Hi all,
Recently built a new PC. My audio however, was noticeably choppy whenever there was audio output. After troubleshooting and reading around the topic I noticed that others were having similar troubles but without any real solution. After running the 'DPC Latency Checker' and receiving the error message instructing me to disable certain devices I still was without luck. Eventually I isolated the issue. My audio runs perfectly smooth when not displaying in 1080p HDMI at 60Hz. Does anyone have any solutions to this problem? I'm considering buying a new monitor anyway so maybe this will fix my troubles.
TL;DR: Audio choppy in 1080p 60Hz, runs perfectly smooth at any other resolution/refresh rate.
Thanks in advance!
EDIT:Using my monitors internal speakers for sound via my HDMI cable.
EDIT 2: I don't know how to pick my own response as the solution so I just chose the first response.
Thanks in advance!
