News
AMD eyes chip memory expansion
Published on January 20, 2006
Advanced Micro Devices is exploring new types of onboard memory for its chips as a way to bump performance and squeeze more out of its manufacturing plants. Read more
VIA Announces Nano-ITX Board With VIA VX800 Chipset
Published on August 20, 2008
VIA Technologies announced the Epia N700 Nano-ITX board, designed as a complete solution for compact industrial PC and embedded automation devices. Read more
ECS and NVIDIA Join AMD Phenomena
Published on January 13, 2008
The MCP78M-A from ECS proves that NVIDIA hasn't given up the AMD market, regardless of competitive forces. Read more
D-Link: Demand for Gigabit Ethernet switches to surge by year-end 2005
Published on April 21, 2005
Demand for Gigabit Ethernet (GbE) switches is expected to surge substantially by the end of 2005 due to a narrowing of the price gap between the GbE and 10/100 Mbps switches, predicts JC Liao, president of Taiwan-based networking equipment maker D-Link. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
Gigabit performance: Onboard vs. PCI-E NIC
More related threads to : Gigabit performance: Onboard vs. PCI-E NIC
(11/11/2008) Networking gigabit managed ethernet switch(11/09/2008) 1Gbps network performance issues on Linux server
(10/26/2008) Realtek NIC and vista business, boot problem.(10/24/2008) Gigabit router suggestion please
(10/07/2008) Maximising Gigabit Network(09/03/2008) 1 internet line into 2 NIC on same PC
(08/22/2008) NFS performance, redhat - vista(08/06/2008) Gigabit Lan & PCI
(10/23/2008) Setup gigabit home network using 100mbps Router but Gigabit switches(07/04/2008) Dual Gigabit Ports - Useful?
(09/26/2008) Windows 2003 Server 2 NIC/Network Cards Multi-homed connection help!(06/01/2008) Onboard ethernet adapter very slow compared to network card - why?
(05/11/2008) Gigabit speed, 100MB bottleneck?(04/30/2008) Network Interface Cards vs Onboard. Worth it?
(03/24/2008) What is Two Gigabit Ethernet ports good for?(03/20/2008) Limited connectivity. Is this a problem with onboard LAN?
(03/02/2008) P2P azureus degrades LAN performance, Vista 32/64(02/08/2008) Netgear GS724TS Smart Gigabit switch
(02/08/2008) Multiple Gigabit ports on motherboards(02/06/2008) gigabit and intel pro/100
(02/05/2008) Jumbo Gigabit ???(02/05/2008) Motherboard PCI-E nic no Jumbo frames or PCI Nic with jumbo frames
(01/29/2008) Connector Ratings affect performance?(01/18/2008) Looking to upgrade to Gigabit, which 5/8 port switch?
(12/26/2007) onboard lan(Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC)??(12/06/2007) Compare performance of Cisco 1230/40 AP to Netgear/Linksys
(11/16/2007) Performance upgrades(11/04/2007) New WHS server, painfully slow gigabit transfer
(10/29/2007) Help setting up LAN with Gigabit(10/09/2007) Can't get more than 100Mbps Full Duplex on Gigabit LAN
(09/20/2007) Gigabit Questions (aka how do I take advantage of what I already have)(09/25/2007) Not recognizing onboard LAN (also HDD shrunk!)
(11/07/2007) Onboard LAN(08/28/2007) What is the best NIC for the price/Huge lag problems on WSU internet
(08/15/2007) Onboard network adapter not found.(08/09/2007) killer NIC
(08/07/2007) Will 100mbps modem/router limit Gigabit switch connections?(07/26/2007) Recommendation for Gigabit Jumbo Frame Switch
(07/31/2007) Multiple IP Address on single NIC(07/24/2007) Killer Nic and Killer K1 network card
(07/10/2007) How do I seperate 2 NIC's on a PC (1 for LAN, 1 for Internet)?(06/12/2007) Netgear XE102 similar performance to normal ethernet?
(05/08/2007) GIGABIT Router or GIGABIT Switch & Recommendation Please(04/10/2007) High performance LAN
(03/20/2007) Dual Gigabit MB W/3 PCs(04/10/2007) Dual gigabit
(03/11/2007) Using both gigabit ports on the asus a8n-sli deluxe(03/04/2007) Best Network Performance
(03/02/2007) Going Gigabit(02/27/2007) Dual Gigabit?
(03/23/2007) Bigfoot Networks Killer NIC horrible bussiness practices(02/28/2007) Need Info on an Intel PWLA8391GT NIC Card
(06/02/2007) 24 port gigabit switch(02/01/2007) Adjusting NIC properties in Device Manager
(02/13/2007) Gigabit Ethernet Chipsets(01/21/2007) New Workstation NIC Setup Trouble
(11/26/2008) Using Dual Gigabit Ethernet Mobo as a switch?(01/14/2007) Gigabit Ethernet PCI card
(01/12/2007) a gigabit lan connection between 2 pc's on a 6 pc network(12/10/2006) Gigabit Router?
(12/09/2006) Free network performance testing utility?(12/06/2006) Performance Monitor Alert Problem
(12/11/2006) amd x64 azus mb gigabytes NIC Internet connection problems.(12/04/2006) Gigabit Router/Switch Shootout DGL-4100 vs RVS4000
(12/04/2006) mixed gigabit and std ethernet network questions(11/30/2006) Dell/Intel based NIC Teaming intermittent connection issue..
(11/13/2006) external vs internal anntennas affect performance on routers(11/08/2006) 2 gigabit network cards?
(11/08/2006) Adding gigabit to an existing setup - Help(05/12/2007) does coupler degrade performance?
(09/23/2007) KILLER NIC(10/26/2006) Nvidia Gigabyte NIC drivers?
(10/26/2006) Good Gigabit Router !(10/05/2006) Enabling the Network Adapter Onboard Processor
(09/29/2006) Gigabit with 1 Mbps connection(09/26/2006) Encore ENLGA-1320 / Realtek 8169 NIC won't link at 1000mbps
(09/29/2006) Onboard NIC performance hits?(09/26/2006) Higher Performance Quality Router - Suggestions?
(09/14/2006) Can't get Gigabit speed from Raid to PC(09/12/2006) Routers in home performance, do they really differ?
(09/11/2006) Only 100Mbps Full Duplex on Gigabit LAN(09/05/2006) Killer Nic card??
(09/26/2006) Gigabit speed problems(08/09/2006) Looking to purchase a managed gigabit switch.
(07/28/2006) GOOD Gigabit switch?(07/26/2006) Gigabit switches: price vs. performance data?
(07/21/2006) 10 fun things to do with dual gigabit ethernet?(07/15/2006) 10/100/1000 vs Gigabit Ethernet
(07/07/2006) Starting a gigabit network(06/29/2006) Looking for solution - transferring video over gigabit
(07/03/2006) Management of 2 NIC's running 2 LANS(06/19/2006) Dual gigabit and one router??
(08/01/2006) Gigabit Switch with Jumbo Frames(06/20/2006) NIC: Old Intel Pro 100 vs New Realtek 100
(07/22/2006) best gigabit switch... for home use?(06/14/2006) Gigabit Network Problem
(06/12/2006) gigabit Switches(01/13/2007) Ideal Gigabit setup? - Thoughts please
(05/16/2006) setting up home gigabit lan(09/24/2007) best gigabit switch and topology for SMB
(05/30/2006) Best Gateway with Gigabit ?(06/06/2006) Best gigabit switch
(03/15/2006) Need 8-port MANAGED GigaBit Switch?(03/06/2006) Onboard LAN issues :( PLEASE HELP!!!!!!!!
(03/06/2006) Nic Failure or something ??!!?(05/05/2006) NAS Caddy via Gigabit Ethernet with Decent performance ?
(04/27/2006) Best PCI NIC(05/30/2006) Speeding up gigabit home network
(02/09/2006) Problem with 2nd NIC, Windows 2k(02/10/2006) ASRock Onboard LAN Help!!!!
(01/31/2006) Is my onboard LAN controller a goner?(02/08/2006) Jumbo frames - router, gigabit switch
(01/22/2006) Asus Onboard lan problem(01/17/2006) Using Gigabit and Fast Ethernet on computer
(12/27/2005) Gigabit LAN w/ Jumbo Frames: Impact on WAN access (non-JF)?(12/21/2005) 10/100/1000 Gigabit Router...
(01/17/2006) PCI Gigabit LAN Card vs OnBoard Gigabit LAn THe SAME?(12/26/2005) Questions regarding Gigabit Ethernet
(12/08/2005) High routing performance broadband router...(09/15/2005) Network performance (latency)
(09/08/2005) Linksys SRW2016/24 gigabit?(09/06/2005) PCI 10baseFL NIC
(08/30/2005) Gigabit Flexibility with Magnum 6K32T Managed Switch from ..(09/02/2005) Can a standard NIC be triggered to send an electrical sign..
(08/29/2005) Auto negotiation and Gigabit cards,(07/15/2005) Managed Gigabit Switch with MAC address filtering
(06/25/2005) Q: redundant uplinks between gigabit switches?(06/17/2005) Issues with CS8900a based NIC...
(06/13/2005) Gigabit Ethernet connector(06/13/2005) Gigabit Ethernet connector
(04/20/2005) "Optimal performance" on Realtek 8139 Windows drivers(08/13/2005) Non-PCI gigabit Ethernet controller
(04/03/2005) End to End Performance Measurement(01/02/2005) TTCP results on Gigabit network
(12/09/2004) gigabit pricing(10/28/2004) Getting Checksum Errors on Gigabit Ethernet Cards
(10/25/2004) gigabit and 1000baseT(09/18/2004) Using Jumbo Frames & Gigabit - Actual BPS is slow !
(08/24/2004) gigabit switch chip(11/08/2004) Using Jumbo packets in gigabit ethernet
(07/09/2004) performance parameters of Ethrnet packet std IEEE 802.3(06/18/2004) advise on gigabit switch?
(06/03/2004) gigabit ethernet link synchronization(04/26/2004) gigabit with 2 100eth adapters on w2k3
(04/14/2004) Greater than Gigabit speeds over Copper(06/29/2005) Encryption overheads and general performance qs
(06/03/2005) sql server and vpn: performance/speed(04/10/2005) Wireless Ipsec, GRE and L2TP (performance analysis)
(04/20/2004) Can secondary NIC's bypass nortel vpn tunnel on win32?(09/02/2005) Suggestions for a gigabit speed SIP & RTP firewall
(07/30/2004) Checkpoint and Gigabit Ethernet(06/29/2004) [hardware] gigabit firewall
(09/09/2005) Some Guidance on Wireless Distance Performance Improvement(08/25/2005) New PCI NIC
(07/27/2005) NIC MAC Physical adress FF:FF:FF:FF:FF:FF(12/21/2004) BCM HPNA 10Mbps NIC
(09/20/2004) Wireless NIC finds network, but not Internet(09/02/2004) MN-710 NIC and D-Link 802.11b Router
(06/23/2004) MN-700 / MN-720 (Base Station - NIC drops connection)(06/03/2004) NIC card loses ip address after 5 minutes
(06/02/2004) Performance Problems with manageble Netgear Switches(05/26/2004) NIC Teaming problem
(04/15/2004) Performance of MN-700 wireless G network(08/09/2005) win95 NIC card
(07/16/2005) Disabling NIC when LAN connected(11/16/2004) Dual NIC
(11/01/2005) help pls w/ NIC uninstallation(10/31/2005) Gigabit and Wifi Madness
(08/03/2006) Gigabit cabling(09/13/2005) Gigabit network?
(08/07/2005) Marvell Yukon Gigabit Ethernet Controller(05/31/2005) check a NIC?
(01/23/2005) Is The Problem My Config Or My NIC?(01/15/2005) why do we see Gigabit devices only in wireless?
(01/21/2005) Slow gigabit network(11/11/2004) Poor performance with a router
(09/24/2004) Plz help, lost internet connection after NIC reloc(08/15/2004) What cables to use for Gigabit network?
(07/02/2004) 10/100 or gigabit ethernet(06/01/2004) Performance Problems with Netgear Switches
(05/25/2004) DI624 poor performance(05/07/2004) Trouble using full Gigabit ethernet
(07/15/2004) A good affordable gigabit router?(03/19/2004) 2nd NIC problem
(02/04/2004) Cable and Computer Performance(12/27/2003) Gigabit Ethernet Questions
(12/04/2003) Routing Performance - Linksys WRT54G & N.G. WGT624(07/09/2003) Network Performance Comparison/Benchmarking?
(06/06/2003) NIC to NIC crossover question(04/13/2003) Erratic network performance.
(03/16/2003) NIC question(03/05/2003) Help w/ Gigabit onboard
(12/17/2002) Linksys USB NIC Driver Steals 15% of CPU(12/14/2002) Q: Slow LAN performance with Windows using BEFSR41
(10/10/2002) Wake on Modem (Onboard) vs. PCI Modem(07/18/2002) DB-15 and BNC NIC
(06/11/2002) Network with WInME and Win2000 Performance Problem(06/11/2002) does NIC+USB Modem = 2xNIC??
(05/19/2002) gigabit over barbed wire!(05/06/2002) onboard lan problem
(04/19/2002) "No Signal" After NIC Installation(04/02/2002) LAN performance question
(02/21/2002) cant remove NIC -Help pls(02/13/2002) 3COM NIC ping=good, all else ping=bad
(01/29/2002) Cable for gigabit ethernet(01/30/2002) Universal/Generic NIC Driver?
(01/21/2002) Performance issues and internet sharing(12/10/2001) enabling ICS makes NIC disappear
(12/10/2001) Do Gigabit NICs improve cable modem speeds?(11/30/2001) OC friendly NIC needed
(11/29/2001) NJ100 review vs NIC shootout data disagreement?(11/13/2001) USB 3Com NIC 3C460B Good Performer?
(11/13/2001) need advice on NIC/cable(10/25/2001) Added 2nd NIC, now 1st NIC gone!?
(10/23/2001) Abysmal Network Performance(09/29/2001) NIC Help
(09/10/2001) networking without NIC and Cross cable(09/01/2001) NIC article
(08/16/2001) Code Red Hurting Performance???(07/09/2001) NIC Cards - What's the diff?
(05/02/2001) NIC card(04/25/2001) NIC causing irq lockup?
(04/08/2001) PCMCIA 3Com NIC problem(02/21/2001) Overclocking & NIC issues
(02/07/2001) NIC will network but no internet(01/28/2001) DOS drivers for Linksys NIC ?
(04/26/2001) Which NIC is fastest?(01/16/2001) Should I enable flow control on my NIC card?
(01/04/2001) Dual Nic Increases performance?(12/22/2000) NIC stops boot up
Google Ads
