gateways and Firewalls Oh My
(12/04/2003) Netgear Networking between a WGR614 and a DM602.(12/14/2003) Linksys Are Bad Routers
(09/30/2003) Routing between 2 differnet networks(09/15/2003) Networks and Routers
(08/24/2003) Dividing the bandwith between the LAN computers(09/08/2003) Netmeeting and routers
(06/28/2003) Routers(01/11/2004) Routers $ SBC Yahoo DSL!?!
(06/18/2003) Can I keep adding routers???(05/07/2003) Networking between two cases
(05/03/2003) Routers protocols etc(02/05/2003) ADSL routers, Ebuyer & Linksys
(01/28/2003) Routers act as hubs?(01/07/2003) XBOX LIVE, Routers, Switches, etc
(12/23/2002) Stacking 2 Linksys Cable/DSL Routers??(12/10/2002) Comunication between two computers
(10/30/2002) Network - Routers & Switches?(10/18/2002) Connection between Apple and PC
(06/05/2009) whats the difference between vc-mux and llc?(09/13/2002) Suggestions on Internet Gateway Routers?
(08/29/2002) Diff between cable modems?(08/07/2002) Difference between core and worskstion switches??
(07/09/2002) File sharing between Win XP Pro(06/24/2002) Sharing files between 2 persons
(06/25/2002) PII 400, Win 2k and using it to route for broadban(06/24/2002) Difference between a Switch and a Hub?
(02/18/2002) ICQ and routers(12/10/2001) Nat enabled routers?
(02/23/2001) File & Printer Sharing between Win2000 & Win98SE(02/19/2001) Visual Route for LAN
Sponsored links
