[Building a pc] Need help with choosing the right parts.
  • Gaming
  • Graphics Cards
  • Build
  • Components
Last response: in Components
April 1, 2013 7:04:54 AM
Now i have been looking around for 2 days trying to find good parts, im trying to build a gaming pc. Here is Parts that ive chosen for now, but i need you'r help aswell, as i dont know anything about this (Just a little).
1.Graphics card: SAPPHIRE TECHNOLOGY Radeon HD 7950 BOOST - 3 Gb GDDR5 - PCI-Express 3.0
2.Processor: INTEL Core i7 Ivy Bridge 3770K - 3,5 GHz - Cache L3 8 Mb - Socket LGA 1155
3.Ram: CORSAIR Vengeance LP 2 x 4 Gb DDR3-1600 - PC3-12800 - CL9
4.Harddrive: SEAGATE Harddrive Barracuda 7200.14 ST2000DM001 3,5" - 2 Tb
5. Dvd: LITEON Internal DVD 5,25" iHAS124
6.Powersupply: COOLER MASTER PC GX-Lite - 500W
7.Processor cooler: NOCTUA Cooler NH-D14
8. Case: ADVANCE PC case X11 - 8102B0
9. Motherboard:GIGABYTE GA-Z77M-D3H - Socket 1155 - Chipset Z77 - Micro-ATX
Questions
1.Do powersupply fit with other parts?
2.Do motherboard fit with other parts?
3.Is the case big enough for all my parts?
More about : building choosing parts
a b U Graphics card
April 1, 2013 7:32:32 AM
I would suggest that you go with Corsair, Seasonic, Antec, PC Power & Cooling, or OCZ as PSU OEMs.
I have never heard of the case you list.
I would not go with a MATX mobo, but rather a full ATX.
April 1, 2013 7:42:50 AM
1. It seems ok but i would recommend a bigger one for the hardware you have. In order to calculate how much power you should need go to http://www.thermaltake.outervision.com/ and calculate how big power supply you need by giving info on your new pc
2.it seems to be fine
3.i believe it should be-your case is a mid tower so it should be good,only thing you should check is how long is the graphics card,that is the most common problem with the case sizes
also,i noticed that you want to buy a mATX motherboard which is a bit smaller than the standard ATX,and your case supports both,it's not a problem but usually ATX motherboards because of their bigger size have more expansion slots ;)
all in all i'd say its all fine but try to wait for someone else to answer,just to maybe get another opinion
(and anyone who is reading this please answer with your toughts)
April 2, 2013 10:26:58 AM
Alright now this is the new parts ive chosen.
1.Graphics card http://netonnet.no/art/data/komponenter/grafikkort/amd-...
2.Processor http://netonnet.no/art/data/komponenter/prosessor/intel...
3.Ram http://netonnet.no/art/data/komponenter/internminne/ddr...
4.HDD http://netonnet.no/art/data/komponenter/harddisker/sata...
5.DVD http://netonnet.no/art/data/komponenter/dvd-og-bluray/i...
6.Powersupply http://netonnet.no/art/data/komponenter/stromforsyning/...
7.Case http://www.netonnet.no/art/data/komponenter/kabinett/to...
8.Motherboard http://netonnet.no/art/data/komponenter/hovedkort/intel...
Questions
1.Is the Case big enough to hold the Graphics card?
2.Is this all right parts to each other?
3. Does the Power supply have enough Watt to hold all of the parts?
Please let me know if there is something wrong.
Thanks
