Hello I recently built a new Rig. Using a Sapphire 7970.
For the last three years with an old computer. I've used a DvI connection to a phillips tv and it's worked perfectly. It worked with the new card too.
I experimented with Dual screens using the HDMI port and the DvI port. It worked but the HDMI caused the TV(the only monitor/tv with HDMI port) to go blue and pink.
http://25.media.tumblr.com/5fae45bd39a2b18a195355cb41d917ed/tumblr_mjkfxuQXVv1qf214po1_500.jpg
http://24.media.tumblr.com/144b518ac0291a26ffb12ecaffc7fca2/tumblr_mjkfxuQXVv1qf214po2_1280.jpg
See links for difference. Which I now just assume to be a problem with the Tv that I cannot fix.
So I decided to try use the Dvi-D slot running to the TV like I've used the DvI port for so long but It won't work. Neither monitor I have will register any signal from the DvI-D port.
I am at a loss as to how I get get dual screens working.
If anyone could help I'd really appreciate it.
