HAF X top mount radiator but keeping the top 200mm fans in place?
- HAF XB + Intel 4th Gen + NH-C14 + i115x Mounting Kit + 200mm Top Exhaust Fan = Airflow problem? - Forum
- Planning to add a 2nd top 200mm fan to my Cooler Master HAF-X case. Bad idea? - Forum
- Coolermaster HAF 922 case - Possible to mount EX360 radiator on top of the case? - Forum
- How to mount top 200mm fan in CM 690 III - Forum
- Push/Pull with (x2) 200mm fans on top, and (x2) 120mm fans on bottom? - Forum
- Cooler Master HAF XB + 200mm fan on top+ 160mm cooler? Forum
- HAF XM 200mm top fan not spinning while in use Forum
- HAF XM dual 200mm top fan, can't get cover back on Forum
- Looking for help with top/horizontal mounted 200mm fans Forum
- Can the Corsair H50 be mounted on the top fan slot of the HAF X case? Forum
- 230mm Side Fan - 2x 200mm Top fans - Thermaltake Chaser MK-1 Forum
- 200mm top exhaust fan mounting in Antec 902 Forum
- Top fans on haf x not needed with h100i Forum
- Is having 2 200mm top outtake fans better than having 3 120mm fans? Forum
- I need 2 200mm Intake fans at the top of my case what should i get? Forum
- Would It be better to have 2 200mm or 3 120mm fans in the top? Forum
- SolvedAny good 200mm ball bearing fans for horizontal use on case top? Forum
- SolvedCan I remove the top 200mm fan? NZXT Phantom Forum
- SolvedShould I get another 200mm fan on the top of my case? Forum
- 140mm radiator in the top of HAF 912? Forum
- More resources
Read discussions in other Overclocking categories
)being that there is not a way to seal the top unless you install everything below the case metal, there is no cause for matching size. The RS/RX360 is a low FPI rad. in other words, lower speed works better. the stock fans with Raystorm kits actually show best match to TDP with that rad. Given a lower rpm, mid CFM, mid static pressure is best, slight modification using a fan controller provides excellent result in a push config. (approx 16-1800rpm on stock fans - 2k and up show loss of TDP) The 200mm fans above, being in a non sealed config, simply aid in air movement and exhaust. Minimal improvement is seen using them and no hinderence. However, they do function in case airflow still, so serve dual purpose, and therefore are in fact an aid to the system as a whole. Curious still? Go to frozencpu.com - they sell a HAF-X with this exact config predesigned with an RS360 kit. I have chatted a bit with them and their design shows the same results i researched on the net.
