Different brands of AP's and cards - what to use?
More related threads to : Different brands of AP's and cards - what to use?
(11/24/2009) What does validating identity mean, a dir615 router, xp home(11/18/2009) Wifi cards for desktops
(11/17/2009) What is the best wireless ethernet adapter out there dollar for dollar?(11/12/2009) VPN connection problems in wireless data cards
(11/10/2009) What router disables wireless quick and easy?(11/01/2009) What Wireless equipment is compatible with 802 3ad ?
(10/28/2009) I set my netgear wep now what do i do(10/27/2009) What happens when router loses connection
(10/30/2009) What is my wpa passphrase(10/24/2009) Wireless router traffic monitoring for different users
(10/19/2009) Need advice what wireless router to buy(10/07/2009) Power ratings on notebook cards: an indicator of ability?
(10/05/2009) What is spi mode in a router(09/29/2009) Lag spikes every minute... what should I do?
(11/20/2009) What is the advantage of having a upnp wifi than normal wifi in a cell phone???(10/11/2009) New to home wireless:what do i do/need?
(09/23/2009) What is the BEST wireless 802.11n router?(09/23/2009) Set up my wireless network, what router, what networkcard in my laptop
(09/19/2009) Two wifi between to connect what range(10/30/2009) What is the best wareless rooter for gaming
(09/14/2009) What is the difference between 802 11b/g WLAN wireless AND Built in 802 11b/g WL(09/07/2009) Networking/wireless internet question- not really sure what to do
(08/24/2009) What to buy(08/23/2009) Pci wireless n cards!are they any good
(08/21/2009) What's the Issue?(08/20/2009) Two routers, no wifi cards, and a next door friend
(07/31/2009) What wireless card?(07/12/2009) Network w/ 2 PCI cards?
(06/29/2009) What do you recommend for this setup?(07/03/2009) Router that can view/allocate bandwidth to different computers?
(06/09/2009) What PCi card is best for me??(05/30/2009) What kind of wireless device do I need?
(05/19/2009) What Do You Think of Microsoft VirtualWiFi?(04/25/2009) What do I need to connect to this router?
(03/01/2009) High gain air cards(02/18/2009) What do I need to set up wireless internet on my PC and my PS3?
(02/17/2009) Cant connect to a network. What happen if two wireless cards.(02/10/2009) What hardware do I need for a large network?
(02/06/2009) What problems might there be?(01/30/2009) What are the best 802.11n routers band now?
(02/09/2009) What wireless adapter (PCI-E or USB) would you recommend?(01/21/2009) What's Wrong With my Internet??? :(((((
(01/04/2009) DBm to RSSI conversion for Dell Wireless cards(01/02/2009) What is the best Wireless G adapter (PCI or USB... whichever is better
(01/02/2009) What could be keeping my speed down?(11/09/2008) Can pc connect to two different wireless routers
(10/18/2008) What type of wireless router do I need? plz help me!(09/22/2008) Hot spot hopper... What to get?
(09/20/2008) which router - what adapters(08/27/2008) What is a good router to buy?
(09/22/2008) What Wireless PCI Card?(08/25/2008) Windows Vista 64bit compatible PCI network cards
(08/22/2008) What are the techniques which can be used to improve the accuracy ?(07/25/2008) What wireless router is best used with an Att DSL Modem?
(06/30/2008) Anyone know which MIMO enabled wireless cards work with Vista x64(04/18/2008) What is a more secure setting ?
(01/29/2008) looking for good reviews on wireless routers, what to buy?(01/29/2008) Wireless card to router with different brand?
(08/25/2008) What's wrong with my wireless connection?(12/30/2007) what is the max thoughput of wireless draft-n
(12/03/2007) What else would I need(11/01/2007) Can you mix and match different Antennas on a Multi Antenna Router
(08/22/2007) What would you say I should do?(08/07/2007) How many types of notebook cards are there???
(05/09/2007) What is going on with my Wireless network...!?(06/21/2007) What to replace my 2db antenna with on my DG834GT Router?
(03/11/2007) From cable tv to my PC wireless streaming? What do I need?(01/31/2007) KVM Switches - what to know?
(01/11/2007) What are the differences between Wifi and 802.11b/g?(01/03/2007) n, g, what?
(11/13/2006) What's wrong with my setup? I can't go anywhere...(11/03/2006) packet injection and monitor mode wifi cards
(10/17/2006) What is best to use? WWZC or manufacturer's software?(10/14/2009) I have a wifi lap top what do I do next?
(07/22/2006) Wireless cards with 64 bit support ?(11/13/2008) Have you used the USR 5453 access point? What doyou think?
(05/23/2006) ORiNOCO Cards and Void11(05/16/2006) What is the best wireless router for G connection?
(02/25/2006) two network cards as one?(01/31/2006) What hardware do you recommend for a bussiness network?
(04/02/2004) Screwy behavior from different wifi pc-cards(04/01/2004) Looking for old wireless cards.
(04/02/2004) Netgear Support. What a Joke!(09/25/2005) Difference In Wireless Cards?
(09/06/2006) Wireless cards can't be installed--"Cannot find file speci..(08/13/2005) Newbie question - what kit do I need?
(08/24/2005) What are risks of WLAN connections at internet cafes?(08/08/2005) Is what I want to buy even out there?
(08/10/2005) What is Ethernet?(07/29/2005) connecting both computers with different operating system ..
(06/30/2005) accesss denied on downstairs computer. what is node type "..(06/12/2005) different LAN Properties???
(07/11/2005) What XML is supposed to be sent back after WPS signup?(05/11/2005) USB Network Cards and Logon Issues
(05/11/2005) what kind of client do i need ??(04/27/2005) Wireless Network and Wired LAN on different subnets
(04/19/2005) "Modem Secure"? What password to use?(03/23/2005) What Is ZigBee?
(02/17/2005) Windows XP Wireless Problem with Orinoco Cards(01/31/2005) Router problems of a different kind
(01/24/2005) what is the dos command to view available wireless network?(01/08/2005) What is a channel?
(01/08/2005) What are channels?(12/30/2004) What is the 3rd group of #'s in an IP address and why do t..
(12/14/2004) What is the radius of the single of the router???(12/18/2004) Attn. MVPs/MSFT - Q: different authentication methods for ..
(11/17/2004) what is the ad_hoc network?(11/14/2004) Do the client cards support PCF
(10/31/2004) Replacing UTP with wireless, what equipment?(11/03/2004) Longhorn Wireless Diagnostics: What's important to you?
(10/20/2004) 2 NIC cards in one XP cpu(10/13/2004) With 2PC AND 2WiFi Cards Can I Set Up Network?
(10/11/2004) What type of Certificate server?(10/13/2004) so... what's the trick in getting wireless working on Serv..
(08/25/2004) what is a 1394 connection and a Network Bridge?(08/11/2004) Client managers and Mini Cards.
(07/31/2004) Seeking advice on what to buy for Win98/XP home network...(07/26/2004) Problems with EAP-TLS with smart cards
(07/14/2004) Wireless, what else?(06/26/2004) What's the IEEE 802.11?
(06/08/2004) Cisco Aironet cards and WinXP(06/01/2004) What software can I use to configure Wireless settings
(05/31/2004) Using 2 wireless network cards in 1 laptop(04/21/2004) What do I need for LAN/ICS via Bluetooth
(04/23/2004) What is good wireless hardware to connect PC to TV(04/22/2004) Windows XP switches to different Access point
(09/06/2005) Can Linksys WAP11 v1.07 (4/16/2003) tell which what device..(08/26/2005) Being Invisible & cards for Mandrake
(08/29/2005) What am I doing wrong???(08/12/2005) Adding DSL to existing wireless network but in different r..
(01/08/2005) What is this connector?(01/04/2005) Raylink wireless cards to an access point
(12/28/2004) What Best USB 54G Adapter for a Desktop?(12/27/2004) sniffer and supported wireless cards
(12/22/2004) Best WIFI cards for PC?(12/22/2004) What to use?
(01/08/2005) What is a wireless repeater?(12/21/2004) What is a wireless repeater?
(12/20/2004) What happens when an 810.11g AP has "b" and "g" clients at..(12/19/2004) What are typical ping times for a WLAN?
(12/21/2004) What are typical ping times for a WLAN?(12/17/2004) What distance to expect
(12/13/2004) What can they see?(12/10/2004) Output from pinging in MS-DOS window. What does it mean?
(12/12/2004) Cisco 350 vs cheaper brands(12/04/2004) To what use(s) could I put a second wireless router?
(12/02/2004) FS: UK Lurker selling 3com PCI wifi cards cheap on ebay(11/14/2004) support for PCF in 802.11 WLAN cards
(11/17/2004) PC Cards for iPAQ(11/12/2004) What's the cheapest WiFi AP ?
(11/11/2004) Have to keep restarting cable modem,: What does this mean?(11/09/2004) what's a repeater?
(11/09/2004) PCMCIA Cards at 108Mbps & D-Link Router(11/08/2004) PCMCIA Cards at 108Mbps & D-Link Router
(11/08/2004) USR2249 Antenna settings. what is what?(11/01/2004) Vonage Phone,Wifi, Traveling, with What Router?
(10/27/2004) Belkin Pre-802.11n Access Point and client cards(10/17/2004) WiMax and HiperMan;What are they realy about?
(10/12/2004) Realtek 8180 PCI cards losing wireless connection(10/04/2004) What authentication system?
(10/08/2004) What is diff between DLink DWL-G810 and DWL-2100AP bridges?(09/27/2004) Want to set up wireless network in house - what do I need?
(09/24/2004) Help on setting up a different home network(09/23/2004) Bridging 2 small workgroups - what to buy?
(09/23/2004) So what's the reccomended wireless solution these days?(09/05/2004) What would you recommend for AP
(09/06/2004) What happens if someone fakes an existing MAC address?(09/02/2004) What is a bridge - and do I need one?
(08/31/2004) Comparing min-pci cards in practical application(08/31/2004) Compareing min-pci cards in pratical aplication
(09/03/2004) Where to find internal 802.11g or combo centrino cards for..(08/29/2004) Bad Netgear WG111 or what?
(08/29/2004) New Wireless Router - What you recommend?(08/25/2004) swapping cards in an AP
(08/24/2004) same card, different computer, different results(08/20/2004) the dell 1170 wireless base station - What is the deal??
(08/11/2004) rebranded orinoco cards(08/11/2004) Mix Matching Brands
(08/09/2004) Choosing between two 3com xjack cards(08/10/2004) 2 wireless cards / DSL / problem
(08/08/2004) What do you guys think of Netgear FWG114P?(08/07/2004) RF Survey -- what's involved or how to do it??
(07/29/2004) What is the diff between Cisco AIR-BR340 and AIR-BR342?(07/30/2004) What is a BEACON SCANNER ?
(07/22/2004) APs that work well with Orinoco cards?(07/19/2004) What am I doing wrong ?
(07/18/2004) what is "interference robustness"?(07/15/2004) What's the scoop on Broadcom's 125
(07/15/2004) What s a "good" signal?(07/14/2004) What do you thin about ORINOCO AP 600 ?
(07/12/2004) Linksys.....what have I got here?(07/08/2004) What gateway?
(07/04/2004) Behavioral Differences Among Cards(07/03/2004) two cards only?
(07/02/2004) what would it take to network range of 2 KM(06/30/2004) What happens to the 'old' wireless numbers?
(06/30/2004) Wireless G Cards(06/30/2004) Slow 54Mbps G network - what are typical speeds?
(06/24/2004) Question about Wireless cards(06/17/2004) What so I need?
(06/12/2004) What's the best wireless solution for interstate travel?(06/13/2004) What am I doing wrong???
(06/08/2004) A Different "Router drops connection" Problem(06/03/2004) what interferes with what?
(06/03/2004) What kind of foil when making home made antenna?(05/28/2004) what exactly is a router doing, when you enable l2tp pass-..
(05/26/2004) di-614+ and dwl-800ap+ give out different IPs?(05/25/2004) 200mW PC Cards???
(05/17/2004) BEFSW11 experiences? What's more reliable?(05/09/2004) Odd problem with my pcmcia 802.11b cards
(04/26/2004) what routers tlel you how many bytes on wan port(04/25/2004) What's missing in my WAP setup?
(04/28/2004) PCMCIA type I (16 bit) wi-fi cards?(04/20/2004) Linksys router/Adelphia Powerlink -- what software needs t..
(04/15/2004) G PCI Cards(04/14/2004) What kind of problem is this?
(04/14/2004) What's the most recommended hardware for setting up a wire..(04/15/2004) what brands of sleeping tents do you recommend???
(04/08/2004) What wireless equipment to add to small business(04/05/2004) What if they sell WAP with enbled WEP by default?
(07/15/2005) not sure what to buy?(04/11/2005) What do these symptoms sound like?
(07/09/2004) What's the difference?(06/19/2004) internal laptop wireless cards
(06/03/2004) What's the best way to do printing wireless?(05/20/2004) Help On What To Buy
(05/07/2004) 802.11B or G - What to install for home network(02/01/2004) dwl-900ap+ d-link help with range or what ?
(02/14/2004) wireless notebook cards(12/09/2003) Newbie question...what do I need?
(11/04/2003) what is wi-fi?(10/10/2003) ETSI firmware for Orinoco cards?
(09/05/2003) MiniPCI WLAN cards question(06/22/2003) LinkSys A+G Wireless Cards -- NO WEP With XP Pro
(06/19/2003) What do i need?(06/28/2003) Cox cable and wireless router, what to get?
(05/15/2003) What is the gain on standard D-link antennas?(04/26/2003) What the heck does this mean?
(02/07/2003) what do you recommend?(10/17/2002) ?what's wireless between friends?
(08/30/2002) Wireless home network - what do I need?
Sponsored links
