Can I use this Router as a Modem?
More related threads to : Can I use this Router as a Modem?
(11/27/2009) I cant connect through my router(11/30/2009) Router connection
(11/27/2009) Can't connect to router settings(11/27/2009) Does an xp computer talk to a windows 7 box using a linksys wired router
(11/25/2009) Router problems(11/24/2009) Can connect to DIR-655 router but no internet access
(11/23/2009) How many laptops can we connect through one wireless router?(11/30/2009) If I use VOIP with my companies Router connected to my router can they see all I
(11/22/2009) Need some help chosing a modem and router...(11/20/2009) What is the best way t odo this?
(11/21/2009) Half duplex on the WAN?(11/19/2009) Modem - Computer - Router
(11/20/2009) I'm baffled at what I encountered yesterday at home. The home I moved to has Ca(11/17/2009) Router Will Not Turn On / Connect to Power
(11/25/2009) Can't Ping DNS(11/17/2009) Need GREAT Wireless Router
(11/13/2009) I have a modem i want to put a switch rather than a router is it possible?(11/12/2009) Can not remove network adapters in xp
(11/12/2009) Can the windows 7 firewall system act tmg?(11/12/2009) 2nd router to att router
(11/09/2009) Fix "This movie has script that is causing ActiveX 10 to run slowly"(11/11/2009) 2 routers cannot access computers on 1st router
(11/07/2009) Two pc connect delete file not go in recycle bin where this file go(11/07/2009) Do I need a new Router?
(11/06/2009) Windows 7 home network on router(11/06/2009) RCA dcm425 modem bridging problems
(11/13/2009) Help with troubleshooting Cisco 1760 router(11/11/2009) Unable to Access Router Admin Page
(11/02/2009) Connect one router to another to make new network?(11/02/2009) Can two desktops go on one modem without paying extra?
(11/01/2009) Looking for recommendation on ADSL/wireless router/powerline in one(11/01/2009) One faculty member who uses Windows 98 wants to set up a shared folder so others
(11/01/2009) How does a router makes difference between a public IP and a local IP(10/31/2009) Can someone hack into my land line phone number?
(10/31/2009) Can someone who uses(or knows about) managed switches answer simple ?(11/02/2009) Installed new router and other computers cant get on the internet
(11/03/2009) Wireless router choise(10/28/2009) Lan part in my router is not working
(10/30/2009) Modem problem(11/06/2009) LINKSYS WRT54GL UNABLE TO CONNECT THE ROUTER
(10/26/2009) At&t 2wire modem(10/25/2009) Configure Wireless Router with Nuvox T1 Circuit
(10/24/2009) Help choose a new router(10/23/2009) You might not have permission to use this network resource contact the administr
(10/22/2009) Since we installed our cisco router interent is very slow(10/21/2009) I have two cable modems and one printer. How do I print from a computer connecte
(10/19/2009) Router and switch connection(10/19/2009) Router Problems....
(10/20/2009) I lost my password for steam and when i send a message of it to my email it dose(10/19/2009) Linksys router cant access browser configuration
(10/19/2009) Edimax BR-6424n Router not connecting to Modem(10/18/2009) BelkinFD8231-4 modem problems
(10/20/2009) Something wrong with my router!(10/19/2009) Silly question -- ISP assigned IP with different subnet than router
(10/14/2009) A good 3g modem(10/14/2009) Good gigabit router.
(10/14/2009) Can you turn on pc over lan or wan(10/13/2009) Can i use more than one IP address on the same DHCP server
(10/14/2009) Can not connect to a computer on my network(10/10/2009) Can fax using adsl router
(10/09/2009) Linksys Router RT41-BU - hangups !!$%?(10/09/2009) How to access internet from wireless router to toshiba laptop
(10/09/2009) It is possible to use 2 routers in 1 cable modem(10/08/2009) How to share the internet connection by two computers without using router
(10/08/2009) Please identify this cable connector(10/09/2009) Netgear Wireless Router Connection Issue
(10/10/2009) Should the firewall/router be the dhcp or should the modem be dhcp(10/09/2009) Is this normal why do i have 2 dns numbers and a ip addres
(10/06/2009) Can a virus spread between non networked yet physically connected pcs?(10/05/2009) Advantages of using router than switch
(10/05/2009) How far can a pc be hooked up via ethertnet from dsl modem(10/04/2009) Guest Access Prob..Connect Belkin N1 Vision to Belkin N+ Gateway
(10/02/2009) Dl 624 router(10/03/2009) Cannot connect Adsl modem wtih wifi router.
(10/01/2009) Wireless Router and AT&T Modem(09/30/2009) Outlook- Can recieve emails, but sending failure.
(09/28/2009) Modem LEDs keeps flashing non-stop(09/28/2009) Added linksys befsr41 router: have internet but no lan
(09/27/2009) Sonicwall pro 200 netgear router and some confusion(10/01/2009) Is this possible?
(09/24/2009) Low siganal strength coming from router(09/24/2009) Cable broadband router/switch
(09/25/2009) Cable router/switch(09/21/2009) Netgear /DG834Bv3 dsl modem/router
(09/20/2009) Belkin router query(09/19/2009) Cable modem
(10/09/2009) No more connections can be made to this remote computer at this time b(09/19/2009) Will this hardware work?
(09/21/2009) Do I need a Firewall when I use a router?(09/18/2009) Using windows server 2008 as a router
(09/19/2009) Computer no longer connecting to router.(09/17/2009) Router/switch problem
(09/17/2009) 2 internet connection in one router(09/22/2009) 2 internet connection in 1 router
(10/21/2009) Can I boot a PC w/o a HardDrive from another PC?(09/19/2009) Using a router as a wireless adapter?
(09/20/2009) Best cheap router?(09/16/2009) LAN speed slow unless through router?!
(09/17/2009) Basic question about wireless router(09/16/2009) How can i set up DSL and Cable modem together
(09/15/2009) Network diagram broadban to switch to router to switch to router(09/15/2009) Can send and receive packets, still no connection
(09/16/2009) How do you connect 3 computers to a router connected to the modem?(09/14/2009) Comcast re booting cable modem.....
(09/13/2009) How to convert AnyDATA AWR 500-A wifi router into switch(09/13/2009) Can i monitor another pc
(09/12/2009) ATT DSL Service with Linksys WRT54G Router(09/17/2009) Can't port forward some ports, getting desperate :(
(09/10/2009) Small business wifi router for voip and LAN traffic(09/14/2009) Router keeps on freezing my browser page
(09/10/2009) I have cox internet and a router need to hook up all my laptops in the house(09/18/2009) Best router for gaming and wifi N?
(09/05/2009) Will External RS-232 Modem Work With 3 Pin Serial Interface(09/06/2009) Will External RS-232 Modem Work With 3 Pin Serial Interface
(09/04/2009) Can I secure 2 ports on an 8 port shared router?(09/03/2009) Good business grade router for under $500.
(09/02/2009) Now that I tried to install a new router my computers are all screwy!(09/01/2009) SMC barricade router blocking access to printer on LAN
(09/02/2009) Netgear router FVS318 & speed limitations(09/21/2009) Bizarre Network issue. Can no logner connect properly to router(s)
(08/31/2009) Connecting a Wireless router to a modem/Wireless router, Help!(08/31/2009) Can't ping netgear prosafe vpn firewall
(09/13/2009) 2Wire Router/Modem and 24 port switch?(08/27/2009) Router and switch
(08/28/2009) Router question(08/27/2009) Connect network switch to DSL modem
(09/14/2009) What Router should I get ?(08/23/2009) Netgear Router problems
(09/23/2009) ZyXEL P-660HW Series router problem(08/25/2009) NAS + Router
(08/24/2009) New Router troubles(08/23/2009) Dont knw what this is
(08/22/2009) Can't connect to Interner using ethernet to Vista(08/20/2009) Can't Print from HArdline
(08/19/2009) Can connect through modem, but not through router(08/18/2009) Linksys router stacking under Thomson?
(08/18/2009) Cannot connect to the internet through a router!(08/16/2009) Will this home gigabyte solution work?
(10/19/2009) Can't Acquire or Install Correct NIC Drivers, GA-EX58-UD5(08/15/2009) What router to buy for high speed gaming
(08/14/2009) Can't send Packets(08/14/2009) Which Cisco Router to choose?
(08/29/2009) 25 year old female Chinese college student vs router(08/11/2009) Weird Networking/Router Problem [SOLVED]
(08/15/2009) Can I share connection with router and switch?(08/08/2009) How would I solve this problem?
(08/03/2009) Router Suggestion for NAS(08/01/2009) Modem and router connection
(07/31/2009) My new pc cannot connect to the router(08/04/2009) New router, bad Xbox Live
(07/30/2009) Can't connect with Remote Desktop(07/30/2009) Sam's Club WRT110 Linksys Router Question
(07/29/2009) Home router setup with no modem password(07/29/2009) Can't get Cat5e cable to work
(07/29/2009) New AT&T Supplied Motorola Modem/Linksys Router Connection Problem(07/31/2009) Can't view available wireless networks
(07/27/2009) Whats the best solution for this setup?(07/25/2009) Modem and Router confusion
(07/23/2009) Router slowing internet(07/21/2009) Would this work for me? (Wirless Bridge)
(07/26/2009) DHCP Client Service Won't Start - Error 1068(07/25/2009) CPU disconnects from the Internet but is still connected to the modem
(07/18/2009) Belkin Wireless G Router(07/16/2009) Router with Firewall adds 6Mb speed reduction!
(07/15/2009) Sharing files/printer through router + switch(07/15/2009) Router issue
(07/14/2009) Router problem(07/22/2009) Trendnet Router Problem
(07/11/2009) Router Problem(07/13/2009) Modem crashing
(07/14/2009) USB Modem workaround to get Ethernet Output(07/08/2009) Need to know what ip to use for modem to open ports
(07/07/2009) Internet And Router Problem(07/06/2009) Netgear router
(07/07/2009) Router hardware question(07/06/2009) Trying to network a Windows ME system with Windows Vista on a router.
(07/05/2009) Fast connection to modem yet download speed only 50%(07/04/2009) Toshiba router wont connect
(06/29/2009) Wow, I Hope This Doesn't Happen in the US(06/28/2009) Lose Router Connection
(07/01/2009) Internet link unstable in Netgear Router(06/27/2009) Can i do this?
(08/24/2009) Industrial Rugged GPRS HSUPA VPN Router(06/26/2009) Problems networking with FiOS router
(06/23/2009) Router and Switch Question(06/23/2009) Modem+router or dedicated?
(06/21/2009) 2 computers, 1 modem, cannot find server(06/19/2009) Connecting DSL modem to hub
(06/18/2009) Network settings problem? Cant change router with same settings(06/17/2009) Severe Packet Loss Between Cable Modem and Computer
(06/19/2009) 2 Router Set Up - 1 Wired, 1 Wireless(06/16/2009) Is this a network problem????
(06/19/2009) Modem+Router+Switch+2 Routers(06/15/2009) Help! Only 1 Computer Can Use Internet on Network - Any Ideas?
(06/26/2009) Is this OK to do?(06/15/2009) Video How-To: Linksys Router Setup
(06/09/2009) Need a rock-solid performance Router for Bittorrent(06/15/2009) How to set connection using Wavecom Fastrack Supreme modem via Windows
(06/09/2009) Please help by suggesting a good router(06/10/2009) Best Wired GB router with SPI
(06/04/2009) Computer loses connection to router(06/07/2009) Can access the Router but doesn't have Internet[Wired]
(06/07/2009) Change IP router automatically(06/03/2009) Can a cheap switch damage an expensive one?
(06/27/2009) Turning a PC into a Router(08/22/2009) D-Link DI-524 router "config.bin"
(05/28/2009) Can i transfer 4 raid5 hdds from one nas to another?(05/28/2009) Can i add an itunes/bittorent/print server to a terastation pro 2?
(05/28/2009) Building a router, where are the NICs?(05/28/2009) SMC Modem vs. Linksys(Reliability)
(05/26/2009) Router Question?(05/30/2009) Which router to buy
(06/02/2009) Router suggestion for a rigged network...(05/29/2009) Ethernet + Router Problem -- extremely weird -- please help
(05/22/2009) I need a new router that doesn't bottleneck my bandwidth speed(05/18/2009) Can't view webcam..!
(05/14/2009) Using RS232 to Ethernet Converter with Serial modem(05/11/2009) Ping does not work on this network
(05/12/2009) Blocking wireless access to single comp on router.(05/10/2009) New modem or router ?
(05/12/2009) 2nd router DSL thru a different phone jack?(05/03/2009) What to do with a bad modem?
(05/02/2009) Windows 7 IE8 "cannot load this page" DNS Problem(05/01/2009) Netgear CG814WG router question
(04/30/2009) FILE TRANSFER PROBLEM - Cable Modem & 1GB Switch(04/26/2009) Please help me with this subnetting
(04/25/2009) Can somone help me solve this subnetting situation(09/09/2009) Linksys Router & ATT DSL Setup Help Please???
(04/20/2009) Router capping speeds?(06/20/2009) How to setup a SB5101 Surfboard Modem
(05/18/2009) Computer won't start with router on(04/16/2009) Router Modem and Nic speeds
(04/15/2009) Help with setting up a Wifi Router(04/18/2009) Wireless router on LAN
(04/14/2009) Problem with WBR-3406TX Router(04/15/2009) Controlling Internet Access via Router Settings
(04/12/2009) Modem says unknown in network(04/11/2009) Help Choosing A Router
(10/10/2009) Can't get wireless Netgear router to work(04/09/2009) Modem connects to interwebs, router won't let my comp connect!
(07/03/2009) Looking for Information on a "Bonded Cable" Modem(04/07/2009) Port forwarding for linksys router model befw11s4
(04/02/2009) Modem dial/handshaking sound with Cable Internet(03/28/2009) Modem to Computer
(03/23/2009) Anyone Can Help me Please?!(03/23/2009) What router should I buy
(03/25/2009) 2 Wire Router, how to Firewall wired connections from Wireless?(03/22/2009) Can you network a Pc and an iMac?
(03/22/2009) Why can't the modem recognize wired router connection but will work on wireless?(03/22/2009) My ADSL MODEM did not connect
(03/19/2009) Gaming Networking/Modem Purchase Question(03/22/2009) Need a recommend for a router
(03/17/2009) Can a switch be used as a hub?(03/17/2009) Router upgrade?
(03/13/2009) Not sure how to make this work...Please help!(03/22/2009) CAN'T Remote Desktop Connection over LAN
(03/11/2009) Switch from Cable internet to DSL router not working(03/08/2009) MSI RG60G router Help what is SPI etc
(03/10/2009) Get router or use main computer as hub?(03/07/2009) Piggyback Linksys NR041 off DSL 4 port modem
(03/22/2009) Can't Ping or Tracert: why?(02/28/2009) Random Request timed out when ping router
(02/28/2009) Need Help Choosing A New Router(02/27/2009) Have no idea how to fix this network problem...
(02/25/2009) Webstar Modem Strange Lights Blinking(05/17/2009) Connecting Verizon Fios Router to a Netgear Wireless Router
(02/24/2009) Linksys Router Help(02/24/2009) Got New Router | Confused by DSL Cable Instead of Ethernet
(02/20/2009) Modem or Motherboard Problem ?(02/19/2009) IP change for modem on Toshiba 4000
(04/22/2009) D-Link Extreme N Dual Router(02/12/2009) Unusual Router Problem
(02/14/2009) Does this make me a nerd?(02/12/2009) LAN via router problem with two PCs
(02/16/2009) Laptop connecting to my router disrupts internet(02/09/2009) Wideview and an 8 port router
(02/09/2009) Wideview and 8 port router(02/07/2009) Linksys WRT54G router and Siemens 4100 bridge mode configuration problem.
(02/05/2009) I want this for my house(02/05/2009) Using router in a college lan
(10/10/2009) Need Router That Routes Multiple External IPs(02/03/2009) How to convert a Wireless B router into a switch?
(02/01/2009) Router to router connection(02/15/2009) How do you connect Router to Router?
(01/31/2009) Need to install Modem CD drivers? Advantages/disadvantages???(01/26/2009) Router vs. Switch
(01/29/2009) Can only get XP pro to run 100Mbps on Gigabit LAN connection(01/24/2009) Router Question
(01/24/2009) Cable Modem(01/22/2009) How can i set up a lan with out a router/server
(01/21/2009) Is it the modem or router!(01/22/2009) Ethernet access away from router?
(06/13/2009) RJ45-shaped ADSL Line port? N+ Wireless Modem Router(01/19/2009) How do I get this to work?
(07/16/2009) Internet Slow Through Router(01/17/2009) Better Router
(01/16/2009) Can access shares but not browser workgroup(01/15/2009) What happend to my router? help!
(01/20/2009) Gaming and p2p router setup and suggestions(01/13/2009) Please help this damsel in distress!! RE: printer network problem. x
(01/11/2009) Vista +modem(01/13/2009) Can's see public folder on one network computer
(01/13/2009) Router hunting(01/06/2009) Is the DGL-4500 Xtreme N Gaming Router the best router for gaming?
(01/06/2009) What is the best router for p2p and gaming? what to buy?(01/05/2009) Best modem / router
(01/05/2009) Need answer to this issue(12/30/2008) Can't Access BEC 5200S Modem/router
(12/29/2008) Problems replacing wireless router w/ new wireless router(04/20/2009) Is there a wireless router with a category content filtering??
(01/07/2009) Can i reset my IP address??(12/21/2008) Can anyone tell me why this is happening?
(12/26/2008) Problems renewing ipconfig without router(12/10/2008) DIR-655 acting as cable modem?
(12/04/2008) Can't get LAN working(12/29/2008) Router + Switch = internet?
(12/05/2008) Modem or Internet issue?(12/03/2008) New Router Suggestions
(12/02/2008) D-Link router problem(10/01/2009) linksys router crashes my connection every time i
(11/25/2008) Internet - Modem Rest(11/23/2008) Linux Router
(11/17/2008) Im noy sure where this falls under(11/17/2008) Upgrading Router, but to which one?
(12/19/2008) VPN on Windows 2000 in domainand behid router(11/09/2008) Can you help me plan my lan party?
(04/20/2009) "Windows cannot load the drivers required for this device. (Code 31)"(10/29/2008) A8N-E kill the internet connection of my cable modem...
(10/27/2008) What Wireslls Router is best? please help!(10/26/2008) Can ping loopback address but now my own IP (mask is Ok!)
(10/24/2008) Gigabit router suggestion please(10/12/2008) will a switch improve my router
(12/03/2008) My Router Suddenly Closed all the Ports I opened - WTF?(12/29/2008) P2P brings router to it's knees?
(10/07/2008) Can someone explain my internet speed drop?(10/03/2008) Two computers with one modem from comcast
(10/01/2008) Question about 1 Router, 1 Network Printer & 2 PCs(10/01/2008) No LAN on router
(09/29/2008) Good router(09/22/2008) Can u "delete" home networking?
(09/17/2008) gaming router(09/21/2008) Secure Router / Firewall
(09/19/2008) New router - ethernet cables?(09/19/2008) unstable wireless connection netgear router
(10/13/2008) I need a router with a *configurable* 10Mbps Full Duplex WAN port!(09/19/2008) Problems with the Linksys WRT54G v2.2 router
(09/19/2008) Problem with recieved packets from modem(10/01/2008) Can a Router slowly fail?
(09/19/2008) Can't share data between two routers(10/01/2008) how to open port on my router
(09/19/2008) What do I need for office router/switch(09/07/2008) Need help with router
(09/06/2008) Do I need to change my router to use Optus ADSL2+?(09/05/2008) New router
(09/06/2008) How to setup DSL router?(01/04/2009) Can't get Linksys router to work with AT&T DSL
(09/06/2008) Bypassing Router Time Restrictions(09/07/2008) need router advice please
(01/17/2009) INTERMITTENT WIRELESS: Netgear router or Dell D620 problem??(08/28/2008) Router recommendation?
(08/20/2008) Newbie trying to setup wireless router,need advice(08/19/2008) Is the D-Link DGL-4300 router cable/dsl or adsl?
(09/03/2008) Modem or provider?(08/22/2008) Connecting PC-PC and sharing internet without router
(08/30/2008) Hook linksys wireless router and 2 switches to main router(08/15/2008) ADSL router and PC cabling
(08/13/2008) Sp3 Router problem(08/11/2008) Can't access domain computers via Remote desktop
(08/09/2008) Router gone bad or conditions worsening to blame(08/04/2008) New Router
(07/31/2008) Please recomend a Cable modem and router.(07/30/2008) High ping when router introduced to network
(07/30/2008) Can you make two routers connect to eachother?(07/30/2008) Cable Modem Receive Power Out of Sync
(07/29/2008) XP Home Can't Join XP Pro Workgroup(07/30/2008) 2 router port forwarding
(03/23/2009) Can't connect to one of three printers!(07/29/2008) New Router - Advice needed.
(07/24/2008) Linksys RV042 router issue(07/23/2008) Possible dying cable modem?
(07/22/2008) Modem Help(07/20/2008) Gaming/Torrent Router
(07/18/2008) Which router?(07/18/2008) Router Woes
(07/16/2008) Router not giving a 192 address(07/16/2008) Can't connect to internet after reformating
(07/20/2008) Basic Router Advice Needed(07/15/2008) Help choosing a router from 4.
(07/12/2008) Modem replacement- clueless(08/21/2008) Router to switch to PCs?
(07/10/2008) Looking for new router(11/30/2009) Setup gigabit home network using 100mbps Router but Gigabit switches
(07/04/2008) Need advise on a cable router(07/03/2008) Looking for a new router
(07/03/2008) Do I really need a new modem for faster internet or is Comcast lying?(07/03/2008) Can't share my documents!!
(06/27/2008) LAN port problem - works fine with adsl modem but not router(06/26/2008) Help getting my linksys wireless router to work
(07/04/2008) Hosting on Modem(Fast) versus Router (Slower) Should I Upgrade Router?(06/18/2008) USR8200 with Airport Extreme and a modem - HELP
(08/06/2008) Wireless router with print server(06/16/2008) Can I beat 15mbps/768kbps?
(06/14/2008) Problem, data call from fixed line data modem to mobile data modem(06/21/2008) Very confused as to which router to get!
(06/08/2008) modem help(03/16/2009) zoom x6 router help
(10/07/2008) Old laptop into linux router(06/04/2008) Router lag issue
(05/31/2008) 2 router configuration issues(05/30/2008) Problems with router (d-link dir 100)
(06/02/2008) linksys router issue(05/13/2008) Can I "get" internet from other pc using
(06/02/2008) Router Advice needed(05/10/2008) DGL-4500 router and Gamefuel Plz Helpppp
(11/27/2009) Two internet connections, 1 router, 1 PC.(05/05/2008) D Link DIR 655/ router check in
(05/01/2008) This stupid computer wont do anything that it needs to with my router(04/29/2008) philips / Talk takl router sna5630/ns
(04/30/2008) My Modem(04/27/2008) Cable Modem resets itself
(04/26/2008) XP Home won't detect 56K PCI Modem(04/26/2008) Looking for application or router for capping bandwidth
(04/24/2008) Windows Can't detect my network?(04/24/2008) Can't share wireless internet connection
(10/01/2008) Connecting a Wireless Router to My ::ahem:: neighbors WiFi Internet(04/20/2008) networking 2 pcs (via adsl router?)
(04/18/2008) gaming router(04/17/2008) how does ADSL router/switch work?
(04/11/2008) Just curious... TV on TV/monitor thru cable modem lan(04/06/2008) two adsl accounts on a single adsl modem
(03/31/2008) Belkin router only allowing max of 2 wired connections!?(03/29/2008) which lower price dual wan router
(03/24/2008) 2Wire DSL Modem/router w/Linksys 4124 switch and Linksys WRT350N(03/24/2008) Need a new reliable wireless router
(03/20/2008) Limited connectivity. Is this a problem with onboard LAN?(03/26/2008) Which router?
(03/24/2008) Router Issue(03/16/2008) Cant get new cable modem to work w/splitter.Tried 3
(03/29/2008) Zoom X6 Modem/Router Security Issues(03/16/2008) loss of speed bec of router?
(03/12/2008) How to network share between router a and router b?(09/20/2009) LAN not working, Wireless working fine (D-Link DGL-4300 router)
(03/09/2008) Media Sharing / router problem(03/12/2008) best QOS router for the money.
(03/12/2008) Looking for router that is fast enough for 27,000 kb/s connection(03/06/2008) Anyone know of any free download boosters.My cable modem is slow
(03/12/2008) P2P and gaming router(03/05/2008) 0 knowledge - need help picking router
(02/28/2008) Did I understand this post correctly?(10/01/2008) Weird problem with Belkin G wireless router.
(02/20/2008) Internet/Modem disconnecting(02/20/2008) Need a new modem?
(02/19/2008) Help with Linksys Router.(02/12/2008) Need Help with VNP and Linksys Router
(02/11/2008) need new wifi router or go powerline(02/08/2008) router ip address changed due to modem
(02/06/2008) Adding Wireless Access Point to 2Wire HGV 2700 Router(12/07/2008) Problem with Lan connection with Telefonica (Spain) ZyXel router
(02/01/2008) Need additional ports than what my existing wireless router provides.(01/31/2008) best wireless router for a wii, 360, ps3
(03/12/2008) Dual Ethernet mobo + router question(01/26/2008) How is a switch different from a router?
(01/25/2008) So is it time to replace this POS (Vonage) Linksys wired router?(02/25/2008) Finding router information
(01/24/2008) Router Dropping connection under heavy load(01/21/2008) lag problem with new wireless router
(01/21/2008) adsl modem + switch no router...(01/19/2008) Cant find Router charts
(01/18/2008) Internet via USB adapter and local network via wired router?(01/22/2008) Linksys 5 port Hub- Can't connect more than 2 computers to internet
(01/17/2008) Please suggest wired router for Vista(01/15/2008) Can I plug a wireless router into a wired router?
(01/15/2008) Can't get internet with GA-M61P-S3 - Network Controller problem?(01/15/2008) Router Troubleshooting Issue
(01/15/2008) need help turning Linksys WRT54G into a bridge router(01/04/2008) Strange problem with router Belkin
(12/25/2007) Connecting two PC and a Router Local Network(01/03/2008) What am I doing wrong? Can't get even 90Mbps
(12/21/2007) Looking for a cheap reliable router(12/14/2007) Can anyone help me?
(12/19/2007) Att 2210 modem wont connect to linksys befsr41 router(12/07/2007) Can't connect to my campus network please help!!!
(12/06/2007) configure router d-link di624, unknown address(12/11/2007) Can you do HTTPS over an alternate port?
(12/04/2007) Router: D-Link DGL-4300 Please Help(11/29/2007) Stable router that can handle BT
(11/29/2007) Which wireless router should i get for my laptop?(11/28/2007) Router - Firewall blocking stuff
(11/27/2007) Aztech DSL600ER Router(08/17/2009) Netgear FVG318 router blocking (some) outgoing FTP
(11/26/2007) router or router+switch(11/21/2007) Router or Switch ?
(11/16/2007) Linux Home Server Behind FIOS Router | No Joy(11/15/2007) Did anyone use/try the router Asus WL-500g Premium?
(11/16/2007) do i need a router?(11/15/2007) Looking for a firewall/router with full featured NAT
(06/10/2009) Need assistance choosing a replacement router on Verizon FIOS(11/10/2007) One router, two 'puters, two speeds - HIS n HERS
(11/12/2007) I think my cable modem is dying, help!!!
Sponsored links
