so i have this psu --------http://www.skytech.lt/itsps520w-power-supply-intertech-booster-sps520-115230v-5060hz-33512v-520w-retai-p-72180.html u can see specs at specifikacija second tab
this gpu ------------ http://www.newegg.com/Product/Product.aspx?Item=N82E16814127478
core 2 duo e6750 2,66ghz
2x 2gb ddr3 1333mhz ram runing at 1066mhz
1xhdd
1x mem card reader
dvd/rw drive ,currently off
fan silencer with 2x fans on 7v and one at 5v ,and one on usb cable
and i have connected gpu to psu like this ----- http://www.tomshardware.co.uk/forum/id-1631762/add-molex-fan-silencer-4pin-molex-cable-powers-gpu.html
and i guess it's capatitor noise, this is how it started ------ so today i tryed to connect this gpu like this,it ran fine,voltages droped to 11,40v lowest on loads,but after few hours of gaming now in game when its under load it emits some weird buzzing sound ,and when i press escape it immideately stops i guess psu is too weak for this,maybe it,s psu capatitor sound cant really tell..... and runs hoter than before but not dat hot to touch ....
so this means psu is too weak and causing this noise or just regular noice whitch means psu using full power ???
previous video card was gt220 1gb and had no buzzing sound....
ANY HELP ??????
1xhdd
1x mem card reader
ANY HELP ??????
