hello, im looking to upgrade the cooling end of my pc. And I'd like to get a custom kit (im not sure what they are really called) and i need some guidance for what needs to be bought. I would like to watercool my cpu (amd fx 8350) and my gpu (zotac 680gtx refrence). heres what i was plan to get...
http://www.frozencpu.com/products/18964/ex-wat-249/EK_L240_Complete_Dual_120mm_Liquid_Cooling_Kit_EK-KIT_L240.html?tl=g30c321s1367#blank
http://www.frozencpu.com/products/16262/ex-blc-1139/EK_GeForce_680_GTX_VGA_Liquid_Cooling_Block_-_Acetal_Nickel_CSQ_EK-FC680_GTX_-_Acetal_Nickel_CSQ.html?tl=g30c311s1631
im still a bit confused on fittings and tube sizes. I don't really plan on doing any serious oc'ing this is mainly for quiet performance. is there anything else i will need to ensure that both my cpu and my gpu can be cooled at once? I want to make sure i get everything i need so things run smoothly, thanks!
