Can a 180watt Power Supply run an AMD Radeon HD 6570
  • Power Supplies
  • AMD
  • HD
  • Radeon
  • Graphics
March 23, 2013 3:52:13 AM
So i have this pc that's pretty weak, i've decided to upgrade it's graphic card to hd 6570 to atleast play skyrim
Here are the detailed spec:
slim tower Lenovo h330
i3-3100 processor
AMD Radeon hd 6450
4gb RAM
180watt power supply
Will an AMD Radeon 6570 be able to run on my desktop
(it has a smaller x16 slot than standard, people say it requires a low profile card)
More about : 180watt power supply run amd radeon 6570
a b ) Power supply
a b À AMD
March 23, 2013 4:00:21 AM
Tell us +12v ratings of psu
March 23, 2013 9:12:39 AM
You trying to see how low a PC budget can go, son?
March 30, 2013 11:35:45 PM
frederick930 said:
Im currently out of town, will be back hopefully tommorow, but as i remember the psu had some chinese gibberish in it, i cant even search the company.
http://www.lenovo.com/shop/americas/content/pdf/system_...
That's the spec of the pc, mine is the one with 180w psu variant, if that helps in any way.
Do you expect that the card can be OC'ed? IF yes, then get an branded 350-450 watt PSU now. With that even the 660 Ti can be run on.
a b ) Power supply
a b À AMD
March 31, 2013 12:28:29 AM
It's probably going to struggle in Skyrim even with a 6570...
Looks like a workstation kind of PC, not meant for gaming. Also 180w is dangerously low for a more powerful graphics card.
October 19, 2013 7:57:27 AM
you're damn right. :D
