Some years ago I built a water cooled system but didn't care for it much as it was loud and that was when water cooling was in its infancy.
I'm wanting to cool the CPU and the two GPU's and have a couple of preliminary questions as I plan this out.
1. Does it make sense to cool the CPU and two GPUs using one line? (I'm not sure if people use two lines or not.)
2. With my lack of experience should I invest the hours to learn about all of the water cooling methods and equipment available or does it make sense to purchase one or two water cooling kits?
3. In the past I was told that water cooling kits were of cheaper quality. Is that still the case?
4.Will using a kit make it easier for me to accomplish what I want to do here?
5. Does anyone have first hand experience installing water cooling in the case I mentioned above?
The primary goal of this computer is silence. At some future point I will also play with overclocking but not right away and I'm set it and forget it when it comes to OCing.
