Find a computer behind a router without port forwarding?
More related threads to : Find a computer behind a router without port forwarding?
(11/27/2009) I cant connect through my router(11/30/2009) Router connection
(11/27/2009) Can't connect to router settings(12/11/2009) How to use my computer at home to bypass a proxy?
(11/25/2009) Does an xp computer talk to a windows 7 box using a linksys wired router(11/25/2009) Router problems
(12/14/2009) Can connect to DIR-655 router but no internet access(11/23/2009) How many laptops can we connect through one wireless router?
(11/30/2009) If I use VOIP with my companies Router connected to my router can they see all I(11/22/2009) Need some help chosing a modem and router...
(11/21/2009) Winxp two connections same computer(11/21/2009) Workgroup computer not visible
(11/21/2009) Half duplex on the WAN?(12/01/2009) How to forward port
(11/19/2009) Modem - Computer - Router(11/19/2009) Port problem
(11/20/2009) I'm baffled at what I encountered yesterday at home. The home I moved to has Ca(11/17/2009) Computer doesnt have a shared tab in wireless connection status
(11/17/2009) Router Will Not Turn On / Connect to Power(11/17/2009) Need GREAT Wireless Router
(11/13/2009) I have a modem i want to put a switch rather than a router is it possible?(11/12/2009) 2nd router to att router
(11/11/2009) Cables needed t connect 360 and computer(11/10/2009) Port bonding
(11/11/2009) 2 routers cannot access computers on 1st router(11/08/2009) How do i disable a proxy server on my computer??
(11/07/2009) Do I need a new Router?(11/06/2009) Windows 7 home network on router
(11/04/2009) Unlocking port forwarding(11/05/2009) Network port going off frequently
(11/13/2009) Help with troubleshooting Cisco 1760 router(11/03/2009) How to remove yellow exclamation point in my WAN mini port?
(11/11/2009) Unable to Access Router Admin Page(11/02/2009) Connect one router to another to make new network?
(11/02/2009) Can two desktops go on one modem without paying extra?(11/01/2009) Looking for recommendation on ADSL/wireless router/powerline in one
(11/01/2009) One faculty member who uses Windows 98 wants to set up a shared folder so others(11/01/2009) How does a router makes difference between a public IP and a local IP
(11/02/2009) Installed new router and other computers cant get on the internet(10/30/2009) TWO ISPs on one computer?
(11/03/2009) Wireless router choise(10/28/2009) Lan part in my router is not working
(11/06/2009) LINKSYS WRT54GL UNABLE TO CONNECT THE ROUTER(10/25/2009) Configure Wireless Router with Nuvox T1 Circuit
(10/25/2009) I have more than two computer connect wirn an 8 port switch ho(10/24/2009) Outlook express for email on new computer
(10/24/2009) Help choose a new router(10/22/2009) Since we installed our cisco router interent is very slow
(10/21/2009) Access denied trying to access a workgroup computer(10/21/2009) I have two cable modems and one printer. How do I print from a computer connecte
(10/21/2009) My computer keeps losing connection(10/21/2009) Wag54g2 connecting to computer
(10/19/2009) Router and switch connection(10/19/2009) Router Problems....
(10/19/2009) Linksys router cant access browser configuration(10/19/2009) Edimax BR-6424n Router not connecting to Modem
(10/21/2009) Interference from TV and wireless computer.(10/20/2009) Something wrong with my router!
(10/19/2009) Ethernet port on ASUS P7P55D pro not working?(10/19/2009) Silly question -- ISP assigned IP with different subnet than router
(10/14/2009) Good gigabit router.(10/14/2009) Goods computer thats no lag when playing games
(10/14/2009) Can not connect to a computer on my network(10/10/2009) Can fax using adsl router
(10/14/2009) Given an IP address of 125.3.54.56, without any subnetting,what is the network n(10/09/2009) Linksys Router RT41-BU - hangups !!$%?
(10/09/2009) How to access internet from wireless router to toshiba laptop(10/08/2009) How to share the internet connection by two computers without using router
(10/08/2009) What year is computer started?(10/09/2009) Netgear Wireless Router Connection Issue
(10/10/2009) Should the firewall/router be the dhcp or should the modem be dhcp(10/06/2009) Port 3389
(10/06/2009) I can't find the answer(10/05/2009) Advantages of using router than switch
(10/04/2009) Guest Access Prob..Connect Belkin N1 Vision to Belkin N+ Gateway(10/02/2009) Dl 624 router
(10/03/2009) Cannot connect Adsl modem wtih wifi router.(10/02/2009) Computer Independent Networked External HDD
(10/01/2009) Wireless Router and AT&T Modem(09/30/2009) Multiple ethernet port configuration
(09/28/2009) Added linksys befsr41 router: have internet but no lan(09/27/2009) Sonicwall pro 200 netgear router and some confusion
(10/01/2009) Slow download speed on single network computer(09/28/2009) Not sure if its the network or the computer
(09/24/2009) Low siganal strength coming from router(09/24/2009) Cable broadband router/switch
(09/25/2009) Cable router/switch(09/23/2009) Computer network classification
(09/21/2009) Netgear /DG834Bv3 dsl modem/router(09/20/2009) Belkin router query
(10/09/2009) No more connections can be made to this remote computer at this time b(09/21/2009) Do I need a Firewall when I use a router?
(09/18/2009) Using windows server 2008 as a router(09/19/2009) Computer no longer connecting to router.
(09/17/2009) Router/switch problem(09/17/2009) 2 internet connection in one router
(09/22/2009) 2 internet connection in 1 router(09/18/2009) Using a router as a wireless adapter?
(09/20/2009) Best cheap router?(09/16/2009) LAN speed slow unless through router?!
(09/17/2009) Basic question about wireless router(09/16/2009) My LAN port lights are not blinking
(09/15/2009) Network diagram broadban to switch to router to switch to router(09/16/2009) How do you connect 3 computers to a router connected to the modem?
(09/13/2009) How to convert AnyDATA AWR 500-A wifi router into switch(09/12/2009) ATT DSL Service with Linksys WRT54G Router
(09/11/2009) Setup VPN for FVS318V3 with WAN port on a privet ip address(09/11/2009) Port forwarding sonicwall tz 210
(09/12/2009) Install dlink wbr-2310 without wired connection(09/12/2009) Sonicwall tz 210 port forwarding
(09/17/2009) Can't port forward some ports, getting desperate :((09/10/2009) Small business wifi router for voip and LAN traffic
(09/14/2009) Router keeps on freezing my browser page(09/10/2009) I have cox internet and a router need to hook up all my laptops in the house
(10/01/2009) Computer to computer(09/10/2009) Some sites wont load without using a proxy
(09/08/2009) How can i setup Port Forwarding behind a wireless gateway?(09/18/2009) Best router for gaming and wifi N?
(09/04/2009) Can I secure 2 ports on an 8 port shared router?(09/03/2009) 2 separate networks on 1 computer
(09/03/2009) Good business grade router for under $500.(09/02/2009) Now that I tried to install a new router my computers are all screwy!
(09/01/2009) SMC barricade router blocking access to printer on LAN(09/02/2009) Netgear router FVS318 & speed limitations
(09/21/2009) Bizarre Network issue. Can no logner connect properly to router(s)(08/31/2009) Connecting a Wireless router to a modem/Wireless router, Help!
(09/13/2009) 2Wire Router/Modem and 24 port switch?(08/30/2009) New computer possibly causeing internet to drop out
(09/08/2009) What is port(08/27/2009) Router and switch
(08/28/2009) Router question(09/14/2009) What Router should I get ?
(08/25/2009) Gigabyte Port forwarding :((((((08/23/2009) Netgear Router problems
(09/23/2009) ZyXEL P-660HW Series router problem(08/25/2009) NAS + Router
(08/24/2009) New Router troubles(08/19/2009) Can connect through modem, but not through router
(08/21/2009) Remote desktop without interference(08/18/2009) Linksys router stacking under Thomson?
(08/18/2009) Cannot connect to the internet through a router!(08/15/2009) Dual port WAN vs dual port NIC
(08/15/2009) What router to buy for high speed gaming(08/29/2009) Port Forwarding Bountiful BWRG 500
(08/14/2009) Which Cisco Router to choose?(08/29/2009) 25 year old female Chinese college student vs router
(08/11/2009) Weird Networking/Router Problem [SOLVED](08/15/2009) Can I share connection with router and switch?
(08/09/2009) Firewall port problems(08/03/2009) Router Suggestion for NAS
(08/01/2009) Modem and router connection(07/31/2009) My new pc cannot connect to the router
(08/04/2009) New router, bad Xbox Live(07/30/2009) Sam's Club WRT110 Linksys Router Question
(07/29/2009) Trying to port forward(07/29/2009) Home router setup with no modem password
(07/29/2009) New AT&T Supplied Motorola Modem/Linksys Router Connection Problem(07/26/2009) Port forwarding help
(07/25/2009) Modem and Router confusion(07/23/2009) Router slowing internet
(07/18/2009) Belkin Wireless G Router(07/16/2009) Router with Firewall adds 6Mb speed reduction!
(07/15/2009) Sharing files/printer through router + switch(07/15/2009) Router issue
(07/14/2009) Router problem(07/22/2009) Trendnet Router Problem
(07/11/2009) Router Problem(07/07/2009) Internet And Router Problem
(07/06/2009) Netgear router(07/07/2009) Router hardware question
(07/06/2009) Trying to network a Windows ME system with Windows Vista on a router.(07/04/2009) Toshiba router wont connect
(07/13/2009) How to Put DVD/Video on iPod, PSP, Computer, Zune, Xbox (Mac/Windows)(06/28/2009) Lose Router Connection
(07/01/2009) Internet link unstable in Netgear Router(06/27/2009) Dont Ping ICS computer
(06/27/2009) Industrial Rugged GPRS HSUPA VPN Router(06/26/2009) Problems networking with FiOS router
(06/23/2009) Router and Switch Question(06/23/2009) Modem+router or dedicated?
(06/21/2009) 2 computers, 1 modem, cannot find server(06/18/2009) Network settings problem? Cant change router with same settings
(06/17/2009) Severe Packet Loss Between Cable Modem and Computer(06/19/2009) 2 Router Set Up - 1 Wired, 1 Wireless
(06/19/2009) Modem+Router+Switch+2 Routers(06/15/2009) Help! Only 1 Computer Can Use Internet on Network - Any Ideas?
(06/16/2009) Problem with lan port on asus mobo(06/15/2009) Booting from lan without server...
(06/11/2009) Can I use this Router as a Modem?(06/15/2009) Video How-To: Linksys Router Setup
(06/15/2009) Port Fowarding Clarification(06/09/2009) Need a rock-solid performance Router for Bittorrent
(06/09/2009) Please help by suggesting a good router(06/10/2009) Best Wired GB router with SPI
(06/04/2009) Computer loses connection to router(06/07/2009) Can access the Router but doesn't have Internet[Wired]
(06/07/2009) Change IP router automatically(06/27/2009) Turning a PC into a Router
(08/22/2009) D-Link DI-524 router "config.bin"(05/28/2009) Building a router, where are the NICs?
(05/26/2009) Router Question?(05/30/2009) Which router to buy
(06/02/2009) Router suggestion for a rigged network...(05/29/2009) Ethernet + Router Problem -- extremely weird -- please help
(05/22/2009) I need a new router that doesn't bottleneck my bandwidth speed(05/14/2009) Connect xp pro notebook through vista pc via pc's 2nd lan port
(05/29/2009) CONTROLLING USB PORT IN A LARGE NETWORK(05/12/2009) Blocking wireless access to single comp on router.
(05/10/2009) New modem or router ?(05/12/2009) 2nd router DSL thru a different phone jack?
(05/01/2009) Netgear CG814WG router question(09/09/2009) Linksys Router & ATT DSL Setup Help Please???
(04/22/2009) How to import music from iPod to iPod without iTunes(04/20/2009) Router capping speeds?
(04/19/2009) Port Forwarding not opening desired ports(05/18/2009) Computer won't start with router on
(04/16/2009) Router Modem and Nic speeds(04/15/2009) Help with setting up a Wifi Router
(04/15/2009) Multihomed Nic and Port Forwarding RRAS(04/18/2009) Wireless router on LAN
(04/14/2009) Problem with WBR-3406TX Router(04/15/2009) Controlling Internet Access via Router Settings
(04/11/2009) Help Choosing A Router(10/10/2009) Can't get wireless Netgear router to work
(04/09/2009) Modem connects to interwebs, router won't let my comp connect!(04/07/2009) Port forwarding for linksys router model befw11s4
(04/21/2009) Computer Will Not Recognize Connection(04/01/2009) LAN Controller without icon
(03/28/2009) Modem to Computer(03/25/2009) Newbie Question - How to setup computer for internet
(03/23/2009) What router should I buy(03/25/2009) 2 Wire Router, how to Firewall wired connections from Wireless?
(03/22/2009) Why can't the modem recognize wired router connection but will work on wireless?(03/22/2009) Need a recommend for a router
(03/17/2009) Unplugged computer on friday, on monday it no longer works(03/17/2009) Router upgrade?
(03/12/2009) Does computer store previous IP addresses?(03/12/2009) Port Forwarding through Cisco 2800
(03/11/2009) Switch from Cable internet to DSL router not working(03/08/2009) MSI RG60G router Help what is SPI etc
(03/10/2009) Get router or use main computer as hub?(03/07/2009) Piggyback Linksys NR041 off DSL 4 port modem
(02/28/2009) Random Request timed out when ping router(02/28/2009) Need Help Choosing A New Router
(02/27/2009) Computer connectivity(03/22/2009) Local network dies if VPN connected on shared files computer
(02/26/2009) Net Send firewall Port for XP2(05/17/2009) Connecting Verizon Fios Router to a Netgear Wireless Router
(02/24/2009) Linksys Router Help(02/24/2009) Got New Router | Confused by DSL Cable Instead of Ethernet
(03/03/2009) LAN connected but not accessible network computer(04/22/2009) D-Link Extreme N Dual Router
(02/12/2009) Unusual Router Problem(02/12/2009) LAN via router problem with two PCs
(02/11/2009) Computer networking(02/16/2009) Laptop connecting to my router disrupts internet
(02/09/2009) Wideview and an 8 port router(02/09/2009) Wideview and 8 port router
(02/07/2009) Linksys WRT54G router and Siemens 4100 bridge mode configuration problem.(02/05/2009) Using router in a college lan
(12/23/2009) Need Router That Routes Multiple External IPs(02/03/2009) How to convert a Wireless B router into a switch?
(02/01/2009) Router to router connection(02/15/2009) How do you connect Router to Router?
(01/27/2009) Traffic getting past closed port.(01/26/2009) Router vs. Switch
(01/24/2009) Router Question(01/22/2009) Computer Temperature App?
(01/22/2009) How can i set up a lan with out a router/server(01/26/2009) Limiting access on a computer to the network
(01/21/2009) Is it the modem or router!(01/22/2009) Ethernet access away from router?
(06/13/2009) RJ45-shaped ADSL Line port? N+ Wireless Modem Router(07/16/2009) Internet Slow Through Router
(01/17/2009) Better Router(01/22/2009) Controlling computer from another
(01/15/2009) What happend to my router? help!(01/20/2009) Gaming and p2p router setup and suggestions
(01/13/2009) Can's see public folder on one network computer(01/13/2009) Router hunting
(01/09/2009) Upgrading circa 2003 computer to gigabit(01/06/2009) Is the DGL-4500 Xtreme N Gaming Router the best router for gaming?
(01/06/2009) What is the best router for p2p and gaming? what to buy?(01/05/2009) Best modem / router
(01/06/2009) I REALLY need some help opening a tcp port... please take a gander >>(01/06/2009) Static IP on computer used wirelessly and wired
(09/20/2009) Why does my wireless on my computer keeps disconnecting...?(12/30/2008) Can't Access BEC 5200S Modem/router
(12/29/2008) Problems replacing wireless router w/ new wireless router(04/20/2009) Is there a wireless router with a category content filtering??
(12/26/2008) Problems renewing ipconfig without router(12/10/2008) Realtek 8111B NIC issues - "Could not find the file specified"
(12/10/2008) remote controlling a computer(12/29/2008) Router + Switch = internet?
(12/03/2008) New Router Suggestions(12/02/2008) D-Link router problem
(10/01/2009) linksys router crashes my connection every time i(11/29/2008) No internet on other computer...PLS HELP:(
(11/23/2008) Linux Router(11/22/2008) IDrive wants access to port 11830
(11/17/2008) Upgrading Router, but to which one?(11/14/2008) Adaptive Port Closing?
(12/19/2008) VPN on Windows 2000 in domainand behid router(11/11/2008) HELP! I can't find the answer
(11/13/2008) Port forwarding comes and goes(03/09/2009) Packet forwarding
(10/31/2008) 1 computer has 30 times faster connection than onter(10/27/2008) What Wireslls Router is best? please help!
(10/22/2008) port forwarding?(10/18/2008) Setting ADSL Internet on a computer + disel TV Details With photo
(10/24/2008) Gigabit router suggestion please(10/13/2008) Limited or no Connectivity on new computer.
(10/12/2008) will a switch improve my router(12/03/2008) My Router Suddenly Closed all the Ports I opened - WTF?
(12/29/2008) P2P brings router to it's knees?(10/01/2008) Question about 1 Router, 1 Network Printer & 2 PCs
(10/01/2008) No LAN on router(09/29/2008) Good router
(09/30/2008) Finding a computer in linear layout(10/09/2008) Port forwarding from behind 2 routers
(09/23/2008) remote control on a linux computer(09/17/2008) gaming router
(09/21/2008) Secure Router / Firewall(09/19/2008) New router - ethernet cables?
(09/19/2008) unstable wireless connection netgear router(10/13/2008) I need a router with a *configurable* 10Mbps Full Duplex WAN port!
(09/14/2008) How to access a PC on a LAN without entering username?(09/19/2008) I built a new computer, and I'm getting horrible ping on TF2
(09/19/2008) Problems with the Linksys WRT54G v2.2 router(10/01/2008) Can a Router slowly fail?
(10/01/2008) how to open port on my router(09/19/2008) What do I need for office router/switch
(09/07/2008) Need help with router(09/06/2008) Do I need to change my router to use Optus ADSL2+?
(09/05/2008) Help connecting new computer to the internet(09/05/2008) New router
(09/06/2008) How to setup DSL router?(01/04/2009) Can't get Linksys router to work with AT&T DSL
(09/06/2008) Bypassing Router Time Restrictions(09/07/2008) need router advice please
(01/17/2009) INTERMITTENT WIRELESS: Netgear router or Dell D620 problem??(08/28/2008) Router recommendation?
(08/20/2008) Computer bringing down the network(08/20/2008) Computer Drops off Workgroup?
(08/20/2008) Newbie trying to setup wireless router,need advice(08/25/2008) Need to password computer on network
(08/19/2008) Is the D-Link DGL-4300 router cable/dsl or adsl?(08/22/2008) Connecting PC-PC and sharing internet without router
(08/30/2008) Hook linksys wireless router and 2 switches to main router(08/13/2008) Chorus/NTL (a UPC company) Cable TV box has an ethernet port
(08/15/2008) ADSL router and PC cabling(08/13/2008) Sp3 Router problem
(08/09/2008) Router gone bad or conditions worsening to blame(08/11/2008) Seting up a restricted computer for small business
(08/04/2008) New Router(08/13/2008) Connect one computer to two routers
(08/23/2008) How do you know what port is free(07/31/2008) Please recomend a Cable modem and router.
(07/30/2008) High ping when router introduced to network(07/30/2008) 2 router port forwarding
(07/29/2008) New Router - Advice needed.(07/27/2008) Need to find a solution to my range problem
(07/24/2008) Linksys RV042 router issue(07/20/2008) Gaming/Torrent Router
(07/18/2008) Which router?(07/18/2008) Router Woes
(07/16/2008) Router not giving a 192 address(07/20/2008) Basic Router Advice Needed
(07/15/2008) Help choosing a router from 4.(08/21/2008) Router to switch to PCs?
(07/10/2008) Looking for new router(07/14/2008) One computer on network no longer connects to the internet.
(12/09/2009) Setup gigabit home network using 100mbps Router but Gigabit switches(07/04/2008) Need advise on a cable router
(07/03/2008) Looking for a new router(06/27/2008) LAN port problem - works fine with adsl modem but not router
(06/26/2008) Help getting my linksys wireless router to work(07/04/2008) Hosting on Modem(Fast) versus Router (Slower) Should I Upgrade Router?
(08/06/2008) Wireless router with print server(06/13/2008) Call forwarding with virtual numbers
(06/21/2008) Very confused as to which router to get!(06/16/2008) How do I set up a network so that the computer I'm on would combine...
(03/16/2009) zoom x6 router help(12/07/2009) Old laptop into linux router
(06/04/2008) Router lag issue(05/31/2008) 2 router configuration issues
(05/30/2008) Port Forwarding through two Routers.(12/05/2009) Problems with router (d-link dir 100)
(06/02/2008) linksys router issue(06/02/2008) Router Advice needed
(05/10/2008) DGL-4500 router and Gamefuel Plz Helpppp(05/12/2008) loose computer on network after 5 hours
(12/17/2009) Two internet connections, 1 router, 1 PC.(05/05/2008) D Link DIR 655/ router check in
(05/04/2008) International conference on computer science and software engineering.(05/01/2008) This stupid computer wont do anything that it needs to with my router
(04/29/2008) philips / Talk takl router sna5630/ns(04/26/2008) Looking for application or router for capping bandwidth
(10/01/2008) Connecting a Wireless Router to My ::ahem:: neighbors WiFi Internet(04/20/2008) networking 2 pcs (via adsl router?)
(04/18/2008) gaming router(04/17/2008) how does ADSL router/switch work?
(04/17/2008) 2 Computers,One without Internet Connection(04/09/2008) Find current Ip adress for used print server
(03/31/2008) Belkin router only allowing max of 2 wired connections!?(03/29/2008) which lower price dual wan router
(03/24/2008) 2Wire DSL Modem/router w/Linksys 4124 switch and Linksys WRT350N(03/24/2008) Need a new reliable wireless router
(03/26/2008) Which router?(03/24/2008) Router Issue
(03/29/2008) Zoom X6 Modem/Router Security Issues(03/16/2008) loss of speed bec of router?
(03/12/2008) How to network share between router a and router b?(09/20/2009) LAN not working, Wireless working fine (D-Link DGL-4300 router)
(03/09/2008) Media Sharing / router problem(03/12/2008) best QOS router for the money.
(03/12/2008) Looking for router that is fast enough for 27,000 kb/s connection(03/12/2008) P2P and gaming router
(03/05/2008) 0 knowledge - need help picking router(02/23/2008) Home network setup problem, one computer wired, one laptop wiress
(10/01/2008) Weird problem with Belkin G wireless router.(02/19/2008) Port forwarding problem
(02/19/2008) Help with Linksys Router.(02/12/2008) Need Help with VNP and Linksys Router
(02/11/2008) need new wifi router or go powerline(02/08/2008) router ip address changed due to modem
(02/06/2008) Adding Wireless Access Point to 2Wire HGV 2700 Router(02/05/2008) Port forwarding does not work!
(12/07/2008) Problem with Lan connection with Telefonica (Spain) ZyXel router(02/01/2008) Need additional ports than what my existing wireless router provides.
(01/31/2008) best wireless router for a wii, 360, ps3(03/12/2008) Dual Ethernet mobo + router question
(01/26/2008) How is a switch different from a router?(01/25/2008) So is it time to replace this POS (Vonage) Linksys wired router?
(01/26/2008) Trying to find date/time webstie was accessed.(02/25/2008) Finding router information
(01/24/2008) Router Dropping connection under heavy load(01/21/2008) lag problem with new wireless router
(01/21/2008) adsl modem + switch no router...(01/19/2008) Cant find Router charts
(01/18/2008) Looking to upgrade to Gigabit, which 5/8 port switch?(01/18/2008) Internet via USB adapter and local network via wired router?
(01/22/2008) Linksys 5 port Hub- Can't connect more than 2 computers to internet(01/17/2008) Please suggest wired router for Vista
(01/15/2008) Can I plug a wireless router into a wired router?(01/15/2008) Router Troubleshooting Issue
(01/15/2008) need help turning Linksys WRT54G into a bridge router(12/28/2007) Media Sharing (Xbox 360/Computer problem?)
(01/04/2008) Strange problem with router Belkin(12/25/2007) Connecting two PC and a Router Local Network
(01/12/2008) Remote Access to my other computer(12/21/2007) Looking for a cheap reliable router
(12/26/2007) Public FTP access to my computer(12/26/2007) Odd behavior with port forwarding
(12/19/2007) Att 2210 modem wont connect to linksys befsr41 router(12/06/2007) configure router d-link di624, unknown address
(12/11/2007) Can you do HTTPS over an alternate port?(12/04/2007) Router: D-Link DGL-4300 Please Help
(11/29/2007) Stable router that can handle BT(11/29/2007) Which wireless router should i get for my laptop?
(11/28/2007) Router - Firewall blocking stuff(11/27/2007) Aztech DSL600ER Router
(12/03/2007) setting up xbox 360 through the second ethernet port on my mobo help?(12/03/2008) Connecting Ethernet Crashes Computer
(08/17/2009) Netgear FVG318 router blocking (some) outgoing FTP(11/26/2007) router or router+switch
(11/21/2007) Router or Switch ?(11/21/2007) mouse/computer stutters when internet loads?
(11/16/2007) Linux Home Server Behind FIOS Router | No Joy(11/15/2007) Did anyone use/try the router Asus WL-500g Premium?
(11/16/2007) do i need a router?(11/15/2007) Looking for a firewall/router with full featured NAT
(06/10/2009) Need assistance choosing a replacement router on Verizon FIOS(11/10/2007) One router, two 'puters, two speeds - HIS n HERS
(11/12/2007) WNR854T router reboots itself on settings update(11/08/2007) my connection dies suddenly behind a router
(11/07/2007) Help! Why wont my Router Talk to my Switch??(09/13/2009) Belkin F5D7230-4 v2000 router stalls when browsing Google Maps
(10/28/2007) Netopia R910: Router -to-Router VPN, Can't PING Remote LAN(10/24/2007) Best ADSL2 Wireless Router
(10/22/2007) After log in the computer ignores all input for 30 minutes...(10/20/2007) Problem with connecting Xbox 360 to computer with a switch
(11/22/2007) cant print on vista's printer from xp computer(09/28/2009) using a dsl router with a cable modem
(10/05/2007) Router Blew Out, Some Computers Connect Through Switch But Not All(09/30/2007) Installing NAT & Firewall behind ADSL Router
(09/25/2007) router slowing int(09/22/2007) i just bought a router... now i have downloading issues
(09/21/2007) Does using a router to split the internet to 2 computers slow it down?(09/20/2007) DSL With Router and switch?
(09/15/2007) find your voip devices here and give you best advice(09/14/2007) Need a new router, g or n? newb-ish
(09/14/2007) Daisy Chaing Router for VoIP(09/16/2007) Sound forwarding ?
(09/13/2007) server behind a university router(10/12/2007) How, exactly, do I connect my 2nd router (D-Link DI-624) to my first
(09/04/2007) Router can't sign in MSN Messenger(10/12/2007) Connecting 2 PCs on 1 router
(09/04/2007) urgent Router help(09/04/2007) What is port 24413?
Sponsored links
