Tom's Hardware: Topic Should a yagi 2.4 GHz antenna appear to be short circuit a..
Tom's Guide
Tom's Games
TOM'S HARDWARE GUIDE Worldwide
Tom's Hardware France
Tom's Hardware Italy
Tom's Hardware China
Tom's Hardware Taiwan
Tom's Hardware Poland
Tom's Hardware Russia
Tom's Hardware Sweden
Tom's Hardware Turkey
Tom's Hardware Germany
Tom's Hardware UK
Tom's Hardware Ireland
Tom's Hardware Hungary
Tom's Hardware US
TOM'S HARDWARE
SEARCH
OK
RSS
Mobile
Join
Sign In
Home
Articles
News
Forums
Charts
Business
Resources
White papers
Compare Prices
Focus On
Holiday Gift Guides from Tom's
Feel the Love & Check Our Lists Twice
Tom's Hardware
Forum
Wireless Networking
Tom's Hardware: Over 1.4 million members in 6 different countries available to answer all your
high-tech
questions.
Sign up now
! Its free!
More related threads to : Should a yagi 2.4 GHz antenna appear to be short circuit a..
(11/27/2009)
Removing the antenna on belkin router
(11/12/2009)
Will yagi antenna work on a usb router
(10/24/2009)
Connect wireless antenna to lynksys wcg200
(10/09/2009)
Antenna advice
(10/03/2009)
Can a wireless router be used as a wifi antenna
(09/29/2009)
Lag spikes every minute... what should I do?
(09/17/2009)
Toshiba bluetooth does not appear in connections for palm 650
(09/14/2009)
Inhouse wireless antenna for cellular phone
(08/10/2009)
Where should i look to find my wep code
(07/04/2009)
Wrt54g dual outdoor antenna?
(06/02/2009)
UMTS antenna cable
(05/09/2009)
Can this computor pick up wireless internet from my modem? or should i go buy a
(05/11/2009)
Using a USB adapter w/SMA antenna
(02/15/2009)
ZyXEL P600 Antenna?
(02/10/2009)
Add an antenna to a D-Link DWA-643 ExpressCard?
(10/04/2008)
Antenna upgrade, how many on n router?
(09/12/2008)
Wireless connection not as fast as is should be
(09/07/2008)
Better Antenna or New Adapter?
(08/08/2008)
Wi-Fi Antenna
(07/08/2008)
USB wireless dongle external antenna
(07/05/2008)
Replacement antenna for Actiontec M1424WR ?
(06/30/2008)
wireless/ and circuit box
(06/22/2008)
Should I upgrade my router?
(11/01/2007)
Can you mix and match different Antennas on a Multi Antenna Router
(10/08/2007)
Upgrading to 802.11n, should old stuff be stay on 802.11b?
(08/26/2007)
Which method should I choose?
(08/22/2007)
What would you say I should do?
(07/18/2007)
Dell notebooks and 5 Ghz router
(06/09/2007)
2.4GHz 5dBi Wireless Magnetic External Antenna
(06/14/2007)
If you wanna make a DIY antenna
(05/28/2007)
Where can you buy extended length Dipole Antenna Cable?
(04/13/2007)
5 gallon directional antenna
(06/21/2007)
What to replace my 2db antenna with on my DG834GT Router?
(03/02/2007)
How to attach Linksys high gain antenna to laptop?
(03/01/2007)
Confused antenna help.
(02/06/2007)
Wi-Fi Nic with external antenna adapter recomendations
(12/17/2006)
Antenna Range
(12/17/2006)
Suggestions for setup? Antenna Question
(01/03/2007)
External wireless antenna for a laptop?
(11/26/2006)
Mimo or larger Antenna?
(11/06/2006)
Making my own bad ass wireless antenna help?
(09/19/2006)
Mounting a wireless antenna outside?
(08/14/2006)
Trying to fix a wireless Antenna
(09/03/2006)
which wireless mini-PCI card should I buy?
(09/12/2006)
Difference between antenna
(03/17/2009)
Belkin Wireless USB Antenna
(04/27/2006)
Laptop Antenna
(04/24/2006)
HELP ! Linksys WAP54G + 7Dbi Antenna = ? % Signal
(04/15/2006)
dual antenna setup - is this possible?
(05/25/2006)
Which router and Adapter should I buy???(for restaurant use)
(09/13/2005)
Attaching antenna to Belkin 802.11g PCMCIA card
(04/03/2004)
Poor wireless speeds (Yagi's and DWL-2000 AP's)
(04/01/2004)
SWR at 2.4 Ghz
(09/20/2005)
Use Directional Antenna (or help in general)
(09/21/2005)
Are MC and MMX antenna connectors (about) the same?
(10/15/2009)
PCMCIA wireless network card with external antenna ?
(01/08/2006)
Antenna
(09/08/2005)
antenna extension?
(07/21/2005)
Should I Bridge?
(06/19/2005)
Wireless connection requires "REPAIR" after short time on ..
(03/20/2005)
Dual Antenna fitted to an AP - Possible??
(03/17/2005)
MN-700 Base Station - adding a signal booster or antenna
(03/19/2005)
Proxim ORiNOCO PC GOLD CARD with antenna problem??!!
(01/14/2005)
Wireless distance far too short
(01/12/2005)
Hawking hi-gain antenna
(12/31/2004)
Adding an Antenna Pigtail to a WiFi card
(11/14/2004)
Netgear WGE101 Antenna
(09/24/2004)
2.4 Ghz phone interference
(06/02/2004)
No connection with built-in WiFi antenna?
(09/12/2005)
Sprint Internet antenna with 802.11b?
(09/06/2005)
Proxim RangeLAN2 PCMCIA card external antenna?
(09/07/2005)
PCMCIA with external antenna
(09/06/2005)
Antenna for GSM or CDMA cell phones?
(08/22/2005)
Angle of antenna? Make any difference?
(08/23/2005)
linksys antenna connector
(08/24/2005)
Trying to setup an offset antenna for wifi
(08/17/2005)
internal wifi antenna
(01/08/2005)
Wireless Antenna
(01/08/2005)
2 Computers...1 Antenna?
(01/08/2005)
Getting short random disconnects... And is there a way to ..
(12/31/2004)
Best 5 GHz Client Card ?
(01/03/2005)
pcmcia with external antenna
(12/29/2004)
Review of Mega-Wave WiFi 12dbi gain antenna wanted
(12/21/2004)
parabolic antenna and AP on the same pole
(12/18/2004)
Antenna Construction Accuracy
(12/26/2004)
AP External Antenna question?
(12/06/2004)
Best Antenna To Use To Extend Wireless Range As Far as Pos..
(12/09/2004)
Hawking antenna and Linksys WRE54G Expander
(12/20/2004)
Netgear MR814v2 external antenna
(12/02/2004)
Antenna Booster for Wireless Routers--can Linksys antenna ..
(12/04/2004)
Recommendations for high gain antenna for Linksys Router?
(11/29/2004)
Can I put a directional antenna on my laptop?
(11/27/2004)
Netgear Antenna Removal
(12/21/2004)
2.4 cordless phone and 2.4g network
(12/13/2004)
parabolic antenna and beam width
(11/18/2004)
Need help with WaveLAN antenna connector
(11/15/2004)
output of one antenna when other is off
(11/08/2004)
USR2249 Antenna settings. what is what?
(11/04/2004)
802.11B PC Card with retractable or removable antenna
(10/30/2004)
802.11a and 5.8 GHz cordless phone
(10/31/2004)
Minimizing antenna lead loss
(10/27/2004)
add antenna to wifi router or remote pc?
(10/30/2004)
Netgear DG834G + external antenna
(10/22/2004)
Attaching External Antenna to Belkin F5D7130 Access Point?
(10/21/2004)
Relocating the antenna
(10/20/2004)
My homebrew dongle reflector antenna extends laptop range,..
(10/17/2004)
Corega + ASUS = short range?
(10/04/2004)
wifi drops after short time
(10/02/2004)
When to Use 2.4 GHz Bandpass Filter
(10/02/2004)
Antenna or Range Extender?
(09/22/2004)
question about wireless strength/antenna/card
(09/18/2004)
Using outdoor antenna with AP - should I leave take off in..
(09/13/2004)
wpc54g external antenna
(09/09/2004)
Hawking HAI15SC HiGain Directional Corner Antenna 15dBi 2...
(09/07/2004)
antenna extension
(09/24/2004)
Wireless Gain Antenna for Wifi Card
(09/04/2004)
Spanning Tree - 5 GHz Link with 2.4 GHz Backup
(08/31/2004)
looking for hi gain antenna & signal amp
(08/30/2004)
Antenna gain question
(08/26/2004)
Yagi Antennas
(08/26/2004)
is this group restricted to short distances?
(08/24/2004)
Length of High Gain Antenna visible for LOS
(08/23/2004)
Any try the SMC or Hawking 2X omni antenna?
(08/21/2004)
DWL-AB520 external antenna: Extend it?
(08/20/2004)
building instructions for OMNI @ 2.4 :)
(08/17/2004)
Slow connecction/short range
(08/13/2004)
Highest power USB dongle for poor mans wifi antenna set-up
(08/14/2004)
Antenna: AP or Computer?
(08/10/2004)
replacement antenna for wireless network card
(07/31/2004)
Antenna booster for internal wireless card? Will a Pringle..
(08/03/2004)
PCMCIA card with eXternal Antenna connector
(07/29/2004)
Setting up a 24dBi antenna to my Senao card, couple questi..
(07/28/2004)
Easy/cheap short range 802.11a point-to-point bridging?
(07/26/2004)
Any good sites for vertical antenna designs?
(08/13/2004)
2.4 Ghz wireless networking and wireless phones
(07/25/2004)
FA: A 2.4 GHz 1 Watt Bi-Directional Wi-Fi Signal Amplifier..
(07/26/2004)
Wifi off standard DBS antenna used for TV?
(07/24/2004)
Can you find the antenna problem at the Homer Alaska Harbo..
(07/22/2004)
where to buy WIFI antenna extenson cable
(07/20/2004)
FA: 2.4 GHz 1 Watt Bi-Directional Wi-Fi Signal Amplifier W..
(07/20/2004)
FA: COMET X2427 2.4 GHz Directional Wi-Fi Antenna YAGI WiFi
(07/18/2004)
Add external antenna to SMC2635W PCMIA adapter
(07/14/2004)
Antenna for wireless G
(07/13/2004)
NG WGT624, WG511T, two walls and antenna
(07/10/2004)
Homemade Sector WiFi Antenna?
(07/09/2004)
5.x GHz Solid vs. Grid Dish / Equinox vs. Pacific Wireless
(07/16/2004)
Who makes retractable antenna for laptop card?
(07/06/2004)
Netgear MR814 Antenna
(07/02/2004)
How connect external antenna to acer aspire 1350
(06/27/2004)
Linksys 4 port wireless router, 2.4 GHz
(07/01/2004)
High Gain Antenna Kit for TNC Connectors
(06/23/2004)
Signal Pattern From a Router Dipole Antenna?
(06/23/2004)
Which Antenna should I buy? 802.11x connection ~ 10km away!
(07/03/2004)
Short distance point-to-point connection between homes
(06/15/2004)
a/b/g card/router with removeable antenna
(06/03/2004)
Intsalling a Netgear WGT624 External Antenna?
(06/03/2004)
What kind of foil when making home made antenna?
(06/04/2004)
Access Points vs. Antenna - Recomendation please
(05/27/2004)
Antenna Orientation???
(05/19/2004)
External antenna with stronger front-to-back gain?
(05/19/2004)
AirPort Exterme ext. antenna in parallel?
(05/20/2004)
antenna required for indoor use only?
(05/17/2004)
WLAN POWER ANTENNA
(05/15/2004)
Orinoco Gold Antenna
(05/09/2004)
Upgrade Antenna???
(05/08/2004)
Placement of wireless router and antenna configuration?
(05/05/2004)
AP / Antenna Power Ratings ?
(05/03/2004)
Wtd: wi-fi booster antenna in London UK
(05/03/2004)
1.9 gHz antenna
(05/05/2004)
tin foil antenna
(04/30/2004)
Omni or Yagi for wardriving
(08/30/2004)
Should I use neighbors' internet access?
(04/19/2004)
How to set up a parabolic antenna WLAN
(04/15/2004)
Which onboard antenna connector WET11 v2?
(04/14/2004)
Newbie: Wifi External Antenna to Cable Modem?
(04/12/2004)
Netgear WGR614 Antenna Question
(04/06/2004)
PCMCIA 802.11g w/antenna connector & netstumbler support?
(08/19/2004)
Antenna concepts and basic question
(07/23/2004)
Should I get a wireless? Help!
(01/16/2004)
A "little" problem for antenna
(11/06/2003)
a/b/g and/or external antenna
(11/03/2003)
Aerialix wireless Antenna vs Fab-corp's Antenna
(07/17/2003)
Antenna question
(07/04/2003)
one antenna or two
(06/11/2003)
Short distance Wireless Link
(06/11/2003)
Antenna DIY
(05/30/2003)
Antenna upgrade - Microsoft MN500
(04/08/2003)
Antenna direction
(03/27/2003)
Will a 11b antenna work for 11g
(02/15/2003)
BEFW11S4 antenna selection
(12/21/2002)
paying for research with logitech 2.4 gig joystick
Forum map
Bestofmedia Forum ©
2000-2009 Bestofmedia Group
Sponsored links
Ask the community now
Message title:
Before asking a question, you can search for existing answers using the search field located at the top section of this site page. When writing your question, please be as detailed as possible for the best results.
Ask your question:
Category:
Sub-category:
Publish
Related Topics
See all relatives topics
