accesss denied on downstairs computer. what is node type "..
More related threads to : accesss denied on downstairs computer. what is node type "..
(11/28/2009) Computer doesn't recognize anymore hardware wireless adapter DWL-520(11/24/2009) What does validating identity mean, a dir615 router, xp home
(11/24/2009) I have to add a computer to the wireless network repeatedly to get my laptop to(11/23/2009) Computer randomly crasches after installing a new network card... Help!
(11/22/2009) How do I put my Vista computer in DHCP mode?(11/20/2009) Administrative priveleges on my computer which im the administrator
(11/17/2009) What is the best wireless ethernet adapter out there dollar for dollar?(11/10/2009) What router disables wireless quick and easy?
(11/01/2009) What Wireless equipment is compatible with 802 3ad ?(10/31/2009) Adding wireless networks for all users on a computer
(10/28/2009) I set my netgear wep now what do i do(10/27/2009) What happens when router loses connection
(10/27/2009) To find out the old computer name(10/30/2009) What is my wpa passphrase
(10/25/2009) Does my gateway computer have wireless(10/24/2009) Unlock my network security key home computer
(10/22/2009) Wireless processing from computer to computer(10/19/2009) Need advice what wireless router to buy
(10/05/2009) Seeing a printer through another computer??????(10/05/2009) What is spi mode in a router
(09/29/2009) Lag spikes every minute... what should I do?(11/20/2009) What is the advantage of having a upnp wifi than normal wifi in a cell phone???
(10/11/2009) New to home wireless:what do i do/need?(09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP?
(09/21/2009) How to boost signal from computer?(09/23/2009) What is the BEST wireless 802.11n router?
(09/23/2009) Set up my wireless network, what router, what networkcard in my laptop(09/19/2009) Two wifi between to connect what range
(10/30/2009) What is the best wareless rooter for gaming(09/14/2009) What is the difference between 802 11b/g WLAN wireless AND Built in 802 11b/g WL
(09/07/2009) Networking/wireless internet question- not really sure what to do(08/26/2009) Need help to connect my wii to my computer
(08/24/2009) What to buy(08/21/2009) What's the Issue?
(08/12/2009) No more than 1 computer on the internet at a time.. please help(08/02/2009) Internet from one computer but not another??
(07/31/2009) What wireless card?(07/27/2009) My computer connection is unreliable, do I need a new router?
(07/27/2009) My computer connection is unreliable, do I need a new router?(07/28/2009) My computer connection is unreliable, do I need a new router?
(07/18/2009) Computer connected, linked, but explorer won't open a website.(07/16/2009) I need to connect a computer to a wireless network, how?
(07/08/2009) 1 computer, one router(06/29/2009) What do you recommend for this setup?
(06/02/2009) Computer(06/09/2009) What PCi card is best for me??
(05/30/2009) What kind of wireless device do I need?(05/19/2009) What Do You Think of Microsoft VirtualWiFi?
(05/19/2009) Computer crashes when setting up a Static IP Address.(05/13/2009) Upstairs/downstairs, how to get a wireless signal
(08/13/2009) How does a mobile node send traffic to hosts in its home network?(04/25/2009) What do I need to connect to this router?
(02/22/2009) Computer as a wireless bridge(02/18/2009) What do I need to set up wireless internet on my PC and my PS3?
(02/17/2009) Cant connect to a network. What happen if two wireless cards.(02/12/2009) My computer won't recognize by new wireless router
(02/10/2009) What hardware do I need for a large network?(02/06/2009) What problems might there be?
(02/01/2009) Network transfer speed slow only on one computer(01/30/2009) What are the best 802.11n routers band now?
(02/09/2009) What wireless adapter (PCI-E or USB) would you recommend?(01/24/2009) Wireless router downstairs. desktop upstairs
(01/21/2009) What's Wrong With my Internet??? :((((((01/02/2009) What is the best Wireless G adapter (PCI or USB... whichever is better
(01/02/2009) What could be keeping my speed down?(01/04/2009) No internet on other computer...PLS HELP ME:(
(10/18/2008) What type of wireless router do I need? plz help me!(09/22/2008) Hot spot hopper... What to get?
(09/20/2008) which router - what adapters(08/27/2008) What is a good router to buy?
(09/22/2008) What Wireless PCI Card?(08/22/2008) What are the techniques which can be used to improve the accuracy ?
(07/25/2008) What wireless router is best used with an Att DSL Modem?(07/07/2008) setting up internet on 2nd computer
(04/18/2008) What is a more secure setting ?(04/06/2008) Connecting wireless client and wired printer to a XP computer
(01/29/2008) looking for good reviews on wireless routers, what to buy?(08/25/2008) What's wrong with my wireless connection?
(12/30/2007) what is the max thoughput of wireless draft-n(12/03/2007) What else would I need
(10/08/2007) Printing network from wireless computer(08/22/2007) What would you say I should do?
(07/06/2007) Wireless AV transmitter/receive for computer?(05/02/2007) I activated WEP and second computer will not connect anymore
(05/09/2007) What is going on with my Wireless network...!?(06/21/2007) What to replace my 2db antenna with on my DG834GT Router?
(03/11/2007) From cable tv to my PC wireless streaming? What do I need?(01/31/2007) KVM Switches - what to know?
(01/11/2007) What are the differences between Wifi and 802.11b/g?(01/03/2007) n, g, what?
(11/13/2006) What's wrong with my setup? I can't go anywhere...(11/11/2006) I need to extend wireless range on my notebook computer
(06/09/2008) Dlink DWA-542 - Computer locks up installing CD-Rom/Drivers(10/17/2006) What is best to use? WWZC or manufacturer's software?
(10/14/2009) I have a wifi lap top what do I do next?(07/17/2006) Computer does not work if both wireless and cableLAN enabled
(11/13/2008) Have you used the USR 5453 access point? What doyou think?(05/16/2006) What is the best wireless router for G connection?
(03/11/2006) Can't access host computer(01/31/2006) What hardware do you recommend for a bussiness network?
(09/27/2005) Add a computer to an existing wireless network(09/25/2005) outdoor type enclosure for a Veo wireless camera?
(04/02/2004) Netgear Support. What a Joke!(02/02/2006) Keep one computer off network
(01/28/2006) CAVEMAN ASK: HOW FAR COMPUTER WORK, WIFI DISTANCE, YARDS?(01/19/2006) How make client computer recognize it's on ICS with ad-hoc?
(09/30/2005) Folders sharing denied(09/28/2005) Wireless Connection in my computer?
(09/23/2005) unable to logon to my network computer(09/10/2005) Node Type Peer-Peer. How can I change that?
(09/08/2005) Computer not accessible. Network path not found(09/05/2005) one computer can't see other workgroup computers
(08/30/2005) Cannot get my computer to serve a shared folder(08/18/2005) access point and unwired computer
(08/16/2005) file sharing aand seeing computer in workgroup(08/15/2005) Wireless Network dropped one computer...
(08/13/2005) Newbie question - what kit do I need?(08/24/2005) What are risks of WLAN connections at internet cafes?
(08/11/2005) Connecting a new computer to an office network(08/08/2005) Is what I want to buy even out there?
(08/05/2005) Can't save Word document to networked computer!(08/10/2005) What is Ethernet?
(07/04/2009) Have an unknown computer in my workgroup(08/05/2005) Access denied????
(08/02/2005) 2 computer Peer to Peer - one computer not able to be ping..(07/31/2005) New computer, New OS, New Wireless Problem :-
(07/18/2005) Can't see the other computer! please help(07/18/2005) workgroup computer not accessible
(07/16/2005) Need help adding computer to network(07/18/2005) New Computer to add to Netwrok
(07/11/2005) EAP type list doesn't populate with anything(07/07/2005) How do I link a wireless computer to a DSL computer?
(07/04/2005) how to connect the internet to anothet computer???(07/11/2005) What XML is supposed to be sent back after WPS signup?
(06/04/2005) a problem concerning the computer using wireless card(06/03/2005) can see each share folder/computer but only one can access?
(07/02/2005) Blocking internet access on networked computer(05/22/2005) How do I setup a network with a wired computer and wireles..
(06/02/2005) Moved printer to new PC. Can't add computer/printr to wire..(05/17/2005) New Computer Network 2 XP Versions
(05/16/2005) access is denied on wire-less computer(05/11/2005) what kind of client do i need ??
(05/11/2005) permission to access computer on network(04/19/2005) "Modem Secure"? What password to use?
(04/14/2005) Computer Certificate Template(04/13/2005) Authenticate as computer when computer information is avai..
(04/13/2005) Why am I getting denied access to wireless network(04/11/2005) Help, 2nd computer connected, can't access internet
(04/11/2005) Computer Programs(04/08/2005) Host computer Sharing
(04/12/2005) Computer policy processing(04/01/2005) Type of Wireless Access Point needed with EAP-TLS
(03/26/2005) connection lost when computer goes to sleep(03/23/2005) What Is ZigBee?
(03/22/2005) 802.1x EAP type setting changes for no reason(03/21/2005) Windows 2000 and computer certificates
(03/25/2005) Adding Apple Macintosh computer to mt network(03/15/2005) 2nd network computer can't see 100% of files in certain fo..
(03/15/2005) Access is denied - Folder is private?(03/13/2005) computer keep restarting.
(03/15/2005) authenticate as guest when computer or user information is..(03/07/2005) Internet very slow on wireless computer
(03/05/2005) seeing computer from one comp but not that other(04/05/2005) unwanted computer on network
(03/06/2005) Computer Recognition Problem(02/15/2005) Connecting 3 computer
(02/15/2005) New computer wireless PCI adapter setup mistake recovery(01/24/2005) what is the dos command to view available wireless network?
(01/14/2005) Computer says it's connected to network but no internet co..(01/10/2005) Can't see other computer files
(01/08/2005) What is a channel?(01/08/2005) What are channels?
(01/09/2005) Can not access host computer from the workgroup(01/19/2005) Can't see other computer on my network
(01/07/2005) my computer wont start(01/07/2005) Access to workgroup denied
(01/05/2005) RADIUS Server that Forces User *and* Computer Authenticati..(12/31/2004) Can't see other computer
(12/30/2004) What is the 3rd group of #'s in an IP address and why do t..(12/23/2004) IE Type 221
(12/19/2004) Computer to computer with Wi-Fi(12/14/2004) What is the radius of the single of the router???
(12/07/2004) one computer can access shared files the other can't even ..(01/07/2005) Can't get to files on other computer?
(11/17/2004) what is the ad_hoc network?(11/18/2004) IEEE 802.1x EAP Type Not Showing
(11/13/2004) Access denied over wireless network(11/04/2004) I can't get my laptop, or any computer to recognizer a sha..
(10/31/2004) Replacing UTP with wireless, what equipment?(12/16/2004) WIRELESS NETWORK, CAN'T SEE OTHER COMPUTER
(11/03/2004) Longhorn Wireless Diagnostics: What's important to you?(10/17/2004) Can i setup a 2 computer network without a Wireless Access..
(10/13/2004) 2 connections on one computer!(10/12/2004) Access denied
(10/11/2004) What type of Certificate server?(10/06/2004) Wired and wireless computer
(10/13/2004) so... what's the trick in getting wireless working on Serv..(09/26/2004) Computer cannot be pinged
(09/21/2004) accessing other computer via wireless(09/15/2004) Accessing applications on each computer using wireless net..
(09/14/2004) Network Computer Reboots when Laptop Connects to Wireless ..(09/03/2004) Cannot access other computer!
(08/30/2004) Connecting to other computer(08/25/2004) what is a 1394 connection and a Network Bridge?
(08/20/2004) WPA - User or Computer(08/11/2004) Access Denied
(08/03/2004) Creating a network with a single wireless computer(07/31/2004) Seeking advice on what to buy for Win98/XP home network...
(07/14/2004) Wireless, what else?(07/23/2004) Computer to computer connection
(06/26/2004) What's the IEEE 802.11?(06/21/2004) 1 computer 'network' Wireless vs Fishooking cable
(06/08/2004) can't view my 2000 computer on my network(06/06/2004) Authenticate as computer and wireless security
(06/01/2004) What software can I use to configure Wireless settings(06/01/2004) Computer Boots up Slowly
(05/15/2004) does my computer have a wireless card(05/13/2004) Computer Freezes
(05/17/2004) client computer keeps getting 169.254.xx address(04/25/2004) One computer not showing up in my workgroup
(04/21/2004) What do I need for LAN/ICS via Bluetooth(04/23/2004) What is good wireless hardware to connect PC to TV
(09/03/2005) european online computer stores?(09/06/2005) Can Linksys WAP11 v1.07 (4/16/2003) tell which what device..
(08/30/2005) Connecting Via Wireless & VPN to a mobile computer(08/19/2005) determine computer name thats sharing out wireless
(08/29/2005) What am I doing wrong???(01/08/2005) What is this connector?
(12/28/2004) What Best USB 54G Adapter for a Desktop?(12/22/2004) What to use?
(01/08/2005) What is a wireless repeater?(12/21/2004) What is a wireless repeater?
(12/20/2004) What happens when an 810.11g AP has "b" and "g" clients at..(12/19/2004) What are typical ping times for a WLAN?
(12/21/2004) What are typical ping times for a WLAN?(12/17/2004) What distance to expect
(12/13/2004) What can they see?(12/10/2004) Output from pinging in MS-DOS window. What does it mean?
(12/04/2004) To what use(s) could I put a second wireless router?(11/29/2004) Using wifi to link laptop and main computer files?
(11/12/2004) What's the cheapest WiFi AP ?(11/11/2004) Have to keep restarting cable modem,: What does this mean?
(11/09/2004) what's a repeater?(11/08/2004) USR2249 Antenna settings. what is what?
(11/01/2004) Vonage Phone,Wifi, Traveling, with What Router?(10/30/2004) how does proxy mobile ip work with arp on the mobile node?
(10/18/2004) computer cant diside on an ip address(10/17/2004) G604T and Computer to Computer speed problem
(10/17/2004) WiMax and HiperMan;What are they realy about?(10/04/2004) What authentication system?
(10/08/2004) What is diff between DLink DWL-G810 and DWL-2100AP bridges?(09/27/2004) Want to set up wireless network in house - what do I need?
(09/23/2004) Bridging 2 small workgroups - what to buy?(09/23/2004) So what's the reccomended wireless solution these days?
(09/08/2004) Wireless node(09/05/2004) What would you recommend for AP
(09/06/2004) What happens if someone fakes an existing MAC address?(09/02/2004) What is a bridge - and do I need one?
(08/29/2004) Bad Netgear WG111 or what?(08/29/2004) New Wireless Router - What you recommend?
(08/24/2004) same card, different computer, different results(08/20/2004) the dell 1170 wireless base station - What is the deal??
(08/14/2004) Antenna: AP or Computer?(08/08/2004) What do you guys think of Netgear FWG114P?
(08/07/2004) Can a desktop computer be used for wireless internet?(08/07/2004) RF Survey -- what's involved or how to do it??
(07/29/2004) What is the diff between Cisco AIR-BR340 and AIR-BR342?(07/30/2004) What is a BEACON SCANNER ?
(07/28/2004) Different brands of AP's and cards - what to use?(07/20/2004) acc point as bridge/feed for game or other computer
(07/18/2004) 2nd Computer Freezes(07/19/2004) What am I doing wrong ?
(07/18/2004) what is "interference robustness"?(07/15/2004) What's the scoop on Broadcom's 125
(07/15/2004) What s a "good" signal?(07/14/2004) What do you thin about ORINOCO AP 600 ?
(07/12/2004) Linksys.....what have I got here?(07/11/2004) Wireless node with analogue modem interface
(07/08/2004) What gateway?(07/04/2004) New Computer
(07/02/2004) what would it take to network range of 2 KM(06/30/2004) What happens to the 'old' wireless numbers?
(06/30/2004) Slow 54Mbps G network - what are typical speeds?(06/27/2004) Computer can't see home LAN but can see internet fine
(06/17/2004) What so I need?(06/12/2004) What's the best wireless solution for interstate travel?
(06/13/2004) What am I doing wrong???(06/03/2004) what interferes with what?
(06/03/2004) What kind of foil when making home made antenna?(05/31/2004) Access to Computer Connected to wreless router
(05/28/2004) what exactly is a router doing, when you enable l2tp pass-..(05/17/2004) BEFSW11 experiences? What's more reliable?
(04/26/2004) what routers tlel you how many bytes on wan port(04/25/2004) WRT54G Connection Type reverts to Default Settings
(04/25/2004) What's missing in my WAP setup?(04/28/2004) PCMCIA type I (16 bit) wi-fi cards?
(04/20/2004) Linksys router/Adelphia Powerlink -- what software needs t..(04/14/2004) What kind of problem is this?
(04/14/2004) What's the most recommended hardware for setting up a wire..(04/15/2004) what brands of sleeping tents do you recommend???
(04/10/2004) wireless and wired Ethernet adapters in the same computer(04/13/2004) Computer Has g Adapter - Router Is b - Any Hope?
(04/08/2004) What wireless equipment to add to small business(04/05/2004) What if they sell WAP with enbled WEP by default?
(07/15/2005) not sure what to buy?(04/11/2005) What do these symptoms sound like?
(03/02/2005) Home Network Connection Problems: Computer Browser(07/09/2004) What's the difference?
(06/03/2004) What's the best way to do printing wireless?(05/20/2004) Help On What To Buy
(05/07/2004) 802.11B or G - What to install for home network(02/01/2004) dwl-900ap+ d-link help with range or what ?
(01/26/2004) Wirelessly networking an XP and a 98 computer(01/14/2004) using WiFi to stream video from computer to TV?
(12/09/2003) Newbie question...what do I need?(11/04/2003) what is wi-fi?
(07/05/2003) Issues with computer as a wireless access point(06/19/2003) What do i need?
(06/28/2003) Cox cable and wireless router, what to get?(05/15/2003) What is the gain on standard D-link antennas?
(04/26/2003) What the heck does this mean?(02/07/2003) what do you recommend?
(10/17/2002) ?what's wireless between friends?(08/30/2002) Wireless home network - what do I need?
Sponsored links
