Can't share my documents!!
More related threads to : Can't share my documents!!
(11/27/2009) Can't connect to router settings(12/14/2009) Can connect to DIR-655 router but no internet access
(12/11/2009) Win7<->winXP share folders help(11/25/2009) Can't Ping DNS
(11/15/2009) *C:\Documents and Settings\Loyd\My Documents\My Videos(11/13/2009) Who to share printer with two ethernet cards in windows xp
(11/12/2009) Can not remove network adapters in xp(11/12/2009) Can the windows 7 firewall system act tmg?
(11/12/2009) How does I file share with Windows7(11/20/2009) Trying to Share a Hard Drive That is Setup in a RAID 0
(11/07/2009) Multiple Hard Drives on one network share?(11/06/2009) Two networks to share one internet connection?
(11/02/2009) Can two desktops go on one modem without paying extra?(10/31/2009) Can someone hack into my land line phone number?
(10/31/2009) Can someone who uses(or knows about) managed switches answer simple ?(10/14/2009) Can you turn on pc over lan or wan
(10/13/2009) Can i use more than one IP address on the same DHCP server(10/14/2009) Can not connect to a computer on my network
(10/16/2009) How i can share a file from vista to winXp(10/10/2009) Can fax using adsl router
(10/09/2009) I want to install my printer on my server and share it to all my netwo(10/09/2009) How to share internet over firewall on
(10/08/2009) How to share the internet connection by two computers without using router(10/06/2009) Can a virus spread between non networked yet physically connected pcs?
(10/01/2009) How to share an Internet connection?(09/30/2009) Outlook- Can recieve emails, but sending failure.
(09/24/2009) Share between mac and pc(10/21/2009) Can I boot a PC w/o a HardDrive from another PC?
(09/15/2009) Can send and receive packets, still no connection(09/13/2009) Can i monitor another pc
(09/17/2009) Can't port forward some ports, getting desperate :((09/04/2009) Can I secure 2 ports on an 8 port shared router?
(09/21/2009) Bizarre Network issue. Can no logner connect properly to router(s)(08/31/2009) Can't ping netgear prosafe vpn firewall
(08/28/2009) Share my treasure with you!(08/22/2009) Can't connect to Interner using ethernet to Vista
(08/20/2009) Can't Print from HArdline(08/19/2009) Can connect through modem, but not through router
(10/19/2009) Can't Acquire or Install Correct NIC Drivers, GA-EX58-UD5(08/14/2009) Can't send Packets
(08/15/2009) Can I share connection with router and switch?(07/30/2009) Can't connect with Remote Desktop
(07/29/2009) Can't get Cat5e cable to work(07/31/2009) Can't view available wireless networks
(07/26/2009) DHCP Client Service Won't Start - Error 1068(07/24/2009) Help me share My docs and Network two printers PLEASE?
(07/04/2009) Access Denied Error when trying to share a DVD drive(06/27/2009) Can i do this?
(06/15/2009) Help! Only 1 Computer Can Use Internet on Network - Any Ideas?(06/11/2009) Can I use this Router as a Modem?
(06/07/2009) Can access the Router but doesn't have Internet[Wired](06/03/2009) Can a cheap switch damage an expensive one?
(05/28/2009) Can i transfer 4 raid5 hdds from one nas to another?(05/28/2009) Can i add an itunes/bittorent/print server to a terastation pro 2?
(05/22/2009) Internet share between two pc's(05/30/2009) Vista and removing the need for a password to access a share
(05/18/2009) Can't view webcam..!(04/25/2009) Can somone help me solve this subnetting situation
(10/10/2009) Can't get wireless Netgear router to work(04/03/2009) Usb to network share
(03/24/2009) Prompted for Guest password in XP Tablet for Samba share(03/23/2009) Anyone Can Help me Please?!
(03/22/2009) Can you network a Pc and an iMac?(03/17/2009) Can a switch be used as a hub?
(03/22/2009) CAN'T Remote Desktop Connection over LAN(03/06/2009) Damaged Documents
(03/22/2009) Can't Ping or Tracert: why?(02/16/2009) Vista and xp able to be hub to share internet?
(01/29/2009) Can only get XP pro to run 100Mbps on Gigabit LAN connection(01/16/2009) Can access shares but not browser workgroup
(01/13/2009) Can's see public folder on one network computer(12/30/2008) Can't Access BEC 5200S Modem/router
(01/07/2009) Can i reset my IP address??(12/21/2008) Can anyone tell me why this is happening?
(12/04/2008) Can't get LAN working(11/11/2008) Network Share?
(11/09/2008) Can you help me plan my lan party?(10/26/2008) Can ping loopback address but now my own IP (mask is Ok!)
(10/07/2008) Can someone explain my internet speed drop?(09/22/2008) Can u "delete" home networking?
(10/01/2008) Can a Router slowly fail?(09/19/2008) Can't share data between two routers
(01/04/2009) Can't get Linksys router to work with AT&T DSL(08/11/2008) Can't access domain computers via Remote desktop
(07/30/2008) Can you make two routers connect to eachother?(07/29/2008) XP Home Can't Join XP Pro Workgroup
(03/23/2009) Can't connect to one of three printers!(07/27/2008) Share USB aircard with multiple PCs
(07/16/2008) Can't connect to internet after reformating(07/14/2008) Cant share files or printer with other computers on my network
(07/04/2008) XP Password protected share, multiple logons(06/16/2008) Can I beat 15mbps/768kbps?
(05/13/2008) Can I "get" internet from other pc using(04/24/2008) Windows Can't detect my network?
(04/24/2008) Can't share wireless internet connection(03/12/2008) How to network share between router a and router b?
(01/22/2008) Linksys 5 port Hub- Can't connect more than 2 computers to internet(01/15/2008) Can I plug a wireless router into a wired router?
(01/15/2008) Can't get internet with GA-M61P-S3 - Network Controller problem?(01/12/2008) Cannot share between Vista and Xp
(01/09/2008) Documents from the network stick in the printer queue(01/03/2008) What am I doing wrong? Can't get even 90Mbps
(12/14/2007) Can anyone help me?(12/07/2007) Can't connect to my campus network please help!!!
(12/11/2007) Can you do HTTPS over an alternate port?(11/03/2007) HELP!! share ADSL line with ethernet PC and wifi laptop
(09/29/2009) help request:how to share your internet over internet via vpn(10/28/2007) Netopia R910: Router -to-Router VPN, Can't PING Remote LAN
(10/21/2007) Cant file share! Need help!(10/11/2007) Can WHS be used as a workstation?
(09/27/2007) Websites/FTP doesn't work. SCP and SFTP does. Can I tunnel/proxy in?(10/09/2007) Can't get more than 100Mbps Full Duplex on Gigabit LAN
(09/14/2007) Making Windows And Linux Share(09/06/2007) Can't access fileserver and internet concurrently
(08/07/2007) Can't access FTP Using Static IP(09/28/2009) Can't connect with windows remote desktop
(07/10/2007) Share computer WI-FI connection with XBox 360 through Ethern(05/15/2007) Can a networking guru please help me set-up my router/LAN?
(05/31/2007) Vonage and Linksys PAP2 - Can be used for other VOIP?(04/24/2007) Can't access my PC remotely.
(04/10/2007) trying to share my connection, solutions please!!!(04/08/2007) Router cannot share internet connection
(04/10/2007) Can't find network (router)(03/03/2007) Can't ping web site using Dos command?
(02/20/2007) Share folder from Win2K Server to XP Home. Simple, right?(02/25/2007) Can't access other computer from Vista machine
(01/29/2007) Can anyone explain the torrent mechanism?(02/04/2007) Can I MOVE my router successfully....?
(01/29/2007) Can not get / use IP-adresses(01/16/2007) Can someone explain torrents use of bandwidth?
(01/18/2007) Can anyone recommend a replacement hub that died on me?(01/15/2007) Can VPN set up on DSL hookup?
(11/27/2006) Please help me share my printer on this network~ thx(11/27/2006) Possible to share dial-up 56k?
(04/15/2007) vnc desktop share over 2000 pro vpn(10/06/2006) Can't see network computer with 2 Routers - HELP
(09/14/2006) Can't get Gigabit speed from Raid to PC(08/31/2006) Can connect with IP but not name? WINS?
(09/10/2006) Can a Router be "Hijacked"?(08/08/2006) Can't connect to internet now with XP
(07/24/2006) Can't uninstall my network to replace(07/23/2006) Can surf but can't connect.
(09/29/2008) Can't connect to the internet(07/06/2006) XP and Win2K/Wired and Wireless - Unable to establish share.
(06/20/2006) Can't see host computer on network using ASUS WL-520g(05/30/2006) 2 internet connections, 1 network; how to share?
(05/13/2006) Can I leave it on?(05/12/2006) Can I leave it on?
(04/11/2006) Can I get online with an access point instead of a router?(04/06/2006) Can't get past my router firewall. Need Help or alternative
(04/17/2006) Can anyone advise a router to setup a FTP server?(03/13/2006) Can't access host computer files
(02/10/2006) Can not connect to shared PC or Printer after new PC(11/17/2009) Can't log into Windows XP,,, doesn't remember my password :(
(01/17/2006) Can't access internet with #2 PC(01/10/2006) Workgroup. PC AA can share folders f PC BB but not reverse.
(01/04/2006) Multiple NICs, Can't connect to 'net, Web servers workfine(12/28/2005) Can't get router to connect at right speed. (please help)
(12/16/2005) Can someone help me untangle a LAN mess?(11/27/2005) How to share folders and files more than two levels deep???
(11/17/2005) outlook and outlook express on the network share cant attach(09/02/2005) Can a standard NIC be triggered to send an electrical sign..
(02/25/2005) Wanting to share internet between two networks(02/24/2005) Wanting to share internet between two networks
(11/26/2004) Intel PRO/100 VM card - Can only get 10Mbps(11/19/2004) Can't access Router admin.
(11/03/2004) Can't access Router admin.(11/02/2004) Can't access Router admin.
(11/02/2004) Can't access Router admin.(11/01/2004) Can't access Router admin.
(03/22/2005) URGENT: Polycom SoundPoint 500 sip.ld problem! Can't go on..(09/19/2005) Can't forward calls to AT&T CallVantage number
(08/03/2005) Can NOT save file, unsupported Codec VoIP(07/05/2005) Can Vonage et al. be used FROM foreign countries?
(05/27/2005) Can Hotels Block VoIP Access?(05/27/2005) When You Dial 911, Can Help Find You?
(04/13/2005) Calling from China to US, Can I install something on home ..(03/21/2005) Can't call my VOIP phone from my cell phone, except when R..
(01/15/2005) Can DLink DVG-1402S router work with Vonage voip service(10/06/2004) Can the Cisco ATA 186 register 2 SIP accounts at the same ..
(08/14/2004) Can Vonage ATA receive calls from softphones like SJPhone(07/08/2004) Can 3 small offices can be connected by VoIP?. How?
(05/09/2004) VoIP Market Share(04/16/2004) Can anyone recommend VoIP solution for Hotel Environment?
(04/10/2004) Can anyone recommend VoIP solution for Hotel Environment?(08/20/2005) Netgear FWAG114 to FVS314: Can ping one LAN, not the other
(06/16/2005) Can't authenticate PPTP to a Cisco VPN 3005(05/24/2005) Can't get PPTP to work
(03/24/2005) Can't logon to W2K Domain through PIX 515 VPN(03/15/2005) Can connect to Check Point VPN server but can't ping?
(03/08/2005) Can connect but cannot see shared resources(03/02/2005) USR8000A-02 + Verizon DSL -- Can't VPN?
(01/24/2005) Can't get BEFSX41 VPN to work(12/17/2004) Can routing table be overruled?
(09/26/2004) Can a router change a port?(09/22/2004) Can't Connect to VPN with Intel NetConnect using RSA SecurID
(09/17/2004) Can only ping once the remote computers(08/05/2004) cannot share files after connecting
(06/09/2005) Can't VPN using WIFI please help!(06/06/2004) Can't access port 6666 through VPN
(05/19/2004) Can ping but no web access(04/20/2004) Can secondary NIC's bypass nortel vpn tunnel on win32?
(09/14/2005) Can ARP broadcasts be blocked?(07/19/2004) Can't reconfigure Netgear router after modem change
(06/17/2004) Can the host computer see what sites are visited on someon..(05/23/2004) Can't get my homepage - Help
(05/19/2004) W2K Firewall That Can Route Outbound Packets on Same Inter..(05/09/2004) Can't get Outpost 2.0 to work on ICS computer
(05/09/2004) Can I unstealth Kerio 2.1.5?(04/06/2004) Help: Can't get shorewall to work in Mandrake 10
(04/02/2004) Can Zone Alarm (Freebie) run...(04/09/2004) Firewall rules for AD and mapping network share
(04/01/2004) Can the linksys WAG54G be updated to do real DMZ (Was Link..(08/26/2005) Can I boost my signal?
(07/14/2005) MN- 510 - Can it do WPA??(07/12/2005) Can't View Workgroup Computers
(06/17/2005) Can I use my MN 700 just to connect 2 computers wireless?(06/15/2005) Can a base station be set up to extend the range of a wire..
(05/19/2005) An easy way to share your Internet(05/09/2005) Can't save file to shared folder
(05/08/2005) Can't install wireless network on windows XP media edition(04/26/2005) How Can I set up a wireless network to Windows 2000 profes..
(04/09/2005) WIRELESS CAN'T CONNECT TO BASE STATION(04/10/2005) Can't access the management console of my MN-700
(04/01/2005) Can't open certain web-sites(03/28/2005) Can not connect...
(03/25/2005) Can't access Managment tools for mn500(03/20/2005) Can't save wizard settings to 700 base station
(03/08/2005) Can access Internet but not Outlook on Wireless Network(02/25/2005) Can't load website through router!
(02/06/2005) Can't Network mn 720 through mn700(02/01/2005) Can't see other computers on Network
(01/22/2005) Can't connect to my sprint dsl modem(01/25/2005) Can ping and transfer files but cannot not access net...
(01/19/2005) Selecting a folder in My Documents starts a search.(01/18/2005) Limited or No Connectivity + Can't renew my IP address = N..
(01/03/2005) Unable to share connection(01/03/2005) Can you connect two Xboxes in Home Network
(01/03/2005) How to share a printer over internet?(01/01/2005) Can't reinstall MBN utillity
(05/22/2009) Can't renew/repair IP address(12/21/2004) Can't get non-microsoft-wireless card to talkt to base sta..
(12/21/2004) Can't get dynamic ip address from ISP(12/12/2004) Can't sign in under my Adminstrator ID
(12/11/2004) PC Can't View Workgroup Computers(12/10/2004) Can I connect to my home pc from work?
(11/24/2004) Can' t keep more than a 3 min conn with my MN 500 with exc..(11/18/2004) Can't send mail if connected through MN-500
(11/10/2004) Can't setup wireless internet connection!(11/17/2004) Three Computer Network - Wireless Laptop Can't Share Resou..
(10/25/2004) Can not connect to base station(01/28/2009) Can't connect to the router
(10/11/2004) Can't connect to wireless network(10/07/2004) Can do static NAT mapping
(09/28/2004) Can't Send E-mail via Wireless connection(09/27/2004) Can't connect after Service Pack 2 Installation
(09/30/2004) Can't access Management Tool(09/24/2004) Can't access Base Station Management tool
(09/21/2004) Can't See File Location on Network(09/25/2004) Can't update MN-700 w/SP2
(09/15/2004) Can't access secure sites(09/14/2004) Can't connect to other computers after download of SP2
(09/13/2004) Can see device!(09/14/2004) Can't host games in Gamespy Arcade.
(09/18/2004) Can't connect to wirless network(09/10/2004) Can't send mail when connected through MN-100
(09/08/2004) Can't Find Drivers For MN-720(09/03/2004) Can't connect to certain websites on MN-700
(08/17/2004) Can't connect with Xbox(08/14/2004) Share broadband internet with Ipaq via w-fi - how?
(08/13/2004) Can the MN-710 and MN-720 ad-hoc(11/07/2007) Can't share files
(08/10/2004) "Can't configure the base station" - MN-700(08/08/2004) Can't find MN-700 anywhere for purchase
(08/03/2004) Dial-up Share through Wireless(08/01/2004) Can't open two of the same ports
(07/28/2004) Can't connect with MN-720 and XP(07/27/2004) Can not connect to selected network
(07/27/2004) Can no longer see wireless network!??!(07/22/2004) how to share folders and printers
(07/21/2004) MN-500 - Can't access base station(07/20/2004) Can't find my MS 500 Program on my computer - need to loca..
(07/15/2004) Can't see other machines on network(07/08/2004) Can't share files and printers, internet is ok
(07/02/2004) Can you change Preamble on MN-500?(07/02/2004) Can not connect to base
(06/27/2004) Can't Get The Laptop Internet(06/26/2004) MN-700 CAn Recieve but not send email via Sympatico
(06/25/2004) Can someone help please, basestation untility won't recogn..(06/22/2004) Access Mode MN-700 Can't get in now.
(06/22/2004) Cant share files(06/21/2004) Can I use 2 different browsers?
(06/20/2004) MN-500 Can I set it up as a hub only(06/12/2004) Can't Run Base Station Management Tool
(06/11/2004) Can't get DSL Xtreme throughput(06/10/2004) Can't share folders
(06/06/2004) Can't even get 30' of range,,, Help?(06/06/2004) Can't connect - WZC Service won't start
(06/05/2004) MN 820 - Can Ping, Can't Browse(06/04/2004) Can MN-520 work on NT4?
(06/03/2004) Can anyone help(06/02/2004) Success Win98 Wifi share
(05/23/2004) MN-500 and Netgear - Can't get these two to work!(05/15/2004) Can't get Internet download upgrades for AVG , Bazookia, e..
(05/12/2004) Can't Connect MN-720 to Base Station(05/05/2004) Can't run Norton's Live Update
(05/05/2004) Can't Access Base Station Mgmt. Tool(05/02/2004) Can't connect to internet
(05/02/2004) Unable to share folders(05/01/2004) Can not access hard disc
(04/26/2004) Can access internet but not other computers(04/27/2004) Can't Access Base w/ Security Enabled
(04/24/2004) Can the MN-100 be uplinked?(04/21/2004) Unable to Share Printer
(05/01/2004) Can two MN-700s share the same broadband?(04/20/2004) SHare Printer MN620 Wireless Broadband
(04/20/2004) HELP SHARE PRINTERS(04/17/2004) Can't open Base Station Mngmnt Tool
(04/15/2004) Can't seem to access files on the network, get a response ..(04/15/2004) no file share
(04/14/2004) no file share(08/17/2009) Can't View Available Wireless Networks....
(04/11/2004) Can't find network w / wireless adapter(09/30/2005) Can't ping anything
(03/01/2005) how do I share wireless internet with my neighbors router?(11/24/2004) Can a LAN be setup using the internet? Read below
(06/09/2004) Can I Split?(05/09/2004) Can you get two ip's through a router?
(10/14/2005) Can't Access Internet With Lan3(10/12/2005) Can't access router page
(09/29/2005) Can't see workgroup computers with new install(12/29/2005) Use switch to share internet, not enough IPs
(03/24/2005) Can't get DFI Lanparty NF4 SLI-Dr to network!(01/24/2005) Can help me to decide which router should I choose
(11/29/2004) Can a kind man tell me what `wallop` is?(10/13/2004) Setting up a Network to 1 Share DSL Connection
(09/28/2004) Can not get online with router(09/21/2004) share internet connection
(08/18/2004) Can I get this router?(07/23/2004) Can't connect to internet when I disable router
(07/28/2004) Can't get to one site(04/24/2004) Can only use IE to browse the web
(04/10/2004) Can access other PC's on ntwk but not the Internet(02/06/2004) Can I use same CAT5 cable for network and phone?
(02/04/2004) Can't access Computers on my LAN!!(02/01/2004) Can't access T-mobile site
(01/29/2004) I Can't Disconnect(11/30/2003) XP Can't Connect
(11/26/2003) Can I install XP thru a network?(11/08/2003) XP Can't network in home *DELETED*
(11/14/2003) Can't search!!!(10/08/2003) Can somebody help with connecting a Labtop to DSL
(09/07/2003) Can't seem to download anything...please help!(06/18/2003) Can I keep adding routers???
(06/04/2003) Easiest way to share the connection(04/01/2003) WinXP share to my Win98 how to?
(03/27/2003) Can someone explain CAT5 pairs?(04/16/2003) Can't communicate with TCP/IP
(03/05/2003) Can no longer access internal ip(03/06/2003) HOw do I share files?
(03/02/2003) XP-->W98 Printer Share(02/13/2003) Help, Can not connect
(02/04/2003) Can my Router be used as a switch?(01/26/2003) DSL share with neighbor, good or bad?
(12/24/2002) Can't connect to internet with network card.(12/13/2002) Can anyone suggest a fax machine?
(10/15/2002) Can video drivers affect internet pings?(09/12/2002) adsl cant share?
(09/11/2002) Can't get ME and 98 to communicate(07/18/2002) Shouldn't be this hard: Can someone help?
(06/07/2002) Can anyone tell me how to network(02/27/2003) Can't receive files
(06/02/2002) Can you share a video/tv source over a network?(04/02/2002) What do I need to share a internet connection?
(03/22/2002) Can I do a WAN?(06/09/2002) Can I make my LAN ping higher?
(03/17/2002) Can I plug the cable modem directly to my hub?(03/03/2002) Can't get Internet Connection Wizard to Work
(02/08/2002) Share Internet connection with two computers(01/27/2002) Can anyone help me on this networking problem?
(01/22/2002) Internet Share...(02/02/2002) Can a Router do this.....
(12/18/2001) Can't get on Internet(10/30/2001) Can anyone tell me WHAT EXACTLY is ADSL?
(10/04/2001) Can't connect to m.o.(08/21/2001) easiest way to share files
(08/14/2001) Can I Network Win200Pro to Win 98 with no hub/swit(08/13/2001) Can anybody get to Hardocp.com..??
(08/03/2001) Can company monitor your web browsing activities?(06/12/2001) problem to share isdn
(04/28/2001) Can't share files(04/17/2001) Is it possible to share a scanner ?
(03/10/2001) Can My Win98 Box act as a VPN Server?(01/12/2001) Can't find Internet Sharing in my Win98
(01/07/2001) Can't Post to NGs(01/17/2001) Can't Update Windows
Sponsored links
