News
Abit releases new Fatality motherboard for AMD AM2 processors
Published on May 25, 2006
Abit has released a new motherboard in its popular Fatal1ty gaming line. The AN9 32X motherboard will support AMD's new socket AM2 processors and will have two full speed X16 PCI Express lanes. Four DDR2 memory slots can support up to 8 gigabytes of RAM running at 800 Mhz. There are also two Gigabit Ethernet ports along with two Firewire ports. Read more
Tyan launches Intel Xeon 5000-series based server lineup
Published on May 24, 2006
Tyan Computer launched a lineup of servers based on the dual-core Intel Xeon 5000-series processors - the Tempest i5000PX (S5380), which targets the high-end sector and the entry-level and mid-range series, the Tempest i5000VS (S5372) and Tempest i5000VF (S5370). Read more
The Fit-PC Slim Is One Super Small PC
Published on September 19, 2008
The fit-PC Slim is an ultra-compact Windows-capable PC that uses just 4 Watts of power Read more
Abit intros Intel quad-core motherboard
Published on August 18, 2006
Abit announced its AW9D and AW9D-MAX motherboards which can be used with Intel's current LGA775 processors such as the Pentium D and Core 2 Duo as well as future quad-core versions of the Core 2 Extreme CPU ("Kentsfield"). Read more
Latest Reviews & Articles
Intel's Core i7: Blazing Fast, But Crippled O/C
Published on November 03, 2008
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
+ Ethernet Ports?
More related threads to : + Ethernet Ports?
(12/02/2008) Ethernet Controller troubles(12/02/2008) Ethernet Controller troubles
(11/20/2008) Dual 10/100/1000Mbps Ports on Mobo?(11/20/2008) Wiring house for ethernet
(11/11/2008) Networking gigabit managed ethernet switch(10/22/2008) Vista blocking ports/udp - help needed
(10/22/2008) Help with marvel ethernet before i blow my brains out(10/24/2008) Ethernet cable not detected !
(10/23/2008) Dorm Ethernet Hub(10/15/2008) Ethernet and Wireless connection difficulties.
(10/18/2008) Opening Multiple Ports on Windows Firewall(10/11/2008) All my ports on my pc become blocked after a while
(11/25/2008) My Router Suddenly Closed all the Ports I opened - WTF?(10/07/2008) Lan Ports don't seem to be working on the motherboard
(10/07/2008) Combination Ethernet, Phone Jack(10/06/2008) What do ethernet colors mean?
(10/07/2008) What ethernet cable should i get?(09/26/2008) How to unblock certain ports. or forward ports.
(09/19/2008) New router - ethernet cables?(08/13/2008) Chorus/NTL (a UPC company) Cable TV box has an ethernet port
(08/08/2008) Notebook Ethernet controller(08/15/2008) Wireless Vs Ethernet
(07/07/2008) Ports(07/04/2008) Dual Gigabit Ports - Useful?
(06/20/2008) Soltek MOBO has ethernet but...(06/11/2008) XP won't detect ethernet card.
(06/08/2008) Dual Ethernet(05/30/2008) 2 network ports on 780i mobo?
(06/01/2008) Onboard ethernet adapter very slow compared to network card - why?(06/01/2008) Ethernet device no longer recognized by Vista?
(05/13/2008) use 2 wireless routers to add ethernet cables?(04/22/2008) Dual ethernet links
(04/15/2008) PC does not realize my ethernet cable(03/24/2008) What is Two Gigabit Ethernet ports good for?
(02/08/2008) Multiple Gigabit ports on motherboards(02/07/2008) Internet / Ethernet stops working when using network drive.
(02/01/2008) Need additional ports than what my existing wireless router provides.(03/12/2008) Dual Ethernet mobo + router question
(01/11/2008) Linksys wrt54g ethernet problem(10/08/2008) 2 Ethernet Connections. Specifying one for internet, other for local?
(12/26/2007) onboard lan(Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC)??(12/03/2007) setting up xbox 360 through the second ethernet port on my mobo help?
(11/26/2007) Connecting Ethernet Crashes Computer(11/19/2007) No ethernet detected
(11/03/2007) HELP!! share ADSL line with ethernet PC and wifi laptop(09/07/2007) MB built-in ethernet suddenly failed, don't understand lights
(08/14/2007) Ethernet Nonfuctional?(07/17/2007) ethernet booster or extender
(07/13/2007) I need help setting up ethernet(06/16/2007) Having a lot of trouble installing Ethernet router modems
(06/12/2007) Netgear XE102 similar performance to normal ethernet?(06/07/2007) Help forward ports through a belkin F5D7230-4 with a dsl502T
(06/05/2007) Vista doesnt install drivers for my ethernet and wont connec(06/02/2007) Ethernet issues
(03/20/2007) newbie question about wired ethernet(04/20/2008) Ethernet over phone line
(03/23/2007) combining phone system with ethernet(03/06/2007) Ethernet Delay
(03/11/2007) Using both gigabit ports on the asus a8n-sli deluxe(03/02/2007) Ethernet Switch Question
(02/19/2007) Second router for more ports don't show on network(03/01/2007) Laptop won't recognise cable modem thru ethernet port
(02/11/2007) no ethernet drivers for avertec 7160(02/21/2007) Opening ports at my University?
(02/09/2007) Opening Ports On Linksys BEFSR41v4 Disconnecting Me(01/24/2007) Ethernet Coax Bridges
(02/13/2007) Gigabit Ethernet Chipsets(11/26/2008) Using Dual Gigabit Ethernet Mobo as a switch?
(01/14/2007) Gigabit Ethernet PCI card(01/07/2007) Email Server on Cable (Blocked ports)
(12/24/2006) Ethernet a worldwide standard?(12/16/2006) please help cpu doesn't recognize ethernet
(12/04/2006) mixed gigabit and std ethernet network questions(11/22/2006) ADSL & ETHERNET Question
(11/22/2006) ADSL & ETHERNET Question(11/22/2006) ADSL & ETHERNET Question
(11/23/2006) ADSL & ETHERNET Question(12/12/2006) ethernet LAN mixed-speed setup
(11/13/2006) Alphabet soup, jargon, and Ethernet LAN specs(01/13/2007) Ethernet speed
(11/03/2006) Assign ip to different Router Ports(10/30/2006) How do I set up a ethernet network with 2 computers?
(10/23/2006) NETGEAR MR814v2 router-only 2/4 of the ports are working(10/27/2006) Router with more than 4 ports and fast wireless
(10/17/2006) ETHERNET PROBLEM, HACKED or BANNED?!(10/14/2006) Ethernet problem, can't receive packets
(09/06/2006) Ethernet Driver for XP PRo 64(08/17/2006) PORTS. HELP PLEASE
(07/27/2006) Internet on ethernet + external disk on wireless......(07/27/2006) Testing Throughput on a 100 Mbs Ethernet Line
(07/21/2006) 10 fun things to do with dual gigabit ethernet?(07/21/2006) New modem/router and ports
(07/15/2006) 10/100/1000 vs Gigabit Ethernet(07/13/2006) New Home... What ethernet cable do I get? I'm new to this.
(06/19/2006) Help needed with ethernet router!!!! PLEASE HELP ME(06/12/2006) ethernet / router help! please!
(05/27/2006) Router ports keep frying. Why?(05/26/2006) Ethernet Switch for 5.25" drive bay?
(05/12/2006) Maximum effective distance of ethernet?(05/02/2006) how to configure Ethernet LAN
(04/27/2006) Ethernet over RG59 cable(04/04/2006) Ethernet connection over 120 metre distance
(04/03/2006) Powerline Ethernet Range?(04/04/2006) Duplicate Ethernet Port
(05/05/2006) NAS Caddy via Gigabit Ethernet with Decent performance ?(03/10/2006) Looking for a co-ax to ethernet converter for wireless use
(03/01/2006) Obscuring ports traffic(02/25/2006) Is there a good ethernet trace tool or software available?
(12/01/2008) *UPDATED* General Ethernet LAN FAQ - 7/11/08(03/14/2006) Bios update killed Ethernet!
(02/16/2006) help solving this problem ethernet setting :oops:(02/13/2006) Question about ethernet cables
(02/01/2006) Wireless/Ethernet Web Server(01/25/2006) Reuse Ethernet Cable End
(01/20/2006) Ethernet constant yello at PC(01/17/2006) Using Gigabit and Fast Ethernet on computer
(01/11/2006) How to enable blocked USB ports?(02/23/2006) How to convert a Ethernet RJ45 port to a Wireless one ?
(01/10/2006) Cant connect ethernet with my 2nd computer(12/29/2005) Ethernet cable problem?
(12/26/2005) Questions regarding Gigabit Ethernet(11/24/2005) HELP! cant connect to internet wit ethernet!
(09/26/2005) Embedded ethernet with high throughput(09/19/2005) Testbench failures for Opencores Ethernet mac
(09/18/2005) hacking ethernet driver - advice needed(09/22/2005) Ethernet breaker
(09/16/2005) Ethernet requirement for Data rate:100 Mbps, Distance:2-3 km(09/10/2005) Alternative Ethernet Connector
(09/04/2005) Connect ethernet devices to an existing wireless router ne..(08/31/2005) Ethernet Controller Basics
(08/19/2005) USB Ethernet controllers that use the ASIX AX88772 or AX88..(08/29/2005) Interpreting Intel 82450EM Ethernet Controller Stats
(08/09/2005) Ethernet, FastEthernet saturation(08/03/2005) Looking for NextGeneration Ethernet Access Products develo..
(06/29/2005) Power over Ethernet Environmental Requirements(06/21/2005) Managed Ethernet Field Switch Provides Support for Tarrife..
(06/23/2005) Power Over Ethernet (PoE) implementation(06/15/2005) Alcatel Switches and span ports
(06/13/2005) Gigabit Ethernet connector(06/13/2005) Gigabit Ethernet connector
(06/16/2005) Industrial Power Over Ethernet (PoE) Switch by GarrettCom,..(06/02/2005) Circuitry behind an Ethernet tap ?
(05/30/2005) Draft Ethernet Overview - "Memo of the month"(08/30/2005) Embedded Ethernet and Corporate LAN
(05/22/2005) Ethernet Braoadband connection to home, assigning static p..(05/22/2005) Ethernet coming to home as Broadband with staic IP addr, c..
(05/22/2005) Is the ethernet connection to home from ISP is secure for ..(05/18/2005) Ethernet Vlan-aware switch query.
(05/10/2005) detecting end/length of Ethernet II frame?(04/20/2008) Ethernet over single UTP
(04/22/2005) Ethernet Switch With a PC at Core(08/13/2005) Non-PCI gigabit Ethernet controller
(04/14/2005) Ports for MSN Messenger(06/16/2008) Ethernet to OC-3 Extender
(04/10/2005) Functioning Ethernet card(04/10/2005) "Wireless Ethernet Bridge" and security ?
(04/11/2005) SOHO routers with 10/100 WAN ports?(04/01/2005) Ethernet 802.3(csma/cd) with host interface
(03/17/2005) Need Ethernet Hub - NOT Switch(03/10/2005) Ethernet Repeaters
(03/09/2005) Layer-2 transparant ethernet encryption device(03/06/2005) Looking for ethernet adaptor with Cirrus CS8900A chip
(03/04/2005) Erratic Ethernet Card - Problems connecting to internet. P..(03/01/2005) one token ring-pc on an ethernet LAN?
(02/24/2005) Do I have an Ethernet card?(02/20/2005) Maximum maximum packets per second on 10 megabit ethernet ..
(02/16/2005) High Integrity Ethernet(03/10/2005) 10Gbit Ethernet Half-Duplex
(02/15/2005) I have 10/100/1000 Mbps ports one side and two switches co..(02/04/2005) Two WAN ports comingout as uplink, I need to trunk them, h..
(01/22/2005) Design of the test for 100baseT Ethernet.(01/19/2005) Why we need a length field in Ethernet while we don't need..
(01/18/2005) Ethernet Frame size(01/11/2005) Ethernet stats
(01/06/2005) Ethernet Transmitter Interrupts(01/13/2005) Metro Ethernet
(12/31/2004) Media Access protocol on IEEE 802.3 and Ethernet ?(12/30/2004) differences between 802.3 and Ethernet ?
(12/31/2004) ethernet failure generator(02/01/2005) Two Ethernet Conns over one CAT5E
(11/25/2004) Ethernet Card(11/18/2004) Ethernet II
(11/15/2004) Ethernet Line fault detection(11/12/2004) Used 3com Components. ATM, FDDI, Router, Ethernet...
(11/15/2004) Maximum size of Ethernet frame(11/09/2004) Ethernet bus transmission (urgent!)
(10/28/2004) Getting Checksum Errors on Gigabit Ethernet Cards(11/08/2004) ethernet frequency and power on ethernet
(10/21/2004) bridged ethernet on Dlink router(02/01/2005) Suggestion for an ethernet setup?
(11/07/2004) About CAT-5 for 2 phone line and ethernet(11/07/2004) Ethernet over T1 (Ethernet over WAN...)
(09/28/2004) Ethernet / ethereal ?(08/04/2005) why is Token ring expensive than ethernet
(09/15/2004) Ethernet auto-negotiate time(09/14/2004) D-Link ethernet Switch ignores 2 PC on network
(02/01/2005) Strange problem with Ethernet switch(04/20/2008) Mutiplexing E1 over Ethernet 100B-FX
(11/09/2004) Long range ethernet / homepna(07/30/2004) Ethernet bridges and tagged BPDUs
(07/22/2004) RS232 over Ethernet(07/26/2004) Best Ethernet switch device for trunking support??
(07/20/2004) Safety insulation requirement ethernet(11/08/2004) Using Jumbo packets in gigabit ethernet
(07/12/2004) Considering UDP/TCP ports in 802.3ad Link Aggregation(11/08/2004) Ethernet Nightmares!
(06/26/2004) Testing ethernet protocol(06/18/2004) low-profile dual port ethernet cards?
(06/16/2004) Fail-open ethernet card(06/15/2004) Will PCI ethernet boards perform better than built-in ethe..
(06/16/2004) High-Port Density Managed Ethernet Switch for Telecom Appl..(06/17/2004) regarding maximum cable length for 100 mbps Ethernet
(06/10/2004) Ethernet, Router & ARP(06/03/2004) gigabit ethernet link synchronization
(06/03/2004) OS x 2.8 Jaguar and Ethernet Speed Default(06/04/2004) Need ethernet -> wireless bridge recommendations
(05/28/2004) PNA; Residential power line ethernet; How well does it wor..(05/12/2004) OEO for fast ethernet applications
(05/06/2004) problem with ethernet connection(04/29/2004) newbee post ethernet modem
(04/26/2004) Ethernet without hubs(04/16/2004) Percentage of switched vs. non-switched Ethernet Networks ..
(07/27/2005) use of ethernet port in vcs(11/12/2004) Used 3com Components. ATM, FDDI, Router, Ethernet...
(05/21/2004) Optical Ethernet distances(07/06/2005) Looking for analogue VoIP adapter with 4x FXS ports
(01/14/2005) asterisk pbx ethernet(01/14/2005) Asterisk PBX on Ethernet
(01/13/2005) Asterisk PBX on Ethernet(06/07/2004) FXO ports for Asteriks...
(06/04/2005) Ports to open to the firewall (Hide Nat, Cisco VPN)(06/02/2005) VPN ports
(02/25/2005) VPN works through wired ports, but with wireless VPN conne..(07/16/2004) Not all Ports through the VPN Tunnel
(05/22/2004) Windows 2000 server VPN ports.........................can ..(09/30/2005) Linksys Routers showing open UDP ports???
(09/13/2005) how to enable the vpn ports in the pix firewall(08/22/2005) RPC Dynamic Ports? Windows 2003 with Checkpoint firewall.
(08/20/2005) Open Ports on Router(08/07/2004) Port forwarding with different internal/external ports on ..
(07/29/2004) ZoneAlarm Pro 5.0 open ports problem(07/30/2004) Checkpoint and Gigabit Ethernet
(07/21/2004) Yahoo, MSN, AOL, etc Instant Messenger ports for firewall ..(06/22/2004) firewall losing NAT ports
(06/16/2004) Must ports be explicitly blocked, or is "default drop" goo..(06/09/2004) How to close all ports?
(06/09/2004) E-Trust Anti-virus opened ports(06/02/2004) Open ports after installing Norton Internet Security 2003
(05/20/2004) Verifying block ports(05/17/2004) what are these ports?
(04/26/2004) Tools for testing ethernet(05/11/2004) Suspicious ports being open...
(04/08/2004) File copying ports?(04/08/2004) blocking in and outgoing ports?
(04/29/2004) svchost exploit on ports 80, 443 &21(04/04/2004) Hijack well-known ports
(08/18/2008) MN-700 Ethernet speeds(05/21/2005) MN-500 ethernet port use for network printer
(04/15/2005) Ethernet Controller Software(05/01/2005) connecting two PC's via ethernet
(03/29/2005) wirelss router - ethernet connection - adsl modem??(03/10/2005) How to open ports on MSN Wireless Base Station
(02/25/2005) Forwarded ports not forwarding(02/20/2005) open ports on the router port 1900udp and port 5643 tcp
(02/14/2005) MN-500 wireless not working / ethernet is(05/21/2005) 2 of the wired ports not working
(01/03/2005) How to know which are ports - Inbound and private(12/25/2004) Configure ports for PCAnywhere
(12/10/2004) Where do i find what ports to limit on kids computer ?(11/12/2004) problems reaching top ethernet speed
(11/03/2004) ethernet/network mystery(10/24/2004) Uninstalling Ethernet Adapter MN-120
(10/31/2004) MN-700 good wireless connection, no ethernet connection(10/21/2004) i will like to forward all ports from my MN-500
(10/18/2004) Win XP SP2 & MN-110 Ethernet Adapter(10/13/2004) Ethernet and internet conection
(10/09/2004) MN-700 powered by Ethernet cable?(09/18/2004) forwarding ports
(09/16/2004) MN-500 (How do you open certain Ports)(09/27/2004) MN-700 Wireless works, wired ethernet does not
(09/12/2004) Ethernet LAN(08/31/2004) switching between wireless adator to ethernet cable
(08/05/2004) Ports 3 and 4 don't work(08/01/2004) existing ethernet wired connections not working
(08/01/2004) Can't open two of the same ports(07/28/2004) Microsoft MN120 ethernet card
(07/17/2004) MN-500 ports ?(07/15/2004) ports
(07/08/2004) mn-700 can't get to setup page from ethernet connection(06/25/2004) Ethernet Adaptors not installing.
(06/17/2004) setting up my ethernet card to work with hotel lan(06/04/2004) ethernet broadband router problems
(05/30/2004) no ethernet(05/26/2004) Having Problems Opening Ports
(05/20/2004) What Ports Does Microsoft VPN Use?(05/04/2004) How can I switch between wireless and ethernet
(04/24/2004) FontPage FTP ports?(05/02/2004) Ports 20 and 21
(04/15/2004) MN-700: how to open ports for Netmeeting(04/15/2004) MN 700 Ports open
(09/06/2005) Question on Ethernet autonegotiation(09/01/2005) PCI Adapter vs Wireless Ethernet bridge recommendations
(07/26/2005) Finding Open Ports(04/12/2005) Combined Firewire & Ethernet networking problem
(04/01/2005) filtering ports on the switch ?(11/28/2004) Adding wireless to existing ethernet network
(09/03/2004) Netgear ME101 Ethernet Bridge question(08/15/2004) FA: Alcatel OmniStack 6024 stack 24-port switch 48 ports
(08/15/2004) FA: Alcatel OmniStack 6024 24-port managed switch 96 ports(07/10/2004) Ethernet controller stopped working?
(06/26/2004) Using a USB modem with an ethernet wireless router(04/12/2004) ethernet connection of 2 macs
(10/07/2005) Recommended ADSL Ethernet Modem(09/27/2005) firewall, blocked ports, and whatnot
(09/09/2005) Configuring XP for Direct Ethernet(08/07/2005) Marvell Yukon Gigabit Ethernet Controller
(06/02/2005) long length ethernet run(01/29/2005) HELP :open ports
(11/16/2004) Opening ports(10/12/2004) forwarding all ports
(10/20/2004) Question about ports(09/28/2004) Forwarding Ports from Modem to Router
(09/28/2004) Forwarding Ports from Modem to Router(08/06/2004) Telnet/IRC ports Blocked?
(07/02/2004) 10/100 or gigabit ethernet(06/18/2004) Cheap Ethernet 80-port 10/100 switch?
(06/03/2004) Ethernet to USB converter?(05/07/2004) Trouble using full Gigabit ethernet
(04/15/2004) Aztech ADSL Ethernet 4 port router+modem(03/30/2004) Cat 6 ethernet cables
(02/18/2004) Opening the same ports on multiple IPs?(03/19/2004) Open ports on my firewall router
(01/20/2004) TCP and UDP ports(12/30/2003) Ethernet Cabling
(12/27/2003) Gigabit Ethernet Questions(12/27/2003) Closing ports in alcatel router
(10/04/2003) Need to know how to change ports.(09/17/2003) ADSL Modem Ethernet or USB?
(07/31/2003) 4 ports, 6 computers(07/01/2003) 1G Ethernet over Cat5e?
(06/19/2003) Open ports(06/05/2003) Ethernet cable, software & ISA questions
(04/08/2003) router ports?(04/06/2003) Using a FC-AL Hub as a Gig-fiber Ethernet repeater
(03/11/2003) Repairing Ethernet Cables(03/07/2003) A7N266 Ethernet Mystery
(03/05/2003) Netgear+Ports :)(03/05/2003) Trying to build a serial to ethernet server
(02/15/2003) Xcess 8port ethernet hub, any good?(01/20/2003) ethernet install
(01/03/2003) cheap USB ethernet or a bit expensive PCI based?(11/25/2002) USB modem to ethernet
(11/15/2002) help! with netgear rt314, opening ports for mssngr(10/03/2002) multiple serial ports
(09/10/2002) USB or Ethernet(09/01/2002) Ethernet becomes slow under WinXP?
(05/29/2002) promblem with ADSL connection / Ethernet card(05/29/2002) I have problem with Ethernet Card/XP
(05/08/2002) Ethernet card brand?(02/06/2002) Blocked ports
(01/29/2002) Cable for gigabit ethernet(12/10/2001) Intergrading wireless and ethernet network
(10/31/2001) ethernet card not working(11/06/2001) ethernet card not working
(10/13/2001) The 5-4-3 ethernet segment riddle(05/05/2001) Ethernet Network Trunking
(04/11/2001) Two IP addresses for 1 ethernet interface(04/03/2001) dialup not working after ethernet removal
(03/22/2001) Switching from a coax network to ethernet, help!?(03/14/2001) Cable Modem to Ethernet card or USB?
(03/13/2001) Remapping Ports for playing internet games at work(02/18/2001) USB Ports with Starband
Google Ads
