| (11/28/2009) Can router be used as adapter? | (11/27/2009) Connecting Laptop to Internet using Instinct G3 phone. |
| (11/27/2009) Removing the antenna on belkin router | (11/29/2009) Cant remember name and password for linksysn router |
| (11/27/2009) Wifi card not supported by mobo? | (11/28/2009) Setting up a Windows 7 machine as a wireless router |
| (11/26/2009) WINDOWS 7 64BIT AND ROUTER | (11/26/2009) Losing signal from my D-link router |
| (11/26/2009) About wifi using in mobile phone | (12/13/2009) Frustrating router problem |
| (12/15/2009) Best Wireless Router For ~ 150$, Please Help !? | (11/25/2009) Will the belkin wireless G router work with AT&T? |
| (11/25/2009) Wireless Router Assigning Wrong IP Address, Need Help | (11/25/2009) Connecting a Linksys Router to a Verizion MiFi router |
| (11/24/2009) What does validating identity mean, a dir615 router, xp home | (11/24/2009) Linksys wmp11 wireless card gets no signal from 2wire access point |
| (11/23/2009) Computer randomly crasches after installing a new network card... Help! | (11/23/2009) Telnet commands for a linksys wireless router |
| (11/22/2009) Can i use a usb adapter without the router | (11/22/2009) Wireless-N Router forum |
| (11/22/2009) Wireless-N Router forum | (12/06/2009) How to get a linksys router to send out a wireless modem stick signal |
| (11/22/2009) Connecting 2 laptop with wireless | (11/20/2009) HP G50-126NR Wireless Mini-PCI 802.11b/g/n adapter??? |
| (11/21/2009) If I have a N router do I need a N adapter to pick up wirless | (11/20/2009) Netgear wgr614 router configuration |
| (11/20/2009) WAP vs booster vs upgrade G->N router? | (11/20/2009) Usb wireless router |
| (11/19/2009) How to configure netgear wireless Router WGR614as a repeater | (11/18/2009) DCS-2121 wifi ip cameras - fixed ip on router. |
| (11/19/2009) Router, And Using Printer With Two PC's ? | (11/18/2009) How to get my WAP key from router |
| (11/17/2009) How can i download software for a linksys wireless router with out a modom | (11/17/2009) Not able to connect to mobile using wifi |
| (11/18/2009) Linksys router problems | (11/17/2009) Why do i get a 169 254 x x address from the router |
| (11/19/2009) Recommendation for a good Wireless Router | (11/16/2009) Need wireless router work |
| (11/16/2009) Wireless card find network | (11/16/2009) Netgear modem/router & Belkin G-Mimo dongle disconnects. |
| (11/15/2009) Does my internet speed match with the speed I'm paying for? | (11/16/2009) Netgear wnr3500 router not compatible with windows vista? |
| (11/14/2009) Linksys WAG200G. Will it work with Windows 7 | (11/13/2009) D-link wireless router dwa-110 driver software |
| (11/13/2009) Connect to wired ADSL2+ modem router | (11/12/2009) Turning a pc wireless using my laptop |
| (11/12/2009) Windows XP, Netgear modem router, Belkin G mimo usb adapter | (11/12/2009) Will yagi antenna work on a usb router |
| (11/12/2009) Best home vpn router | (11/11/2009) Lag spikes caused by network card? |
| (11/10/2009) Setting up wireless router | (11/10/2009) Wireless g router |
| (11/27/2009) Is window 7 compatible with wireless g routers | (11/10/2009) What router disables wireless quick and easy? |
| (11/09/2009) Dlink G520 wireless adapter does NOT work with Windows 7 | (11/08/2009) Modem router combo need more range |
| (11/09/2009) Best cheap router | (11/06/2009) Wireless DSL modem, wired router networking |
| (11/04/2009) Will linksys wmp11 work with windows 7? | (11/03/2009) WDS with AP on Dlink 3200 |
| (11/09/2009) How to connect wireless-b broadband router befw11s4 | (11/06/2009) Windows 7 laptop not connecting to Netgear WGT624 wireless router |
| (11/02/2009) High gaming ping when multiple users on same router | (11/16/2009) Linksys router not working with TWC |
| (11/01/2009) What Wireless equipment is compatible with 802 3ad ? | (11/01/2009) Config wrt54G_V2 with MS xbox wireless adapter |
| (10/31/2009) Netgear wifi router | (10/31/2009) Belkin g wireless router setup now no desktop connection |
| (11/09/2009) How do I find the MAC address of a recently connected device on my wireless rout | (10/30/2009) Looking for a reliable wireless router that supports VPN |
| (10/29/2009) Actualy i am forget our linksys router login id | (10/30/2009) Wireless card no good with windows 7 ? |
| (10/28/2009) Driver/Card Issue | (11/01/2009) Wifi router with WEP WPA(TKIP AES) WPA2(TKIP AES) |
| (10/27/2009) What happens when router loses connection | (10/27/2009) Need to know how hook up wireless router to my desktop pc so i can use wireless |
| (10/27/2009) Netgear WG311v2 Driver fail install with Win7 64 | (10/27/2009) Netgrar router set up fine for laptop need password for mu iphone connection |
| (10/27/2009) 2nd Router as access point/bridge??!? | (10/26/2009) Belkin wireless G router |
| (10/30/2009) Usb wireless router | (10/25/2009) Router into a receiver |
| (10/24/2009) Wireless router traffic monitoring for different users | (10/24/2009) Configure Netopia 2247 Router as Bridge |
| (10/24/2009) MSI Wind u100 843us Wireless Card | (10/23/2009) Laptop connection to telefonica router problems |
| (10/23/2009) Connecting STB to wireless router | (10/27/2009) Hook up router to cpu server modem and hub |
| (10/22/2009) Server 2008 DHCP Netgear Wireless Router | (10/22/2009) Wireless router |
| (10/22/2009) Problems with my key board | (10/21/2009) Enabel to conect wireles router with my laptop |
| (10/20/2009) Know who is using bandwidth | (10/22/2009) Computers not seeing each other over WAN with Tomato router |
| (10/19/2009) Wireless card spec? | (10/19/2009) Need a wireless n pci card |
| (10/19/2009) How to hook up apple wireless router | (10/19/2009) Need advice what wireless router to buy |
| (10/18/2009) How to configure aztech router with linksys | (10/19/2009) Linksys WRT610N router VS Netgear WNDR3700 |
| (10/20/2009) Can you run Xbox LIVE off of a wireless card? | (10/17/2009) Compatable router for cell phone internet? |
| (10/16/2009) Why my router does not work with my modem | (10/17/2009) Pretty please help with my dongle |
| (10/16/2009) Best repeater to set up with dlink dir 615 | (10/16/2009) 0h how can i set up a security password for my router |
| (10/16/2009) My wirelss router can't connect to my laptop | (10/14/2009) Desktop Wireless Card soemtiems doesn't work on reboot |
| (10/16/2009) Which wireless router is right for me? | (10/14/2009) How to implement intranent using wireless router |
| (10/13/2009) Linksys router wrt54g software | (12/17/2009) Im about 7 nmiles from a mountain top with wifi! |
| (10/13/2009) Help with a wireless AP | (10/14/2009) Extending a wireless network using 2 LinkSys WRT54GL routers |
| (10/12/2009) Laptop as router | (10/19/2009) Broadband wireless router 500 meter range |
| (10/11/2009) I have a linksys befw11s4 router. The ADMIN page is 192.168.2.1. When I go to ad | (10/11/2009) Can you alter the range on a router |
| (10/10/2009) Problem with getting online with PS3 slim | (10/17/2009) Best durable wireless N & G router |
| (10/09/2009) How do i connect my netbook to an already existing wireless router | (10/07/2009) Help with speed issues |
| (10/06/2009) Problem with dell laptop | (10/06/2009) 3G Wireless Router/3G USB Modem Interoperability |
| (10/05/2009) Connecting a desktop PC to a wireless router? | (10/06/2009) I can't get my wireless router to see my printer...please help |
| (10/05/2009) What is spi mode in a router | (10/04/2009) Linksys router WR54G routing |
| (10/04/2009) Wired router for Xbox 360 | (10/04/2009) Where do i find ip number on router |
| (10/03/2009) Replacing one roter with another | (10/05/2009) How to add router to ATT uverse |
| (10/03/2009) Can a wireless router be used as a wifi antenna | (09/30/2009) Connecting 2 router together possible? |
| (09/28/2009) Is there an issue with some wireless printers and wireless usb adaptors knocking | (10/06/2009) Only 11mbps off wireless router help!!?? |
| (09/30/2009) Download GRAFIC CARD LAPTOP m-life | (09/28/2009) Need a router for vista 64 |
| (09/28/2009) Need a router for vista 64 , x box 360 psp wii and wireless | (09/30/2009) How to make linksys router an access point |
| (10/05/2009) Broken router | (09/27/2009) Connect to router together |
| (09/26/2009) My netgear ma101 adapter will not connect to Belkin N+ router | (09/29/2009) Recommended wireless router ~$100 ?? |
| (09/27/2009) Wireless router | (09/26/2009) My comp CANT find my wireless router |
| (09/25/2009) Linksys wrt54g v8 router problem | (09/25/2009) Wireless access point and router options |
| (09/23/2009) Which router to buy? | (09/30/2009) Terrible speed with trendnet wirless n pci card |
| (09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP? | (09/23/2009) Best Gaming Wireless Router? |
| (10/05/2009) Difference between router and extender | (09/23/2009) What is the BEST wireless 802.11n router? |
| (10/10/2009) 2 Wire router/linksys bridge WEP problem | (09/23/2009) Set up my wireless network, what router, what networkcard in my laptop |
| (09/20/2009) Problem with MSI PC60G | (09/20/2009) Fax using WIndows XP and ATT UVERSE |
| (09/18/2009) Wireless router & modem | (09/16/2009) Using a router as a wireless adapter? |
| (09/16/2009) Broadcom 802.11g | (09/18/2009) Bad streaming with good internet connection |
| (09/15/2009) QOS router | (09/13/2009) New wireless card needed |
| (09/19/2009) Belkin Router = fail? | (09/25/2009) Dual LAN and Wireless Router |
| (09/21/2009) Wireless network with vonage - need advice | (09/09/2009) Making Google WiFi work with a weak signal. |
| (09/15/2009) Issue with an oddly unstable connection | (09/09/2009) Upgrading wireless router, need advice |
| (09/08/2009) Start wireless card before logon | (09/06/2009) How to install new router on Mac |
| (09/15/2009) Help with wireless network | (09/03/2009) How to connect orange live box to another wireless router |
| (09/03/2009) Zyxel router | (09/01/2009) Att modem with linksys router |
| (09/04/2009) Wired ethernet with wireless router | (08/31/2009) I need help with a Wireless adapter driver |
| (08/31/2009) Connecting a Wireless router to a modem/Wireless router, Help! | (08/31/2009) Wireless kb with touchpad |
| (10/25/2009) Laptop b/g wi-fi adapter work with n router | (08/30/2009) Replacing a 2 wire wireless router |
| (08/30/2009) Router question | (08/30/2009) Wirless Router Problem? |
| (08/29/2009) View camera wireless using internet | (08/29/2009) Is it okay to not unplug the router? |
| (08/30/2009) Connect with secured wireless network | (08/28/2009) How to configure linksys wrt 54g router in apt building w/ethernet jac |
| (08/27/2009) Wireless n router | (09/03/2009) Can I run 2 wireless routers on one DSL line with modem? |
| (08/26/2009) Internal Ethernet Adapter or Standalone Router | (08/27/2009) Connecting to Router |
| (08/26/2009) Router | (08/27/2009) Router |
| (08/26/2009) Router | (11/01/2009) A good wireless pci adapter that works with 64 bit OS? |
| (08/24/2009) Using two Linksys Wireless routers for broader WiFi Coverage | (08/23/2009) Problem "seeing" other computers, but not with getting online? |
| (08/23/2009) Do I need to have a cable modem apart from a router? | (08/21/2009) Wireless Router and Wireless Access Point setup |
| (08/20/2009) My linksys router | (08/21/2009) Security using WEP |
| (08/19/2009) Connecting 2 laptops to one router | (08/20/2009) ADSL modem/router advice. |
| (08/19/2009) Detection Error, Bluetooth can't sync cell phones with Laptop | (08/18/2009) Detection Error, can't sync cell phones with Laptop |
| (12/05/2009) Converting a DIR-625 into a repeater | (08/16/2009) Router for college kids |
| (08/15/2009) Nintendo dsi internet setup with wireless usb adapter | (08/12/2009) Somebody how do I tell if I have a wireless network card installed? |
| (08/10/2009) Sony FW with WLAN, no LAN :( | (08/11/2009) Using wireless gaming adapter in my wireless network |
| (08/09/2009) Connecting ADSL usb modem + Wireless router possible ? | (08/09/2009) Need a wireless card - only have PCIe 1x slots |
| (09/10/2009) NetGear WPN824v3 Wireless Router | (08/18/2009) Which D-link router to buy? |
| (08/09/2009) Wireless Internet Network Card | (10/30/2009) Bought a D-Link DIR-655 Extreme N Wireless Router - Need advice |
| (09/19/2009) Can U upgrade a WEP Wireless card to WPA? | (08/05/2009) Using MN-740 with WPA and Vista |
| (08/03/2009) Help with Compaq 2105US Laptop Wireless Connection | (08/03/2009) Wireless router with built dsl modem |
| (08/02/2009) Can't connect to internet through wireless router | (08/02/2009) Search for a wireless router WITHOUT connectiond drop |
| (08/02/2009) How to increase signal from neighbors router? | (07/31/2009) What wireless card? |
| (07/30/2009) Pc streaming with wired denon a/v receiver on wireless network | (07/29/2009) Signal from router, but no internet. *Help Please* |
| (08/17/2009) Tenda router trouble | (07/28/2009) Can i connect a belkin router to a linksys? |
| (07/27/2009) My computer connection is unreliable, do I need a new router? | (07/27/2009) My computer connection is unreliable, do I need a new router? |
| (07/28/2009) My computer connection is unreliable, do I need a new router? | (07/28/2009) Linksys wireless router bottlenecking my connection speed |
| (07/26/2009) Buying a new router and adapter TODAY | (07/25/2009) Linksys WRT54G setup with verizon |
| (07/29/2009) Best Wireless N Router | (07/24/2009) Would I benefit from a Dual Band N Router? |
| (07/28/2009) 2 DSL Modem/Router, how to extend range? | (07/24/2009) Router As Receiver, Can you distribute? |
| (07/23/2009) Wireless router fail to setup to router modem | (07/23/2009) Need advice on upgrading wireless router with adapter |
| (07/22/2009) Help linksys router not working | (07/22/2009) Slow connection -- need new router? |
| (07/22/2009) Wireless computing with a Dell dimension XPS t450 | (07/21/2009) Can't access router configuration page... |
| (07/18/2009) Vista Ultimate and Linksys Routers and USB Card | (07/17/2009) Can't Connect to Unsecured Network (full signal) with Zonet ZEW2500P |
| (07/17/2009) Problems connecting router. HELP PLEASE! | (07/17/2009) Wifi card not as good on one PC vs another |
| (07/16/2009) I need help with wireless networking | (07/15/2009) Need a new router |
| (07/16/2009) Spotty, slow connection - is it my pci card? | (07/14/2009) DIR-615 mac address filter doesn't work with my macbook |
| (07/13/2009) Help with set up of netgear dg834pn | (07/16/2009) Having problems with router to laptop not getting connectivity |
| (07/11/2009) Help! I cannot connect ibm thinkpad wireless laptop to WPA router | (07/08/2009) Router password and laptop connectivity |
| (07/08/2009) Wireless WLAN Mini-PCI Card, Help. | (07/08/2009) 1 computer, one router |
| (07/06/2009) Cannot share printer connected to XP machine with 2000 via Wireles | (07/03/2009) Monitoring traffic through a wireless router? |
| (06/29/2009) Please Help if good with Port Forwarding | (06/29/2009) Problems with wireless adapter |
| (06/25/2009) Help for Wireless Router | (06/25/2009) Help with settings |
| (06/24/2009) WinProxy setup in windows Server 2003 by using DSL-2640T wireles modem | (06/23/2009) Wireless adapter with the dlink dir-655 |
| (06/23/2009) Can see a SSID with no Security Key, cant connect | (06/18/2009) Wireless router interfering with cordless phone |
| (06/18/2009) Problem with wireless network and restricted user WinXP | (06/16/2009) G+mimo wireless router |
| (06/18/2009) N1 Wireless: Problems With Port Forwarding | (07/03/2009) Router that can view/allocate bandwidth to different computers? |
| (06/14/2009) HELPS on Linksys WRT54G router | (06/12/2009) Wireless N card to Wireless G Router |
| (06/12/2009) Does electirc heat interfere with wireless g | (06/15/2009) Is my wireless card broken? |
| (06/15/2009) Linksys Router - Engenius 2611 CB3 Setup ? | (06/17/2009) Image is blur in browser window while using only Mobile Broadband |
| (11/13/2009) Wireless N adapter to wireless G router? | (06/10/2009) Odd config between wired/wireless router and wired/wireless AP |
| (06/08/2009) I can't connect with Windows XP help! | (06/09/2009) Linksys Router IP: How to Locate? |
| (10/13/2009) Wireless LAN adapter problem with Vista 64-bit OS | (06/04/2009) Bluetooth PCI card for desktop system (bluetooth only card) ?? |
| (06/03/2009) Need advice with linksys WRT54GL router | (06/02/2009) Need a router or access point |
| (08/20/2009) Secured wired and Open wireless with one internet connection | (05/29/2009) 2wire gateway with UVERSE |
| (05/27/2009) Router no power | (05/28/2009) Router Upgrade -help- |
| (06/04/2009) Need help with linking connections | (05/25/2009) Wireless Router Problem! Help needed! Please |
| (06/05/2009) Trendnet Wireless N Router providing less than 1 Mbps Connection!!! | (05/24/2009) Need help setting up a router with Comcast cable |
| (06/09/2009) What PCi card is best for me?? | (06/15/2009) Connecting wireless with vista 64 |
| (05/23/2009) Cannot go on line with Explorer | (05/21/2009) Using wrt320n and 3 wap4410n |
| (05/22/2009) Hi-grade va250d and broadcom mini pci wlan card | (05/20/2009) Need advice for a new "N" wireless router |
| (05/17/2009) Best Home WiFi Router? | (05/16/2009) WIFI card MobilePro 780 |
| (05/15/2009) Advice on Wireless Card | (05/26/2009) Wireless Router drops signal after a few hours |
| (05/14/2009) Want to upgrade to "N" router, questions | (05/11/2009) Need a recommendation on a wireless card that is compatible with server 2003 r2 |
| (11/30/2009) Function key combination for wireless router | (05/11/2009) Using a USB adapter w/SMA antenna |
| (05/08/2009) Using ADSL router for cable internet | (05/09/2009) WLAN with Wireless Router and Wireless Access Point |
| (05/06/2009) Wireless router - comcast | (05/10/2009) Recommended Router for Wireless N Upgrade |
| (05/01/2009) Printer not printing after setting up a lInksys N router | (04/30/2009) Modem/router? |
| (04/25/2009) What do I need to connect to this router? | (04/26/2009) Dual Band Network With Two Routers |
| (04/24/2009) Dlink router | (04/23/2009) IP addressing from wireless router!? |
| (04/22/2009) Stop others from using my wireless internet | (04/22/2009) Sharing broadband with neighbor (sister) |
| (04/20/2009) Change wireless card. PLEASE help! | (04/14/2009) D-Link router isn't working correctly. |
| (04/14/2009) Need help with my Asus WiFi | (04/14/2009) Router problems |
| (04/11/2009) WPA2 adapter with WPA router | (04/10/2009) Router effecting Modem |
| (04/10/2009) Problem with my se w350i phone | (04/09/2009) Wifi phone/wifi voip phone/wifi ip phone with roaming functions |
| (04/08/2009) Looking for help with connection speed | (04/08/2009) Buying a wireless router |
| (04/07/2009) Wireledd Card | (04/07/2009) Wireless N with PCI-E? |
| (04/08/2009) Router Reliability | (04/07/2009) Setting a wireless network with a tv that has ethernet input |
| (04/08/2009) Idiot with wireless needs help | (04/06/2009) V4000 wireless card |
| (04/05/2009) Linksys WRT160N router does not validate identity | (04/02/2009) HELP PLEASE, cant get router to work with charter internet |
| (04/03/2009) Wireless with wired (without internet) | (03/30/2009) Changing encryption from WPA-PSK to WPA.Thompson 585v7 router |
| (03/28/2009) Network card or usb wireless? | (03/25/2009) Need help with linksys wet54g network bridge |
| (03/26/2009) Wireless G with Rangeboost vs. Wireless N with Rangeboost | (03/24/2009) Help the PC illiterate please with network setup |
| (03/24/2009) Wrt54g v.6 router with wet54g v3.1network bridge bridge | (10/05/2009) Laptop with XP wont connect to my wireless network |
| (03/21/2009) Can You Recommend a Wireless Network Card for 64 Bit Windows? | (03/21/2009) 2 wire modem router 1000hw |
| (03/20/2009) Wireless Linksys Router | (03/19/2009) Wirelees router with a cable modem issuses |
| (03/19/2009) Modem to router | (03/19/2009) I need to get a repeater to improve my existing router ...HELP |
| (03/18/2009) Linksys WRT310N & WAP4410N any one using them presently | (03/18/2009) Best WRT54G router replacement? |
| (03/25/2009) Can not connect to Wireless Network with notebook. | (03/16/2009) Need help on router |
| (03/16/2009) Need help with d-link | (03/16/2009) Laptop + Squeezebox having problems with new router |
| (03/14/2009) FASTEST, Longest Range and most reliable wireless router? | (03/12/2009) Connecting Mobile to Laptop to Share WiFi using Bluetooth |
| (03/11/2009) Using 2 Wireless Routers | (03/10/2009) Network Adapter that works with Vista 64? |
| (03/10/2009) Securing my Netgear router | (03/13/2009) Finding the on siwtch for WRT310N Linksys Router |
| (03/09/2009) Wireless with neighbor | (03/08/2009) Why does Wireless Connections drop when using a secured network? |
| (03/08/2009) Help setting up linksys psus4 with hp 6122 printer | (03/10/2009) New "N" router has no range |
| (03/04/2009) Wlan USB stick or a PCI extension card? | (03/04/2009) Which Router to get? |
| (03/03/2009) Good wireless router? | (03/02/2009) Why does my laptop keep disconnecting frommy wirelss router |
| (03/01/2009) Wireless usb with current router. | (11/22/2009) How to connect to internet using wifi from mobile phone? |
| (02/28/2009) Controlling a router remotely | (02/27/2009) Networking Oddity with Vista |
| (03/01/2009) Help with home network | (02/25/2009) Which wireless card to get with WNR 2000 and Vista 64? |
| (02/24/2009) My router d-link dir 655 | (02/24/2009) Help i can't find the wep key for abelkn54g wireless router for my wii |
| (03/03/2009) Can I add a wireless router to an existing wired router? | (02/20/2009) Connect laptop to wireless router |
| (02/19/2009) Using a router to send cricket broadband to my other pc's | (02/18/2009) Router |
| (02/17/2009) Wireless router | (02/16/2009) Need help picking a router (specific needs) |
| (02/14/2009) My ipod is using all my routers bandwidth. How can limit it? | (02/16/2009) Vista 64 bit wireless card |
| (02/12/2009) My computer won't recognize by new wireless router | (02/11/2009) Wirleless Card Not Authenticating |
| (02/11/2009) How to hide one's internet activity from a wireless router | (02/11/2009) Best Wireless Router |
| (02/10/2009) Multiple router? | (02/10/2009) Which Router? |
| (02/08/2009) DWL-650+ Adapter with DI-628 Router | (02/08/2009) Looking for new router any real world suggestions |
| (02/27/2009) Im using a wireless belkin connector and now its not working... | (02/06/2009) Wireless router/modem combo???? |
| (02/03/2009) Router disconnects when viewing any Map web site | (02/03/2009) WAVEBUDDY WIRELESS PC CARD SOFTWARE |
| (02/02/2009) Cant connect to internet without wireless router | (01/29/2009) Windows 7 64 bit wireless pci card compatibility |
| (01/27/2009) Slow wireless with XP 64bit | (01/24/2009) Wireless router downstairs. desktop upstairs |
| (01/23/2009) New Wireless Card not being recognized in Vista | (01/21/2009) What's Wrong With my Internet??? :((((( |
| (01/20/2009) Need Help with slow wireless | (01/18/2009) WPA-PSK using TKIP encryptor connection problem |
| (02/11/2009) Suggestions for wireless router | (02/03/2009) Need Help with Wireless N Routers |
| (01/09/2009) How to set up my Hawking router as a second router? | (01/09/2009) Wireless Router to Wireless router |
| (01/06/2009) Cannot Change Wireless Card Settings - freeze | (01/06/2009) Router/Gaming |
| (02/10/2009) Wireless N adapter and G router | (01/05/2009) Dlink router troubles |
| (02/17/2009) Anyone WIth an Asus Motherboard? Help! | (01/02/2009) Is this router causing my problem? |
| (12/30/2008) GAMING with Wirless PCI Card | (12/31/2008) Netgear wireles router is realy slow compared to my linksys |
| (12/28/2008) 64-bit Drivers for Wireless Network Card | (12/21/2008) Wireless card acting as a wireless router |
| (12/21/2008) Windows XP not recognising network card? | (12/15/2008) Getting WG602 to work with BEFSR41 V3 |
| (12/15/2008) Weird connections with linksys | (12/08/2008) Question About My Router |
| (12/07/2008) Help in finding an all-in-one cable modem with wireless | (12/06/2008) How to setup 2 pc's in a wireless LAN with an AP? |
| (12/05/2008) Using N instead of G for Xbox 360...some questions... | (12/10/2008) looking for a good 200+ simultaneous connection dual-N router |
| (12/02/2008) Difference between Access point and Router? | (11/28/2008) Router Upgrade for 10/1 Cable |
| (11/28/2008) Upgrade PCI card vs Network Repeater-Help Please | (11/26/2008) access point/ wireless router |
| (11/27/2008) Will a better router help? | (12/01/2008) Upgrade Wireless mini-PCI Card? |
| (11/29/2008) Possible to use a router to turn on a tv | (11/12/2008) Can it be done with my current equipiment? |
| (11/10/2008) New Router, page loading issues. Must refresh to see. | (11/05/2008) New PC with existing wireless connection! |
| (11/02/2008) Is D-Link 655 router reliable | (11/07/2008) Suggestion for a Stable Wireless B/G PCMCIA Card for Win 2000 |
| (10/30/2008) Router or something call Access Point??? | (11/03/2008) Wireless print server to wireless router problems! |
| (10/24/2008) Do i need a wireless card? | (11/04/2008) Need a wireless router, please help? |
| (10/18/2008) What type of wireless router do I need? plz help me! | (10/18/2008) WTF? i cant connect laptop to router |
| (10/06/2008) Problem with maintaining a connection with my XBOX. | (10/04/2008) Antenna upgrade, how many on n router? |
| (10/02/2008) do i buy another router? | (09/28/2008) NETGEAR w.router stops working with security on |
| (09/27/2008) Reccomend me a Modem/Router | (09/26/2008) Laptop-Wireless Router |
| (09/23/2008) Using Wifi-Ap as Access Point? | (09/20/2008) which router - what adapters |
| (09/20/2008) Please help with this ad hoc problem | (09/20/2008) USB Adapter or PCI CARD For Wireless |
| (09/17/2008) Best PCI card for the buck? | (09/15/2008) Linksys Wireless Router not working with Motorola Surfboard Cable Mod. |
| (09/15/2008) Help with Wireless Network | (09/15/2008) Help with printer - Urgent |
| (09/14/2008) upgrading topic "placing a second router" | (04/23/2009) Seting up A 2nd router behind an AT&T 2Wire UVerse Router |
| (09/03/2008) Problem with Networking, half works, half doesn't | (09/03/2008) Best Wireless Router |
| (09/03/2008) How to Lan between 2 laptops (Wireless) without a router??? | (09/03/2008) Using DSL Router (w/ wireless) as wireless router alone |
| (08/27/2008) Help with Marvell 88W8335 Wireless Card | (08/27/2008) What is a good router to buy? |
| (08/26/2008) I need help with video streaming | (08/31/2009) Help with Wifi please |
| (09/22/2008) What Wireless PCI Card? | (08/25/2008) Using old 802.11a slow down 802.11g |
| (08/25/2008) Use wireless router as wired router | (08/24/2008) D-Link Rangebooster G Wireless Router |
| (08/20/2008) like to add a second wireless router with no WEP | (08/18/2008) cannot connect with security enabled |
| (08/15/2008) Damm! have to restart the router again #$%^& | (08/12/2008) Connect to my neigbours router and vice versa |
| (08/10/2008) Gaming with a Router connected to other Router | (08/10/2008) Using two Wifi with one Cable modem |
| (08/07/2008) Wireless router vista 64 Xp 64 | (08/04/2008) Linksys router issues |
| (08/04/2008) Desktop Wireless Adapter with Integrated Bluetooth? | (08/04/2008) Looking for a new wireless router.... |
| (08/04/2008) Access point vs router vs repeater vs media center extender | (07/30/2008) Wireless Connection Issues with WRT54G + Windows Vista 64 Bit |
| (07/28/2008) WEP Encryption - one laptop does not work with it | (07/29/2008) SMC wireless router as wired AP |
| (07/27/2008) new 802.11n router + connecting to adsl2 router | (07/27/2008) looking for gigabit wireless/gigabit wire router |
| (07/29/2008) Trouble with DHCP (i think) Please Help! | (07/25/2008) Random disconnects on FIOS router. |
| (07/25/2008) What wireless router is best used with an Att DSL Modem? | (07/24/2008) Router and adapter reccomendations |
| (12/29/2008) Low signal with FIOS router | (07/25/2008) 802.11n PCIE Mini Card Upgrade |
