Modem connects to interwebs, router won't let my comp connect!
More related threads to : Modem connects to interwebs, router won't let my comp connect!
(11/27/2009) I cant connect through my router(11/30/2009) Router connection
(11/27/2009) Can't connect to router settings(11/25/2009) Does an xp computer talk to a windows 7 box using a linksys wired router
(11/25/2009) Router problems(12/14/2009) Can connect to DIR-655 router but no internet access
(11/23/2009) How many laptops can we connect through one wireless router?(11/30/2009) If I use VOIP with my companies Router connected to my router can they see all I
(11/22/2009) Need some help chosing a modem and router...(11/22/2009) Cannot connect to google.com
(11/21/2009) Half duplex on the WAN?(11/19/2009) Modem - Computer - Router
(11/20/2009) I'm baffled at what I encountered yesterday at home. The home I moved to has Ca(11/17/2009) How do I connect my 2 desktop PCs together?
(11/17/2009) Unable connect internet(11/17/2009) Router Will Not Turn On / Connect to Power
(11/17/2009) Need GREAT Wireless Router(11/13/2009) I have a modem i want to put a switch rather than a router is it possible?
(11/13/2009) Dual LAN will not connect to internet on the right LAN(11/12/2009) 2nd router to att router
(11/11/2009) Cables needed t connect 360 and computer(11/10/2009) Connect Tivo to my Windows 7 PC tethered to iPhone
(11/11/2009) 2 routers cannot access computers on 1st router(11/09/2009) 2 NICs 1 Comp
(11/07/2009) Two pc connect delete file not go in recycle bin where this file go(11/06/2009) Miniport connect email
(11/07/2009) Do I need a new Router?(11/06/2009) Windows 7 home network on router
(11/06/2009) RCA dcm425 modem bridging problems(11/13/2009) Help with troubleshooting Cisco 1760 router
(11/11/2009) Unable to Access Router Admin Page(11/02/2009) Connect one router to another to make new network?
(11/02/2009) Can two desktops go on one modem without paying extra?(11/01/2009) Looking for recommendation on ADSL/wireless router/powerline in one
(11/01/2009) How does a router makes difference between a public IP and a local IP(11/02/2009) Installed new router and other computers cant get on the internet
(10/29/2009) ICS error and cannot connect to internet.(11/03/2009) Wireless router choise
(10/29/2009) Slow transfer wired comp to server no middle man(10/28/2009) Lan part in my router is not working
(10/30/2009) Modem problem(11/06/2009) LINKSYS WRT54GL UNABLE TO CONNECT THE ROUTER
(10/26/2009) At&t 2wire modem(10/29/2009) Connect windows 7 and vista
(10/25/2009) Configure Wireless Router with Nuvox T1 Circuit(10/25/2009) I have more than two computer connect wirn an 8 port switch ho
(11/10/2009) How i can see the connect pc with my pc(10/24/2009) Help choose a new router
(10/31/2009) Connect hard drive to network(10/23/2009) How to connect to printer
(10/22/2009) Since we installed our cisco router interent is very slow(10/22/2009) How to connect 2 pcs to 1 server
(10/21/2009) I have two cable modems and one printer. How do I print from a computer connecte(10/19/2009) Router and switch connection
(10/19/2009) Router Problems....(10/19/2009) Linksys router cant access browser configuration
(10/19/2009) Edimax BR-6424n Router not connecting to Modem(10/18/2009) BelkinFD8231-4 modem problems
(10/20/2009) Something wrong with my router!(10/19/2009) Silly question -- ISP assigned IP with different subnet than router
(10/14/2009) A good 3g modem(10/14/2009) Good gigabit router.
(10/14/2009) Can not connect to a computer on my network(10/10/2009) Can fax using adsl router
(10/09/2009) Linksys Router RT41-BU - hangups !!$%?(10/09/2009) How to connect network switch
(10/09/2009) How to access internet from wireless router to toshiba laptop(10/09/2009) It is possible to use 2 routers in 1 cable modem
(10/08/2009) How to share the internet connection by two computers without using router(10/09/2009) Netgear Wireless Router Connection Issue
(10/10/2009) Should the firewall/router be the dhcp or should the modem be dhcp(10/05/2009) Advantages of using router than switch
(10/05/2009) How far can a pc be hooked up via ethertnet from dsl modem(11/07/2009) Accessing a shared printer thats connected to win xp comp
(10/06/2009) Ad hoc vista and XP will connect to the ad hoc but wont see each other(10/04/2009) Guest Access Prob..Connect Belkin N1 Vision to Belkin N+ Gateway
(10/02/2009) Dl 624 router(10/03/2009) Cannot connect Adsl modem wtih wifi router.
(10/01/2009) Wireless Router and AT&T Modem(09/30/2009) Connect work/home
(09/30/2009) My x box live wont connect(09/28/2009) Windows 7 unable to connect to domain
(09/28/2009) Modem LEDs keeps flashing non-stop(09/28/2009) Added linksys befsr41 router: have internet but no lan
(09/27/2009) Sonicwall pro 200 netgear router and some confusion(09/24/2009) Low siganal strength coming from router
(09/24/2009) Cable broadband router/switch(09/25/2009) Cable router/switch
(09/21/2009) Netgear /DG834Bv3 dsl modem/router(09/20/2009) Belkin router query
(09/19/2009) Cable modem(09/21/2009) Do I need a Firewall when I use a router?
(09/18/2009) Using windows server 2008 as a router(09/19/2009) Computer no longer connecting to router.
(09/17/2009) Router/switch problem(09/17/2009) 2 internet connection in one router
(09/22/2009) 2 internet connection in 1 router(09/18/2009) Using a router as a wireless adapter?
(09/20/2009) Best cheap router?(09/16/2009) LAN speed slow unless through router?!
(09/17/2009) Basic question about wireless router(09/16/2009) How can i set up DSL and Cable modem together
(09/15/2009) Network diagram broadban to switch to router to switch to router(09/16/2009) How do you connect 3 computers to a router connected to the modem?
(09/14/2009) Comcast re booting cable modem.....(09/13/2009) How to convert AnyDATA AWR 500-A wifi router into switch
(09/12/2009) ATT DSL Service with Linksys WRT54G Router(09/10/2009) Small business wifi router for voip and LAN traffic
(09/10/2009) Local email server that connects to remote server(09/14/2009) Router keeps on freezing my browser page
(09/10/2009) I have cox internet and a router need to hook up all my laptops in the house(09/18/2009) Best router for gaming and wifi N?
(09/05/2009) Will External RS-232 Modem Work With 3 Pin Serial Interface(09/06/2009) Will External RS-232 Modem Work With 3 Pin Serial Interface
(09/04/2009) Can I secure 2 ports on an 8 port shared router?(09/03/2009) Good business grade router for under $500.
(09/02/2009) Now that I tried to install a new router my computers are all screwy!(09/01/2009) SMC barricade router blocking access to printer on LAN
(09/02/2009) Netgear router FVS318 & speed limitations(09/21/2009) Bizarre Network issue. Can no logner connect properly to router(s)
(08/31/2009) Connecting a Wireless router to a modem/Wireless router, Help!(09/13/2009) 2Wire Router/Modem and 24 port switch?
(08/27/2009) Router and switch(08/28/2009) Router question
(08/27/2009) Connect network switch to DSL modem(09/14/2009) What Router should I get ?
(08/23/2009) Netgear Router problems(09/23/2009) ZyXEL P-660HW Series router problem
(08/25/2009) NAS + Router(08/24/2009) New Router troubles
(08/22/2009) Can't connect to Interner using ethernet to Vista(08/19/2009) Can connect through modem, but not through router
(08/18/2009) Linksys router stacking under Thomson?(08/18/2009) Cannot connect to the internet through a router!
(08/15/2009) What router to buy for high speed gaming(08/14/2009) Which Cisco Router to choose?
(08/29/2009) 25 year old female Chinese college student vs router(08/11/2009) Weird Networking/Router Problem [SOLVED]
(08/15/2009) Can I share connection with router and switch?(08/03/2009) Router Suggestion for NAS
(08/01/2009) Modem and router connection(07/31/2009) My new pc cannot connect to the router
(08/04/2009) New router, bad Xbox Live(07/30/2009) Can't connect with Remote Desktop
(07/30/2009) Sam's Club WRT110 Linksys Router Question(07/29/2009) Home router setup with no modem password
(07/29/2009) New AT&T Supplied Motorola Modem/Linksys Router Connection Problem(07/25/2009) Modem and Router confusion
(07/23/2009) Router slowing internet(07/26/2009) DHCP Client Service Won't Start - Error 1068
(07/25/2009) CPU disconnects from the Internet but is still connected to the modem(07/18/2009) Belkin Wireless G Router
(07/16/2009) Router with Firewall adds 6Mb speed reduction!(07/15/2009) Sharing files/printer through router + switch
(07/15/2009) Router issue(07/14/2009) Router problem
(07/22/2009) Trendnet Router Problem(07/11/2009) Connecting a local app over logmein to access a seperate network on remote comp
(07/11/2009) Router Problem(07/13/2009) Modem crashing
(07/14/2009) USB Modem workaround to get Ethernet Output(07/08/2009) Need to know what ip to use for modem to open ports
(07/07/2009) Internet And Router Problem(07/06/2009) Netgear router
(07/07/2009) Router hardware question(07/06/2009) Trying to network a Windows ME system with Windows Vista on a router.
(07/05/2009) Fast connection to modem yet download speed only 50%(07/04/2009) Toshiba router wont connect
(06/28/2009) Lose Router Connection(07/01/2009) Internet link unstable in Netgear Router
(06/27/2009) Industrial Rugged GPRS HSUPA VPN Router(06/26/2009) Problems networking with FiOS router
(06/23/2009) Router and Switch Question(06/23/2009) Modem+router or dedicated?
(06/21/2009) 2 computers, 1 modem, cannot find server(06/19/2009) Connecting DSL modem to hub
(06/18/2009) Network settings problem? Cant change router with same settings(06/17/2009) Severe Packet Loss Between Cable Modem and Computer
(06/19/2009) 2 Router Set Up - 1 Wired, 1 Wireless(06/19/2009) Modem+Router+Switch+2 Routers
(06/11/2009) Can I use this Router as a Modem?(06/15/2009) Video How-To: Linksys Router Setup
(06/09/2009) Need a rock-solid performance Router for Bittorrent(06/15/2009) How to set connection using Wavecom Fastrack Supreme modem via Windows
(06/08/2009) Comp, tv, DVR(06/09/2009) Please help by suggesting a good router
(06/10/2009) Best Wired GB router with SPI(06/04/2009) Computer loses connection to router
(06/04/2009) HELP! Cannot connect to internet(06/07/2009) Can access the Router but doesn't have Internet[Wired]
(06/07/2009) Change IP router automatically(06/27/2009) Turning a PC into a Router
(08/22/2009) D-Link DI-524 router "config.bin"(05/28/2009) Maximum length of cross over cable to connect 2 computers
(05/28/2009) Building a router, where are the NICs?(05/28/2009) SMC Modem vs. Linksys(Reliability)
(05/26/2009) Router Question?(05/30/2009) Which router to buy
(06/02/2009) Router suggestion for a rigged network...(05/29/2009) Ethernet + Router Problem -- extremely weird -- please help
(05/22/2009) I need a new router that doesn't bottleneck my bandwidth speed(07/16/2009) Could not connect to the internet
(05/20/2009) Connect One: What Do They Do?(05/14/2009) Connect xp pro notebook through vista pc via pc's 2nd lan port
(05/14/2009) Using RS232 to Ethernet Converter with Serial modem(05/12/2009) Blocking wireless access to single comp on router.
(05/10/2009) New modem or router ?(05/12/2009) 2nd router DSL thru a different phone jack?
(05/09/2009) Connect to internet via a pc using a laptop(05/03/2009) What to do with a bad modem?
(05/01/2009) Netgear CG814WG router question(05/01/2009) Vista Ultimate Wont Connect To Internet
(05/02/2009) Cant connect using remote desktop!(04/30/2009) FILE TRANSFER PROBLEM - Cable Modem & 1GB Switch
(04/24/2009) Laptop cant connect to the internet via Local Area Network or Wireless(09/09/2009) Linksys Router & ATT DSL Setup Help Please???
(04/22/2009) Unable to connect to internet via Linksys WRT54G(04/20/2009) Router capping speeds?
(04/18/2009) Dlink EBR 2310 and unable to connect to internet(06/20/2009) How to setup a SB5101 Surfboard Modem
(05/18/2009) Computer won't start with router on(04/16/2009) Router Modem and Nic speeds
(04/15/2009) Help with setting up a Wifi Router(04/18/2009) Wireless router on LAN
(04/14/2009) Problem with WBR-3406TX Router(04/15/2009) Controlling Internet Access via Router Settings
(04/12/2009) Modem says unknown in network(04/11/2009) Help Choosing A Router
(10/10/2009) Can't get wireless Netgear router to work(07/03/2009) Looking for Information on a "Bonded Cable" Modem
(04/07/2009) Port forwarding for linksys router model befw11s4(04/02/2009) Modem dial/handshaking sound with Cable Internet
(03/28/2009) Modem to Computer(04/02/2009) Unable to connect to network, but I can connect to websites, FTP, etc
(03/23/2009) What router should I buy(03/25/2009) 2 Wire Router, how to Firewall wired connections from Wireless?
(03/22/2009) Why can't the modem recognize wired router connection but will work on wireless?(03/22/2009) My ADSL MODEM did not connect
(03/19/2009) Gaming Networking/Modem Purchase Question(03/22/2009) Connect over Internet
(03/22/2009) Need a recommend for a router(03/17/2009) Router upgrade?
(03/11/2009) Switch from Cable internet to DSL router not working(03/08/2009) MSI RG60G router Help what is SPI etc
(03/10/2009) Get router or use main computer as hub?(03/07/2009) PS3 to the interwebs?
(03/07/2009) Piggyback Linksys NR041 off DSL 4 port modem(03/03/2009) Which way to connect?
(02/28/2009) Random Request timed out when ping router(02/28/2009) Need Help Choosing A New Router
(02/25/2009) Webstar Modem Strange Lights Blinking(05/17/2009) Connecting Verizon Fios Router to a Netgear Wireless Router
(02/24/2009) Linksys Router Help(02/24/2009) Got New Router | Confused by DSL Cable Instead of Ethernet
(02/23/2009) Error 769 when trying to connect internet(02/20/2009) Modem or Motherboard Problem ?
(02/19/2009) Help.Supreme commander Account,DGL-4100 Cannot connect(02/19/2009) IP change for modem on Toshiba 4000
(02/17/2009) Xbox 360 live wont connect(02/16/2009) Connect internet for 3 pc using dsl connection through wired lan
(04/22/2009) D-Link Extreme N Dual Router(02/12/2009) Unusual Router Problem
(02/12/2009) LAN via router problem with two PCs(02/11/2009) How to connect IPTV box with RJ-45 via wireless
(02/16/2009) Laptop connecting to my router disrupts internet(02/09/2009) Wideview and an 8 port router
(02/09/2009) Wideview and 8 port router(02/07/2009) Linksys WRT54G router and Siemens 4100 bridge mode configuration problem.
(02/06/2009) How to connect via command line to remote desktop(02/05/2009) Using router in a college lan
(12/09/2009) Need Router That Routes Multiple External IPs(02/03/2009) How to convert a Wireless B router into a switch?
(02/01/2009) Router to router connection(02/15/2009) How do you connect Router to Router?
(01/31/2009) Need to install Modem CD drivers? Advantages/disadvantages???(01/26/2009) Router vs. Switch
(01/24/2009) Router Question(01/24/2009) Cable Modem
(01/22/2009) How can i set up a lan with out a router/server(01/21/2009) Is it the modem or router!
(01/25/2009) Connect extra PC to home network but exclude it from internet access(01/22/2009) Ethernet access away from router?
(06/13/2009) RJ45-shaped ADSL Line port? N+ Wireless Modem Router(07/16/2009) Internet Slow Through Router
(01/17/2009) Better Router(01/21/2009) Cannot connect via wireless...
(01/15/2009) What happend to my router? help!(01/20/2009) Gaming and p2p router setup and suggestions
(01/11/2009) Vista +modem(01/13/2009) Router hunting
(01/06/2009) Is the DGL-4500 Xtreme N Gaming Router the best router for gaming?(01/08/2009) How can I connect to remote web server?
(01/06/2009) What is the best router for p2p and gaming? what to buy?(01/05/2009) Best modem / router
(12/30/2008) Can't Access BEC 5200S Modem/router(12/29/2008) Problems replacing wireless router w/ new wireless router
(01/05/2009) PC won't connect to network(04/20/2009) Is there a wireless router with a category content filtering??
(03/08/2009) Multiple VPN-Connections to connect to W2k3 Server(12/17/2008) Cleared the CMOS now nothing connects
(12/26/2008) Problems renewing ipconfig without router(12/10/2008) DIR-655 acting as cable modem?
(12/29/2008) Router + Switch = internet?(12/05/2008) Modem or Internet issue?
(12/03/2008) New Router Suggestions(12/02/2008) D-Link router problem
(10/01/2009) linksys router crashes my connection every time i(11/25/2008) Internet - Modem Rest
(11/23/2008) Linux Router(11/17/2008) Upgrading Router, but to which one?
(12/19/2008) VPN on Windows 2000 in domainand behid router(11/25/2008) connect to internet after reinstall
(10/29/2008) A8N-E kill the internet connection of my cable modem...(10/27/2008) What Wireslls Router is best? please help!
(10/17/2008) How to connect a cable connection up w/o needing the software disks?(10/24/2008) Gigabit router suggestion please
(10/15/2008) How to connect three routers?(10/15/2008) wireless will not connect
(10/12/2008) will a switch improve my router(10/08/2008) How to connect to the internet through another laptop
(12/03/2008) My Router Suddenly Closed all the Ports I opened - WTF?(10/05/2008) Vista can see network but wont connect
(12/29/2008) P2P brings router to it's knees?(10/03/2008) Two computers with one modem from comcast
(10/01/2008) Question about 1 Router, 1 Network Printer & 2 PCs(10/01/2008) No LAN on router
(10/02/2008) Cant connect to internet with certain apps?(09/29/2008) Good router
(09/17/2008) gaming router(09/18/2008) 2 laptops one connects the other doesn't
(09/21/2008) Secure Router / Firewall(09/19/2008) New router - ethernet cables?
(09/19/2008) unstable wireless connection netgear router(10/13/2008) I need a router with a *configurable* 10Mbps Full Duplex WAN port!
(09/19/2008) Problems with the Linksys WRT54G v2.2 router(09/19/2008) Problem with recieved packets from modem
(10/01/2008) Can a Router slowly fail?(10/01/2008) how to open port on my router
(09/11/2008) Possible to connect laptop to pc to do virus scan?(09/19/2008) What do I need for office router/switch
(09/07/2008) Need help with router(09/06/2008) Do I need to change my router to use Optus ADSL2+?
(09/05/2008) New router(09/06/2008) How to setup DSL router?
(01/04/2009) Can't get Linksys router to work with AT&T DSL(09/06/2008) Bypassing Router Time Restrictions
(09/07/2008) need router advice please(01/17/2009) INTERMITTENT WIRELESS: Netgear router or Dell D620 problem??
(08/25/2008) Cant connect new build to internet or network(08/28/2008) Router recommendation?
(08/29/2008) mom needs help to connect xbox live, apple & alienware notebooks(08/20/2008) Newbie trying to setup wireless router,need advice
(08/19/2008) Is the D-Link DGL-4300 router cable/dsl or adsl?(09/03/2008) Modem or provider?
(08/19/2008) Best Way To Connect?(08/22/2008) Connecting PC-PC and sharing internet without router
(08/30/2008) Hook linksys wireless router and 2 switches to main router(08/15/2008) ADSL router and PC cabling
(08/13/2008) Sp3 Router problem(08/09/2008) Router gone bad or conditions worsening to blame
(08/09/2008) WIN-XP64 will NOT connect to D-Link(08/06/2008) D-Link EBR 2310 unable to connect Help!
(08/04/2008) Dual Lan Connection Direct Connect Help(08/04/2008) New Router
(08/13/2008) Connect one computer to two routers(07/31/2008) Please recomend a Cable modem and router.
(07/30/2008) High ping when router introduced to network(07/30/2008) Can you make two routers connect to eachother?
(07/30/2008) Cable Modem Receive Power Out of Sync(07/30/2008) 2 router port forwarding
(03/23/2009) Can't connect to one of three printers!(07/29/2008) New Router - Advice needed.
(07/26/2008) connect to my IP CAM from internet(07/24/2008) Linksys RV042 router issue
(07/23/2008) Possible dying cable modem?(07/22/2008) Modem Help
(07/20/2008) Gaming/Torrent Router(07/18/2008) Which router?
(07/18/2008) Router Woes(07/16/2008) Router not giving a 192 address
(07/16/2008) Can't connect to internet after reformating(07/20/2008) Basic Router Advice Needed
(07/15/2008) Help choosing a router from 4.(07/12/2008) Modem replacement- clueless
(08/21/2008) Router to switch to PCs?(07/19/2008) cant connect to internet
(07/10/2008) Looking for new router(07/14/2008) One computer on network no longer connects to the internet.
(12/09/2009) Setup gigabit home network using 100mbps Router but Gigabit switches(07/04/2008) Need advise on a cable router
(07/03/2008) Looking for a new router(07/03/2008) Do I really need a new modem for faster internet or is Comcast lying?
(06/27/2008) LAN port problem - works fine with adsl modem but not router(06/26/2008) Help getting my linksys wireless router to work
(07/04/2008) Hosting on Modem(Fast) versus Router (Slower) Should I Upgrade Router?(06/18/2008) USR8200 with Airport Extreme and a modem - HELP
(08/06/2008) Wireless router with print server(06/14/2008) Problem, data call from fixed line data modem to mobile data modem
(06/21/2008) Very confused as to which router to get!(06/08/2008) modem help
(03/16/2009) zoom x6 router help(12/07/2009) Old laptop into linux router
(06/04/2008) Router lag issue(05/31/2008) 2 router configuration issues
(12/05/2009) Problems with router (d-link dir 100)(06/02/2008) linksys router issue
(06/02/2008) Router Advice needed(05/10/2008) DGL-4500 router and Gamefuel Plz Helpppp
(12/17/2009) Two internet connections, 1 router, 1 PC.(05/05/2008) D Link DIR 655/ router check in
(05/08/2008) Trying to connect two computers(05/01/2008) This stupid computer wont do anything that it needs to with my router
(04/29/2008) philips / Talk takl router sna5630/ns(04/30/2008) My Modem
(04/27/2008) Cable Modem resets itself(04/26/2008) XP Home won't detect 56K PCI Modem
(04/26/2008) Looking for application or router for capping bandwidth(10/01/2008) Connecting a Wireless Router to My ::ahem:: neighbors WiFi Internet
(04/20/2008) networking 2 pcs (via adsl router?)(04/18/2008) gaming router
(04/17/2008) how does ADSL router/switch work?(04/11/2008) Just curious... TV on TV/monitor thru cable modem lan
(04/06/2008) two adsl accounts on a single adsl modem(03/31/2008) Belkin router only allowing max of 2 wired connections!?
(03/29/2008) which lower price dual wan router(04/01/2008) How to connect 2 PCs via switch?
(03/24/2008) 2Wire DSL Modem/router w/Linksys 4124 switch and Linksys WRT350N(03/24/2008) Need a new reliable wireless router
(03/26/2008) Which router?(03/24/2008) Router Issue
(03/18/2008) Connect 2 PC's (One Vista one XP)(03/16/2008) Cant get new cable modem to work w/splitter.Tried 3
(03/29/2008) Zoom X6 Modem/Router Security Issues(03/16/2008) loss of speed bec of router?
(03/12/2008) How to network share between router a and router b?(09/20/2009) LAN not working, Wireless working fine (D-Link DGL-4300 router)
(03/09/2008) Media Sharing / router problem(03/12/2008) best QOS router for the money.
(03/12/2008) Looking for router that is fast enough for 27,000 kb/s connection(03/06/2008) Anyone know of any free download boosters.My cable modem is slow
(03/12/2008) P2P and gaming router(03/05/2008) 0 knowledge - need help picking router
(10/01/2008) Weird problem with Belkin G wireless router.(02/20/2008) Internet/Modem disconnecting
(02/20/2008) Need a new modem?(02/19/2008) Help with Linksys Router.
(02/20/2008) I have an open connection, yet I cannot connect?(02/12/2008) Need Help with VNP and Linksys Router
(02/11/2008) need new wifi router or go powerline(02/08/2008) router ip address changed due to modem
(02/06/2008) Adding Wireless Access Point to 2Wire HGV 2700 Router(12/07/2008) Problem with Lan connection with Telefonica (Spain) ZyXel router
(02/01/2008) Need additional ports than what my existing wireless router provides.(01/31/2008) best wireless router for a wii, 360, ps3
(03/12/2008) Dual Ethernet mobo + router question(01/26/2008) How is a switch different from a router?
(01/25/2008) So is it time to replace this POS (Vonage) Linksys wired router?(02/25/2008) Finding router information
(01/24/2008) Router Dropping connection under heavy load(05/10/2009) Some programs can't connect to internet
(01/21/2008) lag problem with new wireless router(01/21/2008) adsl modem + switch no router...
(01/19/2008) Cant find Router charts(01/18/2008) Internet via USB adapter and local network via wired router?
(01/22/2008) Linksys 5 port Hub- Can't connect more than 2 computers to internet(01/17/2008) Please suggest wired router for Vista
(01/15/2008) Can I plug a wireless router into a wired router?(01/15/2008) IE connects but NOTHING ELSE does ?
(01/15/2008) Router Troubleshooting Issue(01/15/2008) need help turning Linksys WRT54G into a bridge router
(12/15/2009) XBOX 360 won't connect to internet!(01/04/2008) Strange problem with router Belkin
(01/03/2008) pc cant connect to internet on xp.. help plz(12/25/2007) Connecting two PC and a Router Local Network
(12/30/2007) why cant I connect through my switch?(12/21/2007) Looking for a cheap reliable router
(12/19/2007) Att 2210 modem wont connect to linksys befsr41 router(12/07/2007) Can't connect to my campus network please help!!!
(03/25/2009) LAN access gone when I connect to VPN(12/06/2007) configure router d-link di624, unknown address
(12/04/2007) Router: D-Link DGL-4300 Please Help(11/29/2007) Stable router that can handle BT
(11/29/2007) Which wireless router should i get for my laptop?(11/28/2007) Router - Firewall blocking stuff
(11/27/2007) Aztech DSL600ER Router(08/17/2009) Netgear FVG318 router blocking (some) outgoing FTP
(11/26/2007) router or router+switch(11/21/2007) Router or Switch ?
(11/16/2007) Linux Home Server Behind FIOS Router | No Joy(11/15/2007) Did anyone use/try the router Asus WL-500g Premium?
(11/16/2007) do i need a router?(11/15/2007) Looking for a firewall/router with full featured NAT
(06/10/2009) Need assistance choosing a replacement router on Verizon FIOS(11/10/2007) One router, two 'puters, two speeds - HIS n HERS
(11/12/2007) I think my cable modem is dying, help!!!(11/12/2007) WNR854T router reboots itself on settings update
(11/08/2007) my connection dies suddenly behind a router(11/07/2007) Help! Why wont my Router Talk to my Switch??
(09/13/2009) Belkin F5D7230-4 v2000 router stalls when browsing Google Maps
Sponsored links
