| (11/28/2009) Can router be used as adapter? | (11/28/2009) Computer doesn't recognize anymore hardware wireless adapter DWL-520 |
| (11/27/2009) Removing the antenna on belkin router | (11/25/2009) Will the belkin wireless G router work with AT&T? |
| (11/24/2009) Belkin drama | (11/22/2009) Can i use a usb adapter without the router |
| (11/20/2009) HP G50-126NR Wireless Mini-PCI 802.11b/g/n adapter??? | (11/21/2009) If I have a N router do I need a N adapter to pick up wirless |
| (11/19/2009) Linksys wireless usb adapter G | (11/19/2009) Best wireless-n adapter for windows 7 64 bit OS |
| (11/18/2009) Can windows 7 use WEP security for Belkin | (11/17/2009) What is the best wireless ethernet adapter out there dollar for dollar? |
| (11/26/2009) WARNING - Realtek RTL 8185 54M Wireless LAN Network Adapter | (11/16/2009) Netgear modem/router & Belkin G-Mimo dongle disconnects. |
| (11/12/2009) Windows XP, Netgear modem router, Belkin G mimo usb adapter | (11/09/2009) Dlink G520 wireless adapter does NOT work with Windows 7 |
| (11/08/2009) Onboard wireless adapter doens't show up in Dev Mgr | (11/08/2009) Wifi adapter loads CPU |
| (11/06/2009) Wireless adapter driver conflict | (11/04/2009) Belkin KVM and windows 7 |
| (11/02/2009) Best wireless adapter for gaming | (11/01/2009) Config wrt54G_V2 with MS xbox wireless adapter |
| (10/31/2009) Belkin g wireless router setup now no desktop connection | (10/31/2009) Gaming adapter to extend wireless network (internet) to 2 or more PCs? |
| (10/26/2009) Belkin wireless G router | (10/30/2009) USB Adapter for a Desktop running Windows 7 |
| (10/25/2009) Windows 7 adapter | (11/17/2009) Looking for windows 7 64 bit wireless adapter |
| (10/22/2009) Belkin F5D7230 WAP as wireless bridge | (10/22/2009) Belkin connection |
| (10/20/2009) Any suggestions for wireless adapter for my Vista 64 machine? | (10/19/2009) USB Wireless Adapter Help |
| (10/10/2009) Installing wireless adapter on Backtrack 3 | (10/07/2009) Routers based on Atheros chipset |
| (10/01/2009) Need Windows 7 (64-bit) 802.11n Wireless Adapter | (09/26/2009) My netgear ma101 adapter will not connect to Belkin N+ router |
| (09/26/2009) How to load usb ethernet adapter into windows 98 | (09/25/2009) Best wireless usb adapter |
| (09/23/2009) Wireless Adapter problem | (11/13/2009) Windows 7 64bit compatible wireless adapter>> |
| (09/17/2009) Belkin usb wi-fi driver for xp 64 bit | (09/16/2009) Using a router as a wireless adapter? |
| (09/19/2009) Belkin Router = fail? | (09/12/2009) How to enable wireless adapter mac(Iatkos) |
| (09/10/2009) Wireless G USB Adapter Help | (09/01/2009) Belking wirerless g network adapter problem |
| (08/31/2009) I need help with a Wireless adapter driver | (08/31/2009) How do I know if my integrated intel (G) adapter has MIMO? |
| (08/31/2009) Wireless Adapter Check | (08/31/2009) Best wireless G adapter for range |
| (10/25/2009) Laptop b/g wi-fi adapter work with n router | (08/30/2009) Will upgrade from G to N adapter increase G reception range? |
| (10/21/2009) USB or ExpressCard wireless adapter? | (08/30/2009) P5w dh wireless adapter |
| (08/26/2009) Internal Ethernet Adapter or Standalone Router | (11/01/2009) A good wireless pci adapter that works with 64 bit OS? |
| (08/25/2009) New build: Network Adapter choice | (08/23/2009) Pci wireless n cards!are they any good |
| (09/30/2009) Wireless network adapter not recognized in w7 HELP!!! | (08/15/2009) Nintendo dsi internet setup with wireless usb adapter |
| (08/11/2009) Using wireless gaming adapter in my wireless network | (07/29/2009) Belkin Bluetooth USB adapter. Error 87: parameter is incorrect |
| (07/28/2009) Can i connect a belkin router to a linksys? | (07/26/2009) Buying a new router and adapter TODAY |
| (07/23/2009) Need advice on upgrading wireless router with adapter | (07/19/2009) Windows 7 / Vista x64 Wireless NIC - PCI |
| (07/16/2009) Is there a performance difference between USB & PCI based wifi modules | (07/16/2009) Wireless Adapter Question |
| (07/12/2009) Network w/ 2 PCI cards? | (07/09/2009) Mn520 wireless adapter driver |
| (07/08/2009) Quality wireless adapter for Vista 64bit | (06/29/2009) Problems with wireless adapter |
| (06/26/2009) PCI Wireless N + AP/Monitor Mode? | (06/23/2009) Wireless adapter with the dlink dir-655 |
| (06/18/2009) Two Belkin F5D7230-4 routers and Wireless Bridge | (11/13/2009) Wireless N adapter to wireless G router? |
| (06/09/2009) PCI vs. USB / Recommended Desktop Solution | (06/16/2009) Decent Wireless Adapter for Gaming |
| (06/07/2009) Strange Belkin wireless problem... | (10/13/2009) Wireless LAN adapter problem with Vista 64-bit OS |
| (06/04/2009) Bluetooth PCI card for desktop system (bluetooth only card) ?? | (05/28/2009) MN-520 Wireless Notebook Adapter |
| (06/09/2009) What PCi card is best for me?? | (05/25/2009) Need a Wireless PC Adapter |
| (05/29/2009) Best solution for low signal (USB or PCI) | (05/24/2009) Belkin g wireless route |
| (05/11/2009) Wireless adapter for gaming pc | (05/13/2009) Best Wireless N Adapter |
| (05/09/2009) Can this computor pick up wireless internet from my modem? or should i go buy a | (05/10/2009) PCI Wireless adapter |
| (05/11/2009) Using a USB adapter w/SMA antenna | (05/06/2009) Better range - USB or PCI? |
| (04/29/2009) Belkin 64 bit drivers | (05/02/2009) Belkin wirless g firewall |
| (04/24/2009) Net adapter driver probs | (04/21/2009) Belkin 64 Bit Drivers for f5d7231-4 |
| (04/14/2009) Can You Recommend a Good Vista 64 Bit Network Adapter Please? | (04/11/2009) WPA2 adapter with WPA router |
| (04/10/2009) Overclocking linksys WUSB100 adapter | (04/10/2009) Wireless Network Adapter Inop in Non-Admin Acct |
| (04/02/2009) Wireless adapter for the xbox360 | (03/29/2009) Need rec for wireless adapter for Windows 7/Vista OS |
| (03/26/2009) Does a Wireless N Adapter's extended range apply to G networks? | (03/23/2009) Laptop Wireless adapter |
| (03/10/2009) Network Adapter that works with Vista 64? | (03/04/2009) Wlan USB stick or a PCI extension card? |
| (03/04/2009) Belkin F5D7632-4 problem. | (02/28/2009) HP Pavilion F70 and Belkin Nimo G Wireless |
| (02/28/2009) Belkin Wireless Network Adapter Setup | (02/19/2009) Remote access via 1394 connection/net adapter |
| (02/20/2009) WUSB54GC wireless USB adapter drops connection | (02/12/2009) Best Wireless Adapter for My Needs |
| (02/12/2009) Wireless USB-N adapter for gaming | (02/10/2009) Access Point or Powerline adapter? |
| (02/08/2009) DWL-650+ Adapter with DI-628 Router | (02/05/2009) Belkin N1 Vision and N1 adapter 2.5MB/s Blunder |
| (02/27/2009) Im using a wireless belkin connector and now its not working... | (02/09/2009) What wireless adapter (PCI-E or USB) would you recommend? |
| (01/30/2009) Windows 7 Doesn't Detect Wireless Adapter | (02/10/2009) Wireless N adapter and G router |
| (01/02/2009) What is the best Wireless G adapter (PCI or USB... whichever is better | (12/30/2008) GAMING with Wirless PCI Card |
| (12/30/2008) Best Wireless-G Adapter for gaming HELP!!! | (12/24/2008) Code 10+28 device cannot start wireless adapter vista |
| (12/14/2008) Belkin 54 g | (12/06/2008) Best Wireless "N" Mini PCI |
| (11/28/2008) Upgrade PCI card vs Network Repeater-Help Please | (12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients |
| (11/22/2008) WDA 2320 PCI adapter not connecting | (11/21/2008) Belkin Wireless G+ MIMO Wireless Adapter Not Finding Wireless Network |
| (12/17/2008) Belkin F5D9050 | (07/09/2009) Vista wireless slow, same adapter on XP is fast! |
| (10/29/2008) wmp54gs wireless adapter - excellent signal, speed fluctuates | (10/26/2008) tried installing over and over..usb adapter won't connect! help |
| (10/08/2008) Desktop Gaming Wireless Adapter | (05/21/2009) Best Wireless Adapter for Vista x64 Ultimate? |
| (09/20/2008) USB Adapter or PCI CARD For Wireless | (09/17/2008) Best PCI card for the buck? |
| (09/07/2008) Better Antenna or New Adapter? | (08/27/2008) strange wireless adapter problem |
| (09/22/2008) What Wireless PCI Card? | (08/25/2008) Windows Vista 64bit compatible PCI network cards |
| (10/12/2008) Best USB Wireless adapter? | (10/10/2008) Linksys wireless usb adapter not connecting to my Linksys wireless Rou |
| (08/04/2008) Desktop Wireless Adapter with Integrated Bluetooth? | (07/26/2008) Belkin F5D7632 |
| (07/24/2008) Router and adapter reccomendations | (07/23/2008) Wireless Adapter Unstable? |
| (07/22/2008) Wireless-G network adapter work with Wireless N router | (07/26/2009) Whats the best wireless adapter for a desktop? |
| (07/13/2008) Wireless Adapter Overheating? | (12/14/2008) Rosewill PCI Wireless adapter RNX-G300(E) Driver Issue Fix for Vista |
| (07/08/2008) intersil PRISM LAN PCI connection problems! | (08/01/2008) Belkin F5D8053 wont connect to any wifi |
| (06/21/2008) Overheating issue with Belkin wireless USB adapter | (06/13/2008) PCI Card That Supports 802.11n 5Ghz? |
| (05/29/2008) USb or PCI card? | (05/23/2008) wusb54g wireless adapter bsod |
| (05/22/2008) vista x64 compatable wireless adapter | (05/14/2008) Can't connect to internet via wireless adapter |
| (05/07/2008) Looking for a new Wireless Adapter or QuickFix | (10/10/2009) D-Link DWL-G122 wireless adapter |
| (05/02/2008) USB Wireless Adapter concentrate signal | (09/26/2008) Belkin Wireless G-MIMO and Cable Internet |
| (05/27/2008) wireless PCI adapter not recognized | (05/09/2008) Looking for USB 802.11N network adapter |
| (04/16/2008) Wireless PCI or USB adapter for vist x64 | (03/26/2008) Belkin USB Wireless Adapter |
| (03/08/2008) replace network card in belkin pre-n desktop adapter | (03/14/2008) help cant find a wireless network adapter |
| (07/14/2008) Belkin Wireless G PCI Problems | (08/26/2009) Internal wireless adapter disappeared after XP reinstall |
| (01/26/2008) Any network sniffer to use with Netgear WN121T USB adapter? | (01/28/2008) Wierd wireless PCI card problem |
| (01/02/2008) Belkin Wireless Router (G+ MIMO) and Windows 98SE | (12/15/2007) Local Only - Vista Usb Adapter Problem !!!! |
| (12/06/2007) buffalo wireless g high gain wli u2 sg54hg usb 2 adapter | (12/03/2007) Belkin N1 or Netgear RangeMax ? |
| (11/26/2007) Wireless adapter for vista? | (11/21/2007) Is this interference? Or just a crappy router/PCI card? |
| (10/02/2007) Intel Pro 3945 ABG Wireless Mini PCI Express Card Opinions | (09/24/2007) Accton WN4201B (Wireless PCI Card Issues! HALP!) |
| (09/07/2009) limited or no connectivity belkin wireless G router | (08/26/2007) Belkin N Wireless USB adapter poor strength |
| (07/23/2007) Can someone recommend good wireless adapter? | (07/19/2007) Netgear wireless adapter causing 100% cpu spikes..and other things. |
| (07/12/2007) Best Apartment Adapter!? | (06/19/2007) Wireless PCI card /USB LAN adaptor |
| (08/08/2007) Windows 2000, Atheros ar5211.sys, and AR5005G chipset | (06/13/2007) belkin problem |
| (06/02/2007) ZyXEL NWD170N wireless adapter + ZyXEL NBG415N wireless rout | (05/16/2007) Weird problem with Belkin PCI card |
| (03/28/2007) Belken Wireless G USB Network Adapter | (07/16/2009) XBox 360 Question(Can you use any USB adapter) |
| (03/16/2007) Wireless PCI card. | (03/10/2007) Dlink DIR-655 Router,Pci Card DWA-552 Problem. |
| (03/09/2007) Belkin adapter connects only to router, any advice? | (02/05/2007) Setting up wireless network with my belkin F5D7632-4 (54g) |
| (02/06/2007) Wi-Fi Nic with external antenna adapter recomendations | (01/16/2007) Belkin Wireless Network |
| (01/08/2007) USB wireless adapter issues at startup | (12/31/2006) PCI Wireless network card issues |
| (12/26/2006) a few domains cant be obtained with belkin wireless router | (12/11/2006) Belkin G+ Mimo Lag Problem |
| (11/28/2006) Is there a way to eneble ICS on a PCI wireless card? | (11/16/2006) US Robotics 5421 usb wireless adapter |
| (03/16/2009) Linksys WGA54G Game Adapter / Bridge - Device is garbage?? | (11/17/2006) Reccomended Wireless PCI card? |
| (11/03/2006) Help me choose router and network adapter, please! | (11/27/2006) "Wi-Fire" Adapter; any input fm ACTUAL users? |
| (12/12/2006) Belkin Issues | (10/20/2006) Problem with Belkin 7011 wireless card |
| (10/17/2006) Question about Belkin High Speed Wireless router F5d7231df4 | (10/03/2006) Belkin N-1 network card for xp laptop |
| (09/18/2006) usb wifi adapter drops to 1mbs when connected in bridge!? | (09/15/2006) usb wifi adapter drops to 1mbs when connected in bridge!? |
| (08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help | (10/13/2009) WEP and Belkin F5D 8231-4 N |
| (08/06/2006) Win98se can't find files when loading Wireless PCI card | (08/22/2006) Help me choose router/network adapter, please! |
| (07/08/2006) Long range wireless adapter | (09/10/2006) USB 1.1 adapter enough? |
| (06/02/2006) Belkin login error | (03/17/2009) Belkin Wireless USB Antenna |
| (05/20/2006) Adapter with 64-bit drivers | (05/24/2006) PCI WiFi question |
| (05/02/2006) Belkin Modem Router won't allocate DHCP foe wireless | (04/25/2006) Wireless Instability with Pre-N Belkin |
| (03/11/2006) PCI Wireless card with Auditor SC | (03/14/2006) which is bettter usb or pci? wich brand belkin or netgear? |
| (05/25/2006) Which router and Adapter should I buy???(for restaurant use) | (01/01/2009) USB wireless adapter drops connection |
| (09/13/2005) Attaching antenna to Belkin 802.11g PCMCIA card | (08/15/2005) Problems with WPA-PSK and Belkin F5D7632uk4 adsl router |
| (05/13/2004) Wireless PCI adapter for GNU/Linux | (09/24/2005) Belkin Wireless Network Access Point (F5D6130) |
| (05/05/2009) problem with linksys wmp11 PCi wireless networking adapter. | (12/27/2005) belkin dmz not working |
| (09/29/2005) Belkin Wireless Router PSU failures | (09/28/2005) Belkin F5D7050 ver.2011 Wireless G USB Adapter Hardware Is.. |
| (09/23/2005) SMC 2802 Wireless PCI Card | (04/03/2004) Netgear DG834G vs. Toshiba Mini Wireless PCI Card - Please.. |
| (04/01/2004) Belkin wireless PC Card | (02/09/2006) how to change WEP password on SMC PCI card? |
| (09/26/2005) Netgear Wireless adapter with Apple iBook | (09/26/2005) usb adapter cantenna |
| (01/14/2006) xbox wireless adapter recommendations | (09/17/2005) Linux newbie help - USB adapter |
| (01/29/2006) Belkin Wireless Issues: Connected, but not really | (02/05/2006) USB Wireless adapter makes my WinXP "deep sleep" |
| (06/03/2009) Problem: Linksys adapter not working with D-Link router | (09/26/2005) Error0x80040707 for wireless PCI card installation |
| (09/20/2005) Belkin wireless network | (09/19/2005) Periodically losing TCP connection through wireless adapter |
| (09/15/2005) Bluetooth Adapter | (09/13/2005) How do you set up a Belkin Ethernet Bridge to allow wirele.. |
| (09/10/2005) SMC wireless adapter USB or PCMCIA? | (09/05/2005) Bluetooth Flash Adapter That Windows XP Auto-Recognizes? |
| (08/29/2005) Quirky internet access with wireless adapter | (08/14/2005) Adding another Pc using a wireless USB adapter |
| (08/13/2005) D-Link DWL-G820 Wireless Gaming adapter | (08/24/2005) Driver/Wizard for Wireless Notebook Adapter MN-520 |
| (08/03/2005) Windows 2000 and Wireless PCI NIC | (08/02/2005) Belkin Installation Problem |
| (08/01/2005) WinMe adapter recommendations? | (07/27/2005) adapter is connected but internet not available |
| (07/25/2005) Upgrade to WinXP SP2 causes loss of USB adapter wireless c.. | (07/18/2005) Linksys Usb wireless B Network adapter |
| (07/12/2005) trouble with WPC54gs adapter | (07/10/2005) Problem installing wireless USB Adapter |
| (07/04/2005) Wireless adapter recognized as network controller ... | (06/27/2005) Not able to disable network adapter during repair |
| (06/30/2005) Wireless adapter purchase | (06/23/2005) Belkin wireless network XP 64 bit drivers required |
| (06/18/2005) PreN and G+ Chipset Compatibility | (06/14/2005) Latest WIndows Update for Wireless-G PCI Adapter Broken? |
| (06/12/2005) I can't install the software that came with my Belkin Netw.. | (06/05/2005) Installing a pci adapter - please help |
| (05/25/2005) Belkin wireless f7000 wont connect to router | (05/11/2005) D-Link wireless PCI adapter problems |
| (05/10/2005) Wireless LAN USB adapter | (05/03/2005) Belkin 125Mbps Router |
| (04/26/2005) possible to disable/enable wireless network adapter via co.. | (04/26/2005) Belkin wireless desktop card |
| (04/25/2005) Wireless 54G USB Adapter question | (04/19/2005) Problems with wireless router and adapter |
| (04/19/2005) Unable to Browse Network w/Netgear wireless adapter | (04/03/2005) Belkin wireless card causes XP to freeze |
| (03/30/2005) Wireless Belkin network problem | (03/31/2005) Problem accessing Belkin modem/router settings |
| (03/26/2005) slower wireless adapter connection on XP | (03/17/2005) Wireless desktop PCI card wont connect to wireless network |
| (03/08/2005) How do I login to domain with USB network adapter? | (03/07/2005) Wireless adapter picks up newly found network... |
| (03/03/2005) having trouble with your PCI wireless card losing connecti.. | (02/21/2005) Wireless Notebook Adapter - Linksys PCMCIA adapter Error E.. |
| (02/20/2005) Belkin 802.11G. | (02/18/2005) WAP and Win2000 w/ Linksys WMP54GS PCI card |
| (02/15/2005) New computer wireless PCI adapter setup mistake recovery | (02/15/2005) Belkin High Speed Wireless G Router |
| (02/03/2005) Range on a pair of Belkin 54G routers in wireless bridge m.. | (01/27/2005) Wireless PCI card & video driver corruption |
| (01/24/2005) Can't connect wired linksys lan to wireless belkin lan | (01/25/2005) Getting WPA to work using Netgear WG511T adapter on Window.. |
| (01/23/2005) PC to TV and Stereo Receiver via Wireless Router and Adapter | (01/10/2005) Which Access Point Device to Buy? USB Adapter? |
| (01/10/2005) Cisco AIR-MP20B PCI wireless notebook card - software needed | (01/13/2005) WPC54G wireless notebook adapter |
| (01/06/2005) USB Bluetooth adapter not working | (01/04/2005) slow Edimax WLAN USB Adapter |
| (12/30/2004) Belkin WIFI Card | (12/29/2004) mn-510 wireless adapter won't function after rebooting |
| (12/23/2004) Repost: D-Link wireless PCI needs rescan every boot | (12/22/2004) D-Link wireless PCI needs rescan every boot |
| (12/19/2004) Win XP wireless network adapter gets released and then con.. | (12/20/2004) Wireless adapter does not search for networks |
| (12/13/2004) Wireless Adapter Seems Capped at 1300 MTU | (12/09/2004) Belkin ADSL wireless router |
| (12/07/2004) How do I choose which adapter to use for Internet access? | (12/04/2004) BELKIN WIRELESS PCI NETWORK ADAPTER F5D6000 |
| (12/03/2004) belkin USB tendency to connect to neighbor's router?! | (12/02/2004) Using a spare laptop wireless LAN adapter |
| (12/01/2004) Belkin Wireless Network Problems | (11/16/2004) usb adapter |
| (11/23/2004) BELKIN WIRELESS 54g | (11/03/2004) belkin 54g always works on 11 Mbps |
| (10/30/2004) Linksys Wireless B Adapter: Connectivity | (11/09/2009) Toshiba Wireless LAN Mini PCI card & WPA |
| (09/26/2004) how to rebind network adapter? | (09/26/2004) Using a PC Card on PC with PCI Adapter |
| (10/10/2004) Netgear 11g 108 mbps PCI Card | (12/19/2004) Service pack 2 - wireless adapter unable to connect DHCP |
| (09/17/2004) PCI interface or USB interface | (09/07/2004) cannot connect to default gateway with netgear usb adapter |
| (09/04/2004) xp and linksys pci adapter | (09/04/2004) Belkin USB Wireless Network Device/ XP SP1&2 - Not working |
| (08/23/2004) router and usb adapter question | (08/13/2004) WLAN USB Adapter w. Win2k - Error Code 10 |
| (08/10/2004) USB 802.11g wireless adapter | (08/04/2004) MN-500 Wireless Base Station and MN-510 Wireless Adapter |
| (07/27/2004) Connecting a non-btvoyager adapter! | (07/15/2004) mn710 wireless usb adapter - preamble |
| (06/19/2004) Belkin access point and 54g pci card for online gaming? | (06/18/2004) Wireless Adapter and WAP |
| (06/08/2004) SBS2003 and Belkin Wireless router/access point | (05/10/2004) Windows 95 Network Adapter |
| (05/09/2004) Belkin Support | (05/08/2004) Belkin Wireless Networking |
| (06/02/2004) Wireless Network adapter disabled... | (05/04/2004) installing 54g wireless network adapter |
| (05/03/2004) installation of 54g wireless network adapter | (06/07/2004) XP crash related to Netgear adapter? |
| (04/30/2004) Belkin F5D7130 | (04/23/2004) problems installing wireless network adapter to dektop... |
| (08/08/2004) Driver for ZyDas wireless (ZD1201) IEEE 802.11b USB Adapter | (04/17/2004) intersil prism wireless Lan PCI card for Fujitsu c series |
| (09/13/2005) My 3Com USB Adapter is very hot! Could it be overheating? | (09/12/2005) Belkin and ADSL line upgrade to 1mb |
| (11/10/2009) Belkin router - turn off wireless? | (09/10/2005) Belkin wireless DHCP problem - 'limited or no connectivity' |
| (09/08/2005) Mini PCI wireless NIC question | (09/05/2005) Belkin router recovery to factory default? |
| (09/04/2005) belkin 54g router | (09/02/2005) Router used as a wireless adapter |
| (08/31/2005) Anyone try Powerline adapter for Ethernet from Corinex? AV.. | (08/30/2005) Choice of wireless adapter: Netgear or Linksys, USB or PCI.. |
| (08/17/2005) Wireless G PCI Adapter 54MPBS 2.4GHz works in Europe? | (01/21/2005) Setup Belkin 802.11g Wireless card with Bigpond ADSL Kit? |
| (01/08/2005) A Belkin Pre-N router with Belkin Pre-N PCMCIA card : Ques.. | (01/20/2005) Belkin Pre-N Router Problem - Continued |
| (01/05/2005) Compatibility issues between wg511v2 and Belkin Pre_N Wire.. | (01/04/2005) problem with Linksys WAP11 AP and WPC54G adapter |
| (01/03/2005) PCI Card Reader? | (01/03/2005) Belkin Pre-N Question |
| (01/03/2005) Hawking Hi-Gain USB Wireless-G Adapter Model: HWU54D | (01/01/2005) wireless PCI card won't connect |
| (12/31/2004) Any recommendations for a USB adapter? | (12/30/2004) Need to Confirm Power Adapter for SMC 7004AWBR |
| (12/28/2004) What Best USB 54G Adapter for a Desktop? | (12/28/2004) Looking for a stronger wireless network USB adapter... |
| (12/27/2004) Any tried the Belkin pre-N router ? | (01/01/2005) Linksys Wireless Adapter Auto-Connect |
| (12/28/2004) Repost: D-LInk wireless PCI needs rescan every log on | (12/26/2004) Belkin F5D7230-4 wireless router problem |
| (12/24/2004) reset access point belkin | (12/22/2004) D-Link wireless PCI needs rescan every boot |
| (03/01/2005) Problem with new Belkin Pre-N router | (12/05/2004) AT&T 6500G 802.11g adapter |
| (12/02/2004) Whats a really good 802.11g USB adapter? | (12/02/2004) FS: UK Lurker selling 3com PCI wifi cards cheap on ebay |
| (12/01/2004) Any way to extend range of internal wireless PCI card in PC? | (12/01/2004) Belkin Wireless Network Problem |
| (11/26/2004) Belkin Wireless G USB Adapter doesn't go faster than 11Mbps | (11/16/2004) replace "non-removable" antennas - Belkin router? |
| (12/21/2004) Belkin 54g PCI and windows xp sp2 | (11/17/2004) Internal vs external 802.11g adapter |
| (11/11/2004) WEP Failing With Belkin 7230. WPA Works? | (11/11/2004) I opened my USB 802.11b adapter - help me locate the anten.. |
| (11/09/2004) Dlink DI-824VUP+ and Belkin F5D6020 ver2 | (11/02/2004) Anyone buy, try and use the Belkin 802.11n (pre) Wireless .. |
| (11/26/2004) WLan USB adapter cannot find router | (10/30/2004) Belkin Cable/DSL Gateway Router 802.11b need the best Wire.. |
| (10/30/2004) Belkin Cable/DSL Gateway Router 802.11b need the best Wire.. | (10/27/2004) belkin wireless router, Belkin F5D7230-4 |
| (11/15/2004) Anyone know if Belkin Pre-n router offers advantage to peo.. | (10/27/2004) Belkin Pre-802.11n Access Point and client cards |
| (10/22/2004) Attaching External Antenna to Belkin F5D7130 Access Point? | (10/21/2004) Recommendation for a Wireless adapter for Win 98 1st |
| (10/31/2004) Belkin desktop wireless card problem | (10/14/2004) Netgear MR814v2 to Belkin F5D7130, bridge problem |
| (10/12/2004) Realtek 8180 PCI cards losing wireless connection | (10/14/2004) Belkin Bridging |
| (10/06/2004) Powerline adapter availability / experience? | (10/03/2004) Wireless PCI card not finding any signal from SMC 2804 WBR.. |
| (09/26/2004) Opinions on this Belkin WPS with HP LaserJet 2300 | (09/23/2004) How to make belkin router work as relay (bridge?) |
| (09/21/2004) Nforce2+PCI ->PCMCIA Adapter + Orinoco=problem? | (09/19/2004) Dell C640 with integrated TrueMobile 1150 WLAN mini PCI card |
| (09/14/2004) linksys and belkin compatibility | (09/13/2004) HOWTO: enable WPA-PSK in Windows for SMC2802W V.2 PCI card |
| (09/10/2004) DHCP on Belkin F5D7630 | (09/07/2004) Belkin F5D 7630-4A keeps dropping connection BT broadband .. |
| (09/07/2004) Belkin wireless router | (09/05/2004) Opinions / Advice - Orinoco Silver and Belkin External F5D.. |
| (08/29/2004) bad wireless adapter. | (08/28/2004) WMP54G wireless PCI card on WIn98SE ? |
| (08/27/2004) Belkin 7630 - How to access hidden menus.. | (08/26/2004) it's OK, but backup : Belkin wireless ADSL - new firmware! |
| (08/25/2004) Strange MAC address on Belkin AP | (08/25/2004) Belkin : Am I Being Cracked ? Possible Exploit? |
| (08/23/2004) Belkin wireless routers 7230 and 7231 | (08/25/2004) Belkin wireless ADSL - new firmware! |
| (08/23/2004) Driver: linksys USB adapter wusb54g | (08/31/2004) Belkin wireless route - power supply requirements. 5v - to.. |
| (07/23/2008) Belkin F5D7230-4 as an Access Point/Bridge.... | (08/15/2004) wireless pci adapter? |
| (08/10/2004) Belkin AP to clientAP/bridge | (08/10/2004) 802.11b or g adapter for Win 98 laptop? |
| (08/14/2004) wanted USB WiFi adapter | (08/05/2004) Can't get wireless adapter to see internet |
| (08/08/2004) Wireless-G PCI Adapter with WPA | (08/07/2004) Belkin F5D7630uk4A Problems |
| (08/06/2004) Didn't Unplug/Eject PCI card, now it won't work. | (07/29/2004) How to Increase Signal Strength on Belkin Wireless 54g |
| (08/12/2004) Belkin 54g wireless access point freezing | (08/12/2004) Belkin Access point as repeater |
| (12/14/2004) Linksys Wireless Range Expander and Adapter Problems | (07/22/2004) Linksys WMA11B Media Adapter |
| (07/18/2004) Add external antenna to SMC2635W PCMIA adapter | (07/15/2004) USB adapter problem...Help please |
| (07/10/2004) MN-720 Microsoft adapter with WPA | (07/09/2004) WEP losing connection (Belkin ADSL/11g/Vaio z1RMP) |
| (08/24/2004) Using USB "stick" adapter inside a cantenna | (07/08/2004) access point or usb adapter? |
| (06/29/2004) Do I need CD-ROM to install adapter? | (06/28/2004) dlink wireless card bus adapter and router |
| (06/26/2004) Issues with Netgear Wireless AP and Adapter | (07/03/2004) Airlink+ WLH3010 G PCI Wireless G cuts out Matrox AGP vide.. |
| (06/23/2004) Linksys and Dell 510m Mini PCI card | (06/28/2004) Belkin equipment |
| (06/20/2004) Low cost community network - senao or smc router & adapter.. | (06/19/2004) Wireless Media Adapter et al |
| (06/21/2004) Belkin access point and 54g wireless card | (06/16/2004) Belkin F5D6231-4 wifi router problems |
| (06/16/2004) Problem with WPA-PSK bridging between Belkin 7230s | (01/04/2005) Intel Pro Wireless Adapter |
| (06/07/2004) Zyxel PCI wireless card - a very bad connection | (06/04/2004) Orinoco pcmcia card and adapter question |
| (06/01/2004) chipset | (05/25/2004) Bridging mode in Belkin or Netgear Access point? |
| (05/25/2004) belkin f5d7000 | (05/21/2004) ProStar D400s Mini PCI ??? |
| (05/18/2004) Belkin 54g PCI card under linux | (05/16/2004) Wanted: Siemens Speedstream 2502 Powerline Ethernet Adapter |
| (05/23/2004) Linksys Wireless-G USB Adapter | (05/12/2004) Low$ a/b/g PCI Ad-hoc vs Hi$ a/b/g AP?? |
| (05/11/2004) adapter or USB bridge? | (05/10/2004) intel wireless 2100 3B adapter connects to network but not.. |
| (05/09/2004) Linksys WUSB54G wireless adapter cannot access internet | (05/24/2004) Connecting D-link Wireless AP to Belkin Wireless router |
| (05/04/2004) WAP54G and Microsoft 802.11G USB adapter | (04/30/2004) Belkin F5D7130 |
| (04/26/2004) Replacement Belkin aerial needed in the UK | (04/24/2004) Belkin Security |
| (04/22/2004) Linksys Wireless G Game Adapter issue | (04/21/2004) Belkin Cable/DSL Gateway Router prob' |
| (04/18/2004) Belkin F5D7230-4 disconnects. | (04/15/2004) Linksys WMP54G PCI card with Windows 98? |
| (04/15/2004) G PCI Cards | (04/11/2004) Ambicom/Prism2 wireless lan wl1100-PC/PCI code 10 solution. |
| (04/10/2004) Belkin FD 72304 | (04/13/2004) Computer Has g Adapter - Router Is b - Any Hope? |
| (10/02/2005) a question about wireless chipset | (08/11/2005) cf-to-pcmcia adapter advice? |
| (06/24/2005) Help Select Mini-PCI or PCMCIA Wireless Adapter | (06/15/2005) Belkin pre-n |
| (04/02/2005) wireless adapter help plz | (04/02/2005) Stupid adapter using neighbor's router, not mine! |
| (12/29/2004) problem installing Linksys Wireless PCI card | |
