Hello I have just finished putting together my first pc build while following the newegg videos on YouTube. Here are my components:
Gpu- http://www.newegg.com/Product/Product.aspx?Item=N82E16814202011
CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
Psu- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
Hardrive- http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Ram- http://www.newegg.com/Product/Product.aspx?Item=N82E16820576003
Motherboard- http://www.newegg.com/Product/Product.aspx?Item=N82E16813138332
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Disc drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
So when I set it up, I plugged two case fans directly into the psu and one case fan into the motherboard (which was never removed throughout all trials). When all case fans were plugged in, only the case fans spun for a little bit. I then unplugged one case fan because I suspected the psu wasn't strong enough but still only the case fan spun for a bit. When I unplugged both case fans, only the CPU fan spun. The GPU never spun at all.
In the newegg video the guy plugged in a 24 and 8 pin into the motherboard from the psu. I only plugged in the 24 pin in because my motherboard doesn't have an 8 pin but has a 4 pin. The problem may be something with the psu, either I didn't plug something in or it isn't powerful enough. Please help! Thank you!
