Making Linksys WRT54G Router and WPC54G LapTop card work w..
More related threads to : Making Linksys WRT54G Router and WPC54G LapTop card work w..
(11/28/2009) Wireless router WGR614 configuration(11/28/2009) Can router be used as adapter?
(11/27/2009) How connect laptop to laptop via lan in vista(11/27/2009) Connecting Laptop to Internet using Instinct G3 phone.
(11/27/2009) Removing the antenna on belkin router(11/29/2009) Cant remember name and password for linksysn router
(11/27/2009) Linksys usb11(11/27/2009) Wifi card not supported by mobo?
(11/28/2009) Setting up a Windows 7 machine as a wireless router(11/26/2009) WINDOWS 7 64BIT AND ROUTER
(11/26/2009) Losing signal from my D-link router(11/26/2009) Linksys can't stay connected for longer then 5 mins
(12/13/2009) Frustrating router problem(12/15/2009) Best Wireless Router For ~ 150$, Please Help !?
(11/25/2009) Will the belkin wireless G router work with AT&T?(11/25/2009) Wireless Router Assigning Wrong IP Address, Need Help
(11/25/2009) Connecting a Linksys Router to a Verizion MiFi router(11/24/2009) What does validating identity mean, a dir615 router, xp home
(11/24/2009) Linksys wmp11 wireless card gets no signal from 2wire access point(11/24/2009) I have to add a computer to the wireless network repeatedly to get my laptop to
(11/23/2009) Computer randomly crasches after installing a new network card... Help!(11/23/2009) Telnet commands for a linksys wireless router
(11/22/2009) Can i use a usb adapter without the router(11/22/2009) Wireless-N Router forum
(11/22/2009) Wireless-N Router forum(11/22/2009) Linksys wmp11 ver2 7 no signal
(12/06/2009) How to get a linksys router to send out a wireless modem stick signal(11/22/2009) I have a laptop and ist connected to a network how to connect to internet
(11/22/2009) Connecting 2 laptop with wireless(11/30/2009) Networking b/t Laptop and Desktop = poor internet connectivity
(11/21/2009) If I have a N router do I need a N adapter to pick up wirless(11/20/2009) Netgear wgr614 router configuration
(11/20/2009) WAP vs booster vs upgrade G->N router?(11/20/2009) Usb wireless router
(11/19/2009) How to configure netgear wireless Router WGR614as a repeater(11/19/2009) Linksys wireless usb adapter G
(11/18/2009) DCS-2121 wifi ip cameras - fixed ip on router.(11/19/2009) Router, And Using Printer With Two PC's ?
(11/18/2009) How to get my WAP key from router(11/17/2009) How can i download software for a linksys wireless router with out a modom
(11/18/2009) Linksys router problems(11/17/2009) Why do i get a 169 254 x x address from the router
(11/19/2009) Recommendation for a good Wireless Router(11/16/2009) Need wireless router work
(11/16/2009) Wireless card find network(11/16/2009) Netgear modem/router & Belkin G-Mimo dongle disconnects.
(11/14/2009) Linksys wap54g connection problem(11/16/2009) Netgear wnr3500 router not compatible with windows vista?
(11/14/2009) Linksys WAG200G. Will it work with Windows 7(11/13/2009) D-link wireless router dwa-110 driver software
(11/13/2009) Linksys WRT 150 N Wireless Setting(11/13/2009) Connect to wired ADSL2+ modem router
(11/12/2009) Turning a pc wireless using my laptop(11/12/2009) Windows XP, Netgear modem router, Belkin G mimo usb adapter
(11/12/2009) Will yagi antenna work on a usb router(11/12/2009) Linksys WRT160N - slow connection time
(11/12/2009) Laptop constantly bumped off wireless home network(11/12/2009) Best home vpn router
(11/11/2009) Lag spikes caused by network card?(11/10/2009) Setting up wireless router
(11/10/2009) Wireless g router(11/10/2009) What router disables wireless quick and easy?
(11/09/2009) Dlink G520 wireless adapter does NOT work with Windows 7(11/08/2009) Modem router combo need more range
(11/08/2009) Lost encryption linksys find(11/09/2009) Best cheap router
(11/06/2009) Wireless DSL modem, wired router networking(11/04/2009) Will linksys wmp11 work with windows 7?
(11/04/2009) I lost my encryption key for my linksys where do I find it(11/09/2009) How to connect wireless-b broadband router befw11s4
(11/02/2009) Setting up a desktop and wireless for laptop(11/06/2009) Windows 7 laptop not connecting to Netgear WGT624 wireless router
(11/02/2009) High gaming ping when multiple users on same router(11/16/2009) Linksys router not working with TWC
(10/31/2009) Netgear wifi router(10/31/2009) Belkin g wireless router setup now no desktop connection
(11/09/2009) How do I find the MAC address of a recently connected device on my wireless rout(10/30/2009) Looking for a reliable wireless router that supports VPN
(10/29/2009) Actualy i am forget our linksys router login id(10/30/2009) Wireless card no good with windows 7 ?
(10/28/2009) Problem connecting to internet on laptop(10/28/2009) Download wireless port for advent laptop
(10/28/2009) Driver/Card Issue(11/01/2009) Wifi router with WEP WPA(TKIP AES) WPA2(TKIP AES)
(10/27/2009) What happens when router loses connection(10/27/2009) Need to know how hook up wireless router to my desktop pc so i can use wireless
(11/14/2009) Wireless slow on desktop but not on laptop(10/27/2009) Netgrar router set up fine for laptop need password for mu iphone connection
(10/27/2009) 2nd Router as access point/bridge??!?(10/26/2009) Belkin wireless G router
(10/30/2009) Usb wireless router(10/25/2009) Router into a receiver
(10/24/2009) Linksys wcg200 wireless-g gateway(10/24/2009) Wireless router traffic monitoring for different users
(10/24/2009) Configure Netopia 2247 Router as Bridge(10/24/2009) MSI Wind u100 843us Wireless Card
(10/24/2009) Linksys WMP54G on W7 64 bit(10/23/2009) Laptop connection to telefonica router problems
(10/23/2009) Connecting STB to wireless router(10/27/2009) Hook up router to cpu server modem and hub
(10/22/2009) Server 2008 DHCP Netgear Wireless Router(10/22/2009) Wireless router
(10/22/2009) Linksys modem not working(10/22/2009) LOST SOFTWARE LINKSYS SETUP
(10/22/2009) Linksys software(10/21/2009) Enabel to conect wireles router with my laptop
(10/21/2009) How to open my nat on my wrt54g(10/22/2009) Computers not seeing each other over WAN with Tomato router
(10/25/2009) Laptop says good connection, but no access(10/19/2009) Wireless card spec?
(10/19/2009) Need a wireless n pci card(10/19/2009) How to hook up apple wireless router
(10/19/2009) Need advice what wireless router to buy(10/18/2009) How to configure aztech router with linksys
(10/18/2009) Linksys WAG54G V.3 Won't broadcast wireless signal(10/19/2009) Linksys WRT610N router VS Netgear WNDR3700
(10/20/2009) Can you run Xbox LIVE off of a wireless card?(10/17/2009) Compatable router for cell phone internet?
(10/16/2009) Why my router does not work with my modem(10/16/2009) How can my laptop get a wifi connection from another laptop through bl
(10/16/2009) 0h how can i set up a security password for my router(10/16/2009) My wirelss router can't connect to my laptop
(10/16/2009) How can i get my network security key off my laptop(10/14/2009) Desktop Wireless Card soemtiems doesn't work on reboot
(10/16/2009) Which wireless router is right for me?(10/14/2009) How to implement intranent using wireless router
(10/13/2009) Linksys router wrt54g software(10/14/2009) Extending a wireless network using 2 LinkSys WRT54GL routers
(10/12/2009) Laptop as router(10/11/2009) One laptop can connect to the wifi two others cant
(10/11/2009) Find linksys wep key(10/19/2009) Broadband wireless router 500 meter range
(10/11/2009) Linksys(10/11/2009) I have a linksys befw11s4 router. The ADMIN page is 192.168.2.1. When I go to ad
(10/11/2009) Can you alter the range on a router(10/17/2009) Best durable wireless N & G router
(10/09/2009) LINKSYS WAG200G connected to a LINKSYS WRT54Gv8(10/09/2009) How do i connect my netbook to an already existing wireless router
(10/08/2009) I try to connect my laptop to my wireless but the laptop dont connect(10/06/2009) Problem with dell laptop
(10/06/2009) 3G Wireless Router/3G USB Modem Interoperability(10/05/2009) Connecting a desktop PC to a wireless router?
(10/06/2009) I can't get my wireless router to see my printer...please help(10/05/2009) What is spi mode in a router
(10/04/2009) Linksys router WR54G routing(10/04/2009) Wired router for Xbox 360
(10/04/2009) Where do i find ip number on router(10/05/2009) How to add router to ATT uverse
(10/03/2009) Can a wireless router be used as a wifi antenna(09/30/2009) Connecting 2 router together possible?
(09/30/2009) Cara seting linksys wcg200(10/06/2009) Only 11mbps off wireless router help!!??
(09/30/2009) Download GRAFIC CARD LAPTOP m-life(09/28/2009) Need a router for vista 64
(09/28/2009) Need a router for vista 64 , x box 360 psp wii and wireless(09/30/2009) How to make linksys router an access point
(10/05/2009) Broken router(09/27/2009) Connect to router together
(09/26/2009) My netgear ma101 adapter will not connect to Belkin N+ router(09/29/2009) Recommended wireless router ~$100 ??
(09/27/2009) Wireless router(09/26/2009) My comp CANT find my wireless router
(09/25/2009) Linksys wrt54g v8 router problem(09/25/2009) Wireless access point and router options
(09/23/2009) Which router to buy?(10/01/2009) Spare wrt54g as a repeater print server
(09/30/2009) Terrible speed with trendnet wirless n pci card(09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP?
(09/22/2009) Network found but no internet on Asus Laptop(09/23/2009) Best Gaming Wireless Router?
(10/05/2009) Difference between router and extender(09/30/2009) Wireless Linksys, shows connected but NO signal...
(09/23/2009) What is the BEST wireless 802.11n router?(10/10/2009) 2 Wire router/linksys bridge WEP problem
(09/23/2009) Set up my wireless network, what router, what networkcard in my laptop(09/19/2009) How to enable dhcp on my wrt54g
(09/18/2009) Wireless router & modem(09/16/2009) Using a router as a wireless adapter?
(09/15/2009) Wireless doesn't work for my laptop(09/15/2009) QOS router
(09/13/2009) New wireless card needed(09/19/2009) Belkin Router = fail?
(09/25/2009) Dual LAN and Wireless Router(09/09/2009) Making Google WiFi work with a weak signal.
(09/09/2009) Upgrading wireless router, need advice(09/08/2009) Start wireless card before logon
(09/06/2009) How to install new router on Mac(09/03/2009) How to connect orange live box to another wireless router
(09/03/2009) Zyxel router(09/02/2009) Laptop does not detect wireless networks.
(09/01/2009) Att modem with linksys router(09/04/2009) Wired ethernet with wireless router
(08/31/2009) Connecting a Wireless router to a modem/Wireless router, Help!(10/25/2009) Laptop b/g wi-fi adapter work with n router
(08/30/2009) Replacing a 2 wire wireless router(08/30/2009) Router question
(08/30/2009) Wirless Router Problem?(08/29/2009) Is it okay to not unplug the router?
(08/28/2009) How to configure linksys wrt 54g router in apt building w/ethernet jac(08/27/2009) Wireless n router
(08/26/2009) Internal Ethernet Adapter or Standalone Router(08/27/2009) Connecting to Router
(08/26/2009) Router(08/27/2009) Router
(08/26/2009) Router(08/24/2009) Using two Linksys Wireless routers for broader WiFi Coverage
(08/23/2009) Do I need to have a cable modem apart from a router?(08/22/2009) Linksys bluetooth
(08/21/2009) Wireless Router and Wireless Access Point setup(08/20/2009) My linksys router
(08/19/2009) Connecting 2 laptops to one router(08/20/2009) ADSL modem/router advice.
(08/19/2009) Detection Error, Bluetooth can't sync cell phones with Laptop(08/18/2009) Detection Error, can't sync cell phones with Laptop
(12/05/2009) Converting a DIR-625 into a repeater(08/16/2009) Router for college kids
(08/12/2009) Somebody how do I tell if I have a wireless network card installed?(08/09/2009) Connecting ADSL usb modem + Wireless router possible ?
(08/09/2009) Don't know how to make it work.(08/09/2009) Need a wireless card - only have PCIe 1x slots
(08/08/2009) Traveling laptop needs to switch workgroups(09/10/2009) NetGear WPN824v3 Wireless Router
(08/18/2009) Which D-link router to buy?(08/09/2009) Wireless Internet Network Card
(10/30/2009) Bought a D-Link DIR-655 Extreme N Wireless Router - Need advice(09/19/2009) Can U upgrade a WEP Wireless card to WPA?
(08/03/2009) Help with Compaq 2105US Laptop Wireless Connection(08/03/2009) Wireless router with built dsl modem
(08/02/2009) Can't connect to internet through wireless router(08/02/2009) Search for a wireless router WITHOUT connectiond drop
(08/02/2009) Linksys(08/02/2009) How to increase signal from neighbors router?
(07/31/2009) What wireless card?(07/29/2009) WRT54G
(07/29/2009) Signal from router, but no internet. *Help Please*(08/17/2009) Tenda router trouble
(07/28/2009) Can i connect a belkin router to a linksys?(07/27/2009) My computer connection is unreliable, do I need a new router?
(07/27/2009) My computer connection is unreliable, do I need a new router?(07/28/2009) My computer connection is unreliable, do I need a new router?
(07/28/2009) Linksys wireless router bottlenecking my connection speed(07/26/2009) Buying a new router and adapter TODAY
(07/25/2009) Linksys WRT54G setup with verizon(07/29/2009) Best Wireless N Router
(07/24/2009) Would I benefit from a Dual Band N Router?(07/28/2009) 2 DSL Modem/Router, how to extend range?
(07/24/2009) Router As Receiver, Can you distribute?(07/23/2009) Wireless router fail to setup to router modem
(07/23/2009) Need advice on upgrading wireless router with adapter(07/22/2009) Palm Tungsten E2 "Fatal Alert" Linksys WRT54G
(07/22/2009) Help linksys router not working(07/22/2009) Slow connection -- need new router?
(07/21/2009) Can't access router configuration page...(07/18/2009) Vista Ultimate and Linksys Routers and USB Card
(07/18/2009) Linksys WRT54G connection problem(07/18/2009) Wireless for laptop
(07/17/2009) Problems connecting router. HELP PLEASE!(07/17/2009) Wifi card not as good on one PC vs another
(07/15/2009) Need a new router(07/16/2009) Spotty, slow connection - is it my pci card?
(07/14/2009) DIR-615 mac address filter doesn't work with my macbook(07/13/2009) Port Forwarding on Linksys WRT54G
(07/16/2009) Having problems with router to laptop not getting connectivity(07/11/2009) Help! I cannot connect ibm thinkpad wireless laptop to WPA router
(07/08/2009) Router password and laptop connectivity(07/08/2009) Wireless WLAN Mini-PCI Card, Help.
(07/08/2009) 1 computer, one router(07/09/2009) Loosing wireless connection when laptop goes to sleep or is restarted
(07/04/2009) Wrt54g dual outdoor antenna?(07/03/2009) Monitoring traffic through a wireless router?
(07/01/2009) Two Linksys WRT54G routers(07/04/2009) Linksys WRTP54G as access point
(06/26/2009) Reconnecting linksys network to laptop(06/25/2009) Help for Wireless Router
(06/23/2009) Laptop kicks network out immediately(06/24/2009) Why Doesn't My Laptop Recognize My Network When its Within Range!????
(06/22/2009) Gateway laptop(06/30/2009) Sharing internet connection via bluetooth from pc to Mac laptop
(06/18/2009) Wireless router interfering with cordless phone(06/17/2009) Laptop modem
(06/17/2009) Linksys as wireless internet reciever(06/16/2009) G+mimo wireless router
(06/16/2009) Linksys wmp110 v2 on winxp x64(07/03/2009) Router that can view/allocate bandwidth to different computers?
(06/14/2009) HELPS on Linksys WRT54G router(06/12/2009) Wireless N card to Wireless G Router
(06/15/2009) Is my wireless card broken?(06/15/2009) Linksys Router - Engenius 2611 CB3 Setup ?
(11/13/2009) Wireless N adapter to wireless G router?(06/10/2009) Odd config between wired/wireless router and wired/wireless AP
(06/09/2009) Linksys Router IP: How to Locate?(06/04/2009) Bluetooth PCI card for desktop system (bluetooth only card) ??
(06/03/2009) Need advice with linksys WRT54GL router(06/02/2009) Need a router or access point
(05/29/2009) How do I get my linksys befsr41 to transmit a wireless lan signal so i(05/27/2009) Router no power
(05/28/2009) Router Upgrade -help-(05/25/2009) Wireless Router Problem! Help needed! Please
(06/05/2009) Trendnet Wireless N Router providing less than 1 Mbps Connection!!!(05/24/2009) Need help setting up a router with Comcast cable
(06/09/2009) What PCi card is best for me??(05/22/2009) Hi-grade va250d and broadcom mini pci wlan card
(05/20/2009) Need advice for a new "N" wireless router(05/17/2009) Best Home WiFi Router?
(05/16/2009) WIFI card MobilePro 780(05/16/2009) Can't get wireless internet on laptop
(05/15/2009) Advice on Wireless Card(05/26/2009) Wireless Router drops signal after a few hours
(05/14/2009) Want to upgrade to "N" router, questions(05/11/2009) Need a recommendation on a wireless card that is compatible with server 2003 r2
(11/30/2009) Function key combination for wireless router(05/08/2009) Using ADSL router for cable internet
(05/09/2009) WLAN with Wireless Router and Wireless Access Point(05/06/2009) Wireless router - comcast
(05/10/2009) Recommended Router for Wireless N Upgrade(05/08/2009) Which one is preferred firmware OpenWRT or original Linksys firmware?
(05/03/2009) Can I make my laptop run a WAN?(05/01/2009) Printer not printing after setting up a lInksys N router
(04/30/2009) Modem/router?(04/27/2009) Xbox via laptop - Bridging connections not working?
(04/25/2009) What do I need to connect to this router?(04/24/2009) Dlink router
(04/23/2009) IP addressing from wireless router!?(04/20/2009) Change wireless card. PLEASE help!
(06/23/2009) [SOLUTION] How to use WRT54GS Linksys as an AP/Switch/Expander(04/14/2009) D-Link router isn't working correctly.
(04/14/2009) Router problems(04/13/2009) Wcg200 for linksys
(04/11/2009) WPA2 adapter with WPA router(04/10/2009) Router effecting Modem
(04/10/2009) Overclocking linksys WUSB100 adapter(04/09/2009) Linksys
(04/08/2009) Buying a wireless router(04/07/2009) Wireledd Card
(04/08/2009) Router Reliability(04/06/2009) V4000 wireless card
(04/05/2009) Linksys WRT160N router does not validate identity(04/02/2009) HELP PLEASE, cant get router to work with charter internet
(03/31/2009) Compatibility will it work?(03/31/2009) My Laptop shows a wireless connection but ...
(03/30/2009) Changing encryption from WPA-PSK to WPA.Thompson 585v7 router(03/29/2009) Dell mini 9 laptop
(03/28/2009) Linksys by Cisco does it has wifi?(03/28/2009) Network card or usb wireless?
(03/25/2009) Need help with linksys wet54g network bridge(03/26/2009) Laptop crashes w/new wireless router--help please??
(03/24/2009) Wrt54g v.6 router with wet54g v3.1network bridge bridge(03/23/2009) Laptop Wireless adapter
(03/23/2009) Linksys Route & Windows 2000(10/05/2009) Laptop with XP wont connect to my wireless network
(03/21/2009) Can You Recommend a Wireless Network Card for 64 Bit Windows?(03/21/2009) 2 wire modem router 1000hw
(03/20/2009) Wireless Linksys Router(03/19/2009) Wirelees router with a cable modem issuses
(03/19/2009) Modem to router(03/19/2009) I need to get a repeater to improve my existing router ...HELP
(03/18/2009) Linksys WRT310N & WAP4410N any one using them presently(03/18/2009) Linksys
(03/18/2009) Best WRT54G router replacement?(03/16/2009) Need help on router
(03/16/2009) Laptop + Squeezebox having problems with new router(03/14/2009) FASTEST, Longest Range and most reliable wireless router?
(03/12/2009) Connecting Mobile to Laptop to Share WiFi using Bluetooth(03/11/2009) Repeated loss of connection on laptop
(03/10/2009) Securing my Netgear router(03/10/2009) Can you connect a wireless 2.4ghz mouse to a wifi chip in a laptop
(03/13/2009) Finding the on siwtch for WRT310N Linksys Router(03/08/2009) Help setting up linksys psus4 with hp 6122 printer
(03/07/2009) Huge headaches since WRT54G died(03/10/2009) New "N" router has no range
(03/04/2009) Wlan USB stick or a PCI extension card?(03/04/2009) Which Router to get?
(03/03/2009) Linksys wireless-G acess point WAP54G-EU(03/03/2009) Good wireless router?
(03/02/2009) Why does my laptop keep disconnecting frommy wirelss router(03/01/2009) Wireless usb with current router.
(02/28/2009) Controlling a router remotely(02/26/2009) Linksys error
(02/25/2009) Which wireless card to get with WNR 2000 and Vista 64?(02/24/2009) My router d-link dir 655
(02/24/2009) Help i can't find the wep key for abelkn54g wireless router for my wii(03/03/2009) Can I add a wireless router to an existing wired router?
(02/20/2009) Connect laptop to wireless router(02/19/2009) Using a router to send cricket broadband to my other pc's
(02/18/2009) Router(02/18/2009) Verizon westell 6100 linksys wrt54gx4 and bitcomet
(02/17/2009) Wireless router(02/16/2009) Need help picking a router (specific needs)
(02/16/2009) Vista 64 bit wireless card(02/12/2009) My computer won't recognize by new wireless router
(02/11/2009) Wirleless Card Not Authenticating(02/11/2009) How to hide one's internet activity from a wireless router
(02/11/2009) Best Wireless Router(02/10/2009) Multiple router?
(02/10/2009) Which Router?(02/08/2009) DWL-650+ Adapter with DI-628 Router
(02/08/2009) Looking for new router any real world suggestions(02/05/2009) SLOW file copies 1.3Mbps over WRT54G
(02/06/2009) Wireless router/modem combo????(02/03/2009) Router disconnects when viewing any Map web site
(02/03/2009) WAVEBUDDY WIRELESS PC CARD SOFTWARE(02/02/2009) Cant connect to internet without wireless router
(01/29/2009) Windows 7 64 bit wireless pci card compatibility(01/24/2009) Wireless router downstairs. desktop upstairs
(01/23/2009) New Wireless Card not being recognized in Vista(01/19/2009) How to configure two routers Linksys(one as access) point via wireless
(01/17/2009) Wireless Network Issue w/Printer on Vista Laptop(02/11/2009) Suggestions for wireless router
(01/09/2009) Having issues getting network to work(01/09/2009) How to set up my Hawking router as a second router?
(01/09/2009) Wireless Router to Wireless router(01/06/2009) Cannot Change Wireless Card Settings - freeze
(01/06/2009) Router/Gaming(02/10/2009) Wireless N adapter and G router
(01/05/2009) Dlink router troubles(01/02/2009) Is this router causing my problem?
(12/30/2008) GAMING with Wirless PCI Card(12/31/2008) Netgear wireles router is realy slow compared to my linksys
(12/28/2008) 64-bit Drivers for Wireless Network Card(12/21/2008) Wireless card acting as a wireless router
(12/21/2008) Windows XP not recognising network card?(12/15/2008) Getting WG602 to work with BEFSR41 V3
(12/13/2008) Vista and linksys, weird connections(12/15/2008) Weird connections with linksys
(12/08/2008) Question About My Router(12/10/2008) looking for a good 200+ simultaneous connection dual-N router
(12/02/2008) Difference between Access point and Router?(12/13/2008) My laptop is not able to connect to WiFi Network after reinstal OS
(11/28/2008) Router Upgrade for 10/1 Cable(11/28/2008) Upgrade PCI card vs Network Repeater-Help Please
(11/26/2008) access point/ wireless router(12/08/2008) Intel 5100 AGN + Linksys WRT610N = good connection?
(11/27/2008) Will a better router help?(11/19/2008) Will This Work
(12/01/2008) Upgrade Wireless mini-PCI Card?(11/29/2008) Possible to use a router to turn on a tv
(11/10/2008) New Router, page loading issues. Must refresh to see.(11/02/2008) Is D-Link 655 router reliable
(11/07/2008) Suggestion for a Stable Wireless B/G PCMCIA Card for Win 2000(10/30/2008) Router or something call Access Point???
(11/13/2008) Wifi laptop stealing bandwidth??(11/03/2008) Wireless print server to wireless router problems!
(10/24/2008) Do i need a wireless card?(10/21/2008) Will a Range extender work in this case?
(11/04/2008) Need a wireless router, please help?(10/18/2008) What type of wireless router do I need? plz help me!
(10/18/2008) WTF? i cant connect laptop to router(10/13/2008) Linksys WRT54GS
(10/04/2008) Antenna upgrade, how many on n router?(10/03/2008) wireless? fujitsu c2220 laptop
(10/02/2008) do i buy another router?(09/28/2008) NETGEAR w.router stops working with security on
(09/27/2008) Reccomend me a Modem/Router(09/26/2008) Laptop-Wireless Router
(09/20/2008) which router - what adapters(09/20/2008) USB Adapter or PCI CARD For Wireless
(09/17/2008) Best PCI card for the buck?(09/16/2008) can't ping desktop from laptop
(09/15/2008) Linksys Wireless Router not working with Motorola Surfboard Cable Mod.(09/14/2008) upgrading topic "placing a second router"
(04/23/2009) Seting up A 2nd router behind an AT&T 2Wire UVerse Router(09/07/2008) Billion 5200N/7300N vs. Linksys WAG160N vs. Netgear DGN 2000
(09/03/2008) Best Wireless Router(09/03/2008) How to Lan between 2 laptops (Wireless) without a router???
(09/03/2008) Using DSL Router (w/ wireless) as wireless router alone(08/27/2008) Help with Marvell 88W8335 Wireless Card
(08/27/2008) What is a good router to buy?(09/22/2008) What Wireless PCI Card?
(08/25/2008) Use wireless router as wired router(08/30/2008) Will my computers work on the 5GHz band?
(08/24/2008) D-Link Rangebooster G Wireless Router(08/20/2008) like to add a second wireless router with no WEP
(08/15/2008) Damm! have to restart the router again #$%^&(08/12/2008) Need a replacment for wrt54g
(08/12/2008) Connect to my neigbours router and vice versa(08/10/2008) Gaming with a Router connected to other Router
(10/10/2008) Linksys wireless usb adapter not connecting to my Linksys wireless Rou(08/07/2008) Wireless router vista 64 Xp 64
(08/06/2008) Making a larger wireless network(08/04/2008) Linksys router issues
(08/04/2008) Looking for a new wireless router....(08/04/2008) Access point vs router vs repeater vs media center extender
(07/30/2008) Wireless Connection Issues with WRT54G + Windows Vista 64 Bit(07/28/2008) WEP Encryption - one laptop does not work with it
(07/29/2008) SMC wireless router as wired AP(07/27/2008) new 802.11n router + connecting to adsl2 router
(07/27/2008) looking for gigabit wireless/gigabit wire router(07/27/2008) Does my PC have to be on to have laptop connect wirelessly?
(07/25/2008) Random disconnects on FIOS router.(07/25/2008) What wireless router is best used with an Att DSL Modem?
(07/24/2008) Router and adapter reccomendations(12/29/2008) Low signal with FIOS router
(07/25/2008) 802.11n PCIE Mini Card Upgrade(09/07/2009) placing a second router
(07/22/2008) CDMA/GSM/EDGE/HSDPA /MODEM/DATA card manufacturer(07/22/2008) Wireless-G network adapter work with Wireless N router
(07/20/2008) Looking for a router that has aliased domain blocking and allowing(07/21/2008) setting up wireless internet for laptop
(07/11/2008) Can't connect Laptop, WEP problems, clueless(07/13/2008) Please help me with my wireless router....
Sponsored links
