Wall mount for Desktop monitor
casacristeva
how can I fit my 24in philips monitor to the wall when there are no holes to place any kind to fit any kind of wall mount stand to it?
I really woul like the monitor off my desk, never realised no mounting holes :(
tomate2
384
maybe a arm that secures itself to the desk?
should take a lot less space then just using the base of the monitor
plus a arm has height adjustments so that you can use your monitor on a healthy sitting position :)
also if you intend on maybe moving it to another spot should be easy
drilling a bunch of holes every time you want to change the position of the monitor is impractical and and ugly o_O
http://www.newegg.com/Monitor-Accessories/SubCategory/ID-233
