NAS too slow, will this be a better alternative?
More related threads to : NAS too slow, will this be a better alternative?
(11/20/2009) What is the best way t odo this?(11/17/2009) Router Will Not Turn On / Connect to Power
(11/14/2009) NO Games Will Lan(11/13/2009) Dual LAN will not connect to internet on the right LAN
(11/12/2009) Please help me very slow internet(11/09/2009) Fix "This movie has script that is causing ActiveX 10 to run slowly"
(11/07/2009) Will PS3 be able to access my network???(11/07/2009) Two pc connect delete file not go in recycle bin where this file go
(11/06/2009) Slow network transfers speeds Windows 7(11/20/2009) Media shearing for NAS to TV
(11/01/2009) One faculty member who uses Windows 98 wants to set up a shared folder so others(10/29/2009) Slow transfer wired comp to server no middle man
(10/30/2009) Conectiog to my NAS via the web(10/28/2009) Cool things to do with Windows 7 Pro setup as my NAS?
(10/26/2009) If I upgrade to windows 7 will i have to upgrade netgear(10/23/2009) You might not have permission to use this network resource contact the administr
(10/22/2009) Since we installed our cisco router interent is very slow(10/22/2009) PIX 515E Slow Upstream Speed
(10/21/2009) Program installed under Admin, but will not work under User profile(10/20/2009) I lost my password for steam and when i send a message of it to my email it dose
(10/19/2009) My internet connection become slow or disconnected(10/08/2009) Please identify this cable connector
(10/09/2009) Is this normal why do i have 2 dns numbers and a ip addres(10/06/2009) Ad hoc vista and XP will connect to the ad hoc but wont see each other
(10/04/2009) Connection to domain slow(10/01/2009) Slow download speed on single network computer
(10/01/2009) Is this possible?(10/09/2009) No more connections can be made to this remote computer at this time b
(09/19/2009) Will this hardware work?(09/16/2009) LAN speed slow unless through router?!
(09/08/2009) Slow File Transfer Only If 10/100 Forced(09/05/2009) Will External RS-232 Modem Work With 3 Pin Serial Interface
(09/06/2009) Will External RS-232 Modem Work With 3 Pin Serial Interface(09/22/2009) Slow network connection/internet until unplug - plug cable twice.
(09/02/2009) Will most routers power a PoE device?(08/25/2009) NAS + Router
(08/23/2009) Dont knw what this is(08/19/2009) Will i get better ping with Vpn or Proxy ?
(08/16/2009) Will this home gigabyte solution work?(08/10/2009) Turn external hard drive into NAS
(11/22/2009) List all IPs on LAN? Access WD WorldBook NAS drive? All under XP(08/08/2009) How would I solve this problem?
(08/03/2009) Router Suggestion for NAS(07/27/2009) Whats the best solution for this setup?
(07/24/2009) Alternative to 3Com 4200(07/21/2009) Would this work for me? (Wirless Bridge)
(07/16/2009) Will i get better ping if i upgrade my internet ?(07/01/2009) I want to turn old PC into a SOHO file or NAS servr. Where to start?
(06/29/2009) Wow, I Hope This Doesn't Happen in the US(06/27/2009) Can i do this?
(06/19/2009) Slow speeds, etc.(06/16/2009) Is this a network problem????
(06/26/2009) Is this OK to do?(06/11/2009) Can I use this Router as a Modem?
(06/23/2009) NAS(06/10/2009) Slow Download rates
(06/23/2009) Nas not being seen by xbox 360(06/02/2009) Slow speeds transfering within nas??
(06/01/2009) Multiple NAS drives under one drive letter.(05/29/2009) Connecting a NAS to second NIC on W2k Server
(05/19/2009) Internet/Network traffic slow through NIC - Normal wirless(05/11/2009) Ping does not work on this network
(05/02/2009) Windows 7 IE8 "cannot load this page" DNS Problem(04/26/2009) Please help me with this subnetting
(04/25/2009) Can somone help me solve this subnetting situation(04/21/2009) Media Server vs NAS, benefits?
(04/20/2009) How much will i get?(04/12/2009) Enjoy Your Favorite Videos on iPod at Will
(04/21/2009) Computer Will Not Recognize Connection(04/05/2009) Slow speed on u torrent
(04/13/2009) Internet download speed all of a sudden SLOW.(03/30/2009) Dell dimension 3000 desktop into a NAS
(04/04/2009) Internet became slow a few days ago; unable to fix(03/31/2009) Slow Download Speed
(03/27/2009) Slow Download Speed but Fast Browsing Speed(03/22/2009) Why can't the modem recognize wired router connection but will work on wireless?
(03/17/2009) Extremely slow upload speed!!!(03/13/2009) Not sure how to make this work...Please help!
(05/01/2009) LAN Teaming - Will it help me out??(03/04/2009) Slow Internet Question
(03/22/2009) Torrents severly slow interent speed(02/27/2009) Have no idea how to fix this network problem...
(03/22/2009) Please give me some NAS advice.(02/21/2009) Gigabit LAN is only 13mbps, way too slow.
(03/01/2009) A question to NAS users...(02/14/2009) Does this make me a nerd?
(02/10/2009) Slow domain authentication against 1 DC only.(02/05/2009) I want this for my house
(01/19/2009) How do I get this to work?(07/16/2009) Internet Slow Through Router
(01/17/2009) Better Router(01/13/2009) Please help this damsel in distress!! RE: printer network problem. x
(01/07/2009) Will I benefit from a faster upload speed?(01/05/2009) Need answer to this issue
(12/29/2008) Helping setup a gigabit network + a NAS(12/21/2008) Can anyone tell me why this is happening?
(12/18/2008) Slow Lan after ATT change from Cox(12/09/2008) Help Internet is extremely slow
(12/03/2008) Help with slow network.(11/23/2008) Which is better?
(11/17/2008) Im noy sure where this falls under(11/19/2008) why is two better than one?
(04/20/2009) "Windows cannot load the drivers required for this device. (Code 31)"(10/26/2008) Synology DS108J security question (NAS)
(10/15/2008) wireless will not connect(10/12/2008) will a switch improve my router
(10/03/2008) NAS storage question(08/10/2009) Vista 64 File transfer very slow & untorrent knocking off my internet
(09/18/2008) Slow Download Speeds(03/14/2009) Slow internet in XP Pro x64
(08/30/2008) Very Slow Download Speeds (Vista-64 bit)(08/13/2008) slow wired connection on 2nd PC
(08/09/2008) WIN-XP64 will NOT connect to D-Link(08/13/2008) Slow Cable Speeds, unknown problem
(07/15/2008) VLAN + NAS?(06/07/2008) Slow download speed after installing Vista?
(06/01/2008) Onboard ethernet adapter very slow compared to network card - why?(05/13/2008) Slow file transfer across LAN network
(05/01/2008) This stupid computer wont do anything that it needs to with my router(03/20/2008) Limited connectivity. Is this a problem with onboard LAN?
(03/06/2008) Anyone know of any free download boosters.My cable modem is slow(02/28/2008) Did I understand this post correctly?
(01/31/2008) Vista Won't Write to NAS(01/25/2008) So is it time to replace this POS (Vonage) Linksys wired router?
(02/25/2008) Anyone experiencing slow video on broadband?(11/04/2007) New WHS server, painfully slow gigabit transfer
(10/26/2007) Slow connection(10/31/2007) HELP with slow lan game.
(10/23/2007) Old 2xPII Servers - slow network speed(10/11/2007) Help with Xbox Live - need alternative solutions
(10/11/2007) WHS Server/NAS System(10/10/2007) NAS File Server
(09/21/2007) Does using a router to split the internet to 2 computers slow it down?(08/29/2007) Buffalo LinkStation Live NAS - drive default as disconneted
(08/31/2007) I need help with this cause it is pissing me off now...(11/06/2009) Will 100mbps modem/router limit Gigabit switch connections?
(07/28/2007) Online NAS backups(07/23/2007) Help with NAS server and ICS
(05/26/2009) Wippien - Hamachi Alternative(07/20/2007) NAS drive, network explaination needed
(07/13/2007) Server talks to Workstation but Program will not run on Workstation?(07/28/2007) slow sbc dsl speeds
(07/03/2007) Mysteriously slow internet on one computer(07/13/2007) This will probably sound crazy but...
(09/20/2007) Direct Digital Filing – direct to NAS?(06/17/2007) Another slow internet question
(06/17/2007) Internet speeds going uber slow, can i have some advice?(06/18/2007) Has anyone ever seen this??
(06/01/2007) Building a Better Network(05/23/2007) Cable Modem: Slow Surf, Fast FTP????
(06/02/2007) NAS vs PC, why(06/30/2007) having issues with slow internet
(05/15/2007) Will Netgear DG834 work with an ASUS K7M mobo?(05/12/2007) What's needed for this to work correctly?
(05/08/2007) What can I do with this setup?(05/07/2007) Alternative to Verizon's Westell Versalink??
(04/27/2007) Who can help me with this question(04/18/2007) What do you think about this new D-Link Router...
(04/10/2007) Internet running REALLY slow(04/04/2007) Software RAID 5 for NAS/File Server – Compiling a resource
(03/29/2007) slow internet speeds please help please !!!!!!!!!!!!!!!!!(03/07/2007) Backup NAS Box with FTP
(02/20/2007) 54mbps vs. 108mbps on slow ADSL: Will it make a difference?(03/03/2007) Never had this Internet Problem
(02/18/2007) XP network really slow one direction(02/15/2007) Wired or Wireless which is better
(02/04/2007) Very slow download speeds(02/15/2007) 100 Mbps Will it translate to U.S. Internet Providers?
(01/21/2007) Does this look normal Packets being droped????(01/11/2007) Trying to decide whats better for me.
(01/12/2007) WRT54g v1.1, slow internet, fast everything else(01/02/2007) Problems using Print Server via NAS on home network
(02/15/2007) Are there any better routers then the D-Link DGL-4300 gaming(12/13/2006) After building new computer, internet slow?
(12/14/2006) Router slow Downs?(12/08/2006) Is this network configuration possible?
(11/27/2006) help: DLink DSL-500T->LinkSys WRT54G: how to set this up?(11/27/2006) Is this a good router?
(11/27/2006) Please help me share my printer on this network~ thx(12/01/2006) SMC BR24Q router and a Linksys NSLU2 NAS Solution
(12/11/2006) NAS?(11/17/2006) Slow transfer between Macbook Pro, Maxtor Shared Storage II
(11/14/2007) Is Fiber optic better then Comcast 8mb?(11/15/2006) NAS Adapter using only Flash Storage
(11/15/2006) why is my download speed so slow if i have DSL?(11/08/2006) My NAS is a pain in the ass
(11/06/2006) cannot see my NAS!(11/03/2006) what is wrong with this thing
(10/31/2006) Need help Badly struggling with this problem(10/22/2006) Natnix - the Hamachi alternative
(10/17/2006) How can I do this? Private LAN, Hotspot, VPN?(10/17/2006) Slow internet page loading and irratic download speeds.
(10/14/2006) power management (drive spin down) with DIY NAS(10/13/2006) Is this setup possible?
(09/19/2006) Wicked Slow Router Speeds(10/14/2006) NAS speeds slower than expected
(09/21/2006) Please help me figure this out.(11/05/2009) Help! My broadband highspeed internet is running slow
(09/19/2006) NAS - windows embedded or not?(05/07/2009) Ultimate NAS/media server & media player
(08/16/2006) Build a Linux NAS - Web Server(08/05/2006) Is there a perfrect NAS solution out there for me?
(08/04/2006) Opinions on suitable NAS required please.(07/31/2006) Slow browsing speed
(08/02/2006) 5-bay NAS is coming up!!(07/24/2006) Wireless slow on XP but fast on VISTA
(07/13/2006) New Home... What ethernet cable do I get? I'm new to this.(08/14/2006) SAN or NAS
(07/23/2006) FTP and NAS(07/23/2006) Need a BYOD IDE NAS for 4 drives
(06/30/2006) Slow NAS Drive(06/23/2006) NVidia Firewall Will Not Allow Me To Access Internet
(06/12/2006) proxy firewall and this scenario from Forouzan Book(06/04/2006) NAS Hardware Advice Needed - Considering Thecus N2100
(06/02/2006) This 'simple network' won't work :( Please Help(05/17/2006) this is just WEIRD. Strange router behaviour within.
(05/10/2006) HELP! need an NAS, but don't know which one to choose(05/03/2006) XP machine claims to be 100Mbit but will not do >9mbit?
(05/05/2006) Will Port Forwarding defeat a router's purpose?(05/02/2006) Fast DSL, but SLOW Download Rates on COD2???
(05/05/2006) Slow DSL speed!!!!!!!(05/05/2006) Slow DSL speed!!!!!!!
(05/05/2006) Slow DSL speed!!!!!!!(05/05/2006) Slow DSL speed!!!!!!!!!
(04/28/2006) First time setting up Lan? How Do I test bandwidth with NAS(04/27/2006) need help finding this program...
(04/21/2006) Will a router work WITHOUT INTERNET?(04/04/2006) Slow 5 Meg connection??
(04/06/2006) Can't get past my router firewall. Need Help or alternative(04/17/2006) compatible router with this modem....
(03/26/2006) Help request - slow downloading(04/17/2006) Is this going to work? And what components are needed?
(03/17/2006) Controlling my NAS remotely.(05/05/2006) NAS Caddy via Gigabit Ethernet with Decent performance ?
(03/28/2006) Slow DSL through router?(02/18/2006) which would be better
(02/16/2006) help solving this problem ethernet setting :oops:(04/21/2006) Want to add NAS device to home network, any thoughts?
(02/28/2006) Which is Better: Cable or DSL???????(02/13/2006) What is SimpleShare NAS printer compatibility spec?
(02/09/2006) NAS/Network Attached Storage !! Please Help(02/10/2006) Xbox NAS / printer server Qs
(11/25/2005) Help! Slow internet!(09/10/2005) Alternative Ethernet Connector
(03/12/2005) slow TCP connections due to very different speed of segmen..(10/16/2004) Missing collisions on unmanaged repeater (this is a proble..
(09/18/2004) Using Jumbo Frames & Gigabit - Actual BPS is slow !(09/15/2004) Someone will Help me ?
(06/15/2004) Will PCI ethernet boards perform better than built-in ethe..(06/01/2004) can anyone identify this network card and chip
(06/08/2005) This is a great Newgroup(12/04/2004) Is this NG dead ?
(08/24/2004) very slow network(09/29/2005) VoIP that will work with StarBand 484 system
(06/24/2005) Linefire.... international plans... who has used this?(04/02/2005) Are all SIP softphones created equal (and will they work w..
(03/15/2005) What is this SIP phone worth?(03/09/2005) Will something like a Linksys SRW2016 do me any good?
(02/24/2005) DrayTek will release all VoIP/DSL/VPN Router model in CeBI..(01/18/2005) Software better than Skype?
(11/19/2004) netgear router + cisco ip phone: will ring with pc closed?(10/08/2004) Will "Skype Phone" work in Israel?
(07/20/2004) FA: Completely unlocked Cisco ATA 186 Will ship WORLDWIDE(06/08/2004) RTP: Who will deny odd RTP (UDP) port numbers?
(08/16/2005) why is vpn slow when establishing secure connection?(08/08/2005) Netscreen 5GT alternative VPN client for Windows
(04/12/2005) VPN setup - is there a standard way to do this?(03/21/2005) VPN application slow
(02/06/2005) Cant be this slow..please help(01/09/2005) Slow navigating
(03/14/2005) L2TP w/ Preshared Key better than PPTP?(01/17/2005) can a netgear router plus VPN client do this??
(05/28/2004) Which VPN router is better?(02/10/2006) How did this get through...
(09/29/2005) What is this?(09/16/2005) Is this possible : filter an internal network
(09/02/2005) BREAK THIS FIREWALL AND GET $10K(08/26/2005) Please help hijack this log. Don't know how to check spywa..
(08/04/2004) AlphaShield - any one tried this?(07/28/2004) What Does this Phrase Mean
(06/26/2004) PIX506E: Cisco insists that this configuration is correct,..(06/24/2004) Does any one know the answer to this?
(06/22/2004) Zonelabs lost this customer forever!(06/03/2004) WatchGuard reture this Error
(05/27/2004) Whis is better behavior based & signature based ?(05/25/2004) Is this enough protection?
(05/19/2004) Is this question unanswerable?(05/19/2004) Is the Netscreen 5GT enough firewall for this...
(05/22/2004) DI-604 "no space to add this entry"(05/15/2004) Will Checkpoint Remember Different IPs of Multihomed Host?
(05/16/2004) Q: Could the wrong cable cause this behavior?(05/10/2004) ZA 5 Beta Better?
(05/20/2004) Will Symantec 100 do the job...?(05/05/2004) Concerning SOHO routers and Port forwarding -- Is this cor..
(04/26/2004) Checkpoint SDL. How to support over this(04/21/2004) ISA Server and hardware firewalls - which is better
(04/12/2004) What is this Spyware and how is it running (Cont'd)(04/11/2004) Help identify this firewall message
(09/20/2006) Kerio 4 very much slow than 2.1.5(04/01/2004) is this normal with SyGate
(09/26/2005) very slow and frozen screen(05/31/2005) Wrong Address to this Newsgroup
(05/29/2005) MN-700 Netwrk Speed slow(04/09/2005) VPN will not stay connected
(03/21/2005) Port forward setting will not save.(03/13/2005) Could this be a hardware problem?
(02/28/2005) Setup will not detect the MN 720 in my laptop(02/22/2005) MN-700 Alternative Firmware
(02/20/2005) What's this?(02/20/2005) Slow network
(01/31/2005) MN700 Slight errors, dont let this router be forgotten(01/22/2005) MN-720 will not stay connected to wireless...
(01/17/2005) Frequent Router crashes? Try this.(01/16/2005) Has anyone tried this for our disconnect issues?
(01/08/2005) MN-740 Firmware will not update(12/27/2004) The purpose of this newsgroup ?
(12/22/2004) USB network will not work(12/06/2004) Will MN-700 act as as a remote device.
(11/17/2004) Slow Speeds, Please help!(11/17/2004) Is this a broadband failure?
(11/05/2004) This router is just killing me.(10/26/2004) Slow file sharing when using 802.11g
(10/21/2004) i will like to forward all ports from my MN-500(10/20/2004) 802.11g - Very Very Slow file sharing
(10/17/2004) MN-710 Slow Connection Speeds(10/18/2004) Slow Internet Explorer
(09/22/2004) MN-700 software will not load(09/09/2004) HOW DO I MANULAAY FLASH THIS DARN MN-700. It will not conn..
(09/06/2004) Power light will not go to green MN-700(08/30/2004) slow network and modem
(08/30/2004) Need a definitive answer to this question please.(08/30/2004) This is irritating
(08/26/2004) Net Meeting: this person is not able to receive internet c..(08/15/2004) MSBBN Will NOT Uninstall for Update
(08/15/2004) MSNBC will not install. HELP!(08/10/2004) MN740 adapter will not update Runtime Firmware
(08/08/2004) connection speed slow(08/04/2004) How to relocate Wireless router for better reception.
(08/20/2004) MN-700 slow(07/28/2004) Internet Slow/Crashes
(07/21/2004) about this update?(07/21/2004) wireless internet will disconnect than reconnect radomly
(07/19/2004) slow or no network with MN-500(07/13/2004) MN-820 slow download/upload
(07/11/2004) mn-700 slow uploads and failed downloads(06/21/2004) Network extremely slow
(06/20/2004) Why is MN-520 slow?(06/04/2004) Will there be new updates?
(06/02/2004) Slow Browser Page Opening(05/21/2004) Slow email through VPN on MN700
(05/17/2004) Dumb question, but will ask anyway: Signal strength proble..(05/12/2004) Whoa -- just saw this
(05/02/2004) This is what the game docs say...(04/30/2004) Slow Response in Outlook Express(Pop3)
(05/02/2004) MN-700-30-40 I have sent this message to microsoft(04/24/2004) Slow Connection With MN-700 and MN-730
(04/24/2004) network utility will not start(04/25/2004) MN720 will not connect on startup
(04/14/2004) MN-110 will not let laptop turnoff(05/22/2005) Slow internet connection through router
(05/23/2005) Anyone have any idea I can fix this problem?(02/09/2005) web browsing slow
(04/05/2009) Slow Internet Browsing(09/23/2004) Is this a cable fault?
(08/24/2004) slow network(03/31/2004) PXE and slow/missing DHCP
(11/07/2005) What does this mean?(10/08/2005) Need advice on NAS Setup
(08/30/2005) what does this IP mean(08/08/2005) Slow RoadRunner
(08/03/2005) Will this work well?(06/29/2009) Slow LAN transfer speeds
(07/07/2005) NAS Device Recommendation..(06/16/2005) Slow Broadband (UK)
(03/08/2005) Where is site this from?(01/21/2005) Slow gigabit network
(01/05/2005) Slow web page loading(11/16/2004) Is this the firewall or Windows doing this?
(11/06/2004) whats the best setup for this?(10/09/2004) Plz help me on this, unable to access internet?
(09/19/2004) Anyone heard of this?(08/18/2004) Can I get this router?
(07/21/2004) 10/100 very slow?(06/30/2004) NAS at home
(05/03/2004) Slow connection(04/22/2004) Network with file server (can I do this??)
(04/15/2004) Will this work? (networking with a USB modem)(03/17/2004) Slow internet when wireless network enabled
(02/13/2004) Frame Relay Alternative(02/10/2004) Whats up with this??
(12/19/2003) NAS for CHEAP!(11/30/2003) Will Scanner on another computer work?
(10/25/2003) Check Out This Funny Site(10/14/2003) Uploads make downloads slow
(10/17/2003) This has me stumped...(08/27/2003) slow response
(08/10/2003) SLOW DSL connection on XP(but not 2000)..pls help!(07/28/2003) No response to Microsoft on this....
(06/30/2003) is this possible?(06/30/2003) is this possible?
(04/09/2003) Does this gateway / router exist(03/19/2003) Slow DSL download speeds
(03/04/2003) Thinking of getting this.(03/23/2003) Network transfers from XP to 98 are slow??
(12/14/2002) Q: Slow LAN performance with Windows using BEFSR41(11/24/2002) Will a Cisco 678 work with Earthlink?
(10/31/2002) Help! Will this work?(10/09/2002) LAN...let me get this straight!
(09/16/2002) which file system for this enviroment(09/09/2002) Very slow internet connection
(09/01/2002) Ethernet becomes slow under WinXP?(07/31/2002) does this peripheral exist?
(08/04/2002) Slow Network?(07/22/2002) Router/Wireless AP.. Which is better?
(07/18/2002) Shouldn't be this hard: Can someone help?(07/11/2002) Australian Internet Woes. scroll thru this!
(07/04/2002) How good is this SMC7004ABR(06/04/2002) ?Could This Really Work?
(05/28/2002) Opinions on this router please(05/27/2002) Ameritech Co. is Rigging lines for slow connect
(05/10/2002) What do you think of this product?(04/16/2002) I'm all better now!
(02/28/2002) Win ME Slow Network(02/26/2002) Why is the net so slow on my CE Handheld?
(02/21/2002) can this router be a hub?(02/08/2002) which modem is better??
(02/01/2002) UPDATED - try to figure this one out.....(01/27/2002) Can anyone help me on this networking problem?
(01/26/2002) Home Network lock up's and slow(02/02/2002) Can a Router do this.....
(11/06/2001) Is this a software or hardware modem?(09/20/2001) Networked Computers Slow on Internet Games...
(09/14/2001) new V.92 seems slow(09/02/2001) 1meg upload, will cap?
(09/04/2001) would a router fix this problem?(05/20/2001) Slow modem connect speeds in Win 2000?!?
(05/16/2001) DSL suddenly got slow(04/22/2001) Will ISDN help?
(04/19/2001) It's getting better, but not much!(04/28/2001) I want to manually SLOW my cable connection
(03/30/2001) Which is better?(03/10/2001) Is this a winmodem
(02/07/2001) NIC will network but no internet(12/22/2000) anyone here old as dirt? need to be to answer this
Sponsored links
