Homemade Sector WiFi Antenna?
More related threads to : Homemade Sector WiFi Antenna?
(11/27/2009) Removing the antenna on belkin router(11/27/2009) Wifi card not supported by mobo?
(11/26/2009) About wifi using in mobile phone(11/26/2009) How to set wifi in mobile phones
(11/18/2009) I have wifi but i can use the internet it says cant conect to server(11/18/2009) DCS-2121 wifi ip cameras - fixed ip on router.
(11/18/2009) Wifi cards for desktops(11/17/2009) Not able to connect to mobile using wifi
(11/15/2009) Connect wifi on phone(11/19/2009) PLEASE HELP ME CONNECT WIFI PRINTER TO PC
(11/14/2009) Streaming video over wifi to windows media center...problems(11/12/2009) Will yagi antenna work on a usb router
(11/11/2009) Wifi is working in ad-hoc but not in infra mode(11/10/2009) How to control sharing internet access thru wifi
(11/08/2009) Vista wifi bridged to xp ethernet(11/08/2009) Wifi reapeter, wireless isp etc?
(11/07/2009) Nintendo DS Wifi(11/08/2009) WiFi interruptions
(11/08/2009) Wifi adapter loads CPU(10/31/2009) Ibm R52 wifi shotcut key
(10/31/2009) Losing wifi(10/31/2009) Netgear wifi router
(10/31/2009) Windows mobile not connecting to wifi modem's internet(10/30/2009) Want to supply public wifi in a 1-2 mile coverage area
(10/29/2009) HP Firebird 802 Wifi Selection(10/28/2009) WiFi drops on high CPU load
(11/01/2009) Wifi router with WEP WPA(TKIP AES) WPA2(TKIP AES)(10/25/2009) Cannot connect Ipod Touch to Home Wifi
(10/25/2009) Ipod Tpuch won't connect to WiFi(10/24/2009) Connect wireless antenna to lynksys wcg200
(10/23/2009) My gateway WiFi switch wont turn on(10/20/2009) Two Wifi Devices Same PC, Is ad hoc or ICS an option?
(10/16/2009) Wifi cpe(10/16/2009) How can my laptop get a wifi connection from another laptop through bl
(10/16/2009) Im about 7 nmiles from a mountain top with wifi!(10/11/2009) One laptop can connect to the wifi two others cant
(10/10/2009) Asus WiFi P5K-E-AP internet drops out(10/09/2009) WiFi handoff problem
(10/09/2009) Antenna advice(10/05/2009) Wifi Problem
(10/04/2009) Mobile wifi(10/03/2009) Can a wireless router be used as a wifi antenna
(11/20/2009) What is the advantage of having a upnp wifi than normal wifi in a cell phone???(09/28/2009) Vista Wifi sleep problem - I have solution but can't implement it!!!
(10/14/2009) I have problem in my psp wifi connection in security(09/22/2009) WILL ROUTER AND WIFI PHONE INTERFER WITH COMPUTER TO RECEIVER HOOKUP?
(09/22/2009) Tutorial pc use wifi(09/20/2009) Configure wifi asus p526
(09/19/2009) Two wifi between to connect what range(09/14/2009) Inhouse wireless antenna for cellular phone
(09/15/2009) Boosting WiFi signal(09/09/2009) Making Google WiFi work with a weak signal.
(09/09/2009) Setting up an WiFi Access Point....?(09/01/2009) Long range wifi
(08/24/2009) Using two Linksys Wireless routers for broader WiFi Coverage(08/20/2009) Two routers, no wifi cards, and a next door friend
(08/10/2009) NO WIFI(08/09/2009) Cant connect to Internet Exploer when connected to wifi
(08/07/2009) Wifi in my woodshop 300 feet away.(08/07/2009) Wifi in my woodshop 300 feet away.
(08/21/2009) Need advice about long range WiFi Connection(07/31/2009) Notebooks and wifi antennas
(07/17/2009) Forgot my wifi password but still connected(07/17/2009) use bluetooth to network laptops & share 1 wifi connection??
(07/17/2009) Wifi card not as good on one PC vs another(07/21/2009) Shield AA lithium batteries from WiFi signals
(07/16/2009) Is there a performance difference between USB & PCI based wifi modules(07/14/2009) Wifi sharing
(07/14/2009) P5k-e Vista Wifi Acess Point = pulling out my hair!(07/12/2009) How to secure wifi?
(07/10/2009) Strange wifi problem...please help!!!!(07/04/2009) Wrt54g dual outdoor antenna?
(06/26/2009) Wifi interference - any workaround?(06/17/2009) Windows XP as WiFi Access Point
(06/16/2009) Pinging and wifi scanning - why do these adapters differ in behavior?(06/10/2009) WiFi help...
(06/02/2009) Hoping to go WIFI(06/02/2009) UMTS antenna cable
(06/02/2009) WiFi Repeater: How to Make?(05/17/2009) Best Home WiFi Router?
(05/16/2009) WIFI card MobilePro 780(05/14/2009) WiFi Hardware for Portable entertainment
(05/14/2009) WiFi Hardware for Portable entertainment(05/11/2009) Using a USB adapter w/SMA antenna
(05/08/2009) WiFi Subscription Sites(05/15/2009) WiFi Adaptor installation crashes network connection menue
(04/25/2009) Wifi server(05/04/2009) Wifi between two houses 1000-1200 ft apart
(11/03/2009) USB 500mW WiFi adaptor(04/14/2009) Need help with my Asus WiFi
(04/09/2009) GSM/WIFI PHONE/Dual mode mobile phone/wifi video phone/ smart phone(04/09/2009) Wifi phone/wifi voip phone/wifi ip phone with roaming functions
(03/28/2009) Linksys by Cisco does it has wifi?(03/12/2009) Connecting Mobile to Laptop to Share WiFi using Bluetooth
(03/12/2009) Netzero and Wifi(03/10/2009) Can you connect a wireless 2.4ghz mouse to a wifi chip in a laptop
(03/03/2009) Enhance wifi signal(03/03/2009) Enhancing wifi signal
(11/22/2009) How to connect to internet using wifi from mobile phone?(02/28/2009) WiFi on a Compaq Evo N800c
(02/15/2009) ZyXEL P600 Antenna?(02/10/2009) Add an antenna to a D-Link DWA-643 ExpressCard?
(02/03/2009) Cable tv over wifi(02/04/2009) Connect 3 PC's via switch to WiFi Access Point to WiFi
(01/11/2009) Wifi conection sharing(12/30/2008) Secured WiFi at School?
(12/13/2008) My laptop is not able to connect to WiFi Network after reinstal OS(12/14/2008) Belkin WiFi G USB Network Adapter - disconnects other clients
(11/13/2008) Wifi laptop stealing bandwidth??(10/09/2008) WiFi Competitor Uses Visible Light While Cleaning RF Spectrum
(10/10/2008) Connect two routers via wifi?(10/04/2008) Antenna upgrade, how many on n router?
(10/21/2008) Printing trough wifi in LAN(09/07/2008) Better Antenna or New Adapter?
(08/29/2008) Combining Wifi connections(08/31/2009) Help with Wifi please
(08/25/2008) Wifi Vista to Ethernet XP?(08/08/2008) Wi-Fi Antenna
(08/10/2008) Using two Wifi with one Cable modem(07/12/2008) ** Still Same Not Able To Enabale Wifi In Aspire 3690 **
(07/08/2008) USB wireless dongle external antenna(08/01/2008) Belkin F5D8053 wont connect to any wifi
(07/05/2008) Replacement antenna for Actiontec M1424WR ?(06/30/2008) Linksys WMP54G 4.1 Trouble picking up wifi signal WinXP SP2 32-bit
(06/02/2008) p5w and my wifi ap solo(05/11/2008) Pooling, Loadbalancing,Bridging three wifi connections ?? Questions?
(03/12/2008) MIMO Wifi is slow, or is it normal?(03/15/2008) Add wifi to Gateway 500S w/wired LAN
(02/24/2008) 100m WiFi(11/17/2007) WIFI
(11/09/2007) DLINK DSL G604TRouter + P5K-e/wifi AP Help(11/01/2007) Can you mix and match different Antennas on a Multi Antenna Router
(08/18/2009) How to connect to Internet, through WiFi; a problem(09/30/2007) Wifi problems on laptop
(08/21/2007) can connect with ethernet but not wireless, conflict with wifi card?(08/05/2007) Wifi Not Connecting - Wired Works Fine
(08/07/2009) Vista & wifi - Can see wireless networks but can't connect to them!(07/26/2007) Having problems with Asus Wifi AP dropping connection
(07/23/2007) Regarding increasing the WiFi range(07/19/2007) Setting up wifi for 18 people
(09/17/2007) Problems connecting to unsecured wifi network in Vista(06/02/2009) Need advice regarding extending WIFI network (picture included)
(06/26/2007) WiFi connected to access point but can't find internet(06/09/2007) 2.4GHz 5dBi Wireless Magnetic External Antenna
(06/14/2007) If you wanna make a DIY antenna(05/28/2007) Where can you buy extended length Dipole Antenna Cable?
(05/17/2007) Wifi better than cat 5 ????(04/16/2007) First Time WIFI Setup
(04/13/2007) 5 gallon directional antenna(04/14/2007) CounterStrike Source causing loss of WiFi connection
(06/21/2007) What to replace my 2db antenna with on my DG834GT Router?(03/02/2007) How to attach Linksys high gain antenna to laptop?
(03/01/2007) Confused antenna help.(02/05/2007) 1st PCI-E Wifi AP combo card! Wireless network card!
(02/06/2007) US Robotics wifi router(02/06/2007) Wi-Fi Nic with external antenna adapter recomendations
(02/02/2007) WiFi Repeater set up! Major headaches. Can you help?(01/18/2007) Netgear trouble with 2 wifi's :(
(01/11/2007) What are the differences between Wifi and 802.11b/g?(12/17/2006) Antenna Range
(12/17/2006) Suggestions for setup? Antenna Question(12/09/2006) Noobness Dual Ethernet Mobo + Wifi question
(12/08/2006) PSP wifi connection(01/03/2007) External wireless antenna for a laptop?
(11/26/2006) Mimo or larger Antenna?(11/06/2006) Making my own bad ass wireless antenna help?
(11/03/2006) packet injection and monitor mode wifi cards(03/23/2007) My neighbours are intruding my wifi security enabled network
(03/17/2009) Desktop WiFi Card(10/26/2006) how can i get wifi?
(10/25/2006) l33t help needed. Using bittorent on my neighbours wifi....(09/22/2006) WiFi Tweaks.
(09/18/2006) usb wifi adapter drops to 1mbs when connected in bridge!?(09/15/2006) usb wifi adapter drops to 1mbs when connected in bridge!?
(09/19/2006) Mounting a wireless antenna outside?(08/22/2006) D-Link DI-634M Router & DWL-G520 WiFi PCI Adapter Help
(08/16/2006) Wifi gurus!! Please assist! Multi AP setup on 1 subnet(08/14/2006) Trying to fix a wireless Antenna
(09/12/2006) Difference between antenna(10/14/2009) I have a wifi lap top what do I do next?
(04/07/2008) WiFi and Dialup?(07/09/2006) Got Wifi connected, but can't get a network going
(07/18/2006) SET UP MY OWN WIFI BUT NEED A LITTLE HELP PLEASE(06/21/2006) Can you disable built in WiFi in favour of an external WiFi?
(06/12/2006) Connecting two wired switches with wifi + using access point(06/04/2006) Recommendations for extending wifi signal
(03/17/2009) Belkin Wireless USB Antenna(05/19/2006) linksys wifi issue
(05/07/2006) How to share wifi with a device that cannot logon?(05/24/2006) PCI WiFi question
(04/27/2006) Laptop Antenna(04/24/2006) HELP ! Linksys WAP54G + 7Dbi Antenna = ? % Signal
(04/15/2006) dual antenna setup - is this possible?(04/05/2006) My WiFi card worked before I formatted my laptop!?
(12/10/2006) Roaming WiFi issues - 3 APs, one switch, one SSID(05/04/2006) wifi spectrum analyzer?
(09/13/2005) Attaching antenna to Belkin 802.11g PCMCIA card(01/25/2006) Linksys wifi Router runnin on cable..
(03/19/2006) auragrid wifi extender(09/26/2005) wifi & iwconfig
(09/22/2005) Long Range wifi troubles(04/11/2009) WiFi security settings
(04/02/2004) Screwy behavior from different wifi pc-cards(04/01/2004) ICS and wifi
(09/06/2005) Wifi connection dropping or timeout ....(09/20/2005) Use Directional Antenna (or help in general)
(09/21/2005) Are MC and MMX antenna connectors (about) the same?(01/16/2006) Using Linksys WRT54G to connect to another wifi router
(01/19/2006) Recommend an access point, 4-p Router wifi(10/15/2009) PCMCIA wireless network card with external antenna ?
(01/28/2006) CAVEMAN ASK: HOW FAR COMPUTER WORK, WIFI DISTANCE, YARDS?(01/15/2006) Will this WiFi setup work?
(01/10/2006) Wifi Signal Mapping question(01/08/2006) Antenna
(09/13/2005) Accessing a wifi printer(09/08/2005) antenna extension?
(09/07/2005) Multiple users logged on one machine with WiFi... is it po..(09/07/2005) Basic setup - USB WiFi on 2 PCs for Internet Sharing... ho..
(08/31/2005) Wifi connection lost(09/20/2005) Win XP PRO SP2 WiFi and DHCP
(08/24/2005) Frequent WiFi Disconnects(07/25/2005) Laptop Only Uses WiFi, Refuses to Use Wired LAN When Conne..
(06/18/2005) Dial-up sharing with WiFi(06/16/2005) Two wifi networks?
(06/07/2005) Wifi et Activesync(05/25/2005) connexion wifi intermitente
(05/25/2005) WiFi card disconnects on logout (XP SP2)(04/26/2005) WiFi doesn't work with LAN card in WINXP sp2
(04/25/2005) WinExplorer slowdown / crash on Wifi transfers(04/20/2005) Lost WIFi connection on each reboot
(04/14/2005) File sharing from a WIFI PC with nobody logged on - How to..(04/11/2005) New WiFi Set Up
(04/11/2005) WiFi Connection Nightmare(04/08/2005) one CAT5 cable, two WiFi laptops
(04/04/2005) difference between Wifi repeater and range extender?(04/04/2005) Roam from Gprs network to Wifi network
(03/25/2005) wifi newbie(03/20/2005) Dual Antenna fitted to an AP - Possible??
(03/19/2005) PC Screen Output to TV via Wifi(03/17/2005) MN-700 Base Station - adding a signal booster or antenna
(03/19/2005) Proxim ORiNOCO PC GOLD CARD with antenna problem??!!(03/25/2005) wifi mystery
(03/10/2005) One wifi laptop(03/11/2005) One wifi laptop
(03/10/2005) Fed up of no WiFi(03/10/2005) Home WiFi security
(03/09/2005) Offline Folders, VPNs, & WiFi(02/17/2005) break Wifi ?
(02/16/2005) Prevent user from modifying WiFi settings(01/29/2005) Wifi Acer
(02/15/2005) aggravating wifi prob(01/22/2005) USR2216 WiFi card causes Win XP to crash - newbie need help!
(01/31/2005) win 64 asus wifi driver(01/12/2005) Hawking hi-gain antenna
(01/07/2005) Printer on WiFI?(01/02/2005) wifi - IE6 problem
(12/31/2004) Adding an Antenna Pigtail to a WiFi card(12/30/2004) Belkin WIFI Card
(12/23/2004) need help, new wifi extension has not internet and can't o..(12/22/2004) Hit & Miss Wifi
(12/17/2004) Basic WiFi Questions(12/04/2004) Mapped drive over WiFi network
(11/23/2004) UK: Wanadoo Wifi Bundle(11/14/2004) Netgear WGE101 Antenna
(11/19/2004) Sp2 + wifi: new headache(10/26/2008) WIFI connection randomly/non randomly disconnects
(10/20/2004) Is it better to use ASUS WiFi Network Setup software or Wi..(10/13/2004) Can I activesync through my wifi on my Ipaq 4150 not the b..
(10/14/2004) WiFi (ad hoc) network doesn't restore after night of logoff(10/06/2004) Best Wifi Cable router under £50?
(09/22/2004) auto switching from LAN to Wifi connection(09/20/2004) Watching movies over wifi
(09/16/2004) WiFi Hotspot Directory now includes over 12,000 sites incl..(10/02/2004) logon using Wireless/WiFI
(09/13/2004) Peer to peer wifi setup(09/12/2004) USR wifi & windows2000
(09/09/2004) Question for Barb Bowman: Wifi Activesync & SP2(08/18/2004) WiFi Continually Disconnects
(08/05/2004) Trouble staying connected to wifi(07/31/2004) connect to wifi not only getting autoconfig ip
(07/27/2004) Wifi can't find my router(07/24/2004) Free WiFi at Airports, how to use?
(07/20/2004) WiFi Bandwidth issue(07/18/2004) internet sharing via WiFi
(06/16/2004) wifi + games = lag(06/16/2004) recommendations for wifi unit as basestation only
(06/11/2004) wifi - can't ping other PC(06/02/2004) No connection with built-in WiFi antenna?
(08/08/2004) locking onto my own wifi signal(05/07/2004) Wifi connection lost
(05/29/2004) Midnight blues with WiFi(04/21/2004) Very large number of wifi clients
(04/28/2009) WiMAX CPE/WiFi AP combo(09/14/2005) IPAQ2200 WiFi Adaptor
(09/12/2005) Sprint Internet antenna with 802.11b?(09/06/2005) Proxim RangeLAN2 PCMCIA card external antenna?
(09/07/2005) PCMCIA with external antenna(09/06/2005) Antenna for GSM or CDMA cell phones?
(09/07/2005) WIFI questions(09/04/2005) WiFi Games?
(09/02/2005) securing laptop for public WiFi spots(08/30/2005) ICS problem on WiFi
(08/25/2005) USB wifi adapters(08/22/2005) Angle of antenna? Make any difference?
(08/23/2005) linksys antenna connector(08/24/2005) Trying to setup an offset antenna for wifi
(08/24/2005) Remote WiFi Printing? Is it possible(08/17/2005) internal wifi antenna
(08/15/2005) Wifi on/off switch stays lit-up when off(01/08/2005) Wireless Antenna
(01/08/2005) 2 Computers...1 Antenna?(01/06/2005) Wifi - connection drops when any security is enabled
(01/03/2005) WIFI in USA and UK(01/03/2005) WiFi v WLAN
(01/03/2005) pcmcia with external antenna(12/29/2004) Review of Mega-Wave WiFi 12dbi gain antenna wanted
(12/28/2004) WIFI works in Adhoc, but not in "Infrastructure mode"(12/22/2004) Best WIFI cards for PC?
(12/21/2004) parabolic antenna and AP on the same pole(12/18/2004) Antenna Construction Accuracy
(12/17/2004) WiFi and Bluetooth(12/16/2004) whats the best all in one wifi router/modem etc for extend..
(12/14/2004) uPNP - needed on WiFi router?(12/26/2004) AP External Antenna question?
(12/14/2004) WiFi Security for Semi-Public locations ?(12/11/2004) WiFi network with 1600Ft between two buildings
(12/20/2004) Wifi's on 2 Laptops don't detect each other even with nets..(12/06/2004) Best Antenna To Use To Extend Wireless Range As Far as Pos..
(12/09/2004) Hawking antenna and Linksys WRE54G Expander(12/20/2004) Netgear MR814v2 external antenna
(12/04/2004) Wifi + apps for sales force ?(12/03/2004) Wifi and Signal finder in one!!
(12/03/2004) wifi video trasmitting(12/03/2004) Multi-home wifi network setup suggestions
(12/04/2004) WiFi Interference: Is 802.11a and better than b/g ?(12/02/2004) FS: UK Lurker selling 3com PCI wifi cards cheap on ebay
(12/02/2004) Antenna Booster for Wireless Routers--can Linksys antenna ..(12/04/2004) Recommendations for high gain antenna for Linksys Router?
(12/01/2004) SD WiFi card(11/30/2004) Suggestions for Condo Wifi Network?
(11/29/2004) Using wifi to link laptop and main computer files?(11/29/2004) wifi power output
(11/29/2004) Can I put a directional antenna on my laptop?(11/27/2004) Netgear Antenna Removal
(11/28/2004) Multi-home wifi network setup suggestions(12/13/2004) parabolic antenna and beam width
(11/23/2004) wifi hates wired(11/18/2004) Need help with WaveLAN antenna connector
(11/15/2004) output of one antenna when other is off(11/14/2004) WiFi network setup problems
(11/12/2004) What's the cheapest WiFi AP ?(11/11/2004) connect desktop appl into wifi network
(11/13/2004) WiFi Finder Smart I D(11/09/2004) WiFi Data Errors
(11/09/2004) WiFi Data Errors(11/08/2004) USR2249 Antenna settings. what is what?
(11/04/2004) 802.11B PC Card with retractable or removable antenna(11/01/2004) Vonage Phone,Wifi, Traveling, with What Router?
(11/06/2004) WAL-MART WiFi(10/31/2004) HIGH power Cardbus Wifi
(11/05/2004) Rural wifi extension (again)(10/31/2004) Minimizing antenna lead loss
(10/27/2004) add antenna to wifi router or remote pc?(10/30/2004) Netgear DG834G + external antenna
(10/26/2004) General Wifi optimizing tricks(10/22/2004) Attaching External Antenna to Belkin F5D7130 Access Point?
(10/21/2004) Relocating the antenna(10/20/2004) My homebrew dongle reflector antenna extends laptop range,..
(10/19/2004) LAN/WiFi Network Plan(10/16/2004) LG Phenom WIFI card
(10/17/2004) getting wifi to work between rooms using multiple access p..(10/16/2004) Calculate Power of WiFi hardware - info
(10/14/2004) rural wifi extension(10/13/2004) Looking for cheapest way to set up wifi hotspot with payment
(10/04/2004) wifi drops after short time(10/02/2004) Suggestions for 5 mile squirt, local AP's and wifi custome..
(09/30/2004) porada - sygnal WiFi i jego podzial(09/30/2004) Metro WiFi and security?
(09/28/2004) WiFi and long term health issues(10/02/2004) Antenna or Range Extender?
(09/25/2004) PALM WIFI card & home wireless network(09/21/2004) If you have a free wifi hotspot you can add it to our dire..
(09/21/2004) Sputnik Inc. launches Hosted WiFI mgmt. service! Be a WISP!(09/22/2004) question about wireless strength/antenna/card
(09/21/2004) 3 sector antennas for sale! only 2hs left!(09/21/2004) Any tips in setting up 1 mile WiFi connection with Senao b..
(09/17/2004) A good DSL WIFI modem?(09/16/2004) WiFi Hotspot Directory now includes over 12,000 sites incl..
(09/18/2004) Using outdoor antenna with AP - should I leave take off in..(09/13/2004) wpc54g external antenna
(09/12/2004) WiFi US Deployments(09/14/2004) wifi bridge
(09/13/2004) Wifi shopping in the US(09/13/2004) Telephone calls over WiFi
(09/09/2004) Hawking HAI15SC HiGain Directional Corner Antenna 15dBi 2...(09/09/2004) Any good nationwide WiFi hotspot locators???
(09/09/2004) Smallest WiFi router?(09/07/2004) antenna extension
(09/24/2004) Wireless Gain Antenna for Wifi Card(09/10/2004) Philadelphia about to become one giant WiFi Hot Spot!!!
(09/01/2004) WIFI DXin(08/31/2004) WiFi PCI-card with packet-driver
(08/31/2004) WiFi Audio Streamer(08/31/2004) looking for hi gain antenna & signal amp
(08/30/2004) Antenna gain question(08/24/2004) Length of High Gain Antenna visible for LOS
(08/23/2004) Any try the SMC or Hawking 2X omni antenna?(08/22/2004) Numerous WiFi Accounts
(08/22/2004) Numerous WiFi Accounts?(08/21/2004) DWL-AB520 external antenna: Extend it?
(08/20/2004) Tungsten C and WiFi Connections(08/21/2004) Palm announced a WiFi card for the T-3 today!
(08/21/2004) WiFi Card for Windows 95?(08/18/2004) Wifi antennas
(08/17/2004) Security and open wifi hotspots(08/17/2004) IBM wifi card in non-IBM machines
(08/13/2004) Highest power USB dongle for poor mans wifi antenna set-up(08/14/2004) Antenna: AP or Computer?
(08/12/2004) Offline way to find Wifi Hotspots(08/10/2004) replacement antenna for wireless network card
(08/14/2004) wanted USB WiFi adapter(08/22/2004) wg111 netgear usb wifi anyone???
(10/28/2008) Should a yagi 2.4 GHz antenna appear to be short circuit a..(08/07/2004) Does weather effect Wifi in the home ?
(08/05/2004) My USB WiFi NIC freezes system on XP :((08/03/2004) ETG now with WiFi Hotspots
(08/03/2004) Wifi dropouts/ intermittent connection(07/31/2004) Antenna booster for internal wireless card? Will a Pringle..
(08/03/2004) PCMCIA card with eXternal Antenna connector(07/29/2004) Setting up a 24dBi antenna to my Senao card, couple questi..
(07/26/2004) Any good sites for vertical antenna designs?(07/26/2004) Big Problem With SENAO WiFi Access Point & WiFi Router .....
(07/26/2004) Wifi off standard DBS antenna used for TV?(07/25/2004) Free Wifi Hotspot Directory..best for offline way to get o..
(07/26/2004) Big Problem With SENAO WiFi Access Point & WiFi Router .....(07/26/2004) laptop wifi g help needed
(07/22/2004) Defcon Wifi Shootout Contest, Sponsors, Prizes!(07/24/2004) Can you find the antenna problem at the Homer Alaska Harbo..
(07/22/2004) where to buy WIFI antenna extenson cable(07/20/2004) WiFi on Tobago
(07/20/2004) FA: COMET X2427 2.4 GHz Directional Wi-Fi Antenna YAGI WiFi(07/20/2004) ADSL modem and WIFI Router
(07/26/2004) WiFi Compass(07/19/2004) cheap portable wifi solution
(07/18/2004) Add external antenna to SMC2635W PCMIA adapter(07/14/2004) Antenna for wireless G
(07/13/2004) NG WGT624, WG511T, two walls and antenna(07/08/2004) Random international wifi experiences
(07/07/2004) good wifi websites(07/16/2004) Who makes retractable antenna for laptop card?
(07/06/2004) Netgear MR814 Antenna(07/02/2004) How connect external antenna to acer aspire 1350
(06/29/2004) wifi recommendations in an apartment(06/26/2004) Help! Streaming rm/cfm radio via wifi Q
(07/01/2004) High Gain Antenna Kit for TNC Connectors(06/23/2004) Signal Pattern From a Router Dipole Antenna?
(06/23/2004) Which Antenna should I buy? 802.11x connection ~ 10km away!(06/24/2004) Good site for wifi router reviews?
(06/20/2004) Connecticut WiFi User Group(07/28/2004) Setting up a WIFI hotspot
(06/18/2004) Dell True Mobile 1300"G" WiFi Card/Notebook and Hotel WiFi..(06/16/2004) Belkin F5D6231-4 wifi router problems
(06/16/2004) Anyone ever used (or seen) a Cisco AIR-ANT2414SR sector an..(06/17/2004) how automatically desactivate wifi interface?
(06/15/2004) a/b/g card/router with removeable antenna(06/08/2004) ICS host with bridged, wifi client setup (?)
(07/02/2004) Traveling and taking WiFi equipment along.....(06/03/2004) Intsalling a Netgear WGT624 External Antenna?
(06/03/2004) What kind of foil when making home made antenna?(06/04/2004) Access Points vs. Antenna - Recomendation please
(05/27/2004) Antenna Orientation???(05/26/2004) linking a laptop to a desk top with wifi
(05/23/2004) Linksys BEFDSR41W router useless for wifi?(06/03/2004) long range wifi question
(05/24/2004) WiFi network of neighbour(05/27/2004) Sending mail on WIFI networks
(05/19/2004) External antenna with stronger front-to-back gain?(05/19/2004) AirPort Exterme ext. antenna in parallel?
(05/20/2004) antenna required for indoor use only?(05/17/2004) WLAN POWER ANTENNA
(05/15/2004) Orinoco Gold Antenna(05/16/2004) Wifi Newbie needs tips
(05/13/2004) Linksys BEFDSR41W useless for wifi?(05/09/2004) Upgrade Antenna???
(05/10/2004) Providing Free WiFi from Home(05/08/2004) Placement of wireless router and antenna configuration?
(05/09/2004) Fixed & WIFI Linksys Routers(05/08/2004) Merge multiple wifi APs and broadband into fat pipe
(05/07/2004) How Do I diagnose WiFi Interference Problems ?(05/05/2004) AP / Antenna Power Ratings ?
(05/05/2004) WiFi Ap keeps dropping ADSL connection(05/05/2004) NetGear Wifi Router problem
(05/03/2004) Wtd: wi-fi booster antenna in London UK(05/14/2004) SanDisk Connect Plus 128Mb+Wifi Compact Flash (SDWCFB-128)..
(05/03/2004) 1.9 gHz antenna(05/03/2004) Advice for a wifi newbie please.
(05/03/2004) WiFi & Win2K connection difficulties(05/05/2004) tin foil antenna
(05/10/2004) Need gateway app to sniff all network/wifi traffic
Sponsored links
