| (11/27/2009) I cant connect through my router | (11/30/2009) Router connection |
| (11/27/2009) Can't connect to router settings | (11/27/2009) Does an xp computer talk to a windows 7 box using a linksys wired router |
| (11/25/2009) Router problems | (11/24/2009) Can connect to DIR-655 router but no internet access |
| (11/23/2009) How many laptops can we connect through one wireless router? | (11/30/2009) If I use VOIP with my companies Router connected to my router can they see all I |
| (11/22/2009) Need some help chosing a modem and router... | (11/21/2009) Half duplex on the WAN? |
| (11/19/2009) Modem - Computer - Router | (11/19/2009) Utorrent slows network speeds when closed |
| (11/20/2009) I'm baffled at what I encountered yesterday at home. The home I moved to has Ca | (11/17/2009) Router Will Not Turn On / Connect to Power |
| (11/17/2009) Need GREAT Wireless Router | (11/13/2009) I have a modem i want to put a switch rather than a router is it possible? |
| (11/12/2009) 2nd router to att router | (11/11/2009) 2 routers cannot access computers on 1st router |
| (11/06/2009) Slow network transfers speeds Windows 7 | (11/07/2009) Do I need a new Router? |
| (11/06/2009) Windows 7 home network on router | (11/13/2009) Help with troubleshooting Cisco 1760 router |
| (11/11/2009) Unable to Access Router Admin Page | (11/02/2009) Connect one router to another to make new network? |
| (11/04/2009) Vast difference in transfer speeds via network | (11/01/2009) Looking for recommendation on ADSL/wireless router/powerline in one |
| (11/01/2009) How does a router makes difference between a public IP and a local IP | (11/02/2009) Installed new router and other computers cant get on the internet |
| (11/03/2009) Wireless router choise | (10/28/2009) Lan part in my router is not working |
| (11/06/2009) LINKSYS WRT54GL UNABLE TO CONNECT THE ROUTER | (10/25/2009) Configure Wireless Router with Nuvox T1 Circuit |
| (10/24/2009) Help choose a new router | (10/22/2009) Since we installed our cisco router interent is very slow |
| (10/19/2009) Router and switch connection | (10/19/2009) Router Problems.... |
| (10/19/2009) Linksys router cant access browser configuration | (10/19/2009) Edimax BR-6424n Router not connecting to Modem |
| (10/20/2009) Something wrong with my router! | (10/19/2009) Silly question -- ISP assigned IP with different subnet than router |
| (10/14/2009) Good gigabit router. | (10/10/2009) Can fax using adsl router |
| (10/09/2009) Linksys Router RT41-BU - hangups !!$%? | (10/09/2009) How to access internet from wireless router to toshiba laptop |
| (10/08/2009) How to share the internet connection by two computers without using router | (10/09/2009) Netgear Wireless Router Connection Issue |
| (10/10/2009) Should the firewall/router be the dhcp or should the modem be dhcp | (10/05/2009) Advantages of using router than switch |
| (10/04/2009) Guest Access Prob..Connect Belkin N1 Vision to Belkin N+ Gateway | (10/02/2009) Dl 624 router |
| (10/03/2009) Cannot connect Adsl modem wtih wifi router. | (10/01/2009) Wireless Router and AT&T Modem |
| (09/28/2009) Added linksys befsr41 router: have internet but no lan | (09/27/2009) Sonicwall pro 200 netgear router and some confusion |
| (09/24/2009) Low siganal strength coming from router | (09/24/2009) Cable broadband router/switch |
| (09/25/2009) Cable router/switch | (09/21/2009) Netgear /DG834Bv3 dsl modem/router |
| (09/20/2009) Belkin router query | (09/21/2009) Do I need a Firewall when I use a router? |
| (09/18/2009) Using windows server 2008 as a router | (09/17/2009) Throughput Speeds |
| (09/19/2009) Computer no longer connecting to router. | (09/17/2009) Router/switch problem |
| (09/17/2009) 2 internet connection in one router | (09/22/2009) 2 internet connection in 1 router |
| (09/19/2009) Using a router as a wireless adapter? | (09/20/2009) Best cheap router? |
| (09/16/2009) LAN speed slow unless through router?! | (09/17/2009) Basic question about wireless router |
| (09/15/2009) Network diagram broadban to switch to router to switch to router | (09/16/2009) How do you connect 3 computers to a router connected to the modem? |
| (09/13/2009) How to convert AnyDATA AWR 500-A wifi router into switch | (09/12/2009) ATT DSL Service with Linksys WRT54G Router |
| (09/10/2009) Small business wifi router for voip and LAN traffic | (09/14/2009) Router keeps on freezing my browser page |
| (09/10/2009) I have cox internet and a router need to hook up all my laptops in the house | (09/18/2009) Best router for gaming and wifi N? |
| (09/04/2009) Can I secure 2 ports on an 8 port shared router? | (09/03/2009) Good business grade router for under $500. |
| (09/02/2009) Now that I tried to install a new router my computers are all screwy! | (09/01/2009) SMC barricade router blocking access to printer on LAN |
| (09/02/2009) Netgear router FVS318 & speed limitations | (09/21/2009) Bizarre Network issue. Can no logner connect properly to router(s) |
| (08/31/2009) Connecting a Wireless router to a modem/Wireless router, Help! | (09/13/2009) 2Wire Router/Modem and 24 port switch? |
| (08/27/2009) Router and switch | (08/28/2009) Router question |
| (09/14/2009) What Router should I get ? | (08/23/2009) Netgear Router problems |
| (09/23/2009) ZyXEL P-660HW Series router problem | (08/25/2009) NAS + Router |
| (08/24/2009) New Router troubles | (08/19/2009) Can connect through modem, but not through router |
| (08/18/2009) Linksys router stacking under Thomson? | (08/18/2009) Cannot connect to the internet through a router! |
| (08/15/2009) What router to buy for high speed gaming | (08/14/2009) Which Cisco Router to choose? |
| (08/29/2009) 25 year old female Chinese college student vs router | (08/11/2009) Weird Networking/Router Problem [SOLVED] |
| (08/15/2009) Can I share connection with router and switch? | (08/03/2009) Router Suggestion for NAS |
| (08/01/2009) Modem and router connection | (07/31/2009) My new pc cannot connect to the router |
| (08/04/2009) New router, bad Xbox Live | (07/31/2009) Not getting the proper download speeds |
| (07/30/2009) Sam's Club WRT110 Linksys Router Question | (07/29/2009) Home router setup with no modem password |
| (07/29/2009) New AT&T Supplied Motorola Modem/Linksys Router Connection Problem | (07/25/2009) Modem and Router confusion |
| (07/23/2009) Router slowing internet | (07/18/2009) Belkin Wireless G Router |
| (07/16/2009) Router with Firewall adds 6Mb speed reduction! | (07/15/2009) Sharing files/printer through router + switch |
| (07/15/2009) Router issue | (07/14/2009) Router problem |
| (07/22/2009) Trendnet Router Problem | (07/11/2009) Router Problem |
| (07/07/2009) Internet And Router Problem | (07/06/2009) Netgear router |
| (07/07/2009) Router hardware question | (07/06/2009) Trying to network a Windows ME system with Windows Vista on a router. |
| (07/04/2009) Toshiba router wont connect | (06/28/2009) Lose Router Connection |
| (07/01/2009) Internet link unstable in Netgear Router | (08/24/2009) Industrial Rugged GPRS HSUPA VPN Router |
| (06/26/2009) Problems networking with FiOS router | (06/23/2009) Router and Switch Question |
| (06/23/2009) Modem+router or dedicated? | (06/19/2009) Slow speeds, etc. |
| (06/18/2009) Network settings problem? Cant change router with same settings | (06/19/2009) 2 Router Set Up - 1 Wired, 1 Wireless |
| (06/19/2009) Modem+Router+Switch+2 Routers | (06/18/2009) Poor network file transfer speeds *overall* |
| (06/11/2009) Can I use this Router as a Modem? | (06/15/2009) Video How-To: Linksys Router Setup |
| (06/09/2009) Need a rock-solid performance Router for Bittorrent | (06/09/2009) Please help by suggesting a good router |
| (06/10/2009) Best Wired GB router with SPI | (06/04/2009) Computer loses connection to router |
| (06/07/2009) Can access the Router but doesn't have Internet[Wired] | (06/07/2009) Change IP router automatically |
| (06/02/2009) Slow speeds transfering within nas?? | (06/27/2009) Turning a PC into a Router |
| (08/22/2009) D-Link DI-524 router "config.bin" | (05/28/2009) Building a router, where are the NICs? |
| (05/26/2009) Limited Lan Speeds | (05/26/2009) Router Question? |
| (05/30/2009) Which router to buy | (06/02/2009) Router suggestion for a rigged network... |
| (05/29/2009) Ethernet + Router Problem -- extremely weird -- please help | (05/22/2009) I need a new router that doesn't bottleneck my bandwidth speed |
| (05/19/2009) Internet speeds for gaming??? | (05/15/2009) Newbie question getting the best speeds outta my nas |
| (05/12/2009) Blocking wireless access to single comp on router. | (05/10/2009) New modem or router ? |
| (05/12/2009) 2nd router DSL thru a different phone jack? | (05/01/2009) Netgear CG814WG router question |
| (06/18/2009) CPU saturation = slower ethernet speeds? | (09/09/2009) Linksys Router & ATT DSL Setup Help Please??? |
| (05/18/2009) Computer won't start with router on | (04/16/2009) Router Modem and Nic speeds |
| (04/15/2009) Help with setting up a Wifi Router | (04/18/2009) Wireless router on LAN |
| (04/14/2009) Problem with WBR-3406TX Router | (04/15/2009) Controlling Internet Access via Router Settings |
| (04/11/2009) Help Choosing A Router | (10/10/2009) Can't get wireless Netgear router to work |
| (04/09/2009) Modem connects to interwebs, router won't let my comp connect! | (04/07/2009) Port forwarding for linksys router model befw11s4 |
| (03/23/2009) What router should I buy | (03/25/2009) 2 Wire Router, how to Firewall wired connections from Wireless? |
| (03/22/2009) Why can't the modem recognize wired router connection but will work on wireless? | (03/22/2009) Need a recommend for a router |
| (03/17/2009) Router upgrade? | (03/11/2009) Switch from Cable internet to DSL router not working |
| (03/08/2009) MSI RG60G router Help what is SPI etc | (03/10/2009) Get router or use main computer as hub? |
| (02/28/2009) Random Request timed out when ping router | (02/28/2009) Need Help Choosing A New Router |
| (05/17/2009) Connecting Verizon Fios Router to a Netgear Wireless Router | (02/24/2009) Linksys Router Help |
| (02/24/2009) Got New Router | Confused by DSL Cable Instead of Ethernet | (04/22/2009) D-Link Extreme N Dual Router |
| (02/12/2009) Unusual Router Problem | (02/12/2009) LAN via router problem with two PCs |
| (02/16/2009) Laptop connecting to my router disrupts internet | (02/09/2009) Wideview and an 8 port router |
| (02/09/2009) Wideview and 8 port router | (02/07/2009) Linksys WRT54G router and Siemens 4100 bridge mode configuration problem. |
| (02/13/2009) 1Gb LAN, 100 Mb WAN - why can't get 1Gb speeds? | (02/06/2009) Help with capping bandwith |
| (02/05/2009) Using router in a college lan | (10/10/2009) Need Router That Routes Multiple External IPs |
| (02/03/2009) How to convert a Wireless B router into a switch? | (02/01/2009) Router to router connection |
| (02/15/2009) How do you connect Router to Router? | (01/26/2009) Router vs. Switch |
| (01/24/2009) Router Question | (01/22/2009) How can i set up a lan with out a router/server |
| (01/21/2009) Is it the modem or router! | (01/22/2009) Ethernet access away from router? |
| (06/13/2009) RJ45-shaped ADSL Line port? N+ Wireless Modem Router | (07/16/2009) Internet Slow Through Router |
| (01/17/2009) Better Router | (01/15/2009) What happend to my router? help! |
| (01/20/2009) Gaming and p2p router setup and suggestions | (01/13/2009) Router hunting |
| (01/06/2009) Is the DGL-4500 Xtreme N Gaming Router the best router for gaming? | (01/06/2009) What is the best router for p2p and gaming? what to buy? |
| (01/05/2009) Best modem / router | (12/30/2008) Can't Access BEC 5200S Modem/router |
| (12/29/2008) Problems replacing wireless router w/ new wireless router | (04/20/2009) Is there a wireless router with a category content filtering?? |
| (12/17/2008) help! need to know more about speeds!! | (12/26/2008) Problems renewing ipconfig without router |
| (12/29/2008) Router + Switch = internet? | (12/03/2008) New Router Suggestions |
| (12/02/2008) D-Link router problem | (10/01/2009) linksys router crashes my connection every time i |
| (11/23/2008) Linux Router | (11/17/2008) Upgrading Router, but to which one? |
| (12/19/2008) VPN on Windows 2000 in domainand behid router | (10/27/2008) What Wireslls Router is best? please help! |
| (10/24/2008) Gigabit router suggestion please | (10/12/2008) will a switch improve my router |
| (12/03/2008) My Router Suddenly Closed all the Ports I opened - WTF? | (12/29/2008) P2P brings router to it's knees? |
| (10/08/2008) 1gbps network, need help hitting target data throughput speeds | (10/01/2008) Question about 1 Router, 1 Network Printer & 2 PCs |
| (10/01/2008) No LAN on router | (09/29/2008) Good router |
| (09/22/2008) My downloads speeds are varying greatly. | (09/17/2008) gaming router |
| (09/21/2008) Secure Router / Firewall | (09/19/2008) New router - ethernet cables? |
| (09/19/2008) unstable wireless connection netgear router | (09/18/2008) Slow Download Speeds |
| (10/13/2008) I need a router with a *configurable* 10Mbps Full Duplex WAN port! | (09/19/2008) Problems with the Linksys WRT54G v2.2 router |
| (10/01/2008) Can a Router slowly fail? | (10/01/2008) how to open port on my router |
| (09/19/2008) What do I need for office router/switch | (09/07/2008) Need help with router |
| (09/06/2008) Do I need to change my router to use Optus ADSL2+? | (09/05/2008) New router |
| (09/06/2008) How to setup DSL router? | (01/04/2009) Can't get Linksys router to work with AT&T DSL |
| (09/06/2008) Bypassing Router Time Restrictions | (09/07/2008) need router advice please |
| (08/30/2008) Very Slow Download Speeds (Vista-64 bit) | (01/17/2009) INTERMITTENT WIRELESS: Netgear router or Dell D620 problem?? |
| (08/28/2008) Router recommendation? | (08/20/2008) Newbie trying to setup wireless router,need advice |
| (08/19/2008) Is the D-Link DGL-4300 router cable/dsl or adsl? | (08/22/2008) Connecting PC-PC and sharing internet without router |
| (08/30/2008) Hook linksys wireless router and 2 switches to main router | (08/15/2008) ADSL router and PC cabling |
| (08/13/2008) Sp3 Router problem | (08/09/2008) Router gone bad or conditions worsening to blame |
| (08/06/2008) How to get Maximum Transfer Speeds between Desktop & Laptop | (08/04/2008) New Router |
| (08/13/2008) Slow Cable Speeds, unknown problem | (07/31/2008) Please recomend a Cable modem and router. |
| (07/30/2008) High ping when router introduced to network | (07/30/2008) 2 router port forwarding |
| (07/29/2008) New Router - Advice needed. | (07/24/2008) Linksys RV042 router issue |
| (07/20/2008) Gaming/Torrent Router | (07/18/2008) Which router? |
| (07/18/2008) Router Woes | (07/16/2008) Router not giving a 192 address |
| (07/20/2008) Basic Router Advice Needed | (07/15/2008) Help choosing a router from 4. |
| (08/21/2008) Router to switch to PCs? | (07/10/2008) Looking for new router |
| (11/30/2009) Setup gigabit home network using 100mbps Router but Gigabit switches | (07/04/2008) Need advise on a cable router |
| (07/03/2008) Looking for a new router | (06/27/2008) LAN port problem - works fine with adsl modem but not router |
| (06/26/2008) Help getting my linksys wireless router to work | (07/04/2008) Hosting on Modem(Fast) versus Router (Slower) Should I Upgrade Router? |
| (08/06/2008) Wireless router with print server | (06/21/2008) Very confused as to which router to get! |
| (03/16/2009) zoom x6 router help | (10/07/2008) Old laptop into linux router |
| (06/04/2008) Router lag issue | (05/31/2008) 2 router configuration issues |
| (05/30/2008) Problems with router (d-link dir 100) | (06/02/2008) linksys router issue |
| (06/02/2008) Router Advice needed | (05/10/2008) DGL-4500 router and Gamefuel Plz Helpppp |
| (11/27/2009) Two internet connections, 1 router, 1 PC. | (05/05/2008) D Link DIR 655/ router check in |
| (05/01/2008) This stupid computer wont do anything that it needs to with my router | (04/29/2008) philips / Talk takl router sna5630/ns |
| (04/26/2008) Looking for application or router for capping bandwidth | (10/01/2008) Connecting a Wireless Router to My ::ahem:: neighbors WiFi Internet |
| (04/20/2008) networking 2 pcs (via adsl router?) | (04/18/2008) gaming router |
| (04/17/2008) how does ADSL router/switch work? | (03/31/2008) Belkin router only allowing max of 2 wired connections!? |
| (03/29/2008) which lower price dual wan router | (03/24/2008) 2Wire DSL Modem/router w/Linksys 4124 switch and Linksys WRT350N |
| (03/24/2008) Need a new reliable wireless router | (03/26/2008) Which router? |
| (03/24/2008) Router Issue | (03/29/2008) Zoom X6 Modem/Router Security Issues |
| (03/16/2008) loss of speed bec of router? | (03/12/2008) How to network share between router a and router b? |
| (09/20/2009) LAN not working, Wireless working fine (D-Link DGL-4300 router) | (03/09/2008) Media Sharing / router problem |
| (03/12/2008) best QOS router for the money. | (03/12/2008) Looking for router that is fast enough for 27,000 kb/s connection |
| (03/12/2008) P2P and gaming router | (03/05/2008) 0 knowledge - need help picking router |
| (10/01/2008) Weird problem with Belkin G wireless router. | (02/19/2008) Help with Linksys Router. |
| (02/12/2008) Need Help with VNP and Linksys Router | (02/11/2008) need new wifi router or go powerline |
| (02/08/2008) router ip address changed due to modem | (02/06/2008) Adding Wireless Access Point to 2Wire HGV 2700 Router |
| (12/07/2008) Problem with Lan connection with Telefonica (Spain) ZyXel router | (02/01/2008) Need additional ports than what my existing wireless router provides. |
| (01/31/2008) best wireless router for a wii, 360, ps3 | (03/12/2008) Dual Ethernet mobo + router question |
| (01/26/2008) How is a switch different from a router? | (01/25/2008) So is it time to replace this POS (Vonage) Linksys wired router? |
| (02/25/2008) Finding router information | (01/24/2008) Router Dropping connection under heavy load |
| (01/21/2008) lag problem with new wireless router | (01/21/2008) adsl modem + switch no router... |
| (01/19/2008) Cant find Router charts | (01/18/2008) Internet via USB adapter and local network via wired router? |
| (01/17/2008) Please suggest wired router for Vista | (01/15/2008) Can I plug a wireless router into a wired router? |
| (01/15/2008) Router Troubleshooting Issue | (01/15/2008) need help turning Linksys WRT54G into a bridge router |
| (01/04/2008) Strange problem with router Belkin | (12/25/2007) Connecting two PC and a Router Local Network |
| (12/21/2007) Looking for a cheap reliable router | (12/19/2007) Att 2210 modem wont connect to linksys befsr41 router |
| (12/06/2007) configure router d-link di624, unknown address | (12/04/2007) Router: D-Link DGL-4300 Please Help |
| (11/29/2007) Stable router that can handle BT | (11/29/2007) Which wireless router should i get for my laptop? |
| (11/28/2007) Router - Firewall blocking stuff | (11/27/2007) Aztech DSL600ER Router |
| (08/17/2009) Netgear FVG318 router blocking (some) outgoing FTP | (11/26/2007) router or router+switch |
| (11/21/2007) Router or Switch ? | (11/16/2007) Linux Home Server Behind FIOS Router | No Joy |
| (11/15/2007) Did anyone use/try the router Asus WL-500g Premium? | (11/16/2007) do i need a router? |
| (11/15/2007) Looking for a firewall/router with full featured NAT | (06/10/2009) Need assistance choosing a replacement router on Verizon FIOS |
| (11/10/2007) One router, two 'puters, two speeds - HIS n HERS | (11/12/2007) WNR854T router reboots itself on settings update |
| (11/08/2007) my connection dies suddenly behind a router | (11/07/2007) Help! Why wont my Router Talk to my Switch?? |
| (09/13/2009) Belkin F5D7230-4 v2000 router stalls when browsing Google Maps | (10/28/2007) Netopia R910: Router -to-Router VPN, Can't PING Remote LAN |
| (10/24/2007) Best ADSL2 Wireless Router | (09/28/2009) using a dsl router with a cable modem |
| (10/05/2007) Router Blew Out, Some Computers Connect Through Switch But Not All | (09/30/2007) Installing NAT & Firewall behind ADSL Router |
| (09/25/2007) router slowing int | (09/22/2007) i just bought a router... now i have downloading issues |
| (09/21/2007) Does using a router to split the internet to 2 computers slow it down? | (09/20/2007) DSL With Router and switch? |
| (09/14/2007) Need a new router, g or n? newb-ish | (09/14/2007) Daisy Chaing Router for VoIP |
| (09/13/2007) server behind a university router | (10/12/2007) How, exactly, do I connect my 2nd router (D-Link DI-624) to my first |
| (09/04/2007) Router can't sign in MSN Messenger | (10/12/2007) Connecting 2 PCs on 1 router |
| (09/04/2007) urgent Router help | (09/03/2007) Connecting router and modem |
| (09/06/2007) WinXP not detecting IP address assigned by router | (08/28/2007) How to Reconnect to router w/ DHCP off |
| (08/22/2007) USR8000-02.Disable router side ? | (08/29/2007) Why does router need DSL login? |
| (09/05/2007) Dual WAN router suggestions needed | (08/21/2007) could i transfer files to another computer using a router? |
| (08/22/2007) Router problems in a new apartment | (08/21/2007) Problem Networking XP Pro for file/printer sharing thru WRT54G Router |
| (08/15/2007) I need help accessing the router to open a port | (08/11/2007) Network Data Transfer Speeds |
| (09/19/2007) Using a router/switch in a dorm room... | (11/06/2009) Will 100mbps modem/router limit Gigabit switch connections? |
| (07/21/2007) Netgear router ton Linksys VOIP box connection problem | (07/18/2007) Buffalo G300N router slows Internet to a stop |
| (08/06/2007) Netgear Router and browser issues | (07/20/2007) 1 of 2 COMPS connected through router |
| (07/28/2007) slow sbc dsl speeds | (07/10/2007) Faster upload speeds without fiber? |
| (07/12/2007) Random & Frequent DSL Drops - Caused by Linksys Router? | (11/05/2007) Is a software firewall needed with a router? |
| (07/02/2007) Router on remote pc? | (06/17/2007) Buffalo Router WHR-HP-G54 - Web Server |
| (06/18/2007) Which router for Westell 6100??? | (06/16/2007) Having a lot of trouble installing Ethernet router modems |
| (06/17/2007) High performence bandwidth-control router. | (06/17/2007) Internet speeds going uber slow, can i have some advice? |
| (06/20/2007) router not working | (07/07/2007) cable router |
| (09/21/2007) problem with daisy chained wireless router | (06/01/2007) Choosing between internet speeds. Need help. |
| (05/21/2007) Router/firewall with gateway a/v protection? | (05/21/2007) Help with router routing tables |
| (05/18/2007) my c4500 cisco router | (05/18/2007) How to connect one router on the internet to a router. |
| (05/17/2007) Reliable router for a hotel | (05/13/2007) TRENDnet router/ USB adapter makes comp freeze. |
| (05/15/2007) Can a networking guru please help me set-up my router/LAN? | (05/10/2007) is my router slowing my lan speed |
| (05/05/2007) Do router/modems go bad? | (05/08/2007) How important is the router's role? |
| (05/08/2007) GIGABIT Router or GIGABIT Switch & Recommendation Please | (04/30/2007) using an extra computer as a firewall/router? |
| (05/20/2007) using an extra computer as a firewall/router? | (04/27/2007) Router or switch? |
| (04/27/2007) Router Help | (05/20/2007) Router |
| (04/26/2007) Linksys PAP2 before or after the router? | (04/24/2007) Wireless public network access with DSL wireless router? |
| (04/21/2007) router, modem compatibility | (07/13/2007) Lag problem with Router and modem! |
| (04/20/2007) How to access my DSL Router ? | (04/22/2007) nub ?: Firewall problem with wireless router |
| (04/18/2007) What do you think about this new D-Link Router... | (04/17/2007) Two routers cannot ping pc's on router 2 |
| (04/15/2007) HELP PLEASE!!! Router Resetting every 8 to 10 seconds!???? | (04/14/2007) Expected data transfer speeds on 10/100 network |
| (04/07/2007) Need router recommendation | (04/08/2007) Router cannot share internet connection |
| (04/05/2007) what's the best wireless vpn cable/dsl router for home offic | (04/04/2007) Sudden Problem with Router |
| (04/10/2007) Can't find network (router) | (03/29/2007) slow internet speeds please help please !!!!!!!!!!!!!!!!! |
| (03/24/2007) busted / bricked router? | (04/01/2007) Need a New Router! |
| (03/20/2007) Vista Compatible Router | (04/10/2007) Router With Bandwidth control for 40 PC's |
| (03/13/2007) ADT Alarm with no Filter Conflicting with ADSL2+ Speeds! | (03/16/2007) Router problem... |
| (03/15/2007) signals: external antenna router & internal one? | (03/15/2007) Recomended Wired Gaming Router? |
| (04/23/2007) Networking to another PC through router. | (03/03/2007) wired router recommendation |
| (02/26/2007) Hi everyone looking for a router for gaming with a high rang | (03/02/2007) monitoring traffic through standard router |
| (02/22/2007) Stupid D Link Router | (02/26/2007) changing channels on wireless router help improve connection |
| (02/19/2007) spare pc to be used as a router.... | (02/24/2007) Router to Dial-up cable |
| (02/19/2007) Second router for more ports don't show on network | (10/05/2008) gaming router |
| (02/19/2007) what do you think of Linksys WRT300N router? | (02/10/2007) how to connect a laptop to someone else wireless router... |
| (02/10/2007) What router to get? | (02/09/2007) My router is acting funny. |
| (02/13/2007) Router or Hub | (02/15/2007) Cisco Router IP Reset? |
| (02/06/2007) having some trouble with router. | (02/11/2007) I can overclock my router?!?! |
| (02/04/2007) Very slow download speeds | (02/01/2007) do i need a router? |
| (02/06/2007) Frequent lag spikes using WRT54GL router wired connection | (02/13/2007) Struggling installing wireless router, losing internet conne |
| (01/30/2007) access-list cisco router 1721 | (01/28/2007) Is the WRT54GL a good wireless router? |
| (01/25/2007) router seems to have been hubified - has it been cracked? | (01/26/2007) PC to router connecting Problem! |
| (01/21/2007) winxp, netgear router, no internet... | (01/20/2007) is it possible to relocate my router? |
| (02/04/2007) Can I MOVE my router successfully....? | (01/20/2007) Actiontec model M1424-WR Router question |
| (01/22/2007) looking for a router | (01/31/2007) What router is best for heavy P2P with heavy limit of 80$? |
| (01/14/2007) WEIRD SHARING PROBLEM W/ WIRELESS ROUTER | (01/23/2007) Setting up a router with the connection from another router |
| (01/14/2007) Good Router Suggestion | (01/30/2007) Firewall is different from router? |
| (01/19/2007) connecting wireless router to a hardwired router | (01/11/2007) new router question |
| (01/12/2007) Need help troubleshooting a router | (01/13/2007) Router Fast enough for Roadrunner Premium? |
| (01/09/2007) P2P programs disconnect Router ! | (01/10/2007) Gaming Router Question |
| (01/10/2007) Time for a Router Upgrade? | (01/03/2007) Old PC into a Router problem |
| (01/02/2007) Wireless network/router advice/questions | (01/01/2007) best cable modem router? |
| (01/03/2007) Which MIMO Gaming g/draft-N Router? | (01/04/2007) Router or Windows problem? Router ignores pc |
| (12/29/2006) question about adsl router | (12/29/2006) Router problems |
| (01/08/2007) USR8200 router...I've tried everything to open a port. | |
