Does FiOS Speed Optimizer work?
Hashio
171
Hello, I am curious if anyone has used FiOS Speed Optimizer without any issues? I am tempted to try it but I am afraid it might screw up my setting badly and won't be able to change it(I am not a network expert). My current Fios plan is 75/35mps(although on speed test it shows 83.05/35.33Mbps)
Before you try it, backup this whole registry key HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip
According to FIOS, the changes they make are inside there. If you don't like something, restore the backup .reg file you made and it's back to how it was.
