| (11/27/2009) How connect laptop to laptop via lan in vista | (11/22/2009) How do I put my Vista computer in DHCP mode? |
| (11/16/2009) Vista trouble | (11/16/2009) Netgear wnr3500 router not compatible with windows vista? |
| (11/16/2009) Internet only works for certain websites | (11/08/2009) Vista wifi bridged to xp ethernet |
| (11/03/2009) Weird Wireless Problem - Only google works | (10/21/2009) Connect more than one network drive from samba server in vista pc |
| (10/20/2009) Any suggestions for wireless adapter for my Vista 64 machine? | (10/19/2009) Vista 64 extremely slow internet |
| (10/02/2009) Nokia7610 bluetoothdriver vista windows | (10/01/2009) Vista and seven |
| (10/06/2009) Only 11mbps off wireless router help!!?? | (09/28/2009) Need a router for vista 64 |
| (09/28/2009) Need a router for vista 64 , x box 360 psp wii and wireless | (09/28/2009) Vista Wifi sleep problem - I have solution but can't implement it!!! |
| (09/26/2009) Wireless Broadcom Slow on Vista / Windows 7 | (09/22/2009) IPv6 PROBLEM |
| (09/17/2009) Lynksys WMP54G // wpa2-psk // vista 64 bits | (09/06/2009) Slow reponse on network but only one PC |
| (08/09/2009) Need a wireless card - only have PCIe 1x slots | (08/06/2009) Vista and XP networking |
| (08/05/2009) Using MN-740 with WPA and Vista | (08/03/2009) Wireless connection dies on notebook only after a fless than 30 mins after vista |
| (07/20/2009) Ethernet driver software download for vista | (07/19/2009) Windows 7 / Vista x64 Wireless NIC - PCI |
| (07/18/2009) Vista Ultimate and Linksys Routers and USB Card | (07/13/2009) Vista wireless usb problem |
| (07/14/2009) P5k-e Vista Wifi Acess Point = pulling out my hair! | (07/11/2009) Xp and Vista aren't compatible? |
| (07/08/2009) Quality wireless adapter for Vista 64bit | (06/16/2009) WDA-2320 and Vista 64 problems |
| (06/17/2009) Image is blur in browser window while using only Mobile Broadband | (10/13/2009) Wireless LAN adapter problem with Vista 64-bit OS |
| (06/04/2009) Bluetooth PCI card for desktop system (bluetooth only card) ?? | (06/02/2009) Way to get around ISP only allowing 1 IP address? |
| (06/15/2009) Connecting wireless with vista 64 | (05/10/2009) Pc to pc local area network via bluetooth |
| (05/05/2009) Share internet connection of 3G usb Modem thru wi fi on vista | (05/01/2009) Vista and xp network |
| (04/24/2009) Vista 64 troubles. | (07/05/2009) Vista Shuts Down My Internet Access--Help! |
| (05/04/2009) Vista wireless trouble | (04/14/2009) Can You Recommend a Good Vista 64 Bit Network Adapter Please? |
| (03/31/2009) Vista asking for username and pass when I try to connect to Net | (03/30/2009) Vista Laptops Not Connecting To Printer |
| (03/29/2009) Need rec for wireless adapter for Windows 7/Vista OS | (03/24/2009) Vista setup problem |
| (03/15/2009) WGR614v5 and vista setup | (03/10/2009) Network Adapter that works with Vista 64? |
| (03/06/2009) Vista 32 connectivity issues | (02/27/2009) Networking Oddity with Vista |
| (02/25/2009) Which wireless card to get with WNR 2000 and Vista 64? | (02/22/2009) Vista & Netgear WGT624 |
| (02/16/2009) Vista 64 bit wireless card | (10/22/2009) Vista 64 and WPN311 |
| (02/02/2009) Shows local only but it's not.... | (02/01/2009) Network transfer speed slow only on one computer |
| (02/10/2009) Vista wont reset DSN | (01/23/2009) New Wireless Card not being recognized in Vista |
| (01/17/2009) Wireless Network Issue w/Printer on Vista Laptop | (01/15/2009) Trouble...shot...me Vista (WZN) lag problems... |
| (01/06/2009) WNC-0600 and Vista 64 bit?? | (12/24/2008) Code 10+28 device cannot start wireless adapter vista |
| (12/13/2008) Vista and linksys, weird connections | (01/06/2009) Slow vista wireless speeds |
| (07/09/2009) Vista wireless slow, same adapter on XP is fast! | (12/21/2008) Vista 64 + WMP54G v4.1 = FAIL! |
| (09/29/2008) Vista 64 Wireless NIC | (05/21/2009) Best Wireless Adapter for Vista x64 Ultimate? |
| (08/25/2008) Windows Vista 64bit compatible PCI network cards | (08/25/2008) Wifi Vista to Ethernet XP? |
| (08/07/2008) Wireless router vista 64 Xp 64 | (07/30/2008) Wireless Connection Issues with WRT54G + Windows Vista 64 Bit |
| (12/14/2008) Rosewill PCI Wireless adapter RNX-G300(E) Driver Issue Fix for Vista | (07/06/2008) how do you change workgroup on vista |
| (06/30/2008) Anyone know which MIMO enabled wireless cards work with Vista x64 | (06/24/2008) Wireless Network after Vista downgrade |
| (06/11/2008) Help. Vista slow download speeds | (06/20/2008) Speedtouch 120g vista problem |
| (05/22/2008) vista x64 compatable wireless adapter | (05/10/2008) Buying a wireless express card for Windows Vista laptop |
| (05/20/2009) D-link USB wireless DWA-110 Vista 64-bit driver | (03/29/2008) [SOLVED]Problems connecting to internet with vista (wireless) |
| (03/08/2008) Network Printer Problem with Vista | (02/28/2008) Windows Zero Config on Vista |
| (01/31/2008) Wireless Print Servers for Vista 64? | (02/10/2009) Wireless issue with Vista and Linksys |
| (02/06/2008) Folder Share between Vista PC's | (12/15/2007) Local Only - Vista Usb Adapter Problem !!!! |
| (12/03/2007) lag spikes in games on vista | (11/26/2007) Wireless adapter for vista? |
| (09/29/2007) Wireless Card for Vista 64 bit - WEP | (09/21/2007) Vista and xp sp1 |
| (09/13/2007) Net connection problem in Vista through wireless network | (08/11/2007) When Using Wireless Routers, Can You Run In Wired Only Mode ? |
| (08/10/2007) ASUS 138g Vista problems -It's on the compatability list | (08/07/2009) Vista & wifi - Can see wireless networks but can't connect to them! |
| (09/17/2007) Problems connecting to unsecured wifi network in Vista | (06/03/2009) Wireless Connection not working with vista |
| (11/20/2009) Vista Wireless Network Lag/Spikes | (06/19/2007) Windows Media Center Extender for Vista? |
| (06/18/2007) a wireless vista solution!?!? | (05/08/2007) Wireless Problems On Vista! |
| (04/19/2007) Wireless network authentication with Vista | (04/06/2007) WPC54G VER2.0 VISTA 64 DRIVERS ? |
| (04/01/2007) Vista Ultimate 64 drivers needed | (03/09/2007) Belkin adapter connects only to router, any advice? |
| (03/06/2007) Home Network w/ Vista and XP Problems | (02/09/2007) laptop will only connect wirelessly when wired pc is logged |
| (02/01/2007) only 11Mb/s with wireless "g" ??? | (01/10/2007) How To Integrate A Wireless Laptop (Internet Access Only) |
| (11/25/2006) WPC300n Ver.2 and Windows Vista Compatibility | (07/19/2006) MY DSL-G604T DLINK IS DRIVING ME MAD!! |
| (03/02/2006) Wireless laptop can only connect to 1 of 2 access points | (08/26/2005) Pure 802.11b NIC = WEP - only ? |
| (07/08/2004) Linux: Default gateway fails, must use local IP for defaul.. | (12/13/2006) Can I only allow 1 active nic at one time? |
| (09/28/2005) Turning NetGear from router to access point only? | (08/23/2005) Wireless Laptop and Router Only |
| (08/16/2005) Wireless router for internet access only? | (07/25/2005) Laptop Only Uses WiFi, Refuses to Use Wired LAN When Conne.. |
| (07/05/2005) How to set up PC to PC connection using only wireless adap.. | (06/21/2005) Windows 98 machine won't access Internet or local shared d.. |
| (06/21/2005) Diconneting wireless networks when connected to local domain | (06/20/2005) Desktop connection drops only when card in laptop is active |
| (06/03/2005) can see each share folder/computer but only one can access? | (05/12/2005) Mapped Network drives to local folders work only when online |
| (04/28/2005) Local Area Connection Status | (04/22/2005) File Sharing over wireless only goes 2 folders down |
| (03/26/2005) Local Area Connection | (03/19/2005) Wireless Network card driver only loads under Admin account |
| (03/10/2005) "Local area connection. A network cable is unplugged" | (03/03/2005) Printer sharing only with IPX? |
| (01/11/2005) Mapping a local folder | (01/09/2005) Local Area internet connection |
| (12/30/2004) Can only see one way on network. | (12/22/2004) local area connection unplugged |
| (11/24/2004) local network file shareing on WLAN | (01/09/2005) Problem setting up Local Area Net work with Linksys wirele.. |
| (11/23/2004) can use wlan only as admin | (11/09/2004) Router for 64 only allows 4 connections |
| (10/29/2004) Internet access machine only | (10/30/2004) Unnecessary Network trafic generated between only two comp.. |
| (01/08/2005) Can only access wireless network as Administrator | (10/28/2004) Unable to get online on 'User' account only |
| (10/12/2004) Brand new - browser only wants to dial | (07/31/2004) connect to wifi not only getting autoconfig ip |
| (07/17/2004) WEP only laptop on a WPA network? | (06/16/2004) recommendations for wifi unit as basestation only |
| (05/31/2004) setting up a wireless network with only 1 laptop | (05/25/2004) DHCP problem wireless only |
| (05/24/2004) Laptop can only access 1 of 3 desktop drives | (05/20/2004) Wireles connection works one way only |
| (04/30/2004) can only get windows ip | (04/12/2004) One Way Connection Only |
| (01/05/2005) D-link DI-524 drops hardwired connection only | (01/08/2005) Wireless Routers used as Access Points only |
| (12/28/2004) Dlink DWL-2000AP+ only shows "Firmware Upgrade" screen | (12/01/2004) Router only works with some IP numbers... |
| (11/16/2004) Laptop to Printer Only | (11/05/2004) Signal strength Excellent... but only 1.0Mbps!! |
| (10/31/2004) Only Administrator users have access to network | (10/28/2004) Newbie question: wireless with only one PC |
| (10/27/2004) NETGEAR WG311T Only Connects to Netgear Networks | (10/02/2004) Suggestions for 5 mile squirt, local AP's and wifi custome.. |
| (09/21/2004) 3 sector antennas for sale! only 2hs left! | (09/20/2004) Internetaccess and sharing the docs only with WLAN? |
| (09/10/2004) DWL 650+ works only when twisted! | (08/30/2004) How to change local IP of wireless router |
| (08/30/2004) WRT54GS Local IP not changing | (07/31/2004) Help running 2 Wi-Fi networks keeping one off local network |
| (07/27/2004) Problem solved! [Was: Don't get local IP after establishin.. | (07/23/2004) Don't get local IP after establishing a connection |
| (07/03/2004) two cards only? | (07/10/2004) I only want to go 500 feet (outdoors), but can't quite get.. |
| (07/12/2004) Running programs only when online | (06/19/2004) Sporadic connections to external AP driving me nuts |
| (06/10/2004) Using WRT54G as Wireless Acess Point Only? | (06/01/2004) Can't send only receive! |
| (05/29/2004) logging in to domain - connection only seems to happen som.. | (05/20/2004) antenna required for indoor use only? |
| (05/06/2004) wireless connection was working, now only to one PC | (04/27/2004) OfficeConnect 11g how to access other systems in local net.. |
| (04/22/2004) wrt51ab dhcp/IP broken on Wireless interface only | (04/14/2004) Netgear WGR641 and G only |
| (04/10/2004) Local Area Network Unplugged | (04/08/2004) Cisco 802.1X Local Authentication Service |
| (02/25/2005) Wireless Network only running @ 11Mbps :( | |
