| (10/22/2009) Limit each IP usage | (10/22/2009) Computers not seeing each other over WAN with Tomato router |
| (10/20/2009) Internect Connection Disruption at Same time each night | (08/26/2009) Internal Ethernet Adapter or Standalone Router |
| (08/23/2009) Problem "seeing" other computers, but not with getting online? | (08/09/2009) Knocking other pc's off the wireless connection |
| (07/03/2009) Wireless N and G, interferance when physically next to each other? | (07/06/2009) SMC |
| (03/05/2009) Help! I need to throttle internal bandwidth! | (02/19/2009) Using a router to send cricket broadband to my other pc's |
| (01/04/2009) No internet on other computer...PLS HELP ME:( | (12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients |
| (08/19/2008) Cannot see other computers in the network. | (08/10/2008) Gaming with a Router connected to other Router |
| (07/29/2008) SMC wireless router as wired AP | (10/16/2009) Wireless connection interrupts each time LAN-connected system is turne |
| (04/17/2008) Laptop suddenly offline with other issue | (08/26/2009) Internal wireless adapter disappeared after XP reinstall |
| (07/19/2007) Netgear wireless adapter causing 100% cpu spikes..and other things. | (01/12/2009) 2 routers, one using WEP, other Using WPA - How to setup? |
| (12/13/2006) Two wireless PCs; can't connect them to each other... | (11/30/2006) Interfence from other wireless networks |
| (10/19/2006) SMC SMCWBR14-G Router with Motorola SB5100 Cable Modem | (07/25/2006) configuring Senao Long-range Bridge and SMC repeaters |
| (03/22/2006) Need Help..cant connet to internet from other access point | (02/24/2006) Slim Device v3 and a SMC WBRT14T-G using WPA or WPA 2 |
| (09/23/2005) SMC 2802 Wireless PCI Card | (02/09/2006) how to change WEP password on SMC PCI card? |
| (01/23/2006) Can I use a wireless router as an access point in other room | (01/07/2006) Installing internal wireless internet card... |
| (09/15/2005) Prevent eccess to other networks | (09/11/2005) Users other than administrator cannot log on |
| (09/10/2005) SMC wireless adapter USB or PCMCIA? | (09/05/2005) one computer can't see other workgroup computers |
| (08/29/2005) Can't see other PC on network | (08/11/2005) both computers can connect to the net, but not to each other |
| (07/29/2005) Wireless and XP machines | (07/19/2005) Can't see other computers on network |
| (07/18/2005) Can't see the other computer! please help | (07/17/2005) Can connect to internet, but can't see other PCs on my net.. |
| (07/15/2005) Cannot ping machines behind a wireless AP | (07/15/2005) Cannot ping machines behind a wireless AP... |
| (06/21/2005) Wireless Connection Drops when other wireless network is a.. | (06/07/2005) Cannot see other computers on Network |
| (06/07/2005) Unable to see machines on the ethernet; Unable to find pri.. | (06/03/2005) can see each share folder/computer but only one can access? |
| (05/22/2005) Can't see some machines | (05/18/2005) Networking Issues - Cannot See Machines Within Workgroup |
| (04/29/2005) Can't see other computers in workgroup | (04/20/2005) Lost WIFi connection on each reboot |
| (04/19/2005) Networking 4 XP SP2 Machines Wirelessly | (04/14/2005) 802.1x for non-domain machines |
| (04/14/2005) Wiress 2200 BG Internal Card problems | (04/08/2005) Removal from host of a Wireless network place (other compu.. |
| (03/26/2005) Bridge or other solution | (03/26/2005) SMC Wireless |
| (03/09/2005) Ad hoc wireless network - my computers can't see each other | (03/07/2005) Problem configuring wireless card (setting SSID and other .. |
| (03/05/2005) laptop and desktop cannot ping each other | (03/05/2005) seeing computer from one comp but not that other |
| (03/02/2005) Req: Help - connecting two machines (one wireless) via Dra.. | (02/08/2005) W98SE Laptop Suddenly Can't See Two XP Machines |
| (01/26/2005) Enabling AdHoc laptop to route data out a desktops other N.. | (01/20/2005) Internal wireless network card not being recognized |
| (01/16/2005) Laptop and PDA cannot ping each other on network | (01/11/2005) Computers Can Share Internet but cannot see each other |
| (01/10/2005) Can't see other computer files | (01/19/2005) Can't see other computer on my network |
| (01/02/2005) Unable to connect to other computers on network | (12/31/2004) Can't see other computer |
| (12/14/2004) cannot browse other machines on domain | (12/07/2004) one computer can access shared files the other can't even .. |
| (01/07/2005) Can't get to files on other computer? | (12/06/2004) other question about securing wireless |
| (12/04/2004) Can share files one direction but not the other | (12/02/2004) Bridging the wireless and other connections |
| (01/14/2005) BEFW11S4 and WMP11 wireless devices don't see each other! | (11/10/2004) Ping is not recognized as an internal or external command... |
| (11/10/2004) Ping is not recognized as an internal or external command... | (12/16/2004) WIRELESS NETWORK, CAN'T SEE OTHER COMPUTER |
| (09/21/2004) accessing other computer via wireless | (09/15/2004) Accessing applications on each computer using wireless net.. |
| (09/16/2004) XP Pro Wireless drivers lost @ each reboot | (09/05/2004) Can't access network printer or other comp |
| (09/03/2004) Cannot access other computer! | (08/30/2004) Connecting to other computer |
| (08/23/2004) Will WPS ever support other EAP methods? | (08/21/2004) DELL WIRELESS 1350 INTERNAL WIRELESS (802.11 b/g) PROBLEMS! |
| (08/13/2004) will two APs talk to each other? | (08/17/2004) will two APs talk to each other? |
| (11/13/2004) Other available network appears and I lose my connection | (06/23/2004) Wireless disconect problem with 3 other wireless networks |
| (06/11/2004) wifi - can't ping other PC | (06/05/2004) Laptop with wireless card failed to connect other desktop .. |
| (06/04/2004) pc's speaking to each other | (05/26/2004) Non XP Machines |
| (05/22/2004) Sharing internet access via internal dial up modem | (05/14/2004) Compatibility problem - SMC 2652W and Toshiba P25 |
| (04/22/2004) Wireless laptop can't find my other computers on my home n.. | (04/19/2004) Wired LAN works, Wireless on same machines does not. (long.. |
| (09/08/2005) Using a router with a usb print server for other uses | (08/27/2005) Dlink DWL 650+ and SMC Barracade router : sudden problem w.. |
| (08/25/2005) laptops disconnect each other | (08/24/2005) B,G SMC can I use both to cover more? |
| (08/17/2005) internal wifi antenna | (12/30/2004) Need to Confirm Power Adapter for SMC 7004AWBR |
| (12/23/2004) Palm (or other) with anonymous proxy | (12/13/2004) Internal pings result in time outs |
| (12/20/2004) Wifi's on 2 Laptops don't detect each other even with nets.. | (12/01/2004) Any way to extend range of internal wireless PCI card in PC? |
| (11/26/2004) Monitoring other comps on my network??? | (11/30/2004) NetGear WG111 Internal Picture? |
| (11/17/2004) in infrastructure mode do stations send to each other? | (11/15/2004) output of one antenna when other is off |
| (11/16/2004) SMC 7004abr loses ME102 | (11/17/2004) Internal vs external 802.11g adapter |
| (10/29/2004) Getting 2 Wireless to Speak to Each Other | (10/19/2004) SMC 2635W card Keeps Dropping Connection |
| (10/07/2004) Wireless disconnect, dhcp doesn't answer and other strange.. | (10/03/2004) Wireless PCI card not finding any signal from SMC 2804 WBR.. |
| (10/04/2004) SMC 2804WBR - Problems in "g" mode | (09/30/2004) SMC 2804WBR - Problems in "g" mode |
| (10/06/2004) SMC Barricade SMC7004AWBR no connection | (09/18/2004) Newbie: check URL visited on other PC in peer-to-peer shar.. |
| (09/11/2004) Connecting D-Link WAP to SMC router | (09/03/2004) Where to find internal 802.11g or combo centrino cards for.. |
| (08/27/2004) Cable modem > SMC Barricade > D-link DI-524 wireless: wire.. | (08/27/2004) SMC 2804WBRP-G router a good choice for small community WA.. |
| (08/23/2004) Any try the SMC or Hawking 2X omni antenna? | (08/24/2004) Question: singal strength, same each end? |
| (08/17/2004) IBM wifi card in non-IBM machines | (08/07/2004) D-link Access Points constantly disconnecting from each ot.. |
| (08/06/2004) MAC Addrss for SMC wireless card | (08/05/2004) Rebooting SMC 7004 Wireless Router |
| (08/04/2004) SMC 2635 Card and 7004 Router Dropping link | (07/31/2004) Antenna booster for internal wireless card? Will a Pringle.. |
| (08/01/2004) static internal IP address on wireless XP network | (07/21/2004) Reference for other sites |
| (07/20/2004) acc point as bridge/feed for game or other computer | (07/15/2004) Upgrading SMC PCCard drivers |
| (07/09/2004) can a wireless access point use an internal IP address? | (07/01/2004) SMC has a 200mW notebook card |
| (06/27/2004) no DHCP with WEP - SMC | (06/26/2004) no DHCP with WEP - SMC |
| (06/26/2004) WPA problems using SMC 2804 | (06/24/2004) no DHCP with WEP - SMC |
| (06/21/2004) no DHCP with WEP - SMC | (06/23/2004) computers don't see each other |
| (06/15/2004) SMC 2655W in "Access Point Client" mode | (06/06/2004) truemobile 1150 card with SMC cannot connect to Internet |
| (06/05/2004) SMC Wireless Bridge? | (06/05/2004) SMC router used as access point and switch |
| (05/30/2004) SMC Passphrase is required in utilitiy upon PC restart ..... | (05/20/2004) Problem with wireless SMC router |
| (05/03/2004) Wireless LAN works great one direction, but not the other | (05/01/2004) Internal WIFI Card in my laptop is SLOW |
| (05/02/2004) Need help with two wireless routers talking to each other | (04/27/2004) OfficeConnect 11g how to access other systems in local net.. |
| (04/26/2004) SMC Barricade MAC Filtering Question | (04/18/2004) Can NetGear wg602 work as a bridge with any other router/a.. |
| (05/02/2005) Wireless signal not reaching other PC. | (06/19/2004) internal laptop wireless cards |
| (05/19/2004) Anyone use SMC wireless routers? | (01/27/2004) wireless comps cant see each other |
| (01/27/2003) USB vs. Internal PCI card | |
