Wlan USB stick or a PCI extension card?
More related threads to : Wlan USB stick or a PCI extension card?
(11/27/2009) Wifi card not supported by mobo?(11/24/2009) Linksys wmp11 wireless card gets no signal from 2wire access point
(11/23/2009) Computer randomly crasches after installing a new network card... Help!(11/22/2009) How to get a linksys router to send out a wireless modem stick signal
(11/24/2009) Usb wireless RiLan driver???(11/20/2009) Usb wireless router
(11/16/2009) Wireless card find network(11/11/2009) Lag spikes caused by network card?
(11/08/2009) USB Printer and Edimax Print Server(10/30/2009) Wirless USB Key and LAN Bridge
(10/30/2009) Wireless card no good with windows 7 ?(10/28/2009) Driver/Card Issue
(10/30/2009) Usb wireless router(10/30/2009) USB Adapter for a Desktop running Windows 7
(10/24/2009) MSI Wind u100 843us Wireless Card(10/19/2009) Wireless card spec?
(10/19/2009) Need a wireless n pci card(10/19/2009) USB Wireless Adapter Help
(10/20/2009) Can you run Xbox LIVE off of a wireless card?(10/14/2009) Desktop Wireless Card soemtiems doesn't work on reboot
(10/11/2009) 3G Usb Modem Sharing Compatiability(10/06/2009) 3G Wireless Router/3G USB Modem Interoperability
(09/30/2009) Download GRAFIC CARD LAPTOP m-life(09/30/2009) Terrible speed with trendnet wirless n pci card
(09/20/2009) USB Booster(09/13/2009) New wireless card needed
(09/14/2009) What is the difference between 802 11b/g WLAN wireless AND Built in 802 11b/g WL(09/10/2009) Wireless G USB Adapter Help
(09/08/2009) Start wireless card before logon(10/21/2009) USB or ExpressCard wireless adapter?
(08/27/2009) IOGEAR's Wireless USB Audio / Video Kit(08/26/2009) GigaFast Wireless USB causes blue screen!!
(08/27/2009) Wlan not working(08/23/2009) Pci wireless n cards!are they any good
(08/16/2009) Wireless USB to Ethernet(08/12/2009) Somebody how do I tell if I have a wireless network card installed?
(08/24/2009) Nergear Rangemax Wireless USB(08/10/2009) Sony FW with WLAN, no LAN :(
(08/09/2009) Need a wireless card - only have PCIe 1x slots(08/09/2009) Wireless Internet Network Card
(09/19/2009) Can U upgrade a WEP Wireless card to WPA?(08/02/2009) Wireless USB Adapters here
(07/31/2009) What wireless card?(07/29/2009) Belkin Bluetooth USB adapter. Error 87: parameter is incorrect
(07/19/2009) Windows 7 / Vista x64 Wireless NIC - PCI(07/19/2009) My NetGear WG111T lik disables MY USb Ports except the ones
(07/18/2009) Vista Ultimate and Linksys Routers and USB Card(07/17/2009) Wifi card not as good on one PC vs another
(07/16/2009) Spotty, slow connection - is it my pci card?(07/16/2009) Is there a performance difference between USB & PCI based wifi modules
(07/12/2009) Network w/ 2 PCI cards?(07/07/2009) Set DI-524 as wlan access point
(07/08/2009) Wireless WLAN Mini-PCI Card, Help.(06/26/2009) PCI Wireless N + AP/Monitor Mode?
(06/22/2009) USB/PANTECH UM-175(06/12/2009) Wireless N card to Wireless G Router
(06/15/2009) Is my wireless card broken?(06/09/2009) PCI vs. USB / Recommended Desktop Solution
(06/04/2009) Bluetooth PCI card for desktop system (bluetooth only card) ??(05/28/2009) Fun problem to solve! Wireless USB Problem!
(06/09/2009) What PCi card is best for me??(05/22/2009) Slow wlan transfer speeds
(05/22/2009) Hi-grade va250d and broadcom mini pci wlan card(05/29/2009) Best solution for low signal (USB or PCI)
(05/16/2009) WIFI card MobilePro 780(05/15/2009) Advice on Wireless Card
(05/11/2009) Need a recommendation on a wireless card that is compatible with server 2003 r2(05/10/2009) PCI Wireless adapter
(05/11/2009) Using a USB adapter w/SMA antenna(05/09/2009) WLAN with Wireless Router and Wireless Access Point
(05/06/2009) Better range - USB or PCI?(11/03/2009) USB 500mW WiFi adaptor
(04/20/2009) Change wireless card. PLEASE help!(04/07/2009) Wireledd Card
(04/06/2009) V4000 wireless card(03/28/2009) Network card or usb wireless?
(03/29/2009) Need rec for wireless adapter for Windows 7/Vista OS(03/21/2009) Can You Recommend a Wireless Network Card for 64 Bit Windows?
(03/13/2009) WLan and Lan connection(02/27/2009) Wlan
(02/25/2009) Which wireless card to get with WNR 2000 and Vista 64?(02/20/2009) WUSB54GC wireless USB adapter drops connection
(02/16/2009) Vista 64 bit wireless card(02/11/2009) Wirleless Card Not Authenticating
(02/09/2009) Finding out my WLAN code(02/03/2009) WAVEBUDDY WIRELESS PC CARD SOFTWARE
(01/29/2009) Windows 7 64 bit wireless pci card compatibility(02/09/2009) What wireless adapter (PCI-E or USB) would you recommend?
(01/25/2009) Ethernet Wireless abd Wireless USB(01/23/2009) New Wireless Card not being recognized in Vista
(01/06/2009) Cannot Change Wireless Card Settings - freeze(01/02/2009) What is the best Wireless G adapter (PCI or USB... whichever is better
(12/30/2008) GAMING with Wirless PCI Card(12/28/2008) 64-bit Drivers for Wireless Network Card
(12/21/2008) Wireless card acting as a wireless router(12/21/2008) Windows XP not recognising network card?
(12/06/2008) Best Wireless "N" Mini PCI(11/28/2008) Upgrade PCI card vs Network Repeater-Help Please
(12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients(11/22/2008) WDA 2320 PCI adapter not connecting
(12/01/2008) Upgrade Wireless mini-PCI Card?(11/07/2008) Suggestion for a Stable Wireless B/G PCMCIA Card for Win 2000
(10/24/2008) Do i need a wireless card?(09/20/2008) USB Adapter or PCI CARD For Wireless
(09/17/2008) Best PCI card for the buck?(08/27/2008) Help with Marvell 88W8335 Wireless Card
(09/22/2008) What Wireless PCI Card?(08/25/2008) Windows Vista 64bit compatible PCI network cards
(10/12/2008) Best USB Wireless adapter?(07/25/2008) 802.11n PCIE Mini Card Upgrade
(07/22/2008) CDMA/GSM/EDGE/HSDPA /MODEM/DATA card manufacturer(12/14/2008) Rosewill PCI Wireless adapter RNX-G300(E) Driver Issue Fix for Vista
(07/08/2008) intersil PRISM LAN PCI connection problems!(07/08/2008) USB wireless dongle external antenna
(06/21/2008) Overheating issue with Belkin wireless USB adapter(06/13/2008) PCI Card That Supports 802.11n 5Ghz?
(06/20/2008) Wireless Router or Hub that has a USB port for a hard drive.(06/07/2008) A newb is completely lost with his wireless card.
(05/29/2008) USb or PCI card?(05/02/2008) USB Wireless Adapter concentrate signal
(05/27/2008) wireless PCI adapter not recognized(05/10/2008) Buying a wireless express card for Windows Vista laptop
(05/09/2008) Looking for USB 802.11N network adapter(04/29/2008) Anyone with macbook wireless issues? (airport extreme card)
(04/16/2008) Wireless PCI or USB adapter for vist x64(05/20/2009) D-link USB wireless DWA-110 Vista 64-bit driver
(04/12/2008) need urgent help 64bit wireless card either pci or usb(03/26/2008) Belkin USB Wireless Adapter
(03/08/2008) replace network card in belkin pre-n desktop adapter(02/20/2008) WLAN Troubleshooting & Analysis
(02/16/2008) Help Picking Out a Wirless Card for PC?(07/14/2008) Belkin Wireless G PCI Problems
(01/31/2008) HP2710 Card Slot Wireless Issue(01/29/2008) Wireless card to router with different brand?
(01/26/2008) Any network sniffer to use with Netgear WN121T USB adapter?(01/28/2008) Wierd wireless PCI card problem
(12/15/2007) Local Only - Vista Usb Adapter Problem !!!!(01/11/2008) Wireless Network - USB Modem
(11/27/2007) Old laptop, new wireless card, old Linksys BEFW11S4(11/21/2007) Is this interference? Or just a crappy router/PCI card?
(10/02/2007) Intel Pro 3945 ABG Wireless Mini PCI Express Card Opinions(09/29/2007) Wireless Card for Vista 64 bit - WEP
(09/24/2007) Accton WN4201B (Wireless PCI Card Issues! HALP!)(08/26/2007) Belkin N Wireless USB adapter poor strength
(08/21/2007) can connect with ethernet but not wireless, conflict with wifi card?(08/09/2007) Crack WEP Network card
(07/02/2007) Gaming - wireless recommended? Or stick to wired?(06/19/2007) Wireless PCI card /USB LAN adaptor
(05/20/2007) Intel Pro/Wireless 2915abg Card(05/16/2007) Weird problem with Belkin PCI card
(06/22/2007) MIMO router without MIMO card?(03/29/2007) Wireless USB question
(03/28/2007) Belken Wireless G USB Network Adapter(03/20/2007) Verizon Wireless Air Card and ICS?
(07/16/2009) XBox 360 Question(Can you use any USB adapter)(03/16/2007) Wireless PCI card.
(03/10/2007) Dlink DIR-655 Router,Pci Card DWA-552 Problem.(02/09/2007) Advice on picking a 802.11n adpater card
(02/05/2007) 1st PCI-E Wifi AP combo card! Wireless network card!(02/06/2007) Can't get wireless card to find network
(01/18/2007) Wireless USB Issues (Fairly long)...Please Help!(01/08/2007) USB wireless adapter issues at startup
(12/31/2006) PCI Wireless network card issues(11/28/2006) Is there a way to eneble ICS on a PCI wireless card?
(11/17/2006) Reccomended Wireless PCI card?(11/09/2009) Range extension using WDS setup question
(10/29/2006) Wireless N for notebook Express card 34/54(06/19/2009) USB Cantenna
(03/17/2009) Desktop WiFi Card(10/24/2006) Wireless Card WILL NOT connect to a wireless network!!!
(10/20/2006) Problem with Belkin 7011 wireless card(10/10/2006) WLAN MAC filter enough as security?
(10/11/2006) Looking for PCMCIA Card(10/03/2006) Belkin N-1 network card for xp laptop
(10/02/2006) 64-bit USB Bluetooth to use with my headset(09/24/2006) configuring network card for auditor
(09/22/2006) I need a new wireless router and destop card for $150(09/06/2006) Question about usb Active Extension Cable
(09/20/2006) Question about usb Active Extension Cable(09/04/2006) Question about usb Active Extension Cable
(08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help(09/03/2006) which wireless mini-PCI card should I buy?
(08/06/2006) Win98se can't find files when loading Wireless PCI card(09/11/2006) Is there a wireless card with an external attena for my dell
(07/24/2006) ASUS / USB / Netgear / Connected, but no IP info(06/24/2006) No wireless card detection
(09/10/2006) USB 1.1 adapter enough?(06/07/2006) Wireless card freezes Win Xp Sp2 at startup Mup.sys
(05/29/2006) New wireless card= limited to no connectivity(03/17/2009) Belkin Wireless USB Antenna
(05/24/2006) PCI WiFi question(10/05/2006) Does any wireless PC card work with any Wireless Router?
(04/30/2006) 1 netgear ma311 pci card 2 pc's(04/26/2006) Legacy AirPort card can't associate with SonicWALL TZ 170
(04/17/2006) Can 802.11b card crack WEP with 802.11g target clients?(04/05/2006) My WiFi card worked before I formatted my laptop!?
(03/27/2006) Best resonably priced wireless router and pci receiver card?(03/20/2006) I need advise: USB or PCMCIA WLAN in linux?
(03/11/2006) PCI Wireless card with Auditor SC(03/09/2006) Setting up a wireless USB dongle for my neighbour..
(01/01/2009) USB wireless adapter drops connection(09/13/2005) Attaching antenna to Belkin 802.11g PCMCIA card
(09/25/2004) Encryption Public WLAN(05/13/2004) Wireless PCI adapter for GNU/Linux
(05/05/2009) problem with linksys wmp11 PCi wireless networking adapter.(09/28/2005) Belkin F5D7050 ver.2011 Wireless G USB Adapter Hardware Is..
(09/28/2005) help: wireless router laptop card problem(09/23/2005) SMC 2802 Wireless PCI Card
(04/02/2004) Disconnection Problem with DWL-G650+ Wireless Card(04/02/2004) Making Linksys WRT54G Router and WPC54G LapTop card work w..
(04/03/2004) Netgear DG834G vs. Toshiba Mini Wireless PCI Card - Please..(04/01/2004) Use of 802.11b card in various countries
(04/01/2004) Belkin wireless PC Card(03/31/2004) WLAN PCMCIA card for Libretto 50ct on Win95???
(02/09/2006) how to change WEP password on SMC PCI card?(09/21/2005) high-gain extension
(09/28/2005) 108 Mbps Cardbus/USB Adapters that accept external antennae(09/17/2005) Linux newbie help - USB adapter
(09/29/2005) Many wireless card doesn't support Linux?(10/15/2009) PCMCIA wireless network card with external antenna ?
(12/23/2005) Wi-network with USB DSL modem(02/05/2006) USB Wireless adapter makes my WinXP "deep sleep"
(01/19/2006) Problem: Weird and random wlan router.(01/20/2006) Wireless card for Laptop (USB or PCMCIA)??
(01/11/2006) Windows configured Wireless card tweak question(01/07/2006) Installing internal wireless internet card...
(11/28/2005) new wireless card(11/24/2005) WIRELESS CARD for Laptop
(09/26/2005) Error0x80040707 for wireless PCI card installation(09/23/2005) WLAN dropping out on big file transfer
(09/24/2005) do i need another network card(09/09/2005) SP2, Benklin Wireless netwrk card, not connecting
(09/10/2005) SMC wireless adapter USB or PCMCIA?(09/08/2005) antenna extension?
(09/08/2005) WLAN connecting problem(09/08/2005) Wireless card disables existing adapters in W2K ?
(09/07/2005) Sharing a USB modem through a wireless router(09/07/2005) Basic setup - USB WiFi on 2 PCs for Internet Sharing... ho..
(09/01/2005) USB config for Windows Connect Now. Did this go anywhere?(09/12/2005) USB wireless not starting soon enough?
(08/30/2005) Wireless Laptop Card..(08/29/2005) Dell Inspiron 600m - Intel wireless card
(08/26/2005) IAS error 16 with Intel 2200BG wireless card !!!(08/24/2005) Lease Expiration Extension?
(08/24/2005) WLAN driver failures after re-install(08/22/2005) Problem about WLAN on windows 2000 pro.
(08/15/2005) Freezes up when wireless card is installed(08/18/2005) Sharing a wireless connection with a neighbours WLAN - Sec..
(08/14/2005) Adding another Pc using a wireless USB adapter(08/13/2005) Wireless Card Snafu
(08/24/2005) What are risks of WLAN connections at internet cafes?(08/07/2005) USB device not showing in "network Connections"
(08/03/2005) Windows 2000 and Wireless PCI NIC(08/02/2005) Periodic breaks in connection between router and PCMCIA card
(07/25/2005) Upgrade to WinXP SP2 causes loss of USB adapter wireless c..(07/17/2005) Wireless Safecom SWLU-5400 USB 2.0 Adaptor
(07/18/2005) Linksys Usb wireless B Network adapter(07/10/2005) Problem installing wireless USB Adapter
(07/07/2005) How do I prevent my wireless card from being accessed by o..(07/06/2005) Linksys Wireless Card Issue
(06/27/2005) 802.11g WLAN performance - HELP!(06/28/2005) Asus wireless network card issue
(07/02/2005) 802.11g Wireless Desktop Network Card(06/20/2005) Desktop connection drops only when card in laptop is active
(06/16/2005) PC Card or USB ?(06/14/2005) Latest WIndows Update for Wireless-G PCI Adapter Broken?
(06/09/2005) WLAN card gets signal but no IP Address(06/08/2005) WLAN novice with connection problem
(06/04/2005) a problem concerning the computer using wireless card(06/11/2005) using Dlink card GWL-G650+ utility software with windowsxp..
(06/03/2005) Setup WLAN card for USA/EMEA std. ?(05/28/2005) External exception E06D7363 message with Linksys card
(05/28/2005) USB Wireless Adapters compatible with Win CE 2.0(05/25/2005) WiFi card disconnects on logout (XP SP2)
(05/22/2005) 802.11b on destop with USB adaptor gigafast(05/21/2005) USB flash drive - wireless networking (infrastructure)
(05/20/2005) Wireless USB "cable"(05/19/2005) Smart Card Certificate Logon and Smart Card Wireless EAP-TLS
(05/24/2005) Wlan disconnects(05/24/2005) XP crash when reinserting wireless USB
(05/11/2005) EVDO Broadband Card(05/12/2005) Problem with Asus WL-138G Network card and Windows 2000
(05/11/2005) USB Network Cards and Logon Issues(05/11/2005) D-Link wireless PCI adapter problems
(05/10/2005) Wireless LAN USB adapter(05/05/2005) Cisco 350 card, XP and Windows Updates
(05/03/2005) WLAN + Notebook + LAN Problem(05/02/2005) How to read data from WLAN card directly and bypassing the..
(05/01/2005) BT Voyager 1040 Wireless Card - Help????(05/02/2005) WinXP + 350 Cisco card vicious circle...
(04/26/2005) Belkin wireless desktop card(04/26/2005) WiFi doesn't work with LAN card in WINXP sp2
(04/28/2005) wireless card install crash name resolution on 98SE(04/25/2005) Wireless 54G USB Adapter question
(04/24/2005) ICS of a WLAN connection(04/25/2005) WPA2 - are new card drivers needed or just a client?
(04/19/2005) 2 ip's on a wireless card(04/14/2005) Wiress 2200 BG Internal Card problems
(04/10/2005) Intel 2200bg Card problems (random blank screens)(04/03/2005) Belkin wireless card causes XP to freeze
(03/30/2005) wireless card does not pick up signal(03/31/2005) How to use the USB Scanner / Printer wirelessly
(03/28/2005) Problem installing wireless card w/ Windows(03/25/2005) Network wireless card configuration
(03/19/2005) Wireless Network card driver only loads under Admin account(03/19/2005) ad hoc wlan
(03/19/2005) Error - Ethernet card unplugged(03/17/2005) Wireless desktop PCI card wont connect to wireless network
(03/14/2005) Verizon wireless router + Netgear Wireless card(03/19/2005) Proxim ORiNOCO PC GOLD CARD with antenna problem??!!
(03/10/2005) USB NIC Group Policy not applying completely(03/10/2005) pc card vs usb network card
(03/09/2005) bridge lan & wlan(03/08/2005) How do I login to domain with USB network adapter?
(03/07/2005) Problem configuring wireless card (setting SSID and other ..(03/03/2005) having trouble with your PCI wireless card losing connecti..
(03/01/2005) Who is accessing my WLAN?(02/25/2005) Misconfigured the USB flash drive
(04/21/2009) Orinoco Wireless Card Problems(02/18/2005) WAP and Win2000 w/ Linksys WMP54GS PCI card
(03/03/2005) XP Won't Recognize Wi-Fi Card(02/21/2005) WinXP sees WLAN, doesn't connect, no error message
(02/15/2005) New computer wireless PCI adapter setup mistake recovery(02/12/2005) Wireless network card in an HP notebook
(02/12/2005) BT Wireless network card problem(02/06/2005) No Connection Until WLAN Utility is Run
(02/01/2005) wireless notebook card with xp drivers(02/01/2005) wireless notebook card with xp drivers
(02/09/2005) wireless notebook card with xp drivers(02/11/2005) BT Voyager USB wireless network adapters.
(01/29/2005) Does frequent enable/disable of wireless card muck up regi..(01/27/2005) Wireless PCI card & video driver corruption
(01/22/2005) Dell 1150 Truemobile Wlan card 'cable unplugged' on W2K(01/21/2005) wireless card not regestering
(01/20/2005) Internal wireless network card not being recognized(05/31/2005) XP Not Recognizing PCMCIA Network Card
(01/22/2005) USR2216 WiFi card causes Win XP to crash - newbie need help!(02/09/2005) File Sharing on External USB Drive
(01/10/2005) Need Help with Wireless Card/Network Problem?(01/10/2005) Which Access Point Device to Buy? USB Adapter?
(01/10/2005) Cisco AIR-MP20B PCI wireless notebook card - software needed(01/07/2005) cannot secure my WLAN
(01/09/2005) XP preference to go for my neighbours WLAN 1st !(01/06/2005) USB Bluetooth adapter not working
(01/02/2005) USB stick question(12/31/2004) Adding an Antenna Pigtail to a WiFi card
(12/30/2004) WindowsXP is using my Wireless card instead of my Wired Nic(12/30/2004) WLAN Light on Linksys BB Router
(12/30/2004) USB Bluetooth install in SP2(01/04/2005) slow Edimax WLAN USB Adapter
(12/30/2004) Belkin WIFI Card(09/06/2009) Linksys Wireless-G card not working
(12/23/2004) Repost: D-Link wireless PCI needs rescan every boot(12/23/2004) need help, new wifi extension has not internet and can't o..
(12/22/2004) No network card(12/22/2004) D-Link wireless PCI needs rescan every boot
(12/11/2004) Linksys WAG54G Wireless Router & PCMCIA Wireless Card(12/04/2004) BELKIN WIRELESS PCI NETWORK ADAPTER F5D6000
(12/03/2004) belkin USB tendency to connect to neighbor's router?!(11/24/2004) local network file shareing on WLAN
(11/23/2004) can use wlan only as admin(11/10/2004) Not able to Connect to Internet while using wireless card
(11/09/2004) Not able to Connect to Internet while using wireless card(11/07/2004) No installation of USB wireless client
(11/01/2004) wireless card adaptor(11/12/2004) Windows XP SP2 and Linksys Wireless-G USB
(10/27/2004) frequent crashes with US Robotics 8054 22MB/s wireless card(10/27/2004) frequent crashes with US Robotics 8054 22MB/s wireless card
(10/27/2004) Wired vs WIRELESS with USB Card(10/24/2004) WI-FI PCMCIA card causing Vaio GRX laptop to crash a boot
(10/22/2004) problem about WAPI card(11/09/2009) Toshiba Wireless LAN Mini PCI card & WPA
(10/16/2004) Wireless PCMCIA card for W95?(10/13/2004) laptop no longer recognises PCMCIA card in XP tho it did i..
(10/08/2004) Wireless Card not recognised using Windows XP(10/08/2004) Problem to work with WPA and my 3Com card
(09/28/2004) which WLAN access point to choose(09/26/2004) Using a PC Card on PC with PCI Adapter
(10/10/2004) Netgear 11g 108 mbps PCI Card(09/17/2004) PCI interface or USB interface
(09/12/2004) Transfer Wlan Property Settings(09/09/2004) Prblm: Radius, WLAN, roaming profiles and software install..
(09/02/2004) Possible to connect 2 computers via USB?(09/04/2004) Belkin USB Wireless Network Device/ XP SP1&2 - Not working
(08/30/2004) low profile pci wireless card(08/31/2004) USB adaptor works but my comp keeps freezing
(08/30/2004) Wireless card suggest(08/30/2004) wireless card; speed?
(08/28/2004) wireless card and great signal, BUT NO INTERNET BROWSER WI..(08/26/2004) Gateway M1300 TabletPC & Linksys WRT54G: WLAN Connection D..
(08/27/2004) Wireless card fails to pick up DHCP address from ICS(08/23/2004) 802.11a card not detected
(08/22/2004) 3COM USB Wireless Adaptor(08/17/2004) Problem with wireless card in w2k
(08/13/2004) WLAN USB Adapter w. Win2k - Error Code 10(08/27/2004) 3Com Wireless Card Manager
(08/10/2004) WLAN setup in Windows XP Pro(08/10/2004) USB 802.11g wireless adapter
(08/02/2004) Dlink Wireless card not showing on XP(07/20/2004) wlan
(07/15/2004) Unable to connect with my PCMCIA card(07/01/2004) Wireless card to Monitor mode
(06/19/2004) Belkin access point and 54g pci card for online gaming?(06/13/2004) Basic connectivity problem on WLAN
(06/14/2004) Problem with Microsoft USB wireless device(02/09/2005) SHARING AN EXTERNAL USB 2.0 DRIVE
(06/07/2004) configuting wiress card(06/05/2004) Laptop with wireless card failed to connect other desktop ..
(06/15/2004) 802.11g Range Shortage Problem for WLAN(06/03/2004) switch off wpa for a non-compatible wlan adapters?
(01/13/2005) Intel ProSET does not configure my WLAN device(05/15/2004) does my computer have a wireless card
(09/19/2009) Wireless Network Card in Toshiba Satellite Pro 2100(05/15/2004) Wireless USB nic and domain logon errors
(05/05/2004) WLan not working on Tosh sat Pro(04/26/2004) Win98 drivers in Win95 / PCMCIA Wireless card in Win95
(08/08/2004) Driver for ZyDas wireless (ZD1201) IEEE 802.11b USB Adapter(04/17/2004) intersil prism wireless Lan PCI card for Fujitsu c series
(04/25/2004) Wireless card takes a while to start.(04/14/2004) WLAN with XP:where are the drivers?
(03/04/2009) background noise from wireless laptop card(09/13/2005) My 3Com USB Adapter is very hot! Could it be overheating?
(09/09/2005) USB 1.1 and 802.11g.(09/08/2005) Mini PCI wireless NIC question
(09/06/2005) Proxim RangeLAN2 PCMCIA card external antenna?(09/07/2005) Replacing USB DSL and Easing Into Wireless
(09/01/2005) Wireless Desktop Card - Windows 98 Compatable(08/30/2005) Choice of wireless adapter: Netgear or Linksys, USB or PCI..
(08/30/2005) Wireless Card Settings for multiple locations(08/25/2005) USB wifi adapters
(08/20/2005) Cisco 340 wireless card(08/22/2005) Sharing WLAN internet connection for LAN - please advise
(08/19/2005) measure thruput between wireless card and wap(08/15/2005) Optimal throughput speed on a 802.11b wlan
(08/17/2005) Wireless G PCI Adapter 54MPBS 2.4GHz works in Europe?(01/21/2005) Setup Belkin 802.11g Wireless card with Bigpond ADSL Kit?
(01/08/2005) A Belkin Pre-N router with Belkin Pre-N PCMCIA card : Ques..(01/06/2005) Old problems never die: WinXP WLAN disconnections
(01/06/2005) USB any good?(01/04/2005) Wireless card and shutdown problem
(01/03/2005) PCI Card Reader?(01/03/2005) WiFi v WLAN
(01/06/2005) best 802.11a Card ?(01/03/2005) Hawking Hi-Gain USB Wireless-G Adapter Model: HWU54D
(01/01/2005) wireless PCI card won't connect(12/31/2004) Best 5 GHz Client Card ?
(12/31/2004) Any recommendations for a USB adapter?(03/21/2009) Data Frame Errors with Netgear MA401 PCMCIA card - solution
(12/28/2004) What Best USB 54G Adapter for a Desktop?(12/31/2004) Good utility for XP and Realtek card?
(12/27/2004) Good utility for XP and Realtek card?(12/28/2004) Looking for a stronger wireless network USB adapter...
(12/25/2004) Cantenna for PC Card or USB?(12/28/2004) Repost: D-LInk wireless PCI needs rescan every log on
(12/25/2004) LinkSys WPC54GS PC Card(12/22/2004) D-Link wireless PCI needs rescan every boot
(12/20/2004) Best Long Range Wireless PC Card or USB?(12/19/2004) What are typical ping times for a WLAN?
(12/21/2004) What are typical ping times for a WLAN?(12/19/2004) router + card combo
(12/17/2004) Cannot remove WLAN and reinstall it under XP SP2(12/12/2004) usb wireless stick for linux
(12/14/2004) Building NAT via Wireless CArd!(12/09/2004) Problems streaming music over WLAN (802.11b)
(12/02/2004) Whats a really good 802.11g USB adapter?(12/02/2004) FS: UK Lurker selling 3com PCI wifi cards cheap on ebay
(12/01/2004) Any way to extend range of internal wireless PCI card in PC?(12/01/2004) SD WiFi card
(11/28/2004) wl110 pc card(11/26/2004) Belkin Wireless G USB Adapter doesn't go faster than 11Mbps
(11/28/2004) Using Ethernet scans to locate WLAN APs ?(11/19/2004) Linksys router and wirless card not talking - BEFW11S4 and..
(11/16/2004) mini pci card inside WG511T ?(11/15/2004) Understanding topology of wireless POS terminal card autho..
(11/15/2004) Security for WLAN(12/21/2004) Belkin 54g PCI and windows xp sp2
(11/14/2004) support for PCF in 802.11 WLAN cards(11/19/2004) any one have experience with the ZCOM XI-325 wireless card?
(11/11/2004) I opened my USB 802.11b adapter - help me locate the anten..(11/07/2004) Wireless USB port?
(11/06/2004) How to access FTP between computers on WLAN?(11/04/2004) 802.11B PC Card with retractable or removable antenna
(11/02/2004) Installing HP Printer driver on WLAN?(11/05/2004) USB extension
(11/26/2004) WLan USB adapter cannot find router(11/01/2004) pc card with pc
(11/05/2004) Rural wifi extension (again)(10/28/2004) using Netgear PS401 wireless card in a notebook PC
(10/24/2004) Tin Cantenna fans - G USB wireless dongle now available $20(10/19/2004) SMC 2635W card Keeps Dropping Connection
(10/16/2004) Change MAC address on Cisco 350 series PCMCIA card(10/16/2004) LG Phenom WIFI card
(10/31/2004) Belkin desktop wireless card problem(10/14/2004) rural wifi extension
(10/12/2004) Realtek 8180 PCI cards losing wireless connection(10/11/2004) Dlink DI-824VUP+ and Nokia D211 Data card
(10/07/2004) AP can be detected - can wireless card user be detected al..(10/06/2004) Problem for using WPA with my 3com PC card.
(10/02/2004) Does ZyXel G-200 on USB 1.2 work?
Sponsored links
