Approximate Purchase Date: Not too sure yet.. hopefully soon but maybe a few months.
Budget Range:I would like to spend about $900. That said, I can up it to $1000 if I absolutely must.
System Usage from Most to Least Important: This will be 90% for gaming, will want to hook it to a tv and monitor for steam big picture mode/movies, some youtube/web browsing etc.
Are you buying a monitor: I need a monitor included in the price(looking for a 1920x1080 over 20")
Do you need to buy OS: Yes I want windows 7.
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts:I would prefer newegg or amazon depending on price difference I would buy elsewhere.
Parts Preferences: Going with AMD cpu and gpu.
Overclocking: Definitely not anytime soon.
SLI or Crossfire: Maybe in the future.
Your Monitor Resolution: I want a 1920x1080 over 20".
Why Are You Upgrading: Intel integrated graphics laptop. Nuff said.
Games I want to play: Simcity, Minecraft, Diablo 3, Starcraft 2, Elder scrolls online, maybe WoW
So I have been researching for about a week and came up with a build:
http://pcpartpicker.com/user/kenh536/saved/1nDU
What do you guys think of it?
My concerns: Im not sure if the cpu will bottleneck the 7870(its the powercolor tahitiLE). I LOVE the look of the case but Im not too sure if it is that good. Is the powercolor 7870 worth it for $245 or should I get something different?
Thanks in advance.
Thanks in advance.
