| (11/28/2009) Can router be used as adapter? | (11/27/2009) Wifi card not supported by mobo? |
| (11/26/2009) About wifi using in mobile phone | (11/26/2009) How to set wifi in mobile phones |
| (11/22/2009) Can i use a usb adapter without the router | (11/18/2009) I have wifi but i can use the internet it says cant conect to server |
| (11/18/2009) DCS-2121 wifi ip cameras - fixed ip on router. | (11/18/2009) Wifi cards for desktops |
| (11/18/2009) Can windows 7 use WEP security for Belkin | (11/17/2009) Not able to connect to mobile using wifi |
| (11/15/2009) Connect wifi on phone | (11/19/2009) PLEASE HELP ME CONNECT WIFI PRINTER TO PC |
| (11/14/2009) Streaming video over wifi to windows media center...problems | (11/11/2009) Wifi is working in ad-hoc but not in infra mode |
| (11/10/2009) How to control sharing internet access thru wifi | (11/08/2009) Vista wifi bridged to xp ethernet |
| (11/08/2009) Wifi reapeter, wireless isp etc? | (11/07/2009) Nintendo DS Wifi |
| (11/08/2009) WiFi interruptions | (11/08/2009) Wifi adapter loads CPU |
| (10/31/2009) Ibm R52 wifi shotcut key | (10/31/2009) Losing wifi |
| (10/31/2009) Netgear wifi router | (10/31/2009) Windows mobile not connecting to wifi modem's internet |
| (10/30/2009) Want to supply public wifi in a 1-2 mile coverage area | (10/29/2009) HP Firebird 802 Wifi Selection |
| (11/09/2009) Can wireless LAN replace wired LAN | (10/28/2009) WiFi drops on high CPU load |
| (11/01/2009) Wifi router with WEP WPA(TKIP AES) WPA2(TKIP AES) | (11/23/2009) How to share files through a wireless network |
| (10/25/2009) Cannot connect Ipod Touch to Home Wifi | (10/25/2009) Ipod Tpuch won't connect to WiFi |
| (10/23/2009) My gateway WiFi switch wont turn on | (10/20/2009) Two Wifi Devices Same PC, Is ad hoc or ICS an option? |
| (10/18/2009) Can't detect netwoks, but connected to network | (10/20/2009) Can you run Xbox LIVE off of a wireless card? |
| (10/16/2009) Wifi cpe | (10/16/2009) How can my laptop get a wifi connection from another laptop through bl |
| (10/16/2009) Im about 7 nmiles from a mountain top with wifi! | (10/11/2009) One laptop can connect to the wifi two others cant |
| (10/11/2009) Can you alter the range on a router | (10/10/2009) Asus WiFi P5K-E-AP internet drops out |
| (10/09/2009) WiFi handoff problem | (10/05/2009) Wifi Problem |
| (10/05/2009) Seeing a printer through another computer?????? | (10/04/2009) Mobile wifi |
| (10/03/2009) Sharing mobile wireless connection through desktops | (10/03/2009) Can a wireless router be used as a wifi antenna |
| (11/20/2009) What is the advantage of having a upnp wifi than normal wifi in a cell phone??? | (09/28/2009) Vista Wifi sleep problem - I have solution but can't implement it!!! |
| (10/14/2009) I have problem in my psp wifi connection in security | (09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP? |
| (09/22/2009) Tutorial pc use wifi | (09/20/2009) Configure wifi asus p526 |
| (09/19/2009) Two wifi between to connect what range | (09/15/2009) Boosting WiFi signal |
| (09/09/2009) Making Google WiFi work with a weak signal. | (09/09/2009) Setting up an WiFi Access Point....? |
| (09/01/2009) Long range wifi | (09/03/2009) Can I run 2 wireless routers on one DSL line with modem? |
| (08/24/2009) Using two Linksys Wireless routers for broader WiFi Coverage | (08/24/2009) Wireless connection through wires....? |
| (08/20/2009) Two routers, no wifi cards, and a next door friend | (08/12/2009) Can this be done ? useing 2wire 2701 as wireless access point |
| (08/10/2009) NO WIFI | (08/09/2009) Cant connect to Internet Exploer when connected to wifi |
| (08/07/2009) Wifi in my woodshop 300 feet away. | (08/07/2009) Wifi in my woodshop 300 feet away. |
| (09/19/2009) Can U upgrade a WEP Wireless card to WPA? | (08/09/2009) Can't See Any of my Wireless Networks |
| (08/02/2009) Can't connect to internet through wireless router | (08/21/2009) Need advice about long range WiFi Connection |
| (07/31/2009) Notebooks and wifi antennas | (07/28/2009) Can i connect a belkin router to a linksys? |
| (07/26/2009) Can i join a clan | (07/24/2009) Router As Receiver, Can you distribute? |
| (07/21/2009) Can't access router configuration page... | (07/17/2009) Forgot my wifi password but still connected |
| (07/17/2009) use bluetooth to network laptops & share 1 wifi connection?? | (07/17/2009) Can't Connect to Unsecured Network (full signal) with Zonet ZEW2500P |
| (07/17/2009) Wifi card not as good on one PC vs another | (07/21/2009) Shield AA lithium batteries from WiFi signals |
| (07/16/2009) Is there a performance difference between USB & PCI based wifi modules | (07/14/2009) Wifi sharing |
| (07/14/2009) P5k-e Vista Wifi Acess Point = pulling out my hair! | (07/12/2009) How to secure wifi? |
| (07/10/2009) Strange wifi problem...please help!!!! | (07/10/2009) Can 802.11a/b/g upgrade to 802.11n |
| (07/03/2009) Monitoring traffic through a wireless router? | (06/23/2009) Can see a SSID with no Security Key, cant connect |
| (06/26/2009) Wifi interference - any workaround? | (06/18/2009) Can't put in wireless key |
| (06/17/2009) Windows XP as WiFi Access Point | (06/16/2009) Pinging and wifi scanning - why do these adapters differ in behavior? |
| (06/13/2009) Can't Find The Drivers I Need (D-Link) | (06/10/2009) WiFi help... |
| (06/02/2009) Hoping to go WIFI | (06/02/2009) Can I use 802.11n and ASUS EEE PC 904 HD ? |
| (06/02/2009) WiFi Repeater: How to Make? | (05/24/2009) Can't get my wireless connection! |
| (05/20/2009) PS3 DNS Error: Can't Go Online | (05/17/2009) Best Home WiFi Router? |
| (05/16/2009) WIFI card MobilePro 780 | (05/16/2009) Can't get wireless internet on laptop |
| (05/14/2009) WiFi Hardware for Portable entertainment | (05/14/2009) WiFi Hardware for Portable entertainment |
| (05/09/2009) Can this computor pick up wireless internet from my modem? or should i go buy a | (05/08/2009) WiFi Subscription Sites |
| (05/03/2009) Can I make my laptop run a WAN? | (05/15/2009) WiFi Adaptor installation crashes network connection menue |
| (04/25/2009) Wifi server | (05/04/2009) Wifi between two houses 1000-1200 ft apart |
| (11/03/2009) USB 500mW WiFi adaptor | (04/14/2009) Need help with my Asus WiFi |
| (04/14/2009) Can You Recommend a Good Vista 64 Bit Network Adapter Please? | (04/09/2009) GSM/WIFI PHONE/Dual mode mobile phone/wifi video phone/ smart phone |
| (04/09/2009) Wifi phone/wifi voip phone/wifi ip phone with roaming functions | (03/28/2009) Linksys by Cisco does it has wifi? |
| (03/27/2009) Can't find network connections icon in the Taskbar | (03/23/2009) Can you help me |
| (03/21/2009) Can You Recommend a Wireless Network Card for 64 Bit Windows? | (03/25/2009) Can not connect to Wireless Network with notebook. |
| (03/12/2009) Connecting Mobile to Laptop to Share WiFi using Bluetooth | (03/12/2009) Netzero and Wifi |
| (03/10/2009) Can you connect a wireless 2.4ghz mouse to a wifi chip in a laptop | (03/03/2009) Enhance wifi signal |
| (03/03/2009) Enhancing wifi signal | (11/22/2009) How to connect to internet using wifi from mobile phone? |
| (02/28/2009) WiFi on a Compaq Evo N800c | (03/03/2009) Can I add a wireless router to an existing wired router? |
| (02/03/2009) Cable tv over wifi | (02/04/2009) Connect 3 PC's via switch to WiFi Access Point to WiFi |
| (01/11/2009) Wifi conection sharing | (12/23/2008) Can't Identify |
| (12/30/2008) Secured WiFi at School? | (12/13/2008) My laptop is not able to connect to WiFi Network after reinstal OS |
| (12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients | (11/12/2008) Can it be done with my current equipiment? |
| (11/09/2008) Can pc connect to two different wireless routers | (11/13/2008) Wifi laptop stealing bandwidth?? |
| (10/09/2008) WiFi Competitor Uses Visible Light While Cleaning RF Spectrum | (10/10/2008) Connect two routers via wifi? |
| (10/21/2008) Printing trough wifi in LAN | (08/29/2008) Combining Wifi connections |
| (08/31/2009) Help with Wifi please | (08/25/2008) Wifi Vista to Ethernet XP? |
| (08/10/2008) Using two Wifi with one Cable modem | (07/12/2008) ** Still Same Not Able To Enabale Wifi In Aspire 3690 ** |
| (07/11/2008) Can't connect Laptop, WEP problems, clueless | (08/01/2008) Belkin F5D8053 wont connect to any wifi |
| (06/30/2008) Linksys WMP54G 4.1 Trouble picking up wifi signal WinXP SP2 32-bit | (06/02/2008) p5w and my wifi ap solo |
| (05/14/2008) Can't connect to internet via wireless adapter | (05/11/2008) Pooling, Loadbalancing,Bridging three wifi connections ?? Questions? |
| (03/27/2008) Can't get WRT54GX2 to connect | (03/12/2008) MIMO Wifi is slow, or is it normal? |
| (03/06/2008) Can I connect a ethernet switch to a wireless bridge? | (03/15/2008) Add wifi to Gateway 500S w/wired LAN |
| (02/24/2008) 100m WiFi | (02/24/2008) Can WRT330N be used as a bridge? |
| (02/16/2008) Can't connect to wireless network..why? | (01/07/2008) Can no longer connect to wireless router IP address :/ |
| (02/27/2008) Can a cordless phone knock out a wireless router? | (12/18/2007) Can't connect to wireless |
| (11/17/2007) WIFI | (11/09/2007) DLINK DSL G604TRouter + P5K-e/wifi AP Help |
| (11/01/2007) Can you mix and match different Antennas on a Multi Antenna Router | (11/01/2007) CAN'T GET INTERNET ON MY WIRELESS LAPTOP TO DIR-655 |
| (08/18/2009) How to connect to Internet, through WiFi; a problem | (08/29/2008) Can't find access point....physically |
| (09/30/2007) Wifi problems on laptop | (09/13/2007) Net connection problem in Vista through wireless network |
| (10/10/2007) Can Access Router But Not Internet | (11/18/2007) Can I use my old wireless router as a wireless bridge? |
| (08/21/2007) can connect with ethernet but not wireless, conflict with wifi card? | (08/20/2007) Can low signal make download currupt? |
| (08/11/2007) When Using Wireless Routers, Can You Run In Wired Only Mode ? | (08/05/2007) Wifi Not Connecting - Wired Works Fine |
| (08/03/2007) I just Can't connect to live messenger using my D-Link DI-624M | (08/07/2009) Vista & wifi - Can see wireless networks but can't connect to them! |
| (07/30/2007) Can't do LAN gaming with wireless connection | (07/29/2007) port forwarding through two routers |
| (07/26/2007) Having problems with Asus Wifi AP dropping connection | (07/23/2007) Can someone recommend good wireless adapter? |
| (07/23/2007) Regarding increasing the WiFi range | (07/19/2007) Setting up wifi for 18 people |
| (09/17/2007) Problems connecting to unsecured wifi network in Vista | (06/02/2009) Need advice regarding extending WIFI network (picture included) |
| (06/26/2007) WiFi connected to access point but can't find internet | (05/17/2007) Wifi better than cat 5 ???? |
| (05/11/2007) Can I connect 2 Wireless Routers without cascading | (04/16/2007) First Time WIFI Setup |
| (04/14/2007) CounterStrike Source causing loss of WiFi connection | (07/16/2009) XBox 360 Question(Can you use any USB adapter) |
| (02/17/2007) Can't receive packets | (02/05/2007) 1st PCI-E Wifi AP combo card! Wireless network card! |
| (02/06/2007) US Robotics wifi router | (02/06/2007) Can't get wireless card to find network |
| (02/02/2007) WiFi Repeater set up! Major headaches. Can you help? | (01/18/2007) Netgear trouble with 2 wifi's :( |
| (01/11/2007) What are the differences between Wifi and 802.11b/g? | (12/09/2006) Noobness Dual Ethernet Mobo + Wifi question |
| (12/08/2006) PSP wifi connection | (11/25/2006) Can't surf any webpage! |
| (12/08/2009) Help!! Can't remember or find my Wep Key | (11/03/2006) packet injection and monitor mode wifi cards |
| (03/23/2007) My neighbours are intruding my wifi security enabled network | (03/17/2009) Desktop WiFi Card |
| (10/26/2006) how can i get wifi? | (10/25/2006) l33t help needed. Using bittorent on my neighbours wifi.... |
| (10/09/2006) Can I extend the reach of my laptop wireless signal? | (01/24/2007) Can I extend the reach of my laptop wireless signal? |
| (09/22/2006) Can't access Internet after installing router | (09/22/2006) WiFi Tweaks. |
| (09/18/2006) usb wifi adapter drops to 1mbs when connected in bridge!? | (09/15/2006) usb wifi adapter drops to 1mbs when connected in bridge!? |
| (08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help | (08/16/2006) Wifi gurus!! Please assist! Multi AP setup on 1 subnet |
| (08/14/2006) Can't connect to shared printer | (08/03/2006) Can I strengthen my signal without spending too much? |
| (10/14/2009) I have a wifi lap top what do I do next? | (04/07/2008) WiFi and Dialup? |
| (10/05/2006) curmugeonly walls... cant get a signal through it. | (07/09/2006) Got Wifi connected, but can't get a network going |
| (07/18/2006) SET UP MY OWN WIFI BUT NEED A LITTLE HELP PLEASE | (06/21/2006) Can you disable built in WiFi in favour of an external WiFi? |
| (06/12/2006) Connecting two wired switches with wifi + using access point | (06/04/2006) Recommendations for extending wifi signal |
| (05/20/2006) Can't install access point? | (05/19/2006) linksys wifi issue |
| (05/07/2006) How to share wifi with a device that cannot logon? | (05/24/2006) PCI WiFi question |
| (04/17/2006) Can 802.11b card crack WEP with 802.11g target clients? | (04/05/2006) My WiFi card worked before I formatted my laptop!? |
| (12/10/2006) Roaming WiFi issues - 3 APs, one switch, one SSID | (03/11/2006) Can't access host computer |
| (05/04/2006) wifi spectrum analyzer? | (10/12/2004) Can we do without user authentication? |
| (01/25/2006) Linksys wifi Router runnin on cable.. | (03/19/2006) auragrid wifi extender |
| (09/26/2005) wifi & iwconfig | (09/24/2005) Can't access internet wirelesly |
| (09/22/2005) Long Range wifi troubles | (04/11/2009) WiFi security settings |
| (04/02/2004) Screwy behavior from different wifi pc-cards | (04/01/2004) ICS and wifi |
| (09/06/2005) Wifi connection dropping or timeout .... | (12/13/2006) Can I only allow 1 active nic at one time? |
| (01/16/2006) Using Linksys WRT54G to connect to another wifi router | (01/19/2006) Recommend an access point, 4-p Router wifi |
| (01/23/2006) Can I use a wireless router as an access point in other room | (01/28/2006) CAVEMAN ASK: HOW FAR COMPUTER WORK, WIFI DISTANCE, YARDS? |
| (01/29/2006) Internet through ad-hoc wireless keeps dropping unless.... | (01/02/2006) Deminished BW using WAP v. Wired through a WRT54GC |
| (01/15/2006) Will this WiFi setup work? | (01/10/2006) Wifi Signal Mapping question |
| (09/22/2005) Can this wired/wireless be possible? | (09/19/2005) Periodically losing TCP connection through wireless adapter |
| (09/19/2005) Windows Wireless Manager Can't See Netowork | (09/14/2005) Can Wireless Security and VPN access Coexist on SBS 2003? |
| (09/13/2005) Accessing a wifi printer | (09/07/2005) Sharing a USB modem through a wireless router |
| (09/07/2005) Multiple users logged on one machine with WiFi... is it po.. | (09/07/2005) Basic setup - USB WiFi on 2 PCs for Internet Sharing... ho.. |
| (09/10/2005) Can't connect to the enter net. | (09/02/2005) Using Win XP to connect Wirelessly to an iPAQ |
| (09/02/2005) Can't stay connected | (08/31/2005) Wifi connection lost |
| (09/20/2005) Win XP PRO SP2 WiFi and DHCP | (08/29/2005) Transferring sound through network |
| (08/29/2005) Can't see other PC on network | (08/28/2005) Laptop connection through PC |
| (08/24/2005) Frequent WiFi Disconnects | (08/10/2005) Unable to browse certain sites through Wireless router |
| (01/28/2009) Can't connect | (08/05/2005) Can't save Word document to networked computer! |
| (08/06/2005) Can't access laptop from desktop, but can access desktop f.. | (08/05/2005) Can't access another XP PC on network |
| (07/27/2005) Can not see print server over wireless | (07/25/2005) Laptop Only Uses WiFi, Refuses to Use Wired LAN When Conne.. |
| (07/25/2005) Can't anyone help ???? | (07/19/2005) Can't see other computers on network |
| (07/18/2005) Can't see the other computer! please help | (07/17/2005) Realtek RTL 8180 Can't Connect to Netgear WGR 614 |
| (07/17/2005) Can connect to internet, but can't see other PCs on my net.. | (07/16/2005) Can not see home network |
| (07/15/2005) WinXP Initial Connection - Can it connect PRIOR to user lo.. | (07/15/2005) Wireless G Router works through ethernet, but not wireless.. |
| (06/28/2005) Can't share files with TKIP | (06/18/2005) Dial-up sharing with WiFi |
| (06/17/2005) Can't Find Shared Files? | (06/20/2005) Can't set up Print Server |
| (06/16/2005) Two wifi networks? | (06/07/2005) Wifi et Activesync |
| (06/02/2005) Can i monitor shared files | (06/18/2005) Can't aquire IP address |
| (06/01/2005) Can get desktop to see files on laptop | (05/25/2005) connexion wifi intermitente |
| (05/26/2005) Can't share files | (05/25/2005) WiFi card disconnects on logout (XP SP2) |
| (05/24/2005) Can't file, print share with 2 Router home network-Vonage .. | (05/22/2005) Can't see some machines |
| (06/02/2005) Moved printer to new PC. Can't add computer/printr to wire.. | (05/31/2005) Can I block specific networks from being detected |
| (05/12/2005) Can't find netword | (04/29/2005) Can't see other computers in workgroup |
| (04/26/2005) WiFi doesn't work with LAN card in WINXP sp2 | (04/25/2005) WinExplorer slowdown / crash on Wifi transfers |
| (04/26/2005) Can I prevent the kids connecting to any available network ? | (04/28/2005) Can't get it up...wireless sharing |
| (04/20/2005) Lost WIFi connection on each reboot | (04/14/2005) File sharing from a WIFI PC with nobody logged on - How to.. |
| (04/11/2005) New WiFi Set Up | (04/11/2005) WiFi Connection Nightmare |
| (04/07/2005) Wireless Network Can't See My wired Network? | (04/05/2005) Can't share between two computers |
| (04/04/2005) Logon to a Domain through a wireless | (04/08/2005) one CAT5 cable, two WiFi laptops |
| (04/04/2005) difference between Wifi repeater and range extender? | (04/04/2005) Roam from Gprs network to Wifi network |
| (03/30/2005) Can't ping wireless pc | (03/25/2005) wifi newbie |
| (03/19/2005) PC Screen Output to TV via Wifi | (03/17/2005) Can't save WordPerfect file on laptop on network |
| (03/16/2005) Can't find networked (hopefully) printer after ethernet ca.. | (03/17/2005) Can't find networked printer IP address |
| (03/25/2005) wifi mystery | (03/10/2005) One wifi laptop |
| (03/11/2005) One wifi laptop | (03/10/2005) Fed up of no WiFi |
| (03/10/2005) Home WiFi security | (03/09/2005) Offline Folders, VPNs, & WiFi |
| (03/07/2005) Can do a simple file transfer. | (03/04/2005) Can't access printer on home network |
| (02/26/2005) Can't connect to internet over wireless link | (02/20/2005) Can a Linksys WRT54G Router be used as access point with n.. |
| (03/31/2005) ActiveSync bluetooth connection | (02/17/2005) break Wifi ? |
| (02/16/2005) Prevent user from modifying WiFi settings | (02/13/2005) Can wireless use ICS to Dial Up through desktop? |
| (02/09/2005) Can't receive e mails in Outlook Express | (02/08/2005) W98SE Laptop Suddenly Can't See Two XP Machines |
| (02/03/2005) Can't print to print server | (02/05/2005) Can't Connect to Router |
| (01/30/2005) Can't sync Win XP to server over wireless | (01/30/2005) Can't view workgroup computers |
| (01/27/2005) Can I convert a router to an access point? | (01/29/2005) Wifi Acer |
| (01/24/2005) Can't connect wired linksys lan to wireless belkin lan | (01/25/2005) Wireless Networking and sharing files! Can see not share. |
| (01/25/2005) Can't connect to wireless network | (01/21/2005) Can't Share Files |
| (02/15/2005) aggravating wifi prob | (01/22/2005) USR2216 WiFi card causes Win XP to crash - newbie need help! |
| (01/31/2005) win 64 asus wifi driver | (01/18/2005) Can't share files??? |
| (01/11/2005) Computers Can Share Internet but cannot see each other | (01/10/2005) Can't see other computer files |
| (01/09/2005) Can not access host computer from the workgroup | (01/19/2005) Can't see other computer on my network |
| (01/07/2005) Printer on WiFI? | (01/05/2005) ActiveSync and Bluetooth working but I have to force a syn.. |
| (01/04/2005) Can't access wireless LAN | (01/02/2005) wifi - IE6 problem |
| (12/31/2004) Adding an Antenna Pigtail to a WiFi card | (12/31/2004) Can't hold a connection? |
| (12/31/2004) Can't see other computer | (12/30/2004) Belkin WIFI Card |
| (12/30/2004) Can only see one way on network. | (12/26/2004) Can't reconnect to tablet pc after system upgrade |
| (12/26/2004) Can not ping myself, but can ping others | (12/26/2004) can somebody guide me through this step by step? |
| (12/23/2004) need help, new wifi extension has not internet and can't o.. | (12/22/2004) Hit & Miss Wifi |
| (12/22/2004) Wireless Connection through existing cell phone number? | (12/17/2004) Basic WiFi Questions |
| (12/17/2004) Can I run two networks in the same place | (05/30/2007) Can't get file or printer sharing to work |
| (12/14/2004) Can not see network computers | (12/20/2004) Can't setup Broadband Help |
| (01/07/2005) Can't get to files on other computer? | (12/05/2004) Help! Can't get minipci to pickup lynksys router. |
| (12/05/2004) Can't share files | (12/04/2004) Can share files one direction but not the other |
| (12/04/2004) Mapped drive over WiFi network | (11/23/2004) UK: Wanadoo Wifi Bundle |
| (11/14/2004) Can't connect sence SP-2 | (11/19/2004) Sp2 + wifi: new headache |
| (11/12/2004) Can I connect an AP directly to a PC? | (11/09/2004) Frustrated with this network setup, Can Anyone Help? |
| (11/11/2004) Can't VPN to work over an MN-700 wireless network. | (11/04/2004) Can't use bluetooth |
| (10/29/2004) Can't Browse Network or use ICS from XP Home Client | (01/08/2005) Can only access wireless network as Administrator |
| (12/16/2004) WIRELESS NETWORK, CAN'T SEE OTHER COMPUTER | (11/06/2004) Can't get LinkSys WPC54G Version 4 running |
| (10/24/2004) Can you use a wireless access point without a wired network? | (10/26/2008) WIFI connection randomly/non randomly disconnects |
| (10/19/2004) Can't login to domain | (10/20/2004) Is it better to use ASUS WiFi Network Setup software or Wi.. |
| (10/17/2004) Can i setup a 2 computer network without a Wireless Access.. | (10/14/2004) WiFi (ad hoc) network doesn't restore after night of logoff |
| (10/13/2004) With 2PC AND 2WiFi Cards Can I Set Up Network? | (10/21/2004) Set TKIP through a GPO? |
| (10/06/2004) Best Wifi Cable router under £50? | (09/26/2004) Can't find Bluethooth Devices in control panel |
| (09/28/2004) IPAQ Bluetooth+ laptop | (09/22/2004) auto switching from LAN to Wifi connection |
| (09/20/2004) Watching movies over wifi | (09/24/2004) Can i shared flofer`s and printer`s with D-Link G604T ? |
| (09/16/2004) WiFi Hotspot Directory now includes over 12,000 sites incl.. | (10/02/2004) logon using Wireless/WiFI |
| (09/13/2004) Peer to peer wifi setup | (09/12/2004) USR wifi & windows2000 |
| (09/09/2004) Question for Barb Bowman: Wifi Activesync & SP2 | (09/07/2004) Can I do this? |
| (09/05/2004) Can't access network printer or other comp | (09/07/2004) Can't secure connection between access point and wireless .. |
| (08/18/2004) WiFi Continually Disconnects | (08/11/2004) Can not get Internet pages to view over network |
| (08/05/2004) Trouble staying connected to wifi | (07/31/2004) connect to wifi not only getting autoconfig ip |
| (07/27/2004) Wifi can't find my router | (07/26/2004) cannot connect my ipaq 555 to my network |
| (07/24/2004) Free WiFi at Airports, how to use? | (07/20/2004) WiFi Bandwidth issue |
| (07/18/2004) internet sharing via WiFi | (07/29/2004) Dial-up through a Cellphone? |
| (06/23/2004) HELPPP - CAN'T SETUP HOME NETWORK | (06/16/2004) wifi + games = lag |
| (06/16/2004) recommendations for wifi unit as basestation only | (06/11/2004) wifi - can't ping other PC |
| (06/02/2004) No connection with built-in WiFi antenna? | (06/09/2004) Can't Connect to School Server |
| (08/08/2004) locking onto my own wifi signal | (05/21/2004) Can't access Internet after Network Wizard setup |
| (05/24/2004) Can't connect to internet thru router | (05/14/2004) Please help!!! Can't connect! |
| (05/09/2004) Can't use wireless connection | (05/07/2004) Wifi connection lost |
| (05/06/2004) Can't view "unsecure" wireless networks in XP Professional | (05/04/2004) Can't see my network |
| (05/29/2004) Midnight blues with WiFi | (04/21/2004) Very large number of wifi clients |
| (04/28/2009) WiMAX CPE/WiFi AP combo | (09/14/2005) IPAQ2200 WiFi Adaptor |
| (09/12/2005) system intrusion through the internet/wireless internet an.. | (09/05/2005) WGR101 DOES ANYONE KNOW WHERE I CAN FIND MANUAL ON LINE |
| (09/07/2005) WIFI questions | (09/04/2005) WiFi Games? |
| (09/03/2005) How Can I calculate EIRP? | (09/02/2005) securing laptop for public WiFi spots |
| (08/30/2005) ICS problem on WiFi | (09/06/2005) Can Linksys WAP11 v1.07 (4/16/2003) tell which what device.. |
| (08/29/2005) Can USR Max-G router connect at 125 Mbps with USR 8054 Tur.. | (08/25/2005) USB wifi adapters |
| (08/21/2005) Linksys WMP54G & WAG54G can't get through gateway | (08/21/2005) Can you plug a wired nic into a Access point ? |
| (08/24/2005) Trying to setup an offset antenna for wifi | (08/24/2005) Remote WiFi Printing? Is it possible |
| (08/17/2005) internal wifi antenna | (08/15/2005) Wifi on/off switch stays lit-up when off |
| (01/06/2005) Wifi - connection drops when any security is enabled | (01/03/2005) WIFI in USA and UK |
| (01/03/2005) WiFi v WLAN | (12/29/2004) Review of Mega-Wave WiFi 12dbi gain antenna wanted |
| (12/28/2004) WIFI works in Adhoc, but not in "Infrastructure mode" | (12/26/2004) Can You Help? Routing Through a Hub |
| (12/22/2004) Best WIFI cards for PC? | (12/20/2004) Can I run two networks in the same place |
| (12/17/2004) WiFi and Bluetooth | (12/16/2004) whats the best all in one wifi router/modem etc for extend.. |
| (12/14/2004) uPNP - needed on WiFi router? | (12/14/2004) WiFi Security for Semi-Public locations ? |
| (12/11/2004) WiFi network with 1600Ft between two buildings | (12/11/2004) Can't connect to internet - (new to Wireless network) |
| (12/09/2004) Can it be 2 wireless router in a current wireless system | (12/20/2004) Wifi's on 2 Laptops don't detect each other even with nets.. |
| (12/04/2004) Wifi + apps for sales force ? | (12/03/2004) Wifi and Signal finder in one!! |
| (12/03/2004) wifi video trasmitting | (12/03/2004) Multi-home wifi network setup suggestions |
| (12/04/2004) WiFi Interference: Is 802.11a and better than b/g ? | (12/02/2004) FS: UK Lurker selling 3com PCI wifi cards cheap on ebay |
| (12/01/2004) SD WiFi card | (11/29/2004) Can't find Linksys IP |
| (11/30/2004) Suggestions for Condo Wifi Network? | (11/29/2004) Using wifi to link laptop and main computer files? |
| (11/29/2004) wifi power output | (12/02/2004) Newbie: Can someone clone your mac address |
| (11/29/2004) Can I put a directional antenna on my laptop? | (11/30/2004) Can't get ThinkPad T42 to connect to Netgear MR314 w/ 128 .. |
| (11/28/2004) Multi-home wifi network setup suggestions | (11/22/2004) Can AP client mode forward DHCP packets? |
| (11/23/2004) wifi hates wired | (11/18/2004) Possible to share a cable modem through D-Link DSL-G604T a.. |
| (11/17/2004) Can't find profiel | (11/18/2004) Possible to share a cable modem through D-Link DSL-G604T a.. |
| (11/18/2004) Can one router be conencted to another | |
