Power supply surges detected During the previous power on asus anti-surge was triggered
rafaelmeijer
I've got the following message when I start my PC.
"Power supply surges detected During the previous power on asus anti-surge was triggered"
My computer:
-Sapphire Radeon HD 7970 3072 MB GDDR5 PCI Express
-Processor-Amd Fx 6100
-Source Corsair CX750w
-Motherboard ASUS M5A78L LE
-Memory 16GB (4x4GB) 1333 Markvision
The computer is running normal, it does not restart or anything...
The message began after installing the video card and that SPU.
I run some risk? Has anyone experienced this problem and solved?
Feldmarschall
1,166
Clear your CMOS. Make sure everything is tight, and installed properly.
You can check reason where it happens. Remove GPU. If happens then check PCI-E power connectors, make sure they are tight, also make sure that GPU is tight in PCI-E slot.
P.S. Is SPU power unit or CPU procesor unit?
