I have 8 GB of trident ram running in my p9x79 pro but the ram isn't running at the speeds newegg says. I know I have to change the settings in the bios to get the ram to run at ddr3 2400 speed but the cas latency isn't the same. Heres what I'm talking about: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231638
CPU-Z says its running at 800.5 MHZ and the cas is 11
So in the bios I should up the speed to 2400 MHZ and the CL down to 9 right?
