Pooling, Loadbalancing,Bridging three wifi connections ?? Questions?
More related threads to : Pooling, Loadbalancing,Bridging three wifi connections ?? Questions?
(08/19/2008) Wifi Vista to Ethernet XP?(08/15/2008) Big Problem: Connections Tray "Not Responding" => No Internet + Slow P
(08/10/2008) Using two Wifi with one Cable modem(08/08/2008) Network Connections Issue
(07/12/2008) ** Still Same Not Able To Enabale Wifi In Aspire 3690 **(08/01/2008) Belkin F5D8053 wont connect to any wifi
(06/30/2008) Linksys WMP54G 4.1 Trouble picking up wifi signal WinXP SP2 32-bit(06/26/2008) bridging 2 wireless nics
(06/02/2008) p5w and my wifi ap solo(03/12/2008) MIMO Wifi is slow, or is it normal?
(03/15/2008) Add wifi to Gateway 500S w/wired LAN(02/24/2008) 100m WiFi
(12/02/2007) Wireless LAN Questions(11/23/2007) A few questions...
(11/17/2007) WIFI(11/09/2007) DLINK DSL G604TRouter + P5K-e/wifi AP Help
(11/05/2007) wireless ethernet bridging(10/03/2007) How to connect to Internet, through WiFi; a problem
(09/30/2007) Wifi problems on laptop(09/01/2007) Vonage and wireless connections!!!
(08/21/2007) can connect with ethernet but not wireless, conflict with wifi card?(08/05/2007) Wifi Not Connecting - Wired Works Fine
(07/29/2007) Vista & wifi - Can see wireless networks but can't connect to them!(07/26/2007) Having problems with Asus Wifi AP dropping connection
(07/23/2007) Regarding increasing the WiFi range(07/19/2007) Setting up wifi for 18 people
(09/17/2007) Problems connecting to unsecured wifi network in Vista(07/18/2007) Need advice regarding extending WIFI network (picture included)
(07/21/2007) Is it possible to have "various" wireless connections?(07/10/2007) Wireless Network questions.....
(06/26/2007) WiFi connected to access point but can't find internet(05/17/2007) Wifi better than cat 5 ????
(04/16/2007) First Time WIFI Setup(04/14/2007) CounterStrike Source causing loss of WiFi connection
(02/28/2007) Multiple Connections: Wireless 802.11g and Verizon EVDO(02/23/2007) bridging 2 wireless routers
(02/13/2007) So I've decided to go wireless, but I have a few questions(02/05/2007) 1st PCI-E Wifi AP combo card! Wireless network card!
(02/06/2007) US Robotics wifi router(02/02/2007) WiFi Repeater set up! Major headaches. Can you help?
(01/18/2007) Netgear trouble with 2 wifi's :((01/11/2007) What are the differences between Wifi and 802.11b/g?
(12/09/2006) Noobness Dual Ethernet Mobo + Wifi question(12/08/2006) PSP wifi connection
(11/17/2006) Multiple Internet Connections to form FAT pipe Wireless Net(11/03/2006) packet injection and monitor mode wifi cards
(03/23/2007) My neighbours are intruding my wifi security enabled network(10/27/2006) Desktop WiFi Card
(10/26/2006) how can i get wifi?(10/25/2006) l33t help needed. Using bittorent on my neighbours wifi....
(11/15/2006) bridging two WAP(09/22/2006) WiFi Tweaks.
(09/18/2006) usb wifi adapter drops to 1mbs when connected in bridge!?(09/15/2006) usb wifi adapter drops to 1mbs when connected in bridge!?
(09/14/2006) network connections(08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help
(08/16/2006) Wifi gurus!! Please assist! Multi AP setup on 1 subnet(08/08/2006) Need help with wireless connections WRT300n and WRT54G
(08/08/2006) Need help with wireless connections and Lynsis SRX400 Router(07/27/2006) I have a wifi lap top what do I do next?
(04/07/2008) WiFi and Dialup?(08/02/2006) Help with Bridging internet between two buildings WinXP
(07/09/2006) Got Wifi connected, but can't get a network going(07/18/2006) SET UP MY OWN WIFI BUT NEED A LITTLE HELP PLEASE
(06/28/2006) Bridging Linksys WAP54GPE Problem(06/21/2006) Can you disable built in WiFi in favour of an external WiFi?
(06/12/2006) Connecting two wired switches with wifi + using access point(06/04/2006) Recommendations for extending wifi signal
(05/19/2006) linksys wifi issue(05/07/2006) How to share wifi with a device that cannot logon?
(05/24/2006) PCI WiFi question(04/05/2006) My WiFi card worked before I formatted my laptop!?
(12/10/2006) Roaming WiFi issues - 3 APs, one switch, one SSID(03/05/2006) WDS Config Questions
(05/04/2006) wifi spectrum analyzer?(10/23/2004) Wireless Linux Questions
(01/25/2006) Linksys wifi Router runnin on cable..(03/19/2006) auragrid wifi extender
(09/26/2005) wifi & iwconfig(09/22/2005) Long Range wifi troubles
(04/03/2004) Linksys WRT54G Setup And Security Questions(04/03/2004) WiFi security settings
(04/02/2004) Screwy behavior from different wifi pc-cards(04/03/2004) Some simple wireless questions
(04/01/2004) ICS and wifi(09/06/2005) Wifi connection dropping or timeout ....
(09/30/2005) Bridging with SWEEX LC000070?(01/16/2006) Using Linksys WRT54G to connect to another wifi router
(01/19/2006) Recommend an access point, 4-p Router wifi(01/27/2006) newbie questions
(01/19/2006) Router connections(01/28/2006) CAVEMAN ASK: HOW FAR COMPUTER WORK, WIFI DISTANCE, YARDS?
(01/15/2006) Will this WiFi setup work?(01/10/2006) Wifi Signal Mapping question
(01/08/2006) Auuughhh!! Airlink Woes, Questions...(12/07/2005) Noob questions and choices.
(09/13/2005) Accessing a wifi printer(09/07/2005) Multiple users logged on one machine with WiFi... is it po..
(09/07/2005) Basic setup - USB WiFi on 2 PCs for Internet Sharing... ho..(09/16/2005) beginner's questions 2
(08/31/2005) Wifi connection lost(09/20/2005) Win XP PRO SP2 WiFi and DHCP
(08/25/2005) VERY odd routing behavior when attempting VPN connections ..(08/24/2005) Frequent WiFi Disconnects
(08/24/2005) What are risks of WLAN connections at internet cafes?(08/07/2005) USB device not showing in "network Connections"
(07/25/2005) Laptop Only Uses WiFi, Refuses to Use Wired LAN When Conne..(07/12/2005) Very Frustrated NooB Questions
(07/14/2005) Jumping wireless Connections(08/24/2005) Jumping wireless Connections
(07/01/2005) No wireless network tabs in Network Connections(06/28/2005) Dual network connections?
(06/23/2005) bridging with ad hoc wireless network(06/18/2005) Dial-up sharing with WiFi
(06/16/2005) Two wifi networks?(06/12/2005) Newbie questions
(06/07/2005) Wifi et Activesync(05/25/2005) connexion wifi intermitente
(05/25/2005) WiFi card disconnects on logout (XP SP2)(04/28/2005) Wireless Networking not visible in Network Connections - S..
(04/28/2005) Is there a timeout on Wireless Network connections(04/26/2005) WiFi doesn't work with LAN card in WINXP sp2
(04/25/2005) WinExplorer slowdown / crash on Wifi transfers(04/24/2005) Does bridging reduce overall speed?
(04/20/2005) Lost WIFi connection on each reboot(04/16/2005) wireless internet connections
(04/14/2005) File sharing from a WIFI PC with nobody logged on - How to..(04/11/2005) New WiFi Set Up
(04/11/2005) WiFi Connection Nightmare(04/06/2005) HELP! Network connections empty and Ipconfig won't work
(04/08/2005) one CAT5 cable, two WiFi laptops(04/04/2005) difference between Wifi repeater and range extender?
(04/04/2005) Roam from Gprs network to Wifi network(03/27/2005) How to troubleshoot intermittent connections.
(03/25/2005) wifi newbie(03/25/2005) Cannot See Internet Connections
(03/18/2005) Wireless connections control(03/19/2005) PC Screen Output to TV via Wifi
(03/25/2005) wifi mystery(03/10/2005) One wifi laptop
(03/11/2005) One wifi laptop(03/10/2005) Fed up of no WiFi
(03/10/2005) Home WiFi security(03/09/2005) Offline Folders, VPNs, & WiFi
(03/07/2005) HP DV1100 and Netgear 802.11G connections...(02/19/2005) How can I Load Balance Two Internet Connections?
(02/21/2005) WDS and wireless bridging And AD(02/17/2005) break Wifi ?
(02/16/2005) Prevent user from modifying WiFi settings(02/05/2005) wireless lan for three computers within a large corporate ..
(02/02/2005) wireless network questions & problems(02/04/2005) General network questions
(01/29/2005) Wifi Acer(01/25/2005) Wireless Questions
(01/23/2005) NETWORK CONNECTIONS(02/15/2005) aggravating wifi prob
(01/22/2005) USR2216 WiFi card causes Win XP to crash - newbie need help!(01/31/2005) win 64 asus wifi driver
(01/07/2005) Printer on WiFI?(01/02/2005) wifi - IE6 problem
(12/31/2004) Adding an Antenna Pigtail to a WiFi card(12/30/2004) Belkin WIFI Card
(12/30/2004) a few wireless questions....(12/29/2004) Enabling Network Connections.
(12/23/2004) need help, new wifi extension has not internet and can't o..(12/22/2004) Hit & Miss Wifi
(12/26/2004) 2 Basic Wired-Wireless Connection Questions(12/17/2004) Basic WiFi Questions
(12/12/2004) Do routers normally drop connections after idle periods?(12/04/2004) Outlook Express and wireless connections
(12/04/2004) Mapped drive over WiFi network(12/04/2004) Wireless questions
(12/02/2004) Bridging the wireless and other connections(11/28/2004) 802.11 Questions
(11/23/2004) UK: Wanadoo Wifi Bundle(11/19/2004) Sp2 + wifi: new headache
(11/14/2004) problems with network bridging(11/09/2004) Router for 64 only allows 4 connections
(10/31/2004) Wireless connections mysteriously stopped working(10/27/2004) Too Many Wireless Connections
(11/16/2004) Bridging Wireless and Ethernet subnets(10/24/2004) Wireless Bridging???
(11/10/2004) WIFI connection randomly/non randomly disconnects(10/20/2004) Is it better to use ASUS WiFi Network Setup software or Wi..
(10/13/2004) Can I activesync through my wifi on my Ipaq 4150 not the b..(10/14/2004) WiFi (ad hoc) network doesn't restore after night of logoff
(10/13/2004) 2 connections on one computer!(10/06/2004) Best Wifi Cable router under £50?
(09/22/2004) auto switching from LAN to Wifi connection(09/20/2004) Watching movies over wifi
(09/16/2004) WiFi Hotspot Directory now includes over 12,000 sites incl..(10/02/2004) logon using Wireless/WiFI
(09/15/2004) New access on the block point dumps wireless connections(09/13/2004) Peer to peer wifi setup
(09/12/2004) USR wifi & windows2000(09/09/2004) Question for Barb Bowman: Wifi Activesync & SP2
(08/24/2004) mixing wireless connection with hard wired network questions(08/18/2004) WiFi Continually Disconnects
(08/17/2004) Restore network connections unreliable(08/05/2004) Trouble staying connected to wifi
(07/31/2004) Network connections not automatically restored at startup(07/31/2004) connect to wifi not only getting autoconfig ip
(07/30/2004) Wireless questions for XP(07/27/2004) Wifi can't find my router
(07/24/2004) Free WiFi at Airports, how to use?(07/22/2004) D-Link questions
(07/20/2004) WiFi Bandwidth issue(07/18/2004) internet sharing via WiFi
(06/16/2004) wifi + games = lag(06/16/2004) recommendations for wifi unit as basestation only
(06/11/2004) wifi - can't ping other PC(06/02/2004) No connection with built-in WiFi antenna?
(08/08/2004) locking onto my own wifi signal(05/10/2004) Questions from a wireles rookie
(05/22/2004) Place full of nincompoops - too many unanswered questions?..(05/07/2004) Wifi connection lost
(04/28/2004) Available Wireless Connections(05/29/2004) Midnight blues with WiFi
(04/21/2004) Very large number of wifi clients(04/23/2004) signal strength questions
(09/19/2005) WiMAX CPE/WiFi AP combo(09/14/2005) IPAQ2200 WiFi Adaptor
(09/07/2005) WIFI questions(09/04/2005) WiFi Games?
(09/02/2005) securing laptop for public WiFi spots(08/30/2005) ICS problem on WiFi
(08/25/2005) USB wifi adapters(08/26/2005) Couple Linksys WRT54G Questions for you Experts
(08/24/2005) Trying to setup an offset antenna for wifi(08/24/2005) Remote WiFi Printing? Is it possible
(08/17/2005) internal wifi antenna(08/15/2005) Wifi on/off switch stays lit-up when off
(01/08/2005) VOIP via Wi-Fi security questions(01/09/2005) Internet connections from my motorhome
(01/06/2005) Wifi - connection drops when any security is enabled(01/03/2005) WIFI in USA and UK
(01/03/2005) WiFi v WLAN(12/31/2004) Linksys wireless questions - MAC filtering and DHCP
(12/29/2004) two wireless connections(12/29/2004) Review of Mega-Wave WiFi 12dbi gain antenna wanted
(12/28/2004) WIFI works in Adhoc, but not in "Infrastructure mode"(12/22/2004) Best WIFI cards for PC?
(12/19/2004) Pelethora of Questions(12/17/2004) WiFi and Bluetooth
(12/15/2004) How can I know Howmany connections my Wirless Router suppo..(12/16/2004) whats the best all in one wifi router/modem etc for extend..
(12/14/2004) uPNP - needed on WiFi router?(12/12/2004) Bridging wrt54g to wgt624
(12/14/2004) WiFi Security for Semi-Public locations ?(12/11/2004) WiFi network with 1600Ft between two buildings
(12/20/2004) Wifi's on 2 Laptops don't detect each other even with nets..(12/08/2004) A few wireless security questions
(12/04/2004) Wifi + apps for sales force ?(12/03/2004) Wifi and Signal finder in one!!
(12/03/2004) wifi video trasmitting(12/03/2004) Multi-home wifi network setup suggestions
(12/04/2004) WiFi Interference: Is 802.11a and better than b/g ?(12/02/2004) FS: UK Lurker selling 3com PCI wifi cards cheap on ebay
(12/01/2004) WG802v2 bridging problem(12/01/2004) SD WiFi card
(11/30/2004) Suggestions for Condo Wifi Network?(11/29/2004) Using wifi to link laptop and main computer files?
(11/29/2004) wifi power output(11/28/2004) Multi-home wifi network setup suggestions
(11/23/2004) wifi hates wired(11/15/2004) A couple of dumb questions...
(11/14/2004) WiFi network setup problems(11/12/2004) What's the cheapest WiFi AP ?
(11/11/2004) connect desktop appl into wifi network(11/13/2004) WiFi Finder Smart I D
(11/09/2004) WiFi Data Errors(11/09/2004) WiFi Data Errors
(11/01/2004) Vonage Phone,Wifi, Traveling, with What Router?(11/06/2004) WAL-MART WiFi
(10/31/2004) HIGH power Cardbus Wifi(10/31/2004) Motorola WR850G - inside connections
(11/05/2004) Rural wifi extension (again)(10/27/2004) add antenna to wifi router or remote pc?
(10/27/2004) Newbie: Is it normal to drop connections w/D-Link DI-524(10/26/2004) General Wifi optimizing tricks
(10/24/2004) Questions about repeating neighbor's wireless network in m..(10/29/2004) Constant drropped network connections
(10/19/2004) LAN/WiFi Network Plan(10/16/2004) LG Phenom WIFI card
(10/17/2004) getting wifi to work between rooms using multiple access p..(10/16/2004) Calculate Power of WiFi hardware - info
(10/14/2004) rural wifi extension(10/13/2004) Looking for cheapest way to set up wifi hotspot with payment
(10/14/2004) Belkin Bridging(10/11/2004) A couple of really dumb questions...
(10/04/2004) wifi drops after short time(10/10/2004) Wireless connections no longer working
(10/02/2004) Suggestions for 5 mile squirt, local AP's and wifi custome..(09/30/2004) porada - sygnal WiFi i jego podzial
(09/30/2004) Metro WiFi and security?(09/28/2004) 802.11 distance, quality questions.
(09/28/2004) WiFi and long term health issues(09/28/2004) Going wireless - basic questions
(09/25/2004) PALM WIFI card & home wireless network(09/21/2004) If you have a free wifi hotspot you can add it to our dire..
(09/21/2004) Sputnik Inc. launches Hosted WiFI mgmt. service! Be a WISP!(09/23/2004) Bridging 2 small workgroups - what to buy?
(09/20/2004) Wireless Bridging Dlink APs and Cisco(09/21/2004) Any tips in setting up 1 mile WiFi connection with Senao b..
(09/17/2004) A good DSL WIFI modem?(09/16/2004) WiFi Hotspot Directory now includes over 12,000 sites incl..
(09/12/2004) WiFi US Deployments(09/14/2004) wifi bridge
(09/13/2004) Wifi shopping in the US(09/13/2004) Telephone calls over WiFi
(09/09/2004) Any good nationwide WiFi hotspot locators???(09/09/2004) Smallest WiFi router?
(09/24/2004) Wireless Gain Antenna for Wifi Card(09/02/2004) Bridging with linksys products... a lost art?
(09/10/2004) Philadelphia about to become one giant WiFi Hot Spot!!!(09/01/2004) WIFI DXin
(08/31/2004) WiFi PCI-card with packet-driver(08/31/2004) WiFi Audio Streamer
(08/27/2004) Questions on 1 vs 2 antennas(09/05/2004) Wi-Fi/Bluetooth PDA questions
(08/23/2004) WUSB11 Ver. 2.6 drops connections Liksys b wl router(08/22/2004) Netgear WG111 Questions
(08/22/2004) Numerous WiFi Accounts(08/22/2004) Numerous WiFi Accounts?
(08/20/2004) Tungsten C and WiFi Connections(08/21/2004) Palm announced a WiFi card for the T-3 today!
(08/21/2004) WiFi Card for Windows 95?(08/18/2004) Wifi antennas
(08/20/2004) DSL questions(08/17/2004) Security and open wifi hotspots
(08/17/2004) Plan to go to DSL questions(08/17/2004) IBM wifi card in non-IBM machines
(08/13/2004) Highest power USB dongle for poor mans wifi antenna set-up(08/12/2004) Offline way to find Wifi Hotspots
(08/11/2004) Wireless Ethernet Bridging at 200 Kilometers(08/10/2004) Security in using wireless connections
(08/14/2004) wanted USB WiFi adapter(08/22/2004) wg111 netgear usb wifi anyone???
(08/07/2004) Does weather effect Wifi in the home ?(08/05/2004) My USB WiFi NIC freezes system on XP :(
(08/03/2004) ETG now with WiFi Hotspots(08/03/2004) Wifi dropouts/ intermittent connection
(07/29/2004) newer technology (reasonably newbie-ish questions)(07/28/2004) Easy/cheap short range 802.11a point-to-point bridging?
(07/26/2004) Big Problem With SENAO WiFi Access Point & WiFi Router .....(07/26/2004) Wifi off standard DBS antenna used for TV?
(07/25/2004) Free Wifi Hotspot Directory..best for offline way to get o..(07/26/2004) Big Problem With SENAO WiFi Access Point & WiFi Router .....
(07/26/2004) laptop wifi g help needed(07/22/2004) Defcon Wifi Shootout Contest, Sponsors, Prizes!
(07/22/2004) where to buy WIFI antenna extenson cable(07/20/2004) WiFi on Tobago
(07/20/2004) FA: COMET X2427 2.4 GHz Directional Wi-Fi Antenna YAGI WiFi(07/20/2004) ADSL modem and WIFI Router
(07/26/2004) WiFi Compass(07/19/2004) cheap portable wifi solution
(07/18/2004) newbie questions(07/11/2004) Wireless routers for Macs (two elementary questions)
(07/10/2004) Homemade Sector WiFi Antenna?(07/08/2004) Random international wifi experiences
(07/07/2004) good wifi websites(07/04/2004) Multi-point bridging with a dwl 2000ap
(06/29/2004) wifi recommendations in an apartment(06/26/2004) Help! Streaming rm/cfm radio via wifi Q
(06/24/2004) Good site for wifi router reviews?(06/23/2004) Safe Passage SSH VPN for securing wireless connections?
(06/20/2004) Connecticut WiFi User Group(06/21/2004) Current inexpensive wi-fi routers that support bridging?
(07/28/2004) Setting up a WIFI hotspot(06/18/2004) Dell True Mobile 1300"G" WiFi Card/Notebook and Hotel WiFi..
(07/02/2004) Piggybacking --technical and ethical questions(06/16/2004) Belkin F5D6231-4 wifi router problems
(06/17/2004) how automatically desactivate wifi interface?(06/16/2004) Problem with WPA-PSK bridging between Belkin 7230s
(06/15/2004) Newbie and a bunch of questions(06/14/2004) Event Wi-Fi Questions for Article.
(06/11/2004) Pheenet Wireless Acess point with bridging(06/19/2004) Sporadic connections to external AP driving me nuts
(06/13/2004) two questions about wi-fi & hotspots(06/08/2004) ICS host with bridged, wifi client setup (?)
(06/07/2004) Wireless LinkSys - very newbie questions...please help(07/02/2004) Traveling and taking WiFi equipment along.....
(05/26/2004) Dropped connections with Windows 98(05/26/2004) linking a laptop to a desk top with wifi
(05/25/2004) Bridging mode in Belkin or Netgear Access point?(05/23/2004) Linksys BEFDSR41W router useless for wifi?
(06/03/2004) long range wifi question(05/22/2004) no more connections with D-Link G520+
(05/24/2004) WiFi network of neighbour(05/27/2004) Sending mail on WIFI networks
(05/18/2004) wireless config for three waps(05/18/2004) Bridging an existing WLAN to a wired LAN
(05/18/2004) Bridging an existing WLAN to a wired LAN(05/16/2004) Wifi Newbie needs tips
(05/15/2004) Two "b" vs "g" questions(05/13/2004) Linksys BEFDSR41W useless for wifi?
(05/10/2004) Providing Free WiFi from Home(05/09/2004) Fixed & WIFI Linksys Routers
(05/08/2004) Merge multiple wifi APs and broadband into fat pipe(05/12/2004) Wireless - Newby Questions 2 Wire home network
(05/07/2004) How Do I diagnose WiFi Interference Problems ?(05/05/2004) WiFi Ap keeps dropping ADSL connection
(05/05/2004) NetGear Wifi Router problem(05/14/2004) SanDisk Connect Plus 128Mb+Wifi Compact Flash (SDWCFB-128)..
(05/03/2004) Advice for a wifi newbie please.(05/03/2004) WiFi & Win2K connection difficulties
(05/10/2004) Need gateway app to sniff all network/wifi traffic(05/01/2004) Internal WIFI Card in my laptop is SLOW
(04/26/2004) Cell Phone Wifi Browser connections(05/31/2004) WiFi Security and XP Internet Connection Sharing ?
(04/18/2004) WiFi Internet connection with wireless home network(04/14/2004) 3 questions about wireless
(04/12/2004) Wifi + Win98 +Dell Inspiron 3000(04/14/2004) Newbie: Wifi External Antenna to Cable Modem?
(04/09/2004) company wide wifi(04/07/2004) Multipoint WiFi with D-Link DLW2000AP+
(04/06/2004) WiFi providers(04/05/2004) Cisco Wireless Bridging 3 sites
(09/01/2005) Laptops WiFi now unuseable!!(07/30/2005) Increasing AP strength/laptop wifi strength
(03/12/2006) Wireless Bridging of Routers(02/14/2005) Sharing wifi between buildings
(11/24/2004) HELP needed seting up wifi network(08/04/2004) Bridging has me stumped!!
(07/24/2004) using BlueTooth as bridging for All-In-One printer(05/21/2004) WiFi & Overclocking
(02/24/2004) Wireless Bridging(02/13/2004) Few questions about wireless routing...
(01/14/2004) using WiFi to stream video from computer to TV?(12/30/2003) New PC...questions about prepping for Wireless
(09/16/2003) Help me get through this WiFi Jargon(09/08/2003) three story network q's
(08/26/2003) Setting up a home wifi network(07/27/2003) Can a WIFI mac address be hacked
(07/16/2003) 2 wireless connections(05/05/2003) Question about multiple wireless connections
(01/22/2003) Switching between wired LAN and WiFi card(12/06/2002) WiFi encryption issue?
(12/13/2002) How to set up a pay per use WiFi network?(10/07/2002) 20m too far for WiFi?
Google Ads
