Using a PC Card on PC with PCI Adapter
More related threads to : Using a PC Card on PC with PCI Adapter
(11/28/2009) Can router be used as adapter?(11/28/2009) Computer doesn't recognize anymore hardware wireless adapter DWL-520
(11/27/2009) Connecting Laptop to Internet using Instinct G3 phone.(11/27/2009) Wifi card not supported by mobo?
(11/26/2009) About wifi using in mobile phone(11/25/2009) Will the belkin wireless G router work with AT&T?
(11/24/2009) Linksys wmp11 wireless card gets no signal from 2wire access point(11/23/2009) Computer randomly crasches after installing a new network card... Help!
(11/22/2009) Can i use a usb adapter without the router(11/22/2009) Connecting 2 laptop with wireless
(11/20/2009) HP G50-126NR Wireless Mini-PCI 802.11b/g/n adapter???(11/21/2009) If I have a N router do I need a N adapter to pick up wirless
(11/19/2009) Linksys wireless usb adapter G(12/19/2009) Best wireless-n adapter for windows 7 64 bit OS
(11/19/2009) Router, And Using Printer With Two PC's ?(11/17/2009) What is the best wireless ethernet adapter out there dollar for dollar?
(11/17/2009) How can i download software for a linksys wireless router with out a modom(11/17/2009) Not able to connect to mobile using wifi
(12/03/2009) WARNING - Realtek RTL 8185 54M Wireless LAN Network Adapter(11/16/2009) Wireless card find network
(11/15/2009) Does my internet speed match with the speed I'm paying for?(11/16/2009) Netgear wnr3500 router not compatible with windows vista?
(11/14/2009) Linksys WAG200G. Will it work with Windows 7(11/12/2009) Turning a pc wireless using my laptop
(11/12/2009) Windows XP, Netgear modem router, Belkin G mimo usb adapter(11/11/2009) Lag spikes caused by network card?
(11/27/2009) Is window 7 compatible with wireless g routers(11/09/2009) Dlink G520 wireless adapter does NOT work with Windows 7
(11/08/2009) Onboard wireless adapter doens't show up in Dev Mgr(11/08/2009) Wifi adapter loads CPU
(11/06/2009) Wireless adapter driver conflict(11/04/2009) Will linksys wmp11 work with windows 7?
(11/03/2009) WDS with AP on Dlink 3200(11/02/2009) Best wireless adapter for gaming
(11/16/2009) Linksys router not working with TWC(11/01/2009) What Wireless equipment is compatible with 802 3ad ?
(11/01/2009) Config wrt54G_V2 with MS xbox wireless adapter(10/31/2009) Gaming adapter to extend wireless network (internet) to 2 or more PCs?
(10/30/2009) Wireless card no good with windows 7 ?(10/28/2009) Driver/Card Issue
(11/01/2009) Wifi router with WEP WPA(TKIP AES) WPA2(TKIP AES)(10/27/2009) Netgear WG311v2 Driver fail install with Win7 64
(10/30/2009) USB Adapter for a Desktop running Windows 7(10/24/2009) MSI Wind u100 843us Wireless Card
(10/25/2009) Windows 7 adapter(11/17/2009) Looking for windows 7 64 bit wireless adapter
(10/22/2009) Problems with my key board(10/21/2009) Enabel to conect wireles router with my laptop
(10/20/2009) Any suggestions for wireless adapter for my Vista 64 machine?(10/20/2009) Know who is using bandwidth
(10/22/2009) Computers not seeing each other over WAN with Tomato router(10/19/2009) Wireless card spec?
(10/19/2009) Need a wireless n pci card(10/19/2009) USB Wireless Adapter Help
(10/18/2009) How to configure aztech router with linksys(10/20/2009) Can you run Xbox LIVE off of a wireless card?
(10/16/2009) Why my router does not work with my modem(10/17/2009) Pretty please help with my dongle
(10/16/2009) Best repeater to set up with dlink dir 615(10/14/2009) Desktop Wireless Card soemtiems doesn't work on reboot
(10/14/2009) How to implement intranent using wireless router(12/17/2009) Im about 7 nmiles from a mountain top with wifi!
(10/13/2009) Help with a wireless AP(10/14/2009) Extending a wireless network using 2 LinkSys WRT54GL routers
(10/11/2009) I have a linksys befw11s4 router. The ADMIN page is 192.168.2.1. When I go to ad(10/10/2009) Installing wireless adapter on Backtrack 3
(10/10/2009) Problem with getting online with PS3 slim(10/07/2009) Help with speed issues
(10/06/2009) Problem with dell laptop(12/24/2009) Replacing one roter with another
(09/28/2009) Is there an issue with some wireless printers and wireless usb adaptors knocking(10/01/2009) Need Windows 7 (64-bit) 802.11n Wireless Adapter
(09/30/2009) Download GRAFIC CARD LAPTOP m-life(09/26/2009) My netgear ma101 adapter will not connect to Belkin N+ router
(09/26/2009) How to load usb ethernet adapter into windows 98(09/25/2009) Best wireless usb adapter
(09/23/2009) Wireless Adapter problem(09/30/2009) Terrible speed with trendnet wirless n pci card
(09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP?(09/20/2009) Problem with MSI PC60G
(09/20/2009) Fax using WIndows XP and ATT UVERSE(12/16/2009) Windows 7 64bit compatible wireless adapter>>
(09/16/2009) Using a router as a wireless adapter?(09/18/2009) Bad streaming with good internet connection
(09/13/2009) New wireless card needed(09/12/2009) How to enable wireless adapter mac(Iatkos)
(09/10/2009) Wireless G USB Adapter Help(09/21/2009) Wireless network with vonage - need advice
(09/09/2009) Making Google WiFi work with a weak signal.(09/15/2009) Issue with an oddly unstable connection
(09/08/2009) Start wireless card before logon(09/15/2009) Help with wireless network
(09/01/2009) Att modem with linksys router(09/04/2009) Wired ethernet with wireless router
(09/01/2009) Belking wirerless g network adapter problem(08/31/2009) I need help with a Wireless adapter driver
(08/31/2009) How do I know if my integrated intel (G) adapter has MIMO?(08/31/2009) Wireless Adapter Check
(08/31/2009) Best wireless G adapter for range(08/31/2009) Wireless kb with touchpad
(10/25/2009) Laptop b/g wi-fi adapter work with n router(08/30/2009) Will upgrade from G to N adapter increase G reception range?
(10/21/2009) USB or ExpressCard wireless adapter?(08/30/2009) P5w dh wireless adapter
(08/29/2009) View camera wireless using internet(08/30/2009) Connect with secured wireless network
(09/03/2009) Can I run 2 wireless routers on one DSL line with modem?(08/26/2009) Internal Ethernet Adapter or Standalone Router
(11/01/2009) A good wireless pci adapter that works with 64 bit OS?(08/25/2009) New build: Network Adapter choice
(08/24/2009) Using two Linksys Wireless routers for broader WiFi Coverage(08/23/2009) Problem "seeing" other computers, but not with getting online?
(08/23/2009) Pci wireless n cards!are they any good(08/21/2009) Security using WEP
(08/19/2009) Detection Error, Bluetooth can't sync cell phones with Laptop(08/18/2009) Detection Error, can't sync cell phones with Laptop
(09/30/2009) Wireless network adapter not recognized in w7 HELP!!!(08/15/2009) Nintendo dsi internet setup with wireless usb adapter
(08/12/2009) Somebody how do I tell if I have a wireless network card installed?(08/10/2009) Sony FW with WLAN, no LAN :(
(08/11/2009) Using wireless gaming adapter in my wireless network(08/09/2009) Need a wireless card - only have PCIe 1x slots
(08/09/2009) Wireless Internet Network Card(09/19/2009) Can U upgrade a WEP Wireless card to WPA?
(08/05/2009) Using MN-740 with WPA and Vista(08/03/2009) Help with Compaq 2105US Laptop Wireless Connection
(08/03/2009) Wireless router with built dsl modem(07/31/2009) What wireless card?
(07/30/2009) Pc streaming with wired denon a/v receiver on wireless network(07/29/2009) Belkin Bluetooth USB adapter. Error 87: parameter is incorrect
(07/26/2009) Buying a new router and adapter TODAY(07/25/2009) Linksys WRT54G setup with verizon
(07/23/2009) Need advice on upgrading wireless router with adapter(07/22/2009) Wireless computing with a Dell dimension XPS t450
(07/19/2009) Windows 7 / Vista x64 Wireless NIC - PCI(07/18/2009) Vista Ultimate and Linksys Routers and USB Card
(07/17/2009) Can't Connect to Unsecured Network (full signal) with Zonet ZEW2500P(07/17/2009) Wifi card not as good on one PC vs another
(07/16/2009) I need help with wireless networking(07/16/2009) Spotty, slow connection - is it my pci card?
(07/16/2009) Is there a performance difference between USB & PCI based wifi modules(07/14/2009) DIR-615 mac address filter doesn't work with my macbook
(07/16/2009) Wireless Adapter Question(07/13/2009) Help with set up of netgear dg834pn
(07/12/2009) Network w/ 2 PCI cards?(07/16/2009) Having problems with router to laptop not getting connectivity
(07/09/2009) Mn520 wireless adapter driver(07/08/2009) Quality wireless adapter for Vista 64bit
(07/08/2009) Wireless WLAN Mini-PCI Card, Help.(07/06/2009) Cannot share printer connected to XP machine with 2000 via Wireles
(06/29/2009) Please Help if good with Port Forwarding(06/29/2009) Problems with wireless adapter
(06/26/2009) PCI Wireless N + AP/Monitor Mode?(06/25/2009) Help with settings
(06/24/2009) WinProxy setup in windows Server 2003 by using DSL-2640T wireles modem(06/23/2009) Wireless adapter with the dlink dir-655
(06/23/2009) Can see a SSID with no Security Key, cant connect(06/18/2009) Wireless router interfering with cordless phone
(06/18/2009) Problem with wireless network and restricted user WinXP(06/18/2009) N1 Wireless: Problems With Port Forwarding
(06/12/2009) Wireless N card to Wireless G Router(06/12/2009) Does electirc heat interfere with wireless g
(06/15/2009) Is my wireless card broken?(06/17/2009) Image is blur in browser window while using only Mobile Broadband
(11/13/2009) Wireless N adapter to wireless G router?(06/09/2009) PCI vs. USB / Recommended Desktop Solution
(06/16/2009) Decent Wireless Adapter for Gaming(06/08/2009) I can't connect with Windows XP help!
(10/13/2009) Wireless LAN adapter problem with Vista 64-bit OS(06/04/2009) Bluetooth PCI card for desktop system (bluetooth only card) ??
(06/03/2009) Need advice with linksys WRT54GL router(08/20/2009) Secured wired and Open wireless with one internet connection
(05/29/2009) 2wire gateway with UVERSE(05/28/2009) MN-520 Wireless Notebook Adapter
(06/04/2009) Need help with linking connections(05/24/2009) Need help setting up a router with Comcast cable
(06/09/2009) What PCi card is best for me??(06/15/2009) Connecting wireless with vista 64
(05/23/2009) Cannot go on line with Explorer(05/21/2009) Using wrt320n and 3 wap4410n
(05/22/2009) Hi-grade va250d and broadcom mini pci wlan card(05/25/2009) Need a Wireless PC Adapter
(05/29/2009) Best solution for low signal (USB or PCI)(05/16/2009) WIFI card MobilePro 780
(05/15/2009) Advice on Wireless Card(05/11/2009) Need a recommendation on a wireless card that is compatible with server 2003 r2
(05/11/2009) Wireless adapter for gaming pc(05/13/2009) Best Wireless N Adapter
(05/09/2009) Can this computor pick up wireless internet from my modem? or should i go buy a(05/10/2009) PCI Wireless adapter
(05/11/2009) Using a USB adapter w/SMA antenna(05/08/2009) Using ADSL router for cable internet
(05/09/2009) WLAN with Wireless Router and Wireless Access Point(05/06/2009) Better range - USB or PCI?
(04/26/2009) Dual Band Network With Two Routers(04/24/2009) Net adapter driver probs
(04/22/2009) Stop others from using my wireless internet(04/22/2009) Sharing broadband with neighbor (sister)
(04/20/2009) Change wireless card. PLEASE help!(04/14/2009) Need help with my Asus WiFi
(04/14/2009) Can You Recommend a Good Vista 64 Bit Network Adapter Please?(04/11/2009) WPA2 adapter with WPA router
(04/10/2009) Overclocking linksys WUSB100 adapter(04/10/2009) Wireless Network Adapter Inop in Non-Admin Acct
(04/10/2009) Problem with my se w350i phone(12/21/2009) Wifi phone/wifi voip phone/wifi ip phone with roaming functions
(04/08/2009) Looking for help with connection speed(04/07/2009) Wireledd Card
(04/07/2009) Wireless N with PCI-E?(04/07/2009) Setting a wireless network with a tv that has ethernet input
(04/08/2009) Idiot with wireless needs help(04/06/2009) V4000 wireless card
(04/02/2009) Wireless adapter for the xbox360(04/02/2009) HELP PLEASE, cant get router to work with charter internet
(04/03/2009) Wireless with wired (without internet)(03/28/2009) Network card or usb wireless?
(03/29/2009) Need rec for wireless adapter for Windows 7/Vista OS(03/26/2009) Does a Wireless N Adapter's extended range apply to G networks?
(03/25/2009) Need help with linksys wet54g network bridge(03/26/2009) Wireless G with Rangeboost vs. Wireless N with Rangeboost
(03/24/2009) Help the PC illiterate please with network setup(03/24/2009) Wrt54g v.6 router with wet54g v3.1network bridge bridge
(03/23/2009) Laptop Wireless adapter(10/05/2009) Laptop with XP wont connect to my wireless network
(03/21/2009) Can You Recommend a Wireless Network Card for 64 Bit Windows?(03/19/2009) Wirelees router with a cable modem issuses
(03/18/2009) Linksys WRT310N & WAP4410N any one using them presently(03/25/2009) Can not connect to Wireless Network with notebook.
(03/16/2009) Need help with d-link(03/16/2009) Laptop + Squeezebox having problems with new router
(03/12/2009) Connecting Mobile to Laptop to Share WiFi using Bluetooth(03/11/2009) Using 2 Wireless Routers
(03/10/2009) Network Adapter that works with Vista 64?(03/09/2009) Wireless with neighbor
(03/08/2009) Why does Wireless Connections drop when using a secured network?(03/08/2009) Help setting up linksys psus4 with hp 6122 printer
(03/04/2009) Wlan USB stick or a PCI extension card?(03/01/2009) Wireless usb with current router.
(11/22/2009) How to connect to internet using wifi from mobile phone?(02/27/2009) Networking Oddity with Vista
(02/28/2009) Belkin Wireless Network Adapter Setup(03/01/2009) Help with home network
(02/25/2009) Which wireless card to get with WNR 2000 and Vista 64?(02/19/2009) Using a router to send cricket broadband to my other pc's
(02/19/2009) Remote access via 1394 connection/net adapter(02/20/2009) WUSB54GC wireless USB adapter drops connection
(02/14/2009) My ipod is using all my routers bandwidth. How can limit it?(02/16/2009) Vista 64 bit wireless card
(02/12/2009) Best Wireless Adapter for My Needs(02/11/2009) Wirleless Card Not Authenticating
(02/12/2009) Wireless USB-N adapter for gaming(02/10/2009) Access Point or Powerline adapter?
(02/08/2009) DWL-650+ Adapter with DI-628 Router(02/05/2009) Belkin N1 Vision and N1 adapter 2.5MB/s Blunder
(02/27/2009) Im using a wireless belkin connector and now its not working...(02/03/2009) WAVEBUDDY WIRELESS PC CARD SOFTWARE
(01/29/2009) Windows 7 64 bit wireless pci card compatibility(01/27/2009) Slow wireless with XP 64bit
(02/09/2009) What wireless adapter (PCI-E or USB) would you recommend?(01/23/2009) New Wireless Card not being recognized in Vista
(01/21/2009) What's Wrong With my Internet??? :((((((01/30/2009) Windows 7 Doesn't Detect Wireless Adapter
(01/20/2009) Need Help with slow wireless(01/18/2009) WPA-PSK using TKIP encryptor connection problem
(02/03/2009) Need Help with Wireless N Routers(01/06/2009) Cannot Change Wireless Card Settings - freeze
(02/10/2009) Wireless N adapter and G router(02/17/2009) Anyone WIth an Asus Motherboard? Help!
(01/02/2009) What is the best Wireless G adapter (PCI or USB... whichever is better(12/30/2008) GAMING with Wirless PCI Card
(12/30/2008) Best Wireless-G Adapter for gaming HELP!!!(12/28/2008) 64-bit Drivers for Wireless Network Card
(12/24/2008) Code 10+28 device cannot start wireless adapter vista(12/21/2008) Wireless card acting as a wireless router
(12/21/2008) Windows XP not recognising network card?(12/15/2008) Getting WG602 to work with BEFSR41 V3
(12/15/2008) Weird connections with linksys(12/07/2008) Help in finding an all-in-one cable modem with wireless
(12/06/2008) How to setup 2 pc's in a wireless LAN with an AP?(12/05/2008) Using N instead of G for Xbox 360...some questions...
(12/06/2008) Best Wireless "N" Mini PCI(11/28/2008) Upgrade PCI card vs Network Repeater-Help Please
(12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients(11/22/2008) WDA 2320 PCI adapter not connecting
(11/21/2008) Belkin Wireless G+ MIMO Wireless Adapter Not Finding Wireless Network(12/01/2008) Upgrade Wireless mini-PCI Card?
(11/12/2008) Can it be done with my current equipiment?(07/09/2009) Vista wireless slow, same adapter on XP is fast!
(11/05/2008) New PC with existing wireless connection!(11/07/2008) Suggestion for a Stable Wireless B/G PCMCIA Card for Win 2000
(10/29/2008) wmp54gs wireless adapter - excellent signal, speed fluctuates(10/26/2008) tried installing over and over..usb adapter won't connect! help
(10/24/2008) Do i need a wireless card?(10/08/2008) Desktop Gaming Wireless Adapter
(10/06/2008) Problem with maintaining a connection with my XBOX.(09/28/2008) NETGEAR w.router stops working with security on
(05/21/2009) Best Wireless Adapter for Vista x64 Ultimate?(09/23/2008) Using Wifi-Ap as Access Point?
(09/20/2008) Please help with this ad hoc problem(09/20/2008) USB Adapter or PCI CARD For Wireless
(09/17/2008) Best PCI card for the buck?(09/15/2008) Linksys Wireless Router not working with Motorola Surfboard Cable Mod.
(09/15/2008) Help with Wireless Network(09/15/2008) Help with printer - Urgent
(09/07/2008) Better Antenna or New Adapter?(09/03/2008) Problem with Networking, half works, half doesn't
(09/03/2008) Using DSL Router (w/ wireless) as wireless router alone(08/27/2008) Help with Marvell 88W8335 Wireless Card
(08/27/2008) strange wireless adapter problem(08/26/2008) I need help with video streaming
(08/31/2009) Help with Wifi please(09/22/2008) What Wireless PCI Card?
(08/25/2008) Using old 802.11a slow down 802.11g(08/25/2008) Windows Vista 64bit compatible PCI network cards
(10/12/2008) Best USB Wireless adapter?(08/20/2008) like to add a second wireless router with no WEP
(08/18/2008) cannot connect with security enabled(08/10/2008) Gaming with a Router connected to other Router
(08/10/2008) Using two Wifi with one Cable modem(10/10/2008) Linksys wireless usb adapter not connecting to my Linksys wireless Rou
(08/04/2008) Desktop Wireless Adapter with Integrated Bluetooth?(07/30/2008) Wireless Connection Issues with WRT54G + Windows Vista 64 Bit
(07/28/2008) WEP Encryption - one laptop does not work with it(07/29/2008) Trouble with DHCP (i think) Please Help!
(07/25/2008) What wireless router is best used with an Att DSL Modem?(07/24/2008) Router and adapter reccomendations
(12/29/2008) Low signal with FIOS router(07/25/2008) 802.11n PCIE Mini Card Upgrade
(07/23/2008) Wireless Adapter Unstable?(07/22/2008) CDMA/GSM/EDGE/HSDPA /MODEM/DATA card manufacturer
(07/22/2008) Wireless-G network adapter work with Wireless N router(07/26/2009) Whats the best wireless adapter for a desktop?
(08/15/2008) You can go to jail/be fined for using hot spots...(07/13/2008) Wireless Adapter Overheating?
(12/14/2008) Rosewill PCI Wireless adapter RNX-G300(E) Driver Issue Fix for Vista(07/13/2008) Please help me with my wireless router....
(07/08/2008) intersil PRISM LAN PCI connection problems!(07/07/2008) Which wireless adapters can I use with a DIR-655?
(07/05/2008) Half speed with wireless connection(06/30/2008) Anyone know which MIMO enabled wireless cards work with Vista x64
(06/26/2008) Difficulities with file sharing on wireless(06/21/2008) Overheating issue with Belkin wireless USB adapter
(06/19/2008) Problem with my wireless router!!(06/13/2008) PCI Card That Supports 802.11n 5Ghz?
(06/15/2008) gaming with wireless g(06/07/2008) A newb is completely lost with his wireless card.
(06/01/2008) Help with creating a wireless network.(05/29/2008) USb or PCI card?
(06/03/2008) extending a wired network with wireless(06/01/2008) Port Forwarding with a Router - Router setup
(05/23/2008) networking two wireless computers with one wireless router?(05/23/2008) wusb54g wireless adapter bsod
(05/22/2008) vista x64 compatable wireless adapter(05/14/2008) Can't connect to internet via wireless adapter
(05/14/2008) help pleaseee i cna't get 1000mb/s with etherent cable(05/10/2008) help with linksys wre54g extender
(05/07/2008) Looking for a new Wireless Adapter or QuickFix(10/10/2009) D-Link DWL-G122 wireless adapter
(05/02/2008) USB Wireless Adapter concentrate signal(05/27/2008) wireless PCI adapter not recognized
(04/29/2008) Wireless router with rackmount design(05/10/2008) Buying a wireless express card for Windows Vista laptop
(05/12/2008) wireless router with switch to turn of wireless radio ?(05/09/2008) Looking for USB 802.11N network adapter
(04/29/2008) Anyone with macbook wireless issues? (airport extreme card)(04/17/2008) Laptop suddenly offline with other issue
(04/16/2008) Wireless PCI or USB adapter for vist x64(04/12/2008) need urgent help 64bit wireless card either pci or usb
(04/05/2008) Wireless N Router with both g and N receivers?(03/29/2008) [SOLVED]Problems connecting to internet with vista (wireless)
(03/26/2008) Belkin USB Wireless Adapter(03/08/2008) Network Printer Problem with Vista
(03/08/2008) replace network card in belkin pre-n desktop adapter(03/14/2008) help cant find a wireless network adapter
(03/02/2008) NEWBIE! Major help with Verizon Westell 6100 and DI-624S?(02/16/2008) Help Picking Out a Wirless Card for PC?
(02/12/2008) sony laptop loses connectivity with Linksys wireless routers(12/02/2009) "Cannot communicate with primary DNS server"
(07/14/2008) Belkin Wireless G PCI Problems(08/26/2009) Internal wireless adapter disappeared after XP reinstall
(01/31/2008) HP2710 Card Slot Wireless Issue(02/10/2009) Wireless issue with Vista and Linksys
(01/29/2008) Wireless card to router with different brand?(01/26/2008) Any network sniffer to use with Netgear WN121T USB adapter?
(01/28/2008) Wierd wireless PCI card problem(01/20/2008) Sharing files/printers on network with wireless/hard wired computers
(01/11/2008) hey guys help me with this please(01/10/2008) News/nntp problem with config change
(08/25/2008) What's wrong with my wireless connection?(03/30/2009) Lost software for Linksys WRT54G but want to secure wireless with WPA2
(12/20/2007) Issues with Paradyne and Linksys routers(12/17/2007) Folder files dont completely load with Wireless G
(12/14/2007) Printer Shutting Down On Wireless Network Using Network Magic Software(12/15/2007) Local Only - Vista Usb Adapter Problem !!!!
(12/13/2009) Problems with Asus WiFi-AP solo(12/06/2007) buffalo wireless g high gain wli u2 sg54hg usb 2 adapter
(01/11/2008) help with Wireless/ethernet router filesharing?(11/27/2007) Old laptop, new wireless card, old Linksys BEFW11S4
(11/26/2007) Wireless adapter for vista?(11/21/2007) Is this interference? Or just a crappy router/PCI card?
(11/14/2007) help with verizon fios(10/31/2007) Wireless N issue with laptop (4965AGN) and Linkysys300 n router
(10/15/2007) Trying to Setup my F5D7230-4 as an AP with a Netgear WGR614 router(10/02/2007) Intel Pro 3945 ABG Wireless Mini PCI Express Card Opinions
(09/29/2007) Wireless Card for Vista 64 bit - WEP(09/24/2007) Accton WN4201B (Wireless PCI Card Issues! HALP!)
(08/30/2007) new to linux and need help with turning the radio on in knoppix(08/25/2007) Help! Need a router with LONG RANGE
(08/26/2007) Belkin N Wireless USB adapter poor strength(08/21/2007) can connect with ethernet but not wireless, conflict with wifi card?
(08/15/2007) Weird problem with wireless connection!(08/11/2007) When Using Wireless Routers, Can You Run In Wired Only Mode ?
(08/07/2007) Help with a new Acer 3680 and internet connection(08/09/2007) Crack WEP Network card
(08/03/2007) I just Can't connect to live messenger using my D-Link DI-624M(07/30/2007) Can't do LAN gaming with wireless connection
(07/26/2007) Having problems with Asus Wifi AP dropping connection(07/27/2007) Need help with wireless repeating
(07/23/2007) Can someone recommend good wireless adapter?(07/19/2007) Netgear wireless adapter causing 100% cpu spikes..and other things.
(06/03/2009) Wireless Connection not working with vista(08/11/2007) need help getting wireless router to work with dsl
(07/12/2007) Best Apartment Adapter!?(06/22/2007) Using two wireless routers on the same network
(06/19/2007) Wireless PCI card /USB LAN adaptor(06/15/2007) Getting DLink AP to work with WRT54GL
(06/02/2007) ZyXEL NWD170N wireless adapter + ZyXEL NBG415N wireless rout(05/31/2007) problem with wpa-psk
(05/20/2007) Intel Pro/Wireless 2915abg Card(05/16/2007) Weird problem with Belkin PCI card
(05/11/2007) Help with point to point network(01/12/2009) 2 routers, one using WEP, other Using WPA - How to setup?
(06/22/2007) MIMO router without MIMO card?(04/19/2007) Wireless network authentication with Vista
(04/19/2007) How to: Keep 1 cpu hardwired and Have 2nd using wireless?(05/11/2007) Help with connecting wireless network
(03/28/2007) Belken Wireless G USB Network Adapter(03/27/2007) Wireless N devices with 10/100 ethernet ports... makes sense
(05/09/2007) What is going on with my Wireless network...!?(03/20/2007) Verizon Wireless Air Card and ICS?
(07/16/2009) XBox 360 Question(Can you use any USB adapter)(06/21/2007) What to replace my 2db antenna with on my DG834GT Router?
(03/16/2007) Wireless PCI card.(03/10/2007) Dlink DIR-655 Router,Pci Card DWA-552 Problem.
(03/09/2007) Belkin adapter connects only to router, any advice?(02/09/2007) Advice on picking a 802.11n adpater card
(02/05/2007) Setting up wireless network with my belkin F5D7632-4 (54g)(02/05/2007) 1st PCI-E Wifi AP combo card! Wireless network card!
(02/06/2007) Can't get wireless card to find network(02/06/2007) Wi-Fi Nic with external antenna adapter recomendations
(02/01/2007) only 11Mb/s with wireless "g" ???(02/01/2007) Need help with odd disconnect (and can't reconnect) problem
(01/28/2007) PC can't connect to Internet with WEP enabled(01/18/2007) Netgear trouble with 2 wifi's :(
(01/18/2007) New Comp having connectivity issues with wireless(01/08/2007) Sony VAIO PCG-Z1XSP wireless problem using BT HomeHub.
(01/08/2007) USB wireless adapter issues at startup(12/31/2006) PCI Wireless network card issues
(12/26/2006) a few domains cant be obtained with belkin wireless router(12/22/2006) Wireless with WPA-Radius
(12/14/2006) need help with wre54g and qwest modem/router(07/15/2009) roaming between ap's with wds link
(11/28/2006) Is there a way to eneble ICS on a PCI wireless card?(11/20/2006) HELP with D-Link and Sony Problem
(11/16/2006) US Robotics 5421 usb wireless adapter(03/16/2009) Linksys WGA54G Game Adapter / Bridge - Device is garbage??
(11/13/2006) What's wrong with my setup? I can't go anywhere...(11/17/2006) Reccomended Wireless PCI card?
(11/05/2006) Problem with DLink DI-624s(11/03/2006) Help me choose router and network adapter, please!
(11/27/2006) "Wi-Fire" Adapter; any input fm ACTUAL users?(11/09/2009) Range extension using WDS setup question
(10/29/2006) Wireless N for notebook Express card 34/54(10/31/2006) Heh, really need help with D-Link router.
(03/17/2009) Desktop WiFi Card(10/25/2006) l33t help needed. Using bittorent on my neighbours wifi....
(10/24/2006) Wireless Card WILL NOT connect to a wireless network!!!(10/20/2006) Ad-hoc ICS with Mac OS X
(10/19/2006) SMC SMCWBR14-G Router with Motorola SB5100 Cable Modem(10/20/2006) Problem with Belkin 7011 wireless card
(10/17/2006) WRT54GS problems with Xbox 360(11/17/2006) Wireless printer server trouble with Actiontec router
(10/14/2006) Connection problems with network(10/11/2006) Looking for PCMCIA Card
(10/03/2006) Belkin N-1 network card for xp laptop(10/02/2006) 64-bit USB Bluetooth to use with my headset
(09/25/2006) compatability copperjet 810 modem with apple airport express(10/05/2006) I need a new router with a built in print server...
(09/24/2006) configuring network card for auditor(09/22/2006) I need a new wireless router and destop card for $150
(09/18/2006) usb wifi adapter drops to 1mbs when connected in bridge!?(09/15/2006) usb wifi adapter drops to 1mbs when connected in bridge!?
(05/29/2009) Problem with Acer Aspire 3620 integrated wireless LAN(10/16/2006) Wireless Print Server with WPA Encryption?
(08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help(08/15/2006) Need help with wireles settings
(08/15/2006) Help with Wireless AP/Briding(09/03/2006) which wireless mini-PCI card should I buy?
(08/13/2006) problem on wireless with win 2003 server(08/08/2006) Need help with wireless connections WRT300n and WRT54G
Sponsored links
