Hello friends.
I have had an issue with low fps for as long as I can remember, however I thought my graphics card (HD 6950) was the culprit.
I ordered my new AMD Radeon HD 7950 graphics card in hopes that it would fix things, but alas, my problems still persist. I've done as much research as I am able to, but I have not been able to find a solution to my predicament.
Let's take Skyrim as an example. In some areas I get as low as 30 fps, while my load on both CPU and GPU remain very low. I have customized the .ini-files of Skyrim so that the game utilizes 5 of my 6 cores. The load on the graphics card never goes above 30%, and the CPU load is around 70% on a couple of cores, the other 4 remaining around 15-20%.
I regularly reformat and reinstall my OS (windows 7 64bit), so I doubt that it can be the cause for my woe. Any insight to my situation would be much appreciated.
My specs are as follows:
CPU: AMD Phenom II X6 1090T (6 cores, overclocked from 3200 to 3600 Mhz)
GPU: AMD Radeon HD 7950 3GB GDDR5 (GPU overclocked to 1080 Mhz, memory overclocked to 1375 Mhz, voltage 1.187 and +5% board power limit)
RAM: 4x 4GB, DDR3 I believe, don't remember frequency
Skyrim is installed on a SSD drive with 120GB capacity
Windows is installed on a 1TB HDD which is quite slow
If you need more thorough specs I can provide them.
