Closed
Logitec Solves Ultrabook Problem: Connectivity
Logitec is releasing two USB hubs that should solve the majority of connectivity problems that Ultrabooks and ultrathins face.
Logitec Solves Ultrabook Problem: Connectivity : Read more
15 answers Last reply
More about logitec solves ultrabook problem connectivity
  1. My Surface Pro will get major benefit from them when on the road. We shall see how the price is...
  2. I really feel that the company names is just a lawsuit waiting to happen. It's also one of the few justified ones, and both companies would benefit by not being associated with the others problems.
  3. I was cringing so much reading Logitec until you guys mentioned that it is a different company.
  4. So, is there also a company named Logitek?
  5. In Japan, Logitech is called LogiCool.
  6. JOSHSKORNSo, is there also a company named Logitek?
    From a simple Google search it seems there are at least 5 companies under that name
  7. lp231In Japan, Logitech is called LogiCool.
    Looks like Logitech was founded Oct 1981, while Logitec was founded June 1982 but the parent company has been using the name since 1974.
    http://en.wikipedia.org/wiki/Logitech
    http://ja.wikipedia.org/wiki/%E3%83%AD%E3%82%B8%E3%83%86%E3%83%83%E3%82%AF
    So likely Logitech owns the trademark on the name in the U.S. and probably most of the world, while Logitec owns it in Japan (hence why Logitech changed their name in Japan). Sorta like how gmail is called googlemail in Germany because another company owns the trademark to gmail there. Fun, fun, fun.
    Personally I'd like to see the old x-jack connector (from PCMCIA cards in the 1990s) revived for ethernet ports on ultrabooks. It's spring-loaded and pops out/in when you press it. Despite how fragile it looks, it survived several drops of my laptop onto it without breaking. And several times when I tripped over the LAN cable it ended up yanking the PCMCIA card out and dumping the laptop on the ground (Thinkpads FTW), instead of breaking the jack.
    http://en.wikipedia.org/wiki/File:XJACK_network_card_extended.jpg
  8. Go Logitech!
  9. Haha, people buying notebooks without LAN knowing they could use it some day or the things with only one USB...
    The name is pretty bad too, I hope whoever got that idea will be neutered.
  10. Also, I'm pretty sure I saw at least two different brands making very similar pieces a year ago.
  11. The problem with Ultrabooks is tiles. aka Windows 8.
  12. adgjlsfhkI really feel that the company names is just a lawsuit waiting to happen. It's also one of the few justified ones, and both companies would benefit by not being associated with the others problems.
    Lol yeah i didn't realise this was a different company till they mentioned it.
  13. So... its basicly a USB hub?
  14. This doesn't really "solve" the connectivity problem.
    And very few people who actually need a LAN connection are going to buy an ultrabook that lacks a LAN port. Lastly, bulky inconvenient connector is bulky and inconvenient. Negates the purpose of having and using an ultrabook...
  15. janetonly42The problem with Ultrabooks is tiles. aka Windows 8.
    Except that has zero to do with Ultrabooks. And FFS, you can get into the desktop with one goddamn click or keystroke. Would you people just shut up already.
Connectivity Ultrabooks
