Need help picking parts for a new computer build mainly for gaming.
Gaming
- Computers
- Build
Systems
Last response: in Systems
dexter9
March 28, 2013 5:33:09 AM
Hi,
I have already picked out parts which I think are good, but because im not very experienced i wanted to ask the community. These are the parts;
CPU: AMD FX 8350 4GHZ 8 CORE
GPU: NIVIDIA 1GB GTX 560 TI
RAM: 4GB 1600mhz pc3-12800 240 PIN ( in a few months i will upgrade to 8GB )
Motherboard: ASUS M5A97 LE R2.0
CASE: Raidmax ATX-238WR Tornado ATX Mid Tower Gaming Case (Red)
As i said i intentially will use this system for gaming. I do not mind low quality and great performance, as long as i can get a good fps and yes it would be nice for perfect quality too.
My budget is £300. I am able to get all these parts for that money too.
If you can suggest any better parts please do!
Thanks in advance
Andrew
Thanks in advance
Andrew
More about : picking parts computer build gaming
omaroma11
March 28, 2013 5:54:24 AM
- new gaming computer but need help picking parts ($1000-1100) - Forum
- New gaming pc build. Need help with picking parts - Forum
- Need help with picking parts for a New Gaming PC Build - Forum
dexter9
March 28, 2013 6:49:03 AM
Apparently i can get the GTX 560 TI for £52. I dont believe it, but i will proceed to checkout and double check the price thoroughly. Xboxgames site is selling it. It sells computer parts and other games. All the other parts on the website seem accurate when you compare the prices with the likes of amazon. If i cant get it for that amount of money i will have to get it of amazon. These parts are new. Amazon.com seem to have them fairly cheap and around my budget. Sorry i know it was good for £300, but what i really want to know is can i play most modern games without lag? Performance? Quality? That sort of thing.
dexter9
March 28, 2013 6:52:48 AM
SamGriffiths
March 28, 2013 7:13:36 AM
dexter9 said:
Hi,I have already picked out parts which I think are good, but because im not very experienced i wanted to ask the community. These are the parts;
Thanks in advance
Andrew
Don't get the 8350, save your self some money and get the 6300, also build it on uk.pcpartpicker.com to find the lowest prices. You can get a better case for the same price http://uk.pcpartpicker.com/part/zalman-case-z11plus. How much are you paying for your ram? Because you can get 2x4gb for £35, http://uk.pcpartpicker.com/part/patriot-memory-pvi38g160c9k. You'll need to get a power supply and Hard Drive too.
dexter9
March 28, 2013 9:05:04 AM
Yes thanks. Thats a very helpful answer. May i ask what is wrong with the FX8350. It has 8 cores, 4GHZ per processor. Im only asking to understand and im ready to take on good advice. Whats the 6300 advantages over the 8350. I know my case is terrible, though it is due to the budget. I will be using my own PSU and i am getting a temporary set up for the HARD DRIVE and DISK DRIVE.
SamGriffiths
March 28, 2013 9:32:27 AM
dexter9 said:
Yes thanks. Thats a very helpful answer. May i ask what is wrong with the FX8350. It has 8 cores, 4GHZ per processor. Im only asking to understand and im ready to take on good advice. Whats the 6300 advantages over the 8350. I know my case is terrible, though it is due to the budget. I will be using my own PSU and i am getting a temporary set up for the HARD DRIVE and DISK DRIVE.Ah okay, well the 6300 is basically a 8350 with 2 less cores, and even with that a lot of applications don't use all of the cores, so you may as well save your money. With the Case, if you are spending £50 on it (that's the cheapest I could find yours) you can get a Z11 plus which has much better cooling for the same price. As for the PSU you will want to make sure it's at least 450w. The Graphics card, what brand are you getting, the cheapest I've found for the GTX 560 TI is £150.
dexter9
March 28, 2013 9:41:19 AM
Yeah ok. In your own opinion which is better for gaming? (Money aside) Yes i realise it has 2 less cores, which i dont mind but it runs at 3.5GHZ how will this affect gameplay? I will have a look at your case and i have a 550 watt PSU. I think i will leave Nividia because the motherboard is quad crossfire, and its an amd chipset. As far as i know Nividia SLI doesnt work in amd crossfire boards. Im still trying to make my mind up on that too. Any suggestions?
dexter9
March 28, 2013 10:41:38 AM
Yes i realise that too. This system, i want to last a long time. I want to get good core components now. FX8350, M5A97. To me these are the most important. I will then get a decent amount of RAM, a decent Case and a decent GPU for now. I will then wait till christmas to upgrade these parts to a very high level. So basically i want a decent GPU (Capable of playin Crysis 3 with little lag).
dexter9
March 28, 2013 10:48:59 AM
How about this Asus ATI Radeon HD 6670 2GB PCI-Express HDMI http://www.dabs.com/products/asus-ati-radeon-hd-6670-2g...
dexter9
March 28, 2013 11:07:29 AM
SamGriffiths
March 28, 2013 12:52:16 PM
dexter9
March 28, 2013 4:59:33 PM
Ok. Thanks. Now i have all that sorted, I needed to pick a case. I found some nice, cheap open cases. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
SamGriffiths
March 28, 2013 5:06:25 PM
dexter9 said:
Ok. Thanks. Now i have all that sorted, I needed to pick a case. I found some nice, cheap open cases. http://www.newegg.com/Product/Product.aspx?Item=N82E168...You don't want to get an Open Case, you're PC will be smashed to peaces with in 24 hours. Also you should try to avoid buying out of the country, customs can be a bitch. I recommend a Z11 (http://uk.pcpartpicker.com/part/zalman-case-z11) or if you can push it a bit a Z11 Plus (http://uk.pcpartpicker.com/part/zalman-case-z11plus)
MJTHOMAS
March 28, 2013 5:16:57 PM
http://uk.pcpartpicker.com/p/MTMK
How about something like that it's £310 but you could always swap the GPU to a 550ti if you like which would take £20 of the price but its not a bad build. What kind of games are you looking to play? Also do you have a OS? Or maybe a GPU like this it has 4GB VRAM which is more than enough http://uk.pcpartpicker.com/part/powercolor-video-card-a... also the 7750 is capable of playing crysis 3 with little lag http://www.youtube.com/watch?v=SNeOMEplZ3s that video shows it although it is on a 720p monitor
SamGriffiths
March 28, 2013 5:26:26 PM
I just read though your post again, if you want to play Crysis 3 this is a good build.
CPU: AMD FX-4100 3.6GHz Quad-Core Processor (£77.40 @ Aria PC)
Motherboard: Asus M5A97 LE R2.0 ATX AM3+ Motherboard (£59.98 @ Dabs)
Memory: Patriot Intel Extreme Master, Limited Ed 8GB (2 x 4GB) DDR3-1600 Memory (£36.23 @ Amazon UK)
Video Card: Gigabyte Radeon HD 7750 1GB Video Card (£75.98 @ Novatech)
Case: Zalman Z11 ATX Mid Tower Case (£44.99 @ Amazon UK)
Total: £294.58
(Generated by PCPartPicker 2013-03-29 00:22 GMT+0000)
Total: £294.58
dexter9
March 29, 2013 2:45:37 AM
SamGriffiths
March 29, 2013 7:20:17 AM
dexter9 said:
Hi, Ok i have thought about it and thought about it again. To get the best PC which will last a bit i will needat to pay the extra money. So i am going with the FX8350. What about the MSI RADEON 7750? Is it anygood?The FX-8350 will burn out faster, it gets hotter, and the Gigabyte HD 7750 is better http://uk.pcpartpicker.com/part/gigabyte-video-card-gvr...
MJTHOMAS
March 29, 2013 7:21:24 AM
dexter9
March 29, 2013 8:55:33 AM
]Yes, i am very interested in those games too. I am using crysis 3 as a guide. I dont expect to ever be playing it. I am thinking of the future. Games have already went to single core to quad core. As software advances it could utilize all 8 cores. It will help with multi tasking and each core runs at 4GHZ! Is the gigabyte version roughly the same price? And is this case anygood?http://imperialprice.com/index.php?route=product/produc..." target="_blank">http://[/url
SamGriffiths
March 29, 2013 9:11:29 AM
dexter9 said:
]Yes, i am very interested in those games too. I am using crysis 3 as a guide. I dont expect to ever be playing it. I am thinking of the future. Games have already went to single core to quad core. As software advances it could utilize all 8 cores. It will help with multi tasking and each core runs at 4GHZ! Is the gigabyte version roughly the same price? And is this case anygood? http://imperialprice.com/index.php?route=product/produc...Well it's up to you but I highly recommend saving your money and getting a Steamroller when they come out. That is the case I have already suggested, you should get the Plus though. http://www.amazon.co.uk/dp/B007C008L2/?tag=pcp0f-21.
dexter9
March 29, 2013 9:36:30 AM
SamGriffiths
March 29, 2013 4:23:38 PM
dexter9 said:
Ok, i know i have been a pain in the back. You have given me advice and we have sort of had our own mini argument. Im sorry. But money out of the question. Will the FX 8350 last me say 3-5 years? I plan then to upgrade to the new architecture then. Thank you for all your help!Hey, it hasn't been a problem, no problem at all. The 8350 should last you at least 3 years if you don't overclock it, most likely a lot more in fact.
dexter9
March 30, 2013 5:43:32 AM
SamGriffiths
March 30, 2013 5:37:02 PM
dexter9
April 1, 2013 6:02:33 AM
The more i think about it, the more i think id be better with a laptop. Hows this Toshiba Satellite S855-S5170? I would be looking an i7 with intel and similar with amd. The only poblem i myself could find was the graphics appear to be quite weak. Am i right? would this run crysis? Is there a better one at roughly the same money?
dexter9
April 1, 2013 12:03:27 PM
Ok. Well for basic gaming then. I will be using monitors/tvs. I will be playing games like Minecraft and other simulation games. My laptop at the minute can handle these games and its 4+ years old. It has intel centrino and ati radeon hd 3650 512mbs graphics. I dont mind not playing games on full i could play on low medium or high. Does this help?
SamGriffiths
April 1, 2013 1:12:24 PM
dexter9 said:
Ok. Well for basic gaming then. I will be using monitors/tvs. I will be playing games like Minecraft and other simulation games. My laptop at the minute can handle these games and its 4+ years old. It has intel centrino and ati radeon hd 3650 512mbs graphics. I dont mind not playing games on full i could play on low medium or high. Does this help?If you want to play games on a laptop at the same fps you will have to pay double or maybe more.
dexter9
April 2, 2013 4:48:44 AM
SamGriffiths
April 2, 2013 5:45:08 PM
SamGriffiths
I think this is going nowhere so why don't you fill this in and we'll see
http://www.tomshardware.co.uk/forum/353572-31-build-upg...
- SolvedNeed help picking parts for my gaming pc build. Forum
- SolvedNeed help picking parts for a Gaming Computer under 1000$ Forum
- SolvedNew!! Need help picking parts for gaming PC? Forum
- SolvedNeed help on picking new computer parts Forum
- SolvedNeed help picking parts for a £600 gaming computer Forum
- SolvedNeed help picking parts for new build! Professional opinions appreciated! Forum
- SolvedNeed help picking parts for my new Gaming PC Forum
- SolvedNeed help picking out parts for new build. Forum
- SolvedNew to building desktops, need help buying parts for a gaming computer Forum
- SolvedNeed help picking a gaming computer build under 1100$ Forum
- Need Help with picking parts for my new build Forum
- Looking to build a computer, need help picking parts Forum
- Need help in building a new system. For mainly casual gaming Forum
- I need help picking parts for a Gaming build (£700). Forum
- More resources
