| (11/25/2009) Will the belkin wireless G router work with AT&T? | (11/28/2009) WAP WEP and WPA |
| (11/22/2009) Connecting 2 laptop with wireless | (11/21/2009) Cannot find wireless connection |
| (11/19/2009) Router, And Using Printer With Two PC's ? | (11/17/2009) How can i download software for a linksys wireless router with out a modom |
| (11/17/2009) Wpa wep | (11/15/2009) Does my internet speed match with the speed I'm paying for? |
| (11/16/2009) Netgear wnr3500 router not compatible with windows vista? | (11/14/2009) Linksys WAG200G. Will it work with Windows 7 |
| (11/27/2009) Is window 7 compatible with wireless g routers | (11/09/2009) Dlink G520 wireless adapter does NOT work with Windows 7 |
| (11/04/2009) Will linksys wmp11 work with windows 7? | (11/03/2009) WDS with AP on Dlink 3200 |
| (11/09/2009) How to connect wireless-b broadband router befw11s4 | (11/16/2009) Linksys router not working with TWC |
| (11/01/2009) What Wireless equipment is compatible with 802 3ad ? | (11/01/2009) Config wrt54G_V2 with MS xbox wireless adapter |
| (10/30/2009) Wirless USB Key and LAN Bridge | (10/30/2009) Wireless card no good with windows 7 ? |
| (11/01/2009) Wifi router with WEP WPA(TKIP AES) WPA2(TKIP AES) | (10/27/2009) Netgear WG311v2 Driver fail install with Win7 64 |
| (10/27/2009) Cannot figure out wireless problem for the life of me | (10/25/2009) Cannot connect Ipod Touch to Home Wifi |
| (10/22/2009) Problems with my key board | (10/21/2009) Enabel to conect wireles router with my laptop |
| (10/22/2009) Computers not seeing each other over WAN with Tomato router | (10/20/2009) Programs to find wireless hidden ssid for windows xp |
| (10/18/2009) How to configure aztech router with linksys | (10/16/2009) Why my router does not work with my modem |
| (10/19/2009) How to disable limited or no connectivity on wireless network | (10/17/2009) Pretty please help with my dongle |
| (10/16/2009) Best repeater to set up with dlink dir 615 | (10/13/2009) Cannot find server Could not make an HTTP connectio or HTTPS connection or |
| (10/16/2009) Im about 7 nmiles from a mountain top with wifi! | (10/13/2009) Help with a wireless AP |
| (10/11/2009) I have a linksys befw11s4 router. The ADMIN page is 192.168.2.1. When I go to ad | (10/10/2009) Problem with getting online with PS3 slim |
| (10/07/2009) Help with speed issues | (10/06/2009) Problem with dell laptop |
| (10/03/2009) Replacing one roter with another | (09/28/2009) Is there an issue with some wireless printers and wireless usb adaptors knocking |
| (09/24/2009) Help Please: 802.11-1997 Shared Key Authentication | (09/30/2009) Terrible speed with trendnet wirless n pci card |
| (09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP? | (09/20/2009) Problem with MSI PC60G |
| (09/18/2009) Bad streaming with good internet connection | (09/21/2009) Wireless network with vonage - need advice |
| (09/09/2009) Making Google WiFi work with a weak signal. | (09/15/2009) Issue with an oddly unstable connection |
| (09/08/2009) IE says that it cannot display the webpage... | (09/15/2009) Help with wireless network |
| (10/11/2009) WPA key or network security key | (09/01/2009) Att modem with linksys router |
| (09/04/2009) Wired ethernet with wireless router | (08/31/2009) I need help with a Wireless adapter driver |
| (08/31/2009) Wireless kb with touchpad | (10/25/2009) Laptop b/g wi-fi adapter work with n router |
| (08/30/2009) Cannot find my wep key | (08/30/2009) Connect with secured wireless network |
| (09/03/2009) Can I run 2 wireless routers on one DSL line with modem? | (11/01/2009) A good wireless pci adapter that works with 64 bit OS? |
| (08/23/2009) Problem "seeing" other computers, but not with getting online? | (08/19/2009) Detection Error, Bluetooth can't sync cell phones with Laptop |
| (08/18/2009) Detection Error, can't sync cell phones with Laptop | (08/15/2009) Nintendo dsi internet setup with wireless usb adapter |
| (08/10/2009) Sony FW with WLAN, no LAN :( | (09/19/2009) Can U upgrade a WEP Wireless card to WPA? |
| (08/05/2009) Using MN-740 with WPA and Vista | (08/03/2009) Help with Compaq 2105US Laptop Wireless Connection |
| (08/03/2009) Wireless router with built dsl modem | (07/30/2009) Pc streaming with wired denon a/v receiver on wireless network |
| (07/25/2009) Linksys WRT54G setup with verizon | (07/23/2009) Need advice on upgrading wireless router with adapter |
| (07/22/2009) Wireless computing with a Dell dimension XPS t450 | (07/17/2009) Can't Connect to Unsecured Network (full signal) with Zonet ZEW2500P |
| (07/16/2009) I need help with wireless networking | (07/14/2009) DIR-615 mac address filter doesn't work with my macbook |
| (07/13/2009) Help with set up of netgear dg834pn | (07/16/2009) Having problems with router to laptop not getting connectivity |
| (07/11/2009) Help! I cannot connect ibm thinkpad wireless laptop to WPA router | (07/06/2009) Cannot share printer connected to XP machine with 2000 via Wireles |
| (06/29/2009) Please Help if good with Port Forwarding | (06/29/2009) Problems with wireless adapter |
| (06/25/2009) Help with settings | (06/23/2009) Wireless adapter with the dlink dir-655 |
| (06/23/2009) Can see a SSID with no Security Key, cant connect | (06/21/2009) Cannot print to shared printer |
| (06/18/2009) Wireless router interfering with cordless phone | (06/18/2009) Problem with wireless network and restricted user WinXP |
| (06/18/2009) N1 Wireless: Problems With Port Forwarding | (06/12/2009) Does electirc heat interfere with wireless g |
| (06/08/2009) I can't connect with Windows XP help! | (10/13/2009) Wireless LAN adapter problem with Vista 64-bit OS |
| (06/03/2009) Need advice with linksys WRT54GL router | (08/27/2009) Secured wired and Open wireless with one internet connection |
| (05/29/2009) 2wire gateway with UVERSE | (06/04/2009) Need help with linking connections |
| (05/24/2009) Need help setting up a router with Comcast cable | (06/15/2009) Connecting wireless with vista 64 |
| (05/23/2009) Cannot go on line with Explorer | (05/14/2009) Verizon wireless DSL cannot get onto internet |
| (05/11/2009) Need a recommendation on a wireless card that is compatible with server 2003 r2 | (05/09/2009) WLAN with Wireless Router and Wireless Access Point |
| (05/05/2009) Network Key characters | (04/26/2009) Dual Band Network With Two Routers |
| (04/22/2009) Sharing broadband with neighbor (sister) | (04/14/2009) Need help with my Asus WiFi |
| (04/11/2009) WPA2 adapter with WPA router | (04/10/2009) Problem with my se w350i phone |
| (04/09/2009) Wifi phone/wifi voip phone/wifi ip phone with roaming functions | (04/08/2009) Looking for help with connection speed |
| (04/07/2009) Wireless N with PCI-E? | (04/07/2009) Setting a wireless network with a tv that has ethernet input |
| (04/06/2009) WPA key problem - please advise | (04/08/2009) Idiot with wireless needs help |
| (04/02/2009) HELP PLEASE, cant get router to work with charter internet | (04/03/2009) Wireless with wired (without internet) |
| (03/30/2009) Changing encryption from WPA-PSK to WPA.Thompson 585v7 router | (03/25/2009) Need help with linksys wet54g network bridge |
| (03/26/2009) Wireless G with Rangeboost vs. Wireless N with Rangeboost | (03/24/2009) Help the PC illiterate please with network setup |
| (03/24/2009) Wrt54g v.6 router with wet54g v3.1network bridge bridge | (10/05/2009) Laptop with XP wont connect to my wireless network |
| (03/19/2009) Wirelees router with a cable modem issuses | (03/19/2009) WPA/WEP security |
| (03/19/2009) Find Hidden WPA-2 Key | (03/25/2009) Can not connect to Wireless Network with notebook. |
| (03/16/2009) Need help with d-link | (03/16/2009) Laptop + Squeezebox having problems with new router |
| (03/22/2009) WEP Key | (03/10/2009) Network Adapter that works with Vista 64? |
| (03/09/2009) Wireless with neighbor | (03/08/2009) Help setting up linksys psus4 with hp 6122 printer |
| (03/01/2009) Wireless usb with current router. | (02/28/2009) How do i find my SSID |
| (02/27/2009) Networking Oddity with Vista | (03/01/2009) Help with home network |
| (02/25/2009) Which wireless card to get with WNR 2000 and Vista 64? | (02/16/2009) WPA/WPA2 Compatability? |
| (02/10/2009) Forgotten Network Key | (02/08/2009) DWL-650+ Adapter with DI-628 Router |
| (01/27/2009) Slow wireless with XP 64bit | (01/21/2009) What's Wrong With my Internet??? :((((( |
| (01/20/2009) Need Help with slow wireless | (02/03/2009) Need Help with Wireless N Routers |
| (01/06/2009) Cannot Change Wireless Card Settings - freeze | (02/17/2009) Anyone WIth an Asus Motherboard? Help! |
| (12/30/2008) GAMING with Wirless PCI Card | (12/24/2008) Code 10+28 device cannot start wireless adapter vista |
| (12/15/2008) Getting WG602 to work with BEFSR41 V3 | (12/15/2008) Weird connections with linksys |
| (12/10/2008) enabled but cannot/will not connect | (12/07/2008) Help in finding an all-in-one cable modem with wireless |
| (12/06/2008) How to setup 2 pc's in a wireless LAN with an AP? | (11/12/2008) Can it be done with my current equipiment? |
| (02/10/2009) WPA network: add WEP access securely | (11/05/2008) New PC with existing wireless connection! |
| (10/06/2008) Problem with maintaining a connection with my XBOX. | (09/28/2008) NETGEAR w.router stops working with security on |
| (09/20/2008) Please help with this ad hoc problem | (09/15/2008) Linksys Wireless Router not working with Motorola Surfboard Cable Mod. |
| (09/15/2008) Help with Wireless Network | (09/15/2008) Help with printer - Urgent |
| (09/03/2008) Problem with Networking, half works, half doesn't | (10/18/2009) Cannot get printer to hook up wirelessly |
| (08/27/2008) Help with Marvell 88W8335 Wireless Card | (08/26/2008) I need help with video streaming |
| (08/31/2009) Help with Wifi please | (08/20/2008) like to add a second wireless router with no WEP |
| (08/18/2008) cannot connect with security enabled | (08/19/2008) Cannot see other computers in the network. |
| (08/10/2008) Gaming with a Router connected to other Router | (08/10/2008) Using two Wifi with one Cable modem |
| (08/04/2008) Desktop Wireless Adapter with Integrated Bluetooth? | (07/30/2008) Wireless Connection Issues with WRT54G + Windows Vista 64 Bit |
| (07/28/2008) WEP Encryption - one laptop does not work with it | (07/29/2008) Trouble with DHCP (i think) Please Help! |
| (07/25/2008) What wireless router is best used with an Att DSL Modem? | (12/29/2008) Low signal with FIOS router |
| (07/22/2008) Wireless-G network adapter work with Wireless N router | (07/12/2008) Cannot Renew the IP Address |
| (07/13/2008) Please help me with my wireless router.... | (07/11/2008) Linksys WMP54G Cannot Connect to Access Point or Net |
| (07/07/2008) Which wireless adapters can I use with a DIR-655? | (07/05/2008) Half speed with wireless connection |
| (06/30/2008) Anyone know which MIMO enabled wireless cards work with Vista x64 | (06/26/2008) Difficulities with file sharing on wireless |
| (06/21/2008) Overheating issue with Belkin wireless USB adapter | (06/19/2008) Problem with my wireless router!! |
| (06/15/2008) gaming with wireless g | (06/07/2008) A newb is completely lost with his wireless card. |
| (06/01/2008) Help with creating a wireless network. | (06/03/2008) extending a wired network with wireless |
| (06/01/2008) Port Forwarding with a Router - Router setup | (05/23/2008) networking two wireless computers with one wireless router? |
| (05/14/2008) help pleaseee i cna't get 1000mb/s with etherent cable | (05/10/2008) help with linksys wre54g extender |
| (04/29/2008) Wireless router with rackmount design | (05/12/2008) wireless router with switch to turn of wireless radio ? |
| (04/29/2008) Anyone with macbook wireless issues? (airport extreme card) | (04/17/2008) Laptop suddenly offline with other issue |
| (04/05/2008) Wireless N Router with both g and N receivers? | (03/29/2008) [SOLVED]Problems connecting to internet with vista (wireless) |
| (03/08/2008) Network Printer Problem with Vista | (03/02/2008) NEWBIE! Major help with Verizon Westell 6100 and DI-624S? |
| (02/12/2008) sony laptop loses connectivity with Linksys wireless routers | (12/02/2009) "Cannot communicate with primary DNS server" |
| (02/10/2009) Wireless issue with Vista and Linksys | (01/29/2008) Wireless card to router with different brand? |
| (01/26/2008) Any network sniffer to use with Netgear WN121T USB adapter? | (01/20/2008) Sharing files/printers on network with wireless/hard wired computers |
| (01/11/2008) hey guys help me with this please | (01/10/2008) News/nntp problem with config change |
| (08/25/2008) What's wrong with my wireless connection? | (01/06/2008) Cannot network my PC and my Laptop. |
| (03/30/2009) Lost software for Linksys WRT54G but want to secure wireless with WPA2 | (12/20/2007) Issues with Paradyne and Linksys routers |
| (12/17/2007) Folder files dont completely load with Wireless G | (06/29/2009) Problems with Asus WiFi-AP solo |
| (01/11/2008) help with Wireless/ethernet router filesharing? | (11/27/2007) Old laptop, new wireless card, old Linksys BEFW11S4 |
| (11/14/2007) help with verizon fios | (10/31/2007) Wireless N issue with laptop (4965AGN) and Linkysys300 n router |
| (10/27/2007) Cannot Renew IP..please help. | (10/15/2007) Trying to Setup my F5D7230-4 as an AP with a Netgear WGR614 router |
| (08/30/2007) new to linux and need help with turning the radio on in knoppix | (08/25/2007) Help! Need a router with LONG RANGE |
| (08/21/2007) can connect with ethernet but not wireless, conflict with wifi card? | (08/15/2007) Weird problem with wireless connection! |
| (08/07/2007) Help with a new Acer 3680 and internet connection | (07/30/2007) Can't do LAN gaming with wireless connection |
| (07/26/2007) Having problems with Asus Wifi AP dropping connection | (07/27/2007) Need help with wireless repeating |
| (06/03/2009) Wireless Connection not working with vista | (08/11/2007) need help getting wireless router to work with dsl |
| (06/18/2007) I cannot configure my Netgear router to AOL | (06/15/2007) Getting DLink AP to work with WRT54GL |
| (05/31/2007) problem with wpa-psk | (05/16/2007) Weird problem with Belkin PCI card |
| (05/12/2007) D-Link router cannot get DHCP information from cable modem | (05/11/2007) Help with point to point network |
| (01/12/2009) 2 routers, one using WEP, other Using WPA - How to setup? | (04/19/2007) Wireless network authentication with Vista |
| (05/11/2007) Help with connecting wireless network | (05/11/2007) Cannot connect to certain sites |
| (11/21/2009) WPA still unsecured | (03/27/2007) Wireless N devices with 10/100 ethernet ports... makes sense |
| (05/09/2007) What is going on with my Wireless network...!? | (06/21/2007) What to replace my 2db antenna with on my DG834GT Router? |
| (05/10/2007) Lost My WEP KEY | (02/05/2007) Setting up wireless network with my belkin F5D7632-4 (54g) |
| (02/06/2007) Wi-Fi Nic with external antenna adapter recomendations | (02/01/2007) only 11Mb/s with wireless "g" ??? |
| (02/01/2007) Need help with odd disconnect (and can't reconnect) problem | (01/28/2007) PC can't connect to Internet with WEP enabled |
| (01/18/2007) Netgear trouble with 2 wifi's :( | (01/18/2007) New Comp having connectivity issues with wireless |
| (12/26/2006) a few domains cant be obtained with belkin wireless router | (12/22/2006) Wireless with WPA-Radius |
| (12/10/2006) DISABLE DHCP!! | (12/06/2006) HELP. Router cannot handle more than 10 IP. |
| (12/14/2006) need help with wre54g and qwest modem/router | (07/15/2009) roaming between ap's with wds link |
| (11/28/2009) Help!! Can't remember or find my Wep Key | (11/20/2006) HELP with D-Link and Sony Problem |
| (11/13/2006) What's wrong with my setup? I can't go anywhere... | (11/09/2006) SSID broadcast off |
| (11/05/2006) Problem with DLink DI-624s | (10/31/2006) Heh, really need help with D-Link router. |
| (10/29/2006) Cannot get WPN824 to work. | (11/01/2006) Cannot get WRT54G connected and functioning on wired network |
| (10/20/2006) Ad-hoc ICS with Mac OS X | (10/19/2006) SMC SMCWBR14-G Router with Motorola SB5100 Cable Modem |
| (10/20/2006) Problem with Belkin 7011 wireless card | (10/17/2006) WRT54GS problems with Xbox 360 |
| (10/17/2006) Extract WEP Key from my Profile | (11/17/2006) Wireless printer server trouble with Actiontec router |
| (10/14/2006) Connection problems with network | (10/02/2006) 64-bit USB Bluetooth to use with my headset |
| (09/25/2006) compatability copperjet 810 modem with apple airport express | (10/05/2006) I need a new router with a built in print server... |
| (02/14/2007) Phantom ssid in dlink dwl-G710 range extender's site survey | (09/14/2006) Linksys WAP54GP pub/private dual SSID pub shows encrypted |
| (05/29/2009) Problem with Acer Aspire 3620 integrated wireless LAN | (10/16/2006) Wireless Print Server with WPA Encryption? |
| (08/15/2006) Need help with wireles settings | (08/15/2006) Help with Wireless AP/Briding |
| (08/13/2006) problem on wireless with win 2003 server | (08/08/2006) Need help with wireless connections WRT300n and WRT54G |
| (08/08/2006) Need help with wireless connections and Lynsis SRX400 Router | (08/02/2006) Problems with LINKSYS Wrt54gx2 urgent! |
| (09/11/2006) Is there a wireless card with an external attena for my dell | (07/25/2006) Max range with regular 802.11g laptop? |
| (07/20/2006) command for enable/disable user in radius server | (08/02/2006) Help with Bridging internet between two buildings WinXP |
| (07/22/2006) Wireless cards with 64 bit support ? | (07/07/2006) Looking for a wireless router with gigabit speed |
| (07/11/2006) Setup wireless network with friend 1 km away. | (07/20/2006) need help badly setting up Xbox Live with a linksys router.. |
| (06/29/2006) mixing g with gs | (06/28/2006) Weird connectivity problem with a Linksys WAP |
| (06/28/2006) Cannot get WAP54G and WAP54GPE to work together. | (06/27/2006) Help please..problem with Linksys WRT54G and WMP54G |
| (06/21/2006) Can you disable built in WiFi in favour of an external WiFi? | (06/13/2006) Issues with filesharing b/w PC and laptop |
| (06/12/2006) Connecting two wired switches with wifi + using access point | (06/20/2006) Troubles with DI-524 and internet |
| (07/27/2006) Needing router with range | (05/26/2006) I can not capture packet with fromds=0 and tods=1 |
| (05/20/2006) Adapter with 64-bit drivers | (05/08/2006) Wireless G+ compatable with G? |
| (05/07/2006) How to share wifi with a device that cannot logon? | (10/05/2006) Does any wireless PC card work with any Wireless Router? |
| (04/29/2006) 2 Mile range with dish | (04/27/2006) Netgear 108mbps to 108mbps with MIMO ? |
| (07/25/2006) Netgear 108mbps to 108mbps with MIMO ? | (04/26/2006) Legacy AirPort card can't associate with SonicWALL TZ 170 |
| (04/17/2006) Can 802.11b card crack WEP with 802.11g target clients? | (04/05/2006) Problems with wireless connection in WR850GP |
| (04/25/2006) Wireless Instability with Pre-N Belkin | (12/10/2006) Roaming WiFi issues - 3 APs, one switch, one SSID |
| (04/06/2006) ASC IV injection with Netgear MA401 | (03/15/2006) Need Help with Broadcom and/or Wireless Router |
| (03/20/2006) Need Help with Broadcom and/or Wireless Router | (03/28/2006) Big time gaming lag with my wireless setup |
| (03/11/2006) EAP-MD5 support issue with Atheros APs | (03/11/2006) PCI Wireless card with Auditor SC |
| (03/07/2006) problem with IpCop and wrt54g being used as a access point | (02/28/2006) Good Value 8-port Wireless Router (with adsl modem built in) |
| (02/27/2006) Looking for Wlan-Router with huge range | (02/24/2006) Slim Device v3 and a SMC WBRT14T-G using WPA or WPA 2 |
| (10/06/2006) Intel 2200BG with Airodump | (03/03/2006) Static IP on Wireless networks with DHCP on |
| (02/17/2006) Cannot maintain Internet IP address | (09/15/2005) Extending my wireless network with a repeater |
| (09/02/2004) Netgear WG511T Connectivity Issues with WGT624 | (11/07/2004) WEP / WPA: hardware or software limitation |
| (09/29/2007) No WPA avail. in XP SP2 | (12/05/2004) Linksys BEFW11S4 and WEP |
| (05/12/2005) WPA on startup | (05/14/2005) WPA Capability |
| (07/21/2005) Keeps connecting and disconnecting when use WPA | (08/15/2005) Problems with WPA-PSK and Belkin F5D7632uk4 adsl router |
| (05/30/2004) Shared Key with wireless in Linux -- is this possible? | (05/05/2009) problem with linksys wmp11 PCi wireless networking adapter. |
| (09/29/2005) Wireless WPA problems | (09/29/2005) Preferred SSID - Hidden SSID |
| (09/05/2009) Linksys BEFW11S4 4.0 Wireless B Router Problems | (09/27/2005) Freezing Aspire 1353 with 2nd DWL-G122 |
| (09/21/2005) Setting up a web server with Netgear WGT 624 and Netgear 632 | (04/02/2004) Disconnection Problem with DWL-G650+ Wireless Card |
| (04/02/2004) Any experience with Netopia 3387W??? | (04/02/2004) WEP or WPA? |
| (04/01/2004) WPA under XP ? | (04/02/2004) Setting Up Wireless Network At Home With T-1 Connection --.. |
| (09/18/2005) WRT54G vulnerabilities with pre-4.20.7 firmware | (09/20/2005) Need Help with Home Network Problem |
| (09/26/2005) Netgear Wireless adapter with Apple iBook | (09/26/2005) Netgear WGR614 incompatibility with Linksys Router BEFSR41 |
| (09/30/2005) Bridging with SWEEX LC000070? | (10/15/2009) PCMCIA wireless network card with external antenna ? |
| (10/05/2009) I can connect to access point but "CANNOT FIND INTERNET | (02/08/2006) Disable WI-FI in a router |
| (01/05/2006) Please help me with setting up a wireless lan... | (12/23/2005) Wi-network with USB DSL modem |
| (09/20/2005) Question on broadcast data encryption using WPA | (06/03/2009) Problem: Linksys adapter not working with D-Link router |
| (01/19/2006) How make client computer recognize it's on ICS with ad-hoc? | (04/16/2006) Great Experience with D-Link 634 MIMO |
| (12/29/2005) Wireless Connection Established But Cannot Communicate | (11/22/2005) The same SSID for 11b AP and 11g AP |
| (09/24/2005) winxp wireless network disable | (09/23/2005) Cannot bind to tcp/ip |
| (09/24/2005) having problems with wireless connection | (09/22/2005) ad hoc network with LAN |
| (09/20/2005) WEP/WPA Key / Network Key...Cant connect ! | (12/31/2005) < New to routers, can't configure with AOL |
| (09/26/2005) Problem with wireless | (09/13/2005) Pb Enabling radio with simple user profile |
| (09/13/2005) Netbios disable hisself | (09/12/2005) Public Key Infrastructure |
| (09/11/2005) Wireless Network with Windows XP Home | (09/06/2006) Wireless cards can't be installed--"Cannot find file speci.. |
| (09/09/2005) Cannot access | (09/11/2005) Users other than administrator cannot log on |
| (09/07/2005) Multiple users logged on one machine with WiFi... is it po.. | (09/05/2005) WPA in Ad Hoc |
| (09/05/2005) Using XP with DSL where, when and how can the DNS entries .. | (09/03/2005) Cannot connect laptop to a wireless metwork |
| (09/04/2005) API for signal strength value with zero configuration feat.. | (09/01/2005) ICS problem with wireless connection |
| (09/02/2005) XP with KB893357 | (08/31/2005) Connecting when ssid not broadcast |
| (08/30/2005) No file sharing with WPA-PSK TKIP | (08/30/2005) Cannot get my computer to serve a shared folder |
| (08/29/2005) Quirky internet access with wireless adapter | (08/26/2005) IAS error 16 with Intel 2200BG wireless card !!! |
| (08/22/2005) Toshiba Qomiso Laptop cannot access Internet thru Netgear .. | (08/22/2005) Set up ssid via script |
| (08/24/2005) Cannot ping peers on a LAN | (08/21/2005) Losing WEP Key Information |
| (08/23/2005) Not valid SSID name during setup using the wizard | (08/16/2005) File permissions with w/networking |
| (08/18/2005) Sharing a wireless connection with a neighbours WLAN - Sec.. | (08/11/2005) Ad-hoc with Win XP Laptop and 98 desktop |
| (08/11/2005) SSID Broadcast Problem | (08/16/2005) cannot renew IP |
| (08/02/2005) Wireless Connection Wizard did not update with SP2 | (08/05/2005) WPA Key in registry |
| (08/10/2005) IE works but can't communicate with desktop NEED TO TRANSF.. | (07/30/2005) cannot share printer on wireless network |
| (07/29/2005) connecting both computers with different operating system .. | (07/28/2005) View Network Key |
| (07/25/2005) Open SSID detected as Security-enabled | (07/28/2005) Need help with wireless router issues PLEASE!!!!! |
| (07/21/2005) Slow File Transfers with WINXP Pro Ed | (07/18/2005) Wireless Networking Requires Braodcast of SSID |
| (07/15/2005) Cannot ping machines behind a wireless AP | (07/15/2005) Cannot ping machines behind a wireless AP... |
| (07/15/2005) Server2000, IAS PEAP cannot find certificate | (07/15/2005) XP Suplicant for WPA and credentials |
| (07/11/2005) EAP type list doesn't populate with anything | (07/12/2005) trouble with WPC54gs adapter |
| (07/09/2005) Cannot access internet | (11/02/2009) Automatically disable wireless |
| (07/15/2005) Device search returns devices with zero length strings | (07/06/2005) Connectivity issues with Bluetooth Stack on PC |
| (07/07/2005) Cannot share printer or files but have wireless internet | (07/03/2005) Disable wireless ? |
| (07/02/2005) Cannot log on to wireless router | (07/01/2005) wireless with sbc |
| (06/29/2005) Wireless with Roaming Profiles issues | (06/28/2005) Can't share files with TKIP |
| (06/28/2005) Networking XP home with 2000 | (06/27/2005) WPA driver |
| (06/26/2005) My router assigns IP address but I cannot ping router?? | (06/26/2005) My router assigns IP address but I cannot ping router?? |
| (06/27/2005) Not able to disable network adapter during repair | (06/25/2005) XP with wireless amnesia |
| (06/25/2005) VPN with Microsoft MN-700 Router | (06/23/2005) bridging with ad hoc wireless network |
| (06/23/2005) Set up WPA connection in advance | (06/22/2005) Problems with DHCP request on Windows XP Home SP2 |
| (06/21/2005) WPA and Wireless Zero Connection utility | (06/20/2005) Laptop Won't Communicate with Desktop |
| (06/20/2005) SSID found but can't ping router? | (07/01/2005) Wpa |
| (06/18/2005) Dial-up sharing with WiFi | (06/21/2005) pda as terminal under xp home (with bt) |
| (06/14/2005) Why can't I get WPA to work with linksys router and linksy.. | (06/14/2005) WPA on Windows Configuration |
| (06/15/2005) Loose Internet with WEP or WPA | (06/16/2005) Why can't I get WPA to work with linkysy router and linksy.. |
| (06/14/2005) help with securing network | (06/12/2005) I can't install the software that came with my Belkin Netw.. |
| (06/17/2005) dsl with linksys | (06/09/2005) Struggling with Wireless network. |
| (06/08/2005) WLAN novice with connection problem | (06/08/2005) Wireless networking using Linksys BEFW11S4 and WMP11 |
| (06/07/2005) Cannot see other computers on Network | (06/07/2005) Trouble with Linksys Router and WEP keys with Windows XP |
| (06/07/2005) Wi-lan listed in availiable detected even with SSID broadc.. | (06/11/2005) using Dlink card GWL-G650+ utility software with windowsxp.. |
| (06/08/2005) Finding a wireless vendor with XP64 Pro drivers | (05/31/2005) cannot set up wireless network |
| (05/28/2005) External exception E06D7363 message with Linksys card | (06/01/2005) Trouble with Airport Express and Microsoft MN-500 Wireless.. |
| (05/28/2005) Looking for a WPA bridge recommendation | (05/28/2005) USB Wireless Adapters compatible with Win CE 2.0 |
| (05/28/2005) Network recognized but cannot connect | (06/09/2005) Wireless networks with Hidden SSID's |
| (05/24/2005) Can't file, print share with 2 Router home network-Vonage .. | (05/22/2005) 802.11b on destop with USB adaptor gigafast |
| (05/22/2005) How do I setup a network with a wired computer and wireles.. | (05/18/2005) Networking Issues - Cannot See Machines Within Workgroup |
| (05/14/2005) device cannot start code 10 | (05/12/2005) Cannot get wireless notebook to connect to NT4.0 Server th.. |
| (05/13/2005) problems with wireless connection | (05/11/2005) Problems with Networked Computers and Printers |
| (05/12/2005) Problem with Asus WL-138G Network card and Windows 2000 | (05/10/2005) Cannot log into my Router |
| (05/08/2005) No internet access with one of networked pcs | (05/06/2005) XP drops wireless connection randomly and cannot repair it.. |
| (07/04/2005) Problem with IrDA in XP with SP2 | (05/04/2005) Disable the wireless network feature |
| (05/03/2005) WAP with Windows 98SE? | (04/29/2005) Need some help with wireless networking & internet connect.. |
| (05/08/2005) DWL-G650 operation with (and without) WPA2 | (04/26/2005) possible to disable/enable wireless network adapter via co.. |
| (04/26/2005) WiFi doesn't work with LAN card in WINXP sp2 | (04/25/2005) Change password with 802.1x WinXP and cached Passwords. |
| (04/23/2005) i forgot my wep key and am trying to connect with my lapto | (05/06/2005) Problem with VPN over Wireless - Help please! |
| (05/02/2005) problem with WPA - please help | (04/20/2005) Pocket PC 2003 WPA PSK |
| (04/19/2005) Problems with wireless router and adapter | (04/21/2005) Help: loosing connection with router while downloading |
| (04/14/2005) File sharing from a WIFI PC with nobody logged on - How to.. | |
