| (11/28/2009) Can router be used as adapter? | (11/28/2009) Computer doesn't recognize anymore hardware wireless adapter DWL-520 |
| (11/27/2009) Connecting Laptop to Internet using Instinct G3 phone. | (11/27/2009) Removing the antenna on belkin router |
| (11/26/2009) About wifi using in mobile phone | (11/22/2009) Can i use a usb adapter without the router |
| (11/24/2009) Usb wireless RiLan driver??? | (11/20/2009) HP G50-126NR Wireless Mini-PCI 802.11b/g/n adapter??? |
| (11/21/2009) If I have a N router do I need a N adapter to pick up wirless | (11/20/2009) Usb wireless router |
| (11/19/2009) Linksys wireless usb adapter G | (11/19/2009) Best wireless-n adapter for windows 7 64 bit OS |
| (11/19/2009) Router, And Using Printer With Two PC's ? | (11/17/2009) What is the best wireless ethernet adapter out there dollar for dollar? |
| (11/17/2009) Not able to connect to mobile using wifi | (12/03/2009) WARNING - Realtek RTL 8185 54M Wireless LAN Network Adapter |
| (11/12/2009) Turning a pc wireless using my laptop | (11/12/2009) Windows XP, Netgear modem router, Belkin G mimo usb adapter |
| (11/12/2009) Will yagi antenna work on a usb router | (11/09/2009) Dlink G520 wireless adapter does NOT work with Windows 7 |
| (11/08/2009) USB Printer and Edimax Print Server | (11/08/2009) Onboard wireless adapter doens't show up in Dev Mgr |
| (11/08/2009) Wifi adapter loads CPU | (11/06/2009) Wireless adapter driver conflict |
| (11/02/2009) Best wireless adapter for gaming | (11/01/2009) Config wrt54G_V2 with MS xbox wireless adapter |
| (10/31/2009) Gaming adapter to extend wireless network (internet) to 2 or more PCs? | (10/30/2009) Wirless USB Key and LAN Bridge |
| (10/30/2009) Usb wireless router | (10/30/2009) USB Adapter for a Desktop running Windows 7 |
| (10/24/2009) Connect wireless antenna to lynksys wcg200 | (10/25/2009) Windows 7 adapter |
| (11/17/2009) Looking for windows 7 64 bit wireless adapter | (10/20/2009) Any suggestions for wireless adapter for my Vista 64 machine? |
| (10/20/2009) Know who is using bandwidth | (10/19/2009) USB Wireless Adapter Help |
| (10/14/2009) How to implement intranent using wireless router | (10/14/2009) Extending a wireless network using 2 LinkSys WRT54GL routers |
| (10/11/2009) 3G Usb Modem Sharing Compatiability | (10/10/2009) Installing wireless adapter on Backtrack 3 |
| (10/09/2009) Antenna advice | (10/06/2009) 3G Wireless Router/3G USB Modem Interoperability |
| (10/03/2009) Can a wireless router be used as a wifi antenna | (10/01/2009) Need Windows 7 (64-bit) 802.11n Wireless Adapter |
| (09/26/2009) My netgear ma101 adapter will not connect to Belkin N+ router | (09/26/2009) How to load usb ethernet adapter into windows 98 |
| (09/25/2009) Best wireless usb adapter | (09/23/2009) Wireless Adapter problem |
| (09/20/2009) Fax using WIndows XP and ATT UVERSE | (09/20/2009) USB Booster |
| (11/13/2009) Windows 7 64bit compatible wireless adapter>> | (09/16/2009) Using a router as a wireless adapter? |
| (09/14/2009) Inhouse wireless antenna for cellular phone | (09/12/2009) How to enable wireless adapter mac(Iatkos) |
| (09/10/2009) Wireless G USB Adapter Help | (09/01/2009) Belking wirerless g network adapter problem |
| (08/31/2009) I need help with a Wireless adapter driver | (08/31/2009) How do I know if my integrated intel (G) adapter has MIMO? |
| (08/31/2009) Wireless Adapter Check | (08/31/2009) Best wireless G adapter for range |
| (10/25/2009) Laptop b/g wi-fi adapter work with n router | (08/30/2009) Will upgrade from G to N adapter increase G reception range? |
| (10/21/2009) USB or ExpressCard wireless adapter? | (08/30/2009) P5w dh wireless adapter |
| (08/29/2009) View camera wireless using internet | (08/27/2009) IOGEAR's Wireless USB Audio / Video Kit |
| (08/26/2009) Internal Ethernet Adapter or Standalone Router | (11/01/2009) A good wireless pci adapter that works with 64 bit OS? |
| (08/26/2009) GigaFast Wireless USB causes blue screen!! | (08/25/2009) New build: Network Adapter choice |
| (08/24/2009) Using two Linksys Wireless routers for broader WiFi Coverage | (08/27/2009) Security using WEP |
| (09/30/2009) Wireless network adapter not recognized in w7 HELP!!! | (08/16/2009) Wireless USB to Ethernet |
| (08/15/2009) Nintendo dsi internet setup with wireless usb adapter | (08/24/2009) Nergear Rangemax Wireless USB |
| (08/11/2009) Using wireless gaming adapter in my wireless network | (08/05/2009) Using MN-740 with WPA and Vista |
| (08/02/2009) Wireless USB Adapters here | (07/29/2009) Belkin Bluetooth USB adapter. Error 87: parameter is incorrect |
| (07/26/2009) Buying a new router and adapter TODAY | (07/23/2009) Need advice on upgrading wireless router with adapter |
| (07/19/2009) My NetGear WG111T lik disables MY USb Ports except the ones | (07/18/2009) Vista Ultimate and Linksys Routers and USB Card |
| (07/16/2009) Is there a performance difference between USB & PCI based wifi modules | (07/16/2009) Wireless Adapter Question |
| (07/09/2009) Mn520 wireless adapter driver | (07/08/2009) Quality wireless adapter for Vista 64bit |
| (07/04/2009) Wrt54g dual outdoor antenna? | (06/29/2009) Problems with wireless adapter |
| (06/24/2009) WinProxy setup in windows Server 2003 by using DSL-2640T wireles modem | (06/23/2009) Wireless adapter with the dlink dir-655 |
| (06/22/2009) USB/PANTECH UM-175 | (06/17/2009) Image is blur in browser window while using only Mobile Broadband |
| (11/13/2009) Wireless N adapter to wireless G router? | (06/09/2009) PCI vs. USB / Recommended Desktop Solution |
| (06/16/2009) Decent Wireless Adapter for Gaming | (10/13/2009) Wireless LAN adapter problem with Vista 64-bit OS |
| (06/02/2009) UMTS antenna cable | (05/28/2009) Fun problem to solve! Wireless USB Problem! |
| (05/28/2009) MN-520 Wireless Notebook Adapter | (05/21/2009) Using wrt320n and 3 wap4410n |
| (05/25/2009) Need a Wireless PC Adapter | (05/29/2009) Best solution for low signal (USB or PCI) |
| (05/11/2009) Wireless adapter for gaming pc | (05/13/2009) Best Wireless N Adapter |
| (05/09/2009) Can this computor pick up wireless internet from my modem? or should i go buy a | (05/10/2009) PCI Wireless adapter |
| (05/08/2009) Using ADSL router for cable internet | (05/06/2009) Better range - USB or PCI? |
| (04/24/2009) Net adapter driver probs | (04/22/2009) Stop others from using my wireless internet |
| (11/03/2009) USB 500mW WiFi adaptor | (04/14/2009) Can You Recommend a Good Vista 64 Bit Network Adapter Please? |
| (04/11/2009) WPA2 adapter with WPA router | (04/10/2009) Overclocking linksys WUSB100 adapter |
| (04/10/2009) Wireless Network Adapter Inop in Non-Admin Acct | (04/02/2009) Wireless adapter for the xbox360 |
| (03/29/2009) Need rec for wireless adapter for Windows 7/Vista OS | (03/26/2009) Does a Wireless N Adapter's extended range apply to G networks? |
| (03/23/2009) Laptop Wireless adapter | (03/18/2009) Linksys WRT310N & WAP4410N any one using them presently |
| (03/12/2009) Connecting Mobile to Laptop to Share WiFi using Bluetooth | (03/11/2009) Using 2 Wireless Routers |
| (03/10/2009) Network Adapter that works with Vista 64? | (03/08/2009) Why does Wireless Connections drop when using a secured network? |
| (03/04/2009) Wlan USB stick or a PCI extension card? | (11/22/2009) How to connect to internet using wifi from mobile phone? |
| (02/28/2009) Belkin Wireless Network Adapter Setup | (02/19/2009) Using a router to send cricket broadband to my other pc's |
| (02/19/2009) Remote access via 1394 connection/net adapter | (02/20/2009) WUSB54GC wireless USB adapter drops connection |
| (02/15/2009) ZyXEL P600 Antenna? | (02/14/2009) My ipod is using all my routers bandwidth. How can limit it? |
| (02/12/2009) Best Wireless Adapter for My Needs | (02/12/2009) Wireless USB-N adapter for gaming |
| (02/10/2009) Add an antenna to a D-Link DWA-643 ExpressCard? | (02/10/2009) Access Point or Powerline adapter? |
| (02/08/2009) DWL-650+ Adapter with DI-628 Router | (02/05/2009) Belkin N1 Vision and N1 adapter 2.5MB/s Blunder |
| (02/27/2009) Im using a wireless belkin connector and now its not working... | (02/09/2009) What wireless adapter (PCI-E or USB) would you recommend? |
| (01/25/2009) Ethernet Wireless abd Wireless USB | (01/30/2009) Windows 7 Doesn't Detect Wireless Adapter |
| (01/18/2009) WPA-PSK using TKIP encryptor connection problem | (02/10/2009) Wireless N adapter and G router |
| (01/02/2009) What is the best Wireless G adapter (PCI or USB... whichever is better | (12/30/2008) Best Wireless-G Adapter for gaming HELP!!! |
| (12/24/2008) Code 10+28 device cannot start wireless adapter vista | (12/05/2008) Using N instead of G for Xbox 360...some questions... |
| (12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients | (11/22/2008) WDA 2320 PCI adapter not connecting |
| (11/21/2008) Belkin Wireless G+ MIMO Wireless Adapter Not Finding Wireless Network | (07/09/2009) Vista wireless slow, same adapter on XP is fast! |
| (10/29/2008) wmp54gs wireless adapter - excellent signal, speed fluctuates | (10/26/2008) tried installing over and over..usb adapter won't connect! help |
| (10/08/2008) Desktop Gaming Wireless Adapter | (10/04/2008) Antenna upgrade, how many on n router? |
| (05/21/2009) Best Wireless Adapter for Vista x64 Ultimate? | (09/23/2008) Using Wifi-Ap as Access Point? |
| (09/20/2008) USB Adapter or PCI CARD For Wireless | (09/07/2008) Better Antenna or New Adapter? |
| (09/03/2008) Using DSL Router (w/ wireless) as wireless router alone | (08/27/2008) strange wireless adapter problem |
| (08/25/2008) Using old 802.11a slow down 802.11g | (10/12/2008) Best USB Wireless adapter? |
| (08/08/2008) Wi-Fi Antenna | (08/10/2008) Using two Wifi with one Cable modem |
| (10/10/2008) Linksys wireless usb adapter not connecting to my Linksys wireless Rou | (08/04/2008) Desktop Wireless Adapter with Integrated Bluetooth? |
| (07/24/2008) Router and adapter reccomendations | (07/23/2008) Wireless Adapter Unstable? |
| (07/22/2008) Wireless-G network adapter work with Wireless N router | (07/26/2009) Whats the best wireless adapter for a desktop? |
| (08/15/2008) You can go to jail/be fined for using hot spots... | (07/13/2008) Wireless Adapter Overheating? |
| (12/14/2008) Rosewill PCI Wireless adapter RNX-G300(E) Driver Issue Fix for Vista | (07/08/2008) USB wireless dongle external antenna |
| (07/05/2008) Replacement antenna for Actiontec M1424WR ? | (06/21/2008) Overheating issue with Belkin wireless USB adapter |
| (06/20/2008) Wireless Router or Hub that has a USB port for a hard drive. | (05/29/2008) USb or PCI card? |
| (05/23/2008) wusb54g wireless adapter bsod | (05/22/2008) vista x64 compatable wireless adapter |
| (05/14/2008) Can't connect to internet via wireless adapter | (05/07/2008) Looking for a new Wireless Adapter or QuickFix |
| (10/10/2009) D-Link DWL-G122 wireless adapter | (05/02/2008) USB Wireless Adapter concentrate signal |
| (05/27/2008) wireless PCI adapter not recognized | (05/09/2008) Looking for USB 802.11N network adapter |
| (04/16/2008) Wireless PCI or USB adapter for vist x64 | (05/20/2009) D-link USB wireless DWA-110 Vista 64-bit driver |
| (03/26/2008) Belkin USB Wireless Adapter | (03/08/2008) replace network card in belkin pre-n desktop adapter |
| (03/14/2008) help cant find a wireless network adapter | (08/26/2009) Internal wireless adapter disappeared after XP reinstall |
| (01/26/2008) Any network sniffer to use with Netgear WN121T USB adapter? | (12/14/2007) Printer Shutting Down On Wireless Network Using Network Magic Software |
| (12/15/2007) Local Only - Vista Usb Adapter Problem !!!! | (12/06/2007) buffalo wireless g high gain wli u2 sg54hg usb 2 adapter |
| (01/11/2008) Wireless Network - USB Modem | (11/26/2007) Wireless adapter for vista? |
| (11/01/2007) Can you mix and match different Antennas on a Multi Antenna Router | (08/26/2007) Belkin N Wireless USB adapter poor strength |
| (08/11/2007) When Using Wireless Routers, Can You Run In Wired Only Mode ? | (08/03/2007) I just Can't connect to live messenger using my D-Link DI-624M |
| (07/23/2007) Can someone recommend good wireless adapter? | (07/19/2007) Netgear wireless adapter causing 100% cpu spikes..and other things. |
| (07/12/2007) Best Apartment Adapter!? | (06/22/2007) Using two wireless routers on the same network |
| (06/19/2007) Wireless PCI card /USB LAN adaptor | (06/09/2007) 2.4GHz 5dBi Wireless Magnetic External Antenna |
| (06/14/2007) If you wanna make a DIY antenna | (06/02/2007) ZyXEL NWD170N wireless adapter + ZyXEL NBG415N wireless rout |
| (05/28/2007) Where can you buy extended length Dipole Antenna Cable? | (01/12/2009) 2 routers, one using WEP, other Using WPA - How to setup? |
| (04/19/2007) How to: Keep 1 cpu hardwired and Have 2nd using wireless? | (04/13/2007) 5 gallon directional antenna |
| (03/29/2007) Wireless USB question | (03/28/2007) Belken Wireless G USB Network Adapter |
| (07/16/2009) XBox 360 Question(Can you use any USB adapter) | (06/21/2007) What to replace my 2db antenna with on my DG834GT Router? |
| (03/09/2007) Belkin adapter connects only to router, any advice? | (03/02/2007) How to attach Linksys high gain antenna to laptop? |
| (03/01/2007) Confused antenna help. | (02/06/2007) Wi-Fi Nic with external antenna adapter recomendations |
| (01/18/2007) Wireless USB Issues (Fairly long)...Please Help! | (01/08/2007) Sony VAIO PCG-Z1XSP wireless problem using BT HomeHub. |
| (01/08/2007) USB wireless adapter issues at startup | (12/17/2006) Antenna Range |
| (12/17/2006) Suggestions for setup? Antenna Question | (01/03/2007) External wireless antenna for a laptop? |
| (11/26/2006) Mimo or larger Antenna? | (11/16/2006) US Robotics 5421 usb wireless adapter |
| (03/16/2009) Linksys WGA54G Game Adapter / Bridge - Device is garbage?? | (11/06/2006) Making my own bad ass wireless antenna help? |
| (11/03/2006) Help me choose router and network adapter, please! | (11/27/2006) "Wi-Fire" Adapter; any input fm ACTUAL users? |
| (11/09/2009) Range extension using WDS setup question | (06/19/2009) USB Cantenna |
| (10/25/2006) l33t help needed. Using bittorent on my neighbours wifi.... | (10/02/2006) 64-bit USB Bluetooth to use with my headset |
| (09/18/2006) usb wifi adapter drops to 1mbs when connected in bridge!? | (09/15/2006) usb wifi adapter drops to 1mbs when connected in bridge!? |
| (09/19/2006) Mounting a wireless antenna outside? | (08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help |
| (08/14/2006) Trying to fix a wireless Antenna | (09/12/2006) Difference between antenna |
| (08/22/2006) Help me choose router/network adapter, please! | (07/24/2006) ASUS / USB / Netgear / Connected, but no IP info |
| (07/08/2006) Long range wireless adapter | (06/23/2006) Wireless WAN using Seanao ECB-3220 |
| (09/10/2006) USB 1.1 adapter enough? | (03/25/2007) Wirless network of Xbox using D-Link bridge |
| (06/12/2006) Connecting two wired switches with wifi + using access point | (03/17/2009) Belkin Wireless USB Antenna |
| (05/20/2006) Adapter with 64-bit drivers | (04/27/2006) Laptop Antenna |
| (04/24/2006) HELP ! Linksys WAP54G + 7Dbi Antenna = ? % Signal | (04/15/2006) dual antenna setup - is this possible? |
| (04/14/2006) Wireless Networking and Acces Point using IPCop | (03/20/2006) I need advise: USB or PCMCIA WLAN in linux? |
| (03/09/2006) Setting up a wireless USB dongle for my neighbour.. | (05/25/2006) Which router and Adapter should I buy???(for restaurant use) |
| (01/01/2009) USB wireless adapter drops connection | (02/24/2006) Slim Device v3 and a SMC WBRT14T-G using WPA or WPA 2 |
| (09/13/2005) Attaching antenna to Belkin 802.11g PCMCIA card | (04/27/2004) Linux using windows drivers. |
| (05/13/2004) Wireless PCI adapter for GNU/Linux | (05/05/2009) problem with linksys wmp11 PCi wireless networking adapter. |
| (09/28/2005) Belkin F5D7050 ver.2011 Wireless G USB Adapter Hardware Is.. | (03/31/2004) DI-714P+ Problems: File Sharing (not using Firewall) |
| (09/17/2005) Using a D-Link DI-824VUP as a Print Server | (09/26/2005) Netgear Wireless adapter with Apple iBook |
| (09/20/2005) Use Directional Antenna (or help in general) | (09/21/2005) Are MC and MMX antenna connectors (about) the same? |
| (09/28/2005) 108 Mbps Cardbus/USB Adapters that accept external antennae | (09/26/2005) usb adapter cantenna |
| (12/08/2005) internet using two access points | (11/08/2005) Share wi-fi net connection using wi-fi? |
| (07/22/2009) Using a Linksys router as an access point | (01/16/2006) Using Linksys WRT54G to connect to another wifi router |
| (01/14/2006) xbox wireless adapter recommendations | (09/17/2005) Linux newbie help - USB adapter |
| (11/29/2009) Using Netgear router as an access point | (10/15/2009) PCMCIA wireless network card with external antenna ? |
| (01/02/2006) Deminished BW using WAP v. Wired through a WRT54GC | (01/29/2006) How to Crack WEP - error using Auditor Security Collection |
| (12/23/2005) Wi-network with USB DSL modem | (09/20/2005) Question on broadcast data encryption using WPA |
| (02/05/2006) USB Wireless adapter makes my WinXP "deep sleep" | (06/03/2009) Problem: Linksys adapter not working with D-Link router |
| (01/20/2006) Wireless card for Laptop (USB or PCMCIA)?? | (01/08/2006) Antenna |
| (11/30/2005) hello - a question about using a router | (09/19/2005) Periodically losing TCP connection through wireless adapter |
| (09/15/2005) Bluetooth Adapter | (09/11/2005) using ftp over wireless network |
| (09/10/2005) SMC wireless adapter USB or PCMCIA? | (09/08/2005) antenna extension? |
| (09/07/2005) Sharing a USB modem through a wireless router | (09/07/2005) Basic setup - USB WiFi on 2 PCs for Internet Sharing... ho.. |
| (09/05/2005) Bluetooth Flash Adapter That Windows XP Auto-Recognizes? | (09/05/2005) Using XP with DSL where, when and how can the DNS entries .. |
| (09/02/2005) Using Win XP to connect Wirelessly to an iPAQ | (09/01/2005) USB config for Windows Connect Now. Did this go anywhere? |
| (09/12/2005) USB wireless not starting soon enough? | (08/29/2005) Quirky internet access with wireless adapter |
| (08/22/2005) Setting up a network using a desktop and laptop on a wirel.. | (08/23/2005) Not valid SSID name during setup using the wizard |
| (08/15/2005) Wireless networking using PC and Mac | (08/14/2005) Adding another Pc using a wireless USB adapter |
| (08/13/2005) Using Outlook Express in home network | (08/13/2005) D-Link DWL-G820 Wireless Gaming adapter |
| (08/24/2005) Driver/Wizard for Wireless Notebook Adapter MN-520 | (08/07/2005) USB device not showing in "network Connections" |
| (08/01/2005) Setting up network using domain name | (08/05/2005) Home Network Troubles using Windows XP Network Setup Wizard |
| (08/01/2005) WinMe adapter recommendations? | (07/27/2005) adapter is connected but internet not available |
| (07/25/2005) Upgrade to WinXP SP2 causes loss of USB adapter wireless c.. | (07/25/2005) 2 PC wireless network using router Please!! |
| (07/17/2005) Wireless Safecom SWLU-5400 USB 2.0 Adaptor | (07/18/2005) Linksys Usb wireless B Network adapter |
| (07/14/2005) Ad Hoc using router? | (07/11/2005) Logon Failure - using Taskkill.exe |
| (07/12/2005) trouble with WPC54gs adapter | (07/10/2005) Problem installing wireless USB Adapter |
| (07/05/2005) How to set up PC to PC connection using only wireless adap.. | (07/04/2005) Wireless adapter recognized as network controller ... |
| (06/27/2005) Not able to disable network adapter during repair | (06/30/2005) Wireless adapter purchase |
| (06/16/2005) PC Card or USB ? | (08/15/2005) Column: Set up a secure wireless network using Windows Con.. |
| (06/14/2005) Latest WIndows Update for Wireless-G PCI Adapter Broken? | (06/13/2005) who is using my wireless? |
| (06/11/2005) Using NDISUIO on XP 64-Bit Edition | (06/09/2005) Enable ICS to a wireless network (using windows auto IP co.. |
| (06/08/2005) Wireless networking using Linksys BEFW11S4 and WMP11 | (06/07/2005) Losing internet when using static IP |
| (06/04/2005) a problem concerning the computer using wireless card | (06/11/2005) using Dlink card GWL-G650+ utility software with windowsxp.. |
| (06/05/2005) Installing a pci adapter - please help | (05/28/2005) USB Wireless Adapters compatible with Win CE 2.0 |
| (05/22/2005) 802.11b on destop with USB adaptor gigafast | (05/21/2005) USB flash drive - wireless networking (infrastructure) |
| (05/20/2005) Wireless USB "cable" | (05/24/2005) XP crash when reinserting wireless USB |
| (05/11/2005) USB Network Cards and Logon Issues | (05/11/2005) D-Link wireless PCI adapter problems |
| (05/10/2005) Wireless LAN USB adapter | (05/01/2005) Sharing PCs using wireless router |
| (04/28/2005) Got the network set up now how to I print using wireless n.. | (04/26/2005) possible to disable/enable wireless network adapter via co.. |
| (04/25/2005) Wireless 54G USB Adapter question | (04/19/2005) Problems with wireless router and adapter |
| (04/19/2005) Unable to Browse Network w/Netgear wireless adapter | (04/20/2005) Using Windows to configure my wirelss network setting |
| (04/05/2005) 8021.x WPA settings using group policy on a 2000 server | (03/31/2005) How to use the USB Scanner / Printer wirelessly |
| (03/26/2005) slower wireless adapter connection on XP | (03/20/2005) Dual Antenna fitted to an AP - Possible?? |
| (03/18/2005) using laptop thinkpad wireless with linksys WCG200 | (03/17/2005) MN-700 Base Station - adding a signal booster or antenna |
| (03/19/2005) Proxim ORiNOCO PC GOLD CARD with antenna problem??!! | (03/10/2005) USB NIC Group Policy not applying completely |
| (03/08/2005) How do I login to domain with USB network adapter? | (03/07/2005) Wireless adapter picks up newly found network... |
| (03/12/2005) How to delete old router which was installed using Windows.. | (02/25/2005) Misconfigured the USB flash drive |
| (02/21/2005) Wireless Notebook Adapter - Linksys PCMCIA adapter Error E.. | (02/15/2005) New computer wireless PCI adapter setup mistake recovery |
| (01/31/2005) Anyone using Linksys WUSB54G with Check Point VPN-1 | (02/11/2005) BT Voyager USB wireless network adapters. |
| (01/29/2005) Access problems when using wireless | (01/25/2005) Getting WPA to work using Netgear WG511T adapter on Window.. |
| (01/23/2005) PC to TV and Stereo Receiver via Wireless Router and Adapter | (01/19/2005) File Transfer using 54Mbps Wireless Adaptor/Router |
| (02/09/2005) File Sharing on External USB Drive | (01/12/2005) Hawking hi-gain antenna |
| (01/10/2005) Which Access Point Device to Buy? USB Adapter? | (01/07/2005) playing games using a router |
| (01/13/2005) WPC54G wireless notebook adapter | (01/06/2005) USB Bluetooth adapter not working |
| (01/02/2005) USB stick question | (12/31/2004) Adding an Antenna Pigtail to a WiFi card |
| (12/30/2004) WindowsXP is using my Wireless card instead of my Wired Nic | (07/27/2005) Error Message using Bluetooth from PC to Nokia N-Gage |
| (12/30/2004) USB Bluetooth install in SP2 | (01/04/2005) slow Edimax WLAN USB Adapter |
| (12/31/2004) Using Internet on wireless network | (12/29/2004) mn-510 wireless adapter won't function after rebooting |
| (12/29/2004) Peer to Peer Connection using ICQ | (12/21/2004) how can I wirelessly network my computers using dialup |
| (12/19/2004) Win XP wireless network adapter gets released and then con.. | (12/20/2004) Wireless adapter does not search for networks |
| (12/13/2004) Wireless Adapter Seems Capped at 1300 MTU | (12/07/2004) How do I choose which adapter to use for Internet access? |
| (12/04/2004) BELKIN WIRELESS PCI NETWORK ADAPTER F5D6000 | (12/03/2004) belkin USB tendency to connect to neighbor's router?! |
| (12/02/2004) Using a spare laptop wireless LAN adapter | (11/29/2004) I can access a laptop from a desktop using a wireless cone.. |
| (11/16/2004) usb adapter | (11/14/2004) Netgear WGE101 Antenna |
| (11/11/2004) syncronizing pocketPc using bluetooth | (11/12/2004) Using a laptop as an internet gateway |
| (11/10/2004) Not able to Connect to Internet while using wireless card | (11/09/2004) Not able to Connect to Internet while using wireless card |
| (11/07/2004) No installation of USB wireless client | (11/12/2004) Windows XP SP2 and Linksys Wireless-G USB |
| (10/30/2004) Linksys Wireless B Adapter: Connectivity | (10/27/2004) Wired vs WIRELESS with USB Card |
| (10/25/2004) SMA Jack-Plug-Jack Tee | (10/16/2004) No internet connection after installing SP2 using Microsof.. |
| (10/08/2004) Wireless Card not recognised using Windows XP | (09/26/2004) how to rebind network adapter? |
| (09/26/2004) Using a PC Card on PC with PCI Adapter | (12/19/2004) Service pack 2 - wireless adapter unable to connect DHCP |
| (09/17/2004) Sharing my Internet Connection without using a router | (10/02/2004) logon using Wireless/WiFI |
| (09/15/2004) Accessing applications on each computer using wireless net.. | (09/17/2004) PCI interface or USB interface |
| (09/07/2004) cannot connect to default gateway with netgear usb adapter | (09/04/2004) xp and linksys pci adapter |
| (09/02/2004) Possible to connect 2 computers via USB? | (09/04/2004) Belkin USB Wireless Network Device/ XP SP1&2 - Not working |
| (08/31/2004) USB adaptor works but my comp keeps freezing | (08/23/2004) router and usb adapter question |
| (08/22/2004) 3COM USB Wireless Adaptor | (08/13/2004) WLAN USB Adapter w. Win2k - Error Code 10 |
| (08/09/2004) Problems re setup for Home Network using XP Wizard | (09/09/2004) Setting WPA using a Windows 2003 Group Policy |
| (08/10/2004) wireless network using a router | (08/10/2004) USB 802.11g wireless adapter |
| (08/04/2004) MN-500 Wireless Base Station and MN-510 Wireless Adapter | (07/27/2004) Connecting a non-btvoyager adapter! |
| (07/15/2004) mn710 wireless usb adapter - preamble | (06/18/2004) Lose ability to get on/off line (via dial up) using wirele.. |
| (06/18/2004) Wireless Adapter and WAP | (06/17/2004) using wireless purely for ethernet access |
| (06/14/2004) Problem with Microsoft USB wireless device | (02/09/2005) SHARING AN EXTERNAL USB 2.0 DRIVE |
| (03/19/2005) Roaming profiles and WPA using PEAP MS-CHAPv2 | (06/03/2004) Using Windows XP to configure wireless network settings |
| (06/03/2004) Infrared connection using WinXP | (06/02/2004) No connection with built-in WiFi antenna? |
| (05/15/2004) Wireless USB nic and domain logon errors | (05/10/2004) Windows 95 Network Adapter |
| (05/09/2004) logging back in using a wireless connection | (06/28/2004) Wireless Problems Using IAS |
| (06/02/2004) Wireless Network adapter disabled... | (05/31/2004) Using 2 wireless network cards in 1 laptop |
| (05/04/2004) installing 54g wireless network adapter | (05/03/2004) installation of 54g wireless network adapter |
| (06/07/2004) XP crash related to Netgear adapter? | (04/23/2004) problems installing wireless network adapter to dektop... |
| (08/08/2004) Driver for ZyDas wireless (ZD1201) IEEE 802.11b USB Adapter | (09/13/2005) My 3Com USB Adapter is very hot! Could it be overheating? |
| (09/12/2005) Sprint Internet antenna with 802.11b? | (09/09/2005) USB 1.1 and 802.11g. |
| (09/08/2005) Using a router with a usb print server for other uses | (09/06/2005) Proxim RangeLAN2 PCMCIA card external antenna? |
| (09/07/2005) PCMCIA with external antenna | (09/07/2005) Replacing USB DSL and Easing Into Wireless |
| (09/06/2005) Antenna for GSM or CDMA cell phones? | (09/03/2005) Loss of connection when using eDonkey2000 |
| (09/02/2005) Router used as a wireless adapter | (08/31/2005) Anyone try Powerline adapter for Ethernet from Corinex? AV.. |
| (08/30/2005) Choice of wireless adapter: Netgear or Linksys, USB or PCI.. | (08/25/2005) USB wifi adapters |
| (08/22/2005) Angle of antenna? Make any difference? | (08/23/2005) linksys antenna connector |
| (08/09/2009) Using a Netgear WG602 in Repeater Mode (Please Help!) | (08/24/2005) Trying to setup an offset antenna for wifi |
| (08/17/2005) internal wifi antenna | (08/15/2005) Using WRT54G WDS Repeater? |
| (08/17/2005) Wireless G PCI Adapter 54MPBS 2.4GHz works in Europe? | (01/12/2005) Weird ping behaviour using 3Com OfficeConnect Wireless-G a.. |
| (01/08/2005) Wireless Antenna | (01/08/2005) 2 Computers...1 Antenna? |
| (01/06/2005) USB any good? | (01/05/2005) cannot send emails on USR8054 using Sympatico high speed |
| (01/04/2005) problem with Linksys WAP11 AP and WPC54G adapter | (01/04/2005) Using a Linksys W54G (or W11S4) in existing office that ha.. |
| (01/08/2005) Protocol for using others' network??? | (01/03/2005) Hawking Hi-Gain USB Wireless-G Adapter Model: HWU54D |
| (01/07/2005) bandwidth degradation using wireless vs wired | (12/31/2004) Any recommendations for a USB adapter? |
| (01/03/2005) pcmcia with external antenna | (12/29/2004) Review of Mega-Wave WiFi 12dbi gain antenna wanted |
| (12/30/2004) Need to Confirm Power Adapter for SMC 7004AWBR | (12/28/2004) What Best USB 54G Adapter for a Desktop? |
| (12/27/2004) befws11s4 locking up when using AOL 9.0 | (12/28/2004) Looking for a stronger wireless network USB adapter... |
| (01/01/2005) Linksys Wireless Adapter Auto-Connect | (12/25/2004) Using a Linksys WRT54G & Netgear DG834 together... |
| (12/25/2004) Cantenna for PC Card or USB? | (12/25/2004) Using a Linksys WRT54G & Netgear DG834 together... |
| (12/20/2004) Using powerline to get wireless past a "thick" kitchen wall | |
