First Build Parts list, critiques welcome
SpazticPorpoise
First off, I want to let you all know that i am a complete noob when it comes to computers. I've wanted to build a PC for a while, so i put together a parts list. One of my friends helped me put it together, but i am willing to make any changes that are necessary.
Here's the list: http://pcpartpicker.com/p/KQMu
I dont want to spend more than $1000, and if any money can be spared, it would be much appreciated. I also don't plan on building this until midsummer/fall, so it isnt urgent.
monitor
http://us.ncix.com/products/?sku=64579&vpn=VS228H%2DP&manufacture=ASUS&promoid=1293
the rest
http://pcpartpicker.com/p/L6QW
its over a 1000 dollars, but performs waay better than what you have put together. you will need the larger SSD if you want to put some real apps on a SSD. if you dont want to spend that much, you can get this and setup Intel SRT to use the SSD as a cache
http://us.ncix.com/products/?sku=75140&vpn=SDSSDP%2D064G%2DG25&manufacture=SANDISK&promoid=1293
if you need a dvd drive, here
http://us.ncix.com/products/?sku=49597&vpn=DRW%2D24B1ST%20Bulk&manufacture=ASUS&promoid=1293
wifi. really dont recommend wifi
http://us.ncix.com/products/?sku=48083&vpn=TEW-649UB&manufacture=TRENDnet&promoid=1293
SpazticPorpoise
thanks for the help! i really appreciate it. However, won't this overheat? would a full tower suit it better? or will the stock fan do?
also, how do you set up the ssd as a cache?
no it wont overheat. i can cram it into a even smaller itx case (assuming i use a itx board) and it would run fine. there is no reason to get a full tower unless you are watercooling
instruction manual should have details
