Hi, apologies if this is in the wrong place. Didn't see a forum for help.
Anyways, I just finished with my first build and all went fine and dandy (except a few stupid mistakes by yours truly).
I turned on the power supply, put my HDMI cable into my graphics card, and pressed the power button. When I pressed it, the case/cpu fans turned on, but still no signal on my tv. Few seconds later, the case/cpu fans turn off, and then another couple seconds later they turn back on. They keep doing this until I turn off the power supply manually. I dunno what I'm doing wrong, I've followed several tutorials on the youtubez. I'm not sure if it's the HDMI cable, or if it's the GPU or whatever it is. Any help would be appreciated
Thanks,
Uehm
E2: Okay, I switched the memory slots and it appears to be semi-working. The fans don't turn off anymore, only when I want them to. The only problem still is the HDMI. My tv still won't ready the signal, even though it's powered on. I got no beeps at all this time even though everything is plugged in.
Thanks,
Uehm
