Can I connect a 120mm loose-wired fan?
  • Battery
  • Connection
  • Fan
  • Motherboards
  • Components
Last response: in Components
April 13, 2013 7:12:37 AM
I found this fan somewhere, and it still works, because i attached it to a 9V battery. It has allot of airflow so i was thinking i would put it on my case. I have the Asrock X79 Extreme4 motherboard and the Corsair TX-850 850W power supply. So this is the fan:
(if you cant open the link, tell me, i'll post on another site.)
http://shrani.si/f/3t/12g/1iPM551p/img1136.jpg
These are the standard black&red wires:
http://shrani.si/f/S/ao/1dA9fuT6/img1137.jpg
here are the specs written on the back, if it is useful:
http://shrani.si/f/34/R9/4NtSnaRn/img1138.jpg
And here are 2 different wires that have the 3 pin connectors that i can take apart if neccercary:
1. this is a fan splitter that i use in my case for my fans and it works great! on one side you have a 3 pin input to put on the Mobo on the other 2 to connect your 3pin fans. ( could i just solder to one of the 2 3 pins connectors?
http://shrani.si/f/w/ju/2Gq4uO2u/img1139.jpg
2. this is some kind of lenghtener or something with a 3 pin input, and a 3 pin output with another cable as you can see.
http://shrani.si/f/3Z/nC/3oLMu6re/img1142.jpg
On thing i'm worried about is connecting this and blowing the motherboard or something because i dont know anything about amps, voltages ect...
thanks!
More about : connect 120mm loose wired fan
a c 100 V Motherboard
April 13, 2013 7:38:04 AM
It should be fine, as long as you do everything correctly when connecting the loose wires to the connector.
April 13, 2013 10:13:05 AM
Ok, thanks!
I'll solder them together one of these days and I'll get back to you.
