Hey.
I'm running the latest Catalyst 13.1 drivers for my XFX R7950 DD, and my monitor is an LED Philips 226V (native resolution of 1920x1080 @ 16:9). I can't figure out how to allow games to run at custom resolutions - or if it's even possible.
The problem occurs mainly in older games that run at a native resolution of 1024x768. I want to run these games at the available resolutions without my image being stretched across the screen to create a blurry, stretched picture fill. Is there a way to keep the aspect ratio and resolution within the center of the screen?
I was able to do it on my old computer (nvidia geforce 9200)/monitor. Is it a problem with Radeon cards?
I'm unable to locate any option that allows you to change anything to do with scaling or GPU scaling within my drivers. Any help/advice? Thanks.
