difference between Wifi repeater and range extender?
More related threads to : difference between Wifi repeater and range extender?
(11/27/2009) Wifi card not supported by mobo?(11/26/2009) About wifi using in mobile phone
(11/26/2009) How to set wifi in mobile phones(11/19/2009) How to configure netgear wireless Router WGR614as a repeater
(11/18/2009) I have wifi but i can use the internet it says cant conect to server(11/18/2009) DCS-2121 wifi ip cameras - fixed ip on router.
(11/18/2009) Wifi cards for desktops(11/17/2009) Not able to connect to mobile using wifi
(11/15/2009) Connect wifi on phone(11/19/2009) PLEASE HELP ME CONNECT WIFI PRINTER TO PC
(11/14/2009) Streaming video over wifi to windows media center...problems(11/11/2009) Wifi is working in ad-hoc but not in infra mode
(11/10/2009) How to control sharing internet access thru wifi(11/08/2009) Vista wifi bridged to xp ethernet
(11/08/2009) Modem router combo need more range(11/08/2009) Wifi reapeter, wireless isp etc?
(11/07/2009) Nintendo DS Wifi(11/08/2009) WiFi interruptions
(11/08/2009) Wifi adapter loads CPU(11/01/2009) Difference between pci and usb wireless lan
(10/31/2009) Ibm R52 wifi shotcut key(10/31/2009) Losing wifi
(10/31/2009) Netgear wifi router(10/31/2009) Windows mobile not connecting to wifi modem's internet
(10/30/2009) Want to supply public wifi in a 1-2 mile coverage area(10/29/2009) HP Firebird 802 Wifi Selection
(10/28/2009) WiFi drops on high CPU load(11/01/2009) Wifi router with WEP WPA(TKIP AES) WPA2(TKIP AES)
(10/27/2009) Wap54g repeater mode(10/25/2009) Cannot connect Ipod Touch to Home Wifi
(10/25/2009) Ipod Tpuch won't connect to WiFi(10/23/2009) My gateway WiFi switch wont turn on
(10/20/2009) Two Wifi Devices Same PC, Is ad hoc or ICS an option?(10/16/2009) Wifi cpe
(10/16/2009) How can my laptop get a wifi connection from another laptop through bl(10/16/2009) Best repeater to set up with dlink dir 615
(10/16/2009) AP that can limit range(12/17/2009) Im about 7 nmiles from a mountain top with wifi!
(10/11/2009) One laptop can connect to the wifi two others cant(10/19/2009) Broadband wireless router 500 meter range
(10/11/2009) Can you alter the range on a router(10/10/2009) Asus WiFi P5K-E-AP internet drops out
(10/09/2009) WiFi handoff problem(10/07/2009) Dlink dwl 2100ap repeater mode problems
(10/10/2009) Differences between N and G(10/05/2009) Wifi Problem
(10/04/2009) Mobile wifi(10/03/2009) Can a wireless router be used as a wifi antenna
(11/20/2009) What is the advantage of having a upnp wifi than normal wifi in a cell phone???(09/28/2009) Vista Wifi sleep problem - I have solution but can't implement it!!!
(10/14/2009) I have problem in my psp wifi connection in security(10/01/2009) Spare wrt54g as a repeater print server
(09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP?(09/22/2009) Tutorial pc use wifi
(10/05/2009) Difference between router and extender(09/20/2009) Configure wifi asus p526
(09/19/2009) Two wifi between to connect what range(09/22/2009) Range of Wireless connection
(09/19/2009) Extend range dir 825(09/17/2009) Powerline vs Long Range Wireless
(09/14/2009) What is the difference between 802 11b/g WLAN wireless AND Built in 802 11b/g WL(09/15/2009) Boosting WiFi signal
(09/09/2009) Making Google WiFi work with a weak signal.(09/09/2009) Setting up an WiFi Access Point....?
(09/15/2009) Recommendation - Repeater(09/01/2009) Long range wifi
(08/31/2009) Best wireless G adapter for range(08/30/2009) Will upgrade from G to N adapter increase G reception range?
(08/25/2009) Edimax repeater to be connected to a baffalo route wireless(08/24/2009) Using two Linksys Wireless routers for broader WiFi Coverage
(08/20/2009) Two routers, no wifi cards, and a next door friend(12/05/2009) Converting a DIR-625 into a repeater
(08/10/2009) NO WIFI(08/09/2009) Cant connect to Internet Exploer when connected to wifi
(08/07/2009) Wifi in my woodshop 300 feet away.(08/07/2009) Wifi in my woodshop 300 feet away.
(08/04/2009) Wireless networking within 500 meter range(08/21/2009) Need advice about long range WiFi Connection
(07/31/2009) Notebooks and wifi antennas(07/28/2009) 2 DSL Modem/Router, how to extend range?
(07/17/2009) Forgot my wifi password but still connected(07/17/2009) use bluetooth to network laptops & share 1 wifi connection??
(07/17/2009) Wifi card not as good on one PC vs another(07/21/2009) Shield AA lithium batteries from WiFi signals
(07/16/2009) Is there a performance difference between USB & PCI based wifi modules(07/14/2009) Wifi sharing
(07/12/2009) Long range Microwave internet Transfer, help(07/14/2009) P5k-e Vista Wifi Acess Point = pulling out my hair!
(07/12/2009) How to secure wifi?(07/10/2009) Strange wifi problem...please help!!!!
(06/26/2009) Long range(06/24/2009) Why Doesn't My Laptop Recognize My Network When its Within Range!????
(06/26/2009) Wifi interference - any workaround?(06/17/2009) Windows XP as WiFi Access Point
(06/16/2009) Pinging and wifi scanning - why do these adapters differ in behavior?(06/10/2009) Odd config between wired/wireless router and wired/wireless AP
(06/10/2009) WiFi help...(06/02/2009) Hoping to go WIFI
(06/02/2009) WiFi Repeater: How to Make?(05/17/2009) Best Home WiFi Router?
(05/16/2009) WIFI card MobilePro 780(05/14/2009) WiFi Hardware for Portable entertainment
(05/14/2009) WiFi Hardware for Portable entertainment(05/08/2009) WiFi Subscription Sites
(05/06/2009) Better range - USB or PCI?(06/10/2009) Repeater Problems WNR3500/WNR3300
(05/15/2009) WiFi Adaptor installation crashes network connection menue(04/25/2009) Wifi server
(05/04/2009) Wifi between two houses 1000-1200 ft apart(10/01/2009) How to add wireless repeater to Dlink DIR-825
(11/03/2009) USB 500mW WiFi adaptor(04/14/2009) Need help with my Asus WiFi
(04/09/2009) GSM/WIFI PHONE/Dual mode mobile phone/wifi video phone/ smart phone(04/09/2009) Wifi phone/wifi voip phone/wifi ip phone with roaming functions
(04/10/2009) Wireless bridging/repeater for neighbor's network(03/28/2009) Linksys by Cisco does it has wifi?
(03/26/2009) Does a Wireless N Adapter's extended range apply to G networks?(03/19/2009) I need to get a repeater to improve my existing router ...HELP
(03/23/2009) Extended range(03/14/2009) FASTEST, Longest Range and most reliable wireless router?
(03/12/2009) Connecting Mobile to Laptop to Share WiFi using Bluetooth(03/12/2009) Netzero and Wifi
(03/10/2009) Can you connect a wireless 2.4ghz mouse to a wifi chip in a laptop(03/10/2009) New "N" router has no range
(03/03/2009) Enhance wifi signal(03/03/2009) Enhancing wifi signal
(11/22/2009) How to connect to internet using wifi from mobile phone?(02/28/2009) WiFi on a Compaq Evo N800c
(02/03/2009) Cable tv over wifi(02/04/2009) Connect 3 PC's via switch to WiFi Access Point to WiFi
(11/12/2009) Verizon Fios + Wireless Repeater/Range Extender -Please Help(02/03/2009) Options for Extreme Range
(01/24/2009) Wireless range extender or replace antennas?(11/06/2009) Need to extend wireless range at home. Pls help.
(01/11/2009) Wifi conection sharing(01/11/2009) Repeater
(12/30/2008) Secured WiFi at School?(12/02/2008) Difference between Access point and Router?
(12/13/2008) My laptop is not able to connect to WiFi Network after reinstal OS(12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients
(11/13/2008) Wifi laptop stealing bandwidth??(10/21/2008) Will a Range extender work in this case?
(10/09/2008) WiFi Competitor Uses Visible Light While Cleaning RF Spectrum(10/10/2008) Connect two routers via wifi?
(10/21/2008) Printing trough wifi in LAN(09/18/2008) wpn824 as repeater ?
(09/08/2008) Help needed configuring D - Link DWL 2200 AP as repeater(09/03/2008) How to Lan between 2 laptops (Wireless) without a router???
(08/29/2008) Combining Wifi connections(08/31/2009) Help with Wifi please
(08/25/2008) Wifi Vista to Ethernet XP?(08/14/2008) Product to boost range
(08/10/2008) Using two Wifi with one Cable modem(08/04/2008) Access point vs router vs repeater vs media center extender
(07/18/2008) Directional Wireless Networking between two ranches.(07/12/2008) ** Still Same Not Able To Enabale Wifi In Aspire 3690 **
(08/01/2008) Belkin F5D8053 wont connect to any wifi(06/30/2008) Linksys WMP54G 4.1 Trouble picking up wifi signal WinXP SP2 32-bit
(06/02/2008) p5w and my wifi ap solo(05/17/2008) increase range on laptop?
(05/11/2008) Pooling, Loadbalancing,Bridging three wifi connections ?? Questions?(05/10/2008) help with linksys wre54g extender
(03/20/2008) Will a wireless N router improve range of wireless G notebook?(03/12/2008) MIMO Wifi is slow, or is it normal?
(03/15/2008) Add wifi to Gateway 500S w/wired LAN(02/24/2008) 100m WiFi
(02/20/2008) Simple tutorial for establishing wi-fi connection between ppc and winx(02/06/2008) Folder Share between Vista PC's
(11/26/2007) Problem....Copying between two system via wireless...overload(11/17/2007) WIFI
(11/09/2007) DLINK DSL G604TRouter + P5K-e/wifi AP Help(12/06/2008) BT Home Hub range problems!
(10/09/2007) Wireless accesspoints between 2 buildings(10/04/2007) Choosing Wireless Router, BIG RANGE
(08/18/2009) How to connect to Internet, through WiFi; a problem(09/30/2007) Wifi problems on laptop
(09/03/2007) Real Range of Wireless Router(08/25/2007) Help! Need a router with LONG RANGE
(08/21/2007) can connect with ethernet but not wireless, conflict with wifi card?(08/05/2007) Wifi Not Connecting - Wired Works Fine
(08/07/2009) Vista & wifi - Can see wireless networks but can't connect to them!(07/26/2007) Having problems with Asus Wifi AP dropping connection
(07/23/2007) Regarding increasing the WiFi range(07/19/2007) Setting up wifi for 18 people
(09/17/2007) Problems connecting to unsecured wifi network in Vista(07/18/2007) Extending wireless range
(06/02/2009) Need advice regarding extending WIFI network (picture included)(06/26/2007) WiFi connected to access point but can't find internet
(06/19/2007) Windows Media Center Extender for Vista?(05/17/2007) Wifi better than cat 5 ????
(04/16/2007) First Time WIFI Setup(04/17/2007) Advice on Extender Choice
(04/11/2007) Range extender problem(04/14/2007) CounterStrike Source causing loss of WiFi connection
(02/23/2007) extend range....(02/05/2007) 1st PCI-E Wifi AP combo card! Wireless network card!
(02/06/2007) US Robotics wifi router(02/02/2007) WiFi Repeater set up! Major headaches. Can you help?
(01/18/2007) Netgear trouble with 2 wifi's :((01/11/2007) What are the differences between Wifi and 802.11b/g?
(06/21/2007) wireless range for neighbours(12/17/2006) Antenna Range
(12/09/2006) Noobness Dual Ethernet Mobo + Wifi question(12/08/2006) PSP wifi connection
(07/15/2009) roaming between ap's with wds link(01/15/2007) Wireless bridge between 2 buildings?
(11/15/2006) How can make link between tow devices WRT300N(11/03/2006) packet injection and monitor mode wifi cards
(11/11/2006) I need to extend wireless range on my notebook computer(11/09/2009) Range extension using WDS setup question
(03/23/2007) My neighbours are intruding my wifi security enabled network(03/17/2009) Desktop WiFi Card
(10/26/2006) how can i get wifi?(10/25/2006) l33t help needed. Using bittorent on my neighbours wifi....
(10/23/2006) Extend range of Toshiba A75-S231 wireless(10/10/2006) USR Wireless Access Point 5450 + MAXg Range Extender 5441a
(01/26/2007) Need to setup a wireless lan between 2 building 150m away .(09/22/2006) WiFi Tweaks.
(02/14/2007) Phantom ssid in dlink dwl-G710 range extender's site survey(09/18/2006) usb wifi adapter drops to 1mbs when connected in bridge!?
(09/15/2006) usb wifi adapter drops to 1mbs when connected in bridge!?(08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help
(08/16/2006) Normal throughput between connected computers?(08/16/2006) Wifi gurus!! Please assist! Multi AP setup on 1 subnet
(08/07/2006) Wireless network connection between a desktop and laptop(09/12/2006) Difference between antenna
(10/14/2009) I have a wifi lap top what do I do next?(07/25/2006) Max range with regular 802.11g laptop?
(04/07/2008) WiFi and Dialup?(08/02/2006) Help with Bridging internet between two buildings WinXP
(07/09/2006) Got Wifi connected, but can't get a network going(07/08/2006) Long range wireless adapter
(07/18/2006) SET UP MY OWN WIFI BUT NEED A LITTLE HELP PLEASE(07/01/2006) quick question about signal range and distance
(06/21/2006) Can you disable built in WiFi in favour of an external WiFi?(06/15/2006) 2 wireless pcs; WRT54GS router & WRE54G Range Expander
(06/12/2006) Connecting two wired switches with wifi + using access point(07/27/2006) Needing router with range
(06/04/2006) connecting to home network between PC and Laptop(06/04/2006) Recommendations for extending wifi signal
(05/12/2006) newbie to the wireless game...range problems(05/19/2006) linksys wifi issue
(05/07/2006) How to share wifi with a device that cannot logon?(05/24/2006) PCI WiFi question
(04/29/2006) 2 Mile range with dish(04/05/2006) My WiFi card worked before I formatted my laptop!?
(12/10/2006) Roaming WiFi issues - 3 APs, one switch, one SSID(03/14/2006) My Wi-Fi range has shrunk!
(03/06/2006) PLEASE HELP Wiresless Router and Repeater(02/27/2006) Looking for Wlan-Router with huge range
(05/04/2006) wifi spectrum analyzer?(09/14/2005) How can I use WDS as repeater ?
(09/15/2005) Extending my wireless network with a repeater(11/11/2004) REDUCING Range
(11/11/2004) REDUCING Range(01/15/2006) How do i increase bandwidth between 2 comps on my lan?
(01/25/2006) Linksys wifi Router runnin on cable..(09/24/2005) Network in range... won't detect
(03/19/2006) auragrid wifi extender(09/26/2005) wifi & iwconfig
(09/22/2005) Long Range wifi troubles(04/11/2009) WiFi security settings
(04/02/2004) Screwy behavior from different wifi pc-cards(04/02/2004) Wireless network options between neighbors
(04/01/2004) ICS and wifi(09/06/2005) Wifi connection dropping or timeout ....
(09/20/2005) Network between 2 cars(09/27/2005) Wireless Extender kills my internet connection
(09/17/2005) Extending range of wireless router(09/21/2005) Need to boost range of wireless
(09/28/2005) Range of Wireless Networking.(01/16/2006) Using Linksys WRT54G to connect to another wifi router
(01/19/2006) Recommend an access point, 4-p Router wifi(01/28/2006) CAVEMAN ASK: HOW FAR COMPUTER WORK, WIFI DISTANCE, YARDS?
(11/28/2005) Home Network Range Problem/Paradox...Advice?(01/15/2006) Will this WiFi setup work?
(01/10/2006) Wifi Signal Mapping question(09/28/2005) Syncing Outlook between desktop and laptop
(09/25/2005) Difference In Wireless Cards?(09/21/2005) wpa-psk & repeater
(09/19/2005) wireless range not quite enough(12/30/2005) File sharing between wired and wireless
(09/15/2005) How can I use WDS as a repeater ?(09/13/2005) Accessing a wifi printer
(09/08/2005) Switching between automatic IP address/DNS server, and cho..(09/07/2005) Multiple users logged on one machine with WiFi... is it po..
(09/07/2005) Basic setup - USB WiFi on 2 PCs for Internet Sharing... ho..(09/06/2005) File shareing between PPC and Desktop
(09/01/2005) How do I boost my Network range?(08/31/2005) Wifi connection lost
(09/20/2005) Win XP PRO SP2 WiFi and DHCP(08/24/2005) Frequent WiFi Disconnects
(08/16/2005) Determine Wireless Range from AP(08/08/2005) No wireless networks were found in range
(08/02/2005) Periodic breaks in connection between router and PCMCIA card(07/27/2005) Speed up file transfer between home network
(07/27/2005) Wirless Network between 2 PCs(07/25/2005) Laptop Only Uses WiFi, Refuses to Use Wired LAN When Conne..
(07/22/2005) Repeater network(07/16/2005) MN-700 range
(07/02/2005) How to extend the range of my MN-700 Base Station(06/30/2005) Weird Wireless Range problem
(06/28/2005) can not share printer between xp pro and xp home(06/20/2005) Sharing printers between XP and 2000
(06/18/2005) Dial-up sharing with WiFi(06/16/2005) Two wifi networks?
(06/10/2005) Channel and range(06/07/2005) Wifi et Activesync
(06/01/2005) wireless speed difference(05/25/2005) connexion wifi intermitente
(05/25/2005) WiFi card disconnects on logout (XP SP2)(05/14/2005) Question on WEP and Linksys WRE54G Range Extender??
(05/03/2005) How change user name on Linksys Router and Range Extender?(04/26/2005) WiFi doesn't work with LAN card in WINXP sp2
(04/25/2005) WinExplorer slowdown / crash on Wifi transfers(04/20/2005) repeater
(04/20/2005) Lost WIFi connection on each reboot(04/14/2005) File sharing from a WIFI PC with nobody logged on - How to..
(04/11/2005) New WiFi Set Up(04/11/2005) WiFi Connection Nightmare
(04/24/2005) Improving signal / range(04/05/2005) Can't share between two computers
(04/08/2005) one CAT5 cable, two WiFi laptops(04/04/2005) Roam from Gprs network to Wifi network
(04/09/2005) Not connecting to DWL-G800AP Extender(03/26/2005) No IP connectivity between Ad-Hoc network with excellent s..
(03/26/2005) Network cycle between available and unavailable(03/25/2005) wifi newbie
(03/19/2005) PC Screen Output to TV via Wifi(03/17/2005) No Wirless Networks In Range
(03/22/2005) D-Link AP as repeater setup(03/25/2005) wifi mystery
(03/10/2005) One wifi laptop(03/11/2005) One wifi laptop
(03/10/2005) Fed up of no WiFi(03/10/2005) Home WiFi security
(03/09/2005) Offline Folders, VPNs, & WiFi(03/13/2005) bluetooth network problems between laptop and desktop
(02/21/2005) Interconnect problems between XP/SP2 and 98SE(02/22/2005) no wireless network were found in the range
(02/17/2005) break Wifi ?(02/16/2005) Prevent user from modifying WiFi settings
(02/03/2005) Range on a pair of Belkin 54G routers in wireless bridge m..(01/29/2005) Wifi Acer
(02/15/2005) aggravating wifi prob(01/16/2005) can you use a wireless repeater/access point in place of a..
(01/22/2005) USR2216 WiFi card causes Win XP to crash - newbie need help!(01/31/2005) win 64 asus wifi driver
(01/07/2005) Printer on WiFI?(01/02/2005) wifi - IE6 problem
(12/31/2004) Adding an Antenna Pigtail to a WiFi card(12/30/2004) Belkin WIFI Card
(12/23/2004) need help, new wifi extension has not internet and can't o..(12/22/2004) Hit & Miss Wifi
(12/17/2004) Wireless Won't Recognize in Range Networks(12/18/2004) Cannot share internet between wireless network
(12/17/2004) Basic WiFi Questions(12/29/2004) no wireless networks in range
(12/04/2004) Mapped drive over WiFi network(12/02/2004) Media Extender for XBOX
(11/25/2004) difference between 802.3b and 802.11b(11/23/2004) UK: Wanadoo Wifi Bundle
(11/19/2004) Sp2 + wifi: new headache(10/31/2004) Reported Wireless speed w/ repeater 7-9x Measured Speed
(10/30/2004) Unnecessary Network trafic generated between only two comp..(10/31/2004) No Wireless Network in Range - post-reinstall
(10/25/2004) wireless range(10/26/2008) WIFI connection randomly/non randomly disconnects
(10/20/2004) Is it better to use ASUS WiFi Network Setup software or Wi..(10/13/2004) Can I activesync through my wifi on my Ipaq 4150 not the b..
(10/14/2004) WiFi (ad hoc) network doesn't restore after night of logoff(10/06/2004) Best Wifi Cable router under £50?
(10/01/2004) How do I transfer files between desktop and notebook(09/28/2004) printer sharing between xp home and win98se
(09/22/2004) auto switching from LAN to Wifi connection(09/20/2004) Watching movies over wifi
(09/16/2004) WiFi Hotspot Directory now includes over 12,000 sites incl..(10/02/2004) logon using Wireless/WiFI
(11/05/2004) DLINK Repeater setup(09/13/2004) Peer to peer wifi setup
(09/12/2004) USR wifi & windows2000(09/18/2004) Major problems roaming between access points
(09/09/2004) Question for Barb Bowman: Wifi Activesync & SP2(09/07/2004) Can't secure connection between access point and wireless ..
(08/19/2004) Difference : WEP open / shared ?(08/18/2004) WiFi Continually Disconnects
(08/05/2004) Trouble staying connected to wifi(07/31/2004) connect to wifi not only getting autoconfig ip
(07/27/2004) Wifi can't find my router(07/24/2004) Free WiFi at Airports, how to use?
(07/20/2004) WiFi Bandwidth issue(07/18/2004) internet sharing via WiFi
(07/04/2004) Repeater for an Origo 7210(06/16/2004) wifi + games = lag
(06/16/2004) recommendations for wifi unit as basestation only(06/11/2004) wifi - can't ping other PC
(06/12/2004) Wireless connection between 3 computers(06/08/2004) switching between wireless profiles?
(06/15/2004) 802.11g Range Shortage Problem for WLAN(06/02/2004) No connection with built-in WiFi antenna?
(05/27/2004) Wireless repeater(05/23/2004) Sharing printers& files between XP Pro & 98Se computers
(08/08/2004) locking onto my own wifi signal(05/22/2004) Switch between wired domain and wireless workgroup networks
(05/21/2004) Cannot communicate between 2 computers(05/17/2004) range
(05/16/2004) repeater recognition(05/12/2004) Extend wireless range
(05/07/2004) Wifi connection lost(04/25/2004) on the same wireless LAN, how to route a packet between 2 ..
(05/29/2004) Midnight blues with WiFi(04/21/2004) Very large number of wifi clients
(04/21/2004) Wireless 'bridge' between two physical parts of an etherne..(01/11/2006) Differences between Windows 2000 and XP handling of wireless
(04/14/2004) Wireless range,(04/13/2004) Too much range? Too much security?
(04/28/2009) WiMAX CPE/WiFi AP combo(09/14/2005) IPAQ2200 WiFi Adaptor
(09/06/2005) Wireless roaming between access points connected by a switch(09/07/2005) WIFI questions
(09/04/2005) WiFi Games?(06/09/2006) How to configure 3com officeconnect AP as repeater
(09/02/2005) securing laptop for public WiFi spots(09/01/2005) D-Link AirPlus Wireless Range Extender ?
(08/30/2005) ICS problem on WiFi(08/29/2005) Westell 327 Signal Repeater?
(08/25/2005) USB wifi adapters(08/22/2005) Angle of antenna? Make any difference?
(08/21/2005) Roaming between Linksys WAP54G APs works!(08/09/2009) Using a Netgear WG602 in Repeater Mode (Please Help!)
(08/24/2005) Trying to setup an offset antenna for wifi(08/19/2005) measure thruput between wireless card and wap
(08/24/2005) Remote WiFi Printing? Is it possible(08/17/2005) internal wifi antenna
(08/15/2005) Wifi on/off switch stays lit-up when off(08/15/2005) Using WRT54G WDS Repeater?
(08/13/2005) Help with Gateway Router and Range Extender(08/13/2005) Long range 802.11 kit for auction...
(08/13/2005) aerial or wap or repeater(08/14/2005) WRT54G as repeater
(01/06/2005) Wifi - connection drops when any security is enabled(01/05/2005) Compatibility issues between wg511v2 and Belkin Pre_N Wire..
(01/03/2005) WIFI in USA and UK(01/03/2005) WiFi v WLAN
(01/03/2005) WGR614 as range extender / WAP(01/08/2005) extending wireless range?
(12/31/2004) HELP: turned on WEP, and range plumetted(12/29/2004) Review of Mega-Wave WiFi 12dbi gain antenna wanted
(12/29/2004) Usable Range(12/28/2004) WIFI works in Adhoc, but not in "Infrastructure mode"
(12/25/2004) Experiences with thruput between DWL-2100AP and MP115 ?(12/25/2004) Wireless router range
(12/23/2004) range expansion/signal boosting(12/22/2004) Best WIFI cards for PC?
(01/08/2005) What is a wireless repeater?(12/21/2004) What is a wireless repeater?
(12/19/2004) Repeater problem(12/20/2004) Best Long Range Wireless PC Card or USB?
(12/17/2004) WiFi and Bluetooth(12/17/2004) a repeater
(12/16/2004) whats the best all in one wifi router/modem etc for extend..(12/15/2004) Starwood (Sheraton) properties and Wi-Fi range extender fr..
(12/14/2004) uPNP - needed on WiFi router?(12/14/2004) WiFi Security for Semi-Public locations ?
(12/11/2004) WiFi network with 1600Ft between two buildings(12/10/2004) Extending the range of a 3com wireless router
(12/13/2004) Linksys Wireless-G Range Expander(12/10/2004) Out of range?
(12/20/2004) Wifi's on 2 Laptops don't detect each other even with nets..(12/06/2004) Newbi question: receive/transmit differences between PCMCI..
(12/06/2004) Best solution for increasing range(12/06/2004) Best Antenna To Use To Extend Wireless Range As Far as Pos..
(12/08/2004) ping Request timed out between wireless laptops(12/09/2004) File Sharing Between Wired and Wireless Computers
(12/04/2004) Wifi + apps for sales force ?(12/03/2004) Wifi and Signal finder in one!!
(12/03/2004) wifi video trasmitting(12/03/2004) Multi-home wifi network setup suggestions
(12/04/2004) WiFi Interference: Is 802.11a and better than b/g ?(12/02/2004) FS: UK Lurker selling 3com PCI wifi cards cheap on ebay
(12/01/2004) Any way to extend range of internal wireless PCI card in PC?(11/30/2004) AP in repeater mode..
(12/01/2004) SD WiFi card(11/30/2004) Linksys WRT54G as a repeater or print server?
(11/30/2004) Suggestions for Condo Wifi Network?(11/29/2004) Using wifi to link laptop and main computer files?
(11/29/2004) wifi power output(11/28/2004) REDUCING Range
(11/28/2004) WAP54G V1.1 in Repeater Mode(11/28/2004) Multi-home wifi network setup suggestions
(11/25/2004) MAC Filter required on repeater?(11/30/2004) repeater problem with wap11
(12/22/2004) Linksys WAP-11 in Repeater Mode(11/23/2004) is this range normal?
(11/21/2004) Sweex "wireless adsl modem/router" No connection between c..(11/23/2004) wifi hates wired
(11/21/2004) 802.11b vs 802.11g and range problems(11/22/2004) REDUCING Range
(11/16/2004) authentication range Linksys
Sponsored links
